14th May 2009, 23:18 | #381 | Link |
Programmer (or just 教务长)
A problem
Hi again!
I have the following problem: Code:
Decoding frame 11/1037 at offset 0x0000a800 Decoding frame 12/1037 at offset 0x0000b800 Decoding frame 13/1037 at offset 0x0000c800 Decoding frame 14/1037 at offset 0x0000d800 Decoding frame 15/1037 at offset 0x0000e800 Decoding frame 16/1037 at offset 0x0000f800 Decoding frame 17/1037 at offset 0x00010800 ERROR: Corrupt buffer offset information BDsup2Sub imports all subpictures but won't export them to SUP - stops with the error and the rest is not included. Let me know if I can be of any help with this. Here is a link to the problematic pair, extracted with mencoder from my Y Tu Mama Tambien DVD. Dean Last edited by deank; 14th May 2009 at 23:21. |
15th May 2009, 00:46 | #382 | Link |
Author of BDSup2Sub
Hm, ok, I analyzed it and the problem stems from an invalid size entry at offset 0x1081d:
0x10800: 000001BA pack ID 400000000000 (invalid) system clock reference 000000 (invalid) multiplexer rate 00 (invalid) stuffing info 000001BD subpacket ID 07EC (valid) packet length 8080 packet type 05 210241F0C1 PTS 20 Stream ID 07E4 (invalid) Subpicture size in bytes (offset: 0x1081d + 0x7e4 = 0x011001) 07C6 (valid) Offset to control header Anyway: although IMHO this is a bug in the stream, the next version will have a workaround for this issue. Already works locally but it's nearly 2 o'clock in the morning around here and I'm too tired to release an update right now, so you'll have to wait a few hours while I get a nap. If you can't wait, you could also try to patch the size at offset 0x1081d from 0x7e4 to the correct value of 0x7e3. Haven't tested this, but in theory, this should work with the current version of BDSup2Sub. Last edited by 0xdeadbeef; 15th May 2009 at 00:48. |
15th May 2009, 09:38 | #383 | Link |
It seems there are a lot of problem streams and this particular generates 200-300 warnings... If it is possible to make bdsup2sub to ignore the erroneous segments (not to include the subpictures) and add all it can decode it will be nice (if it doesn't do it already). I'll try with patching the value, just for a test. *** Yes, it worked but stopped again at another offset with "Corrupt buffer offset information". I suspected it will happen - probably the subtitle stream is not authored properly and has a lot of errors, but if your tool can skip/fix those it will be great! Last edited by deank; 15th May 2009 at 09:41. |
15th May 2009, 11:02 | #384 | Link |
Author of BDSup2Sub
Most of the warnings are due to missing end times. Though this is allowed in the DVD caption transport stream AFAIK, this currently gives a warning in BDSup2Sub as my original understanding was that in a VobSub, each control buffer needs an end sequence.
It's hard to tell if the main issue is an authoring fault, a bug in the demuxer or something that is on the edge of what is allowed. To me this looks like a bug in either the authoring tool or demuxer that happens only if the pack is one byte too large. Instead of appending an additional pack for that one byte, it's simply dropped, but the size info is not decreased accordingly. Anyway, here's the update: 15.05.2009 3.5.5 -> 3.5.6
16th May 2009, 20:07 | #386 | Link |
Author of BDSup2Sub
16.05.2009 3.5.6 -> 3.6.0
16th May 2009, 20:38 | #388 | Link |
Is there a way to change start and end time per sub? I tried editing but preview/re-edit/output kept the original times.
Also is there a way to specify a delay or change one subs start time and all others can be changed like vobsub resync? If not, any plans for adding either of these? Last edited by turbojet; 16th May 2009 at 21:33. |
16th May 2009, 21:21 | #389 | Link | ||
Author of BDSup2Sub
If we want to be nit-picking, there might be minimal visual differences in the border pixels after scaling compared to the uncropped image (simply because additional half tone pixels could be created outside the cropping range when scaling). Then again, as this also happens with typical captions which are already cropped, a general solution for this isssue is already on my list though. Quote:
Well, specifying a delay is in since revision 1.0. Again, I really dunno how to make this easier or clearer. You enter a value and press ok. In this (special) case, not even pressing return is needed. Though it generally never hurts to press return in any edit box of any application to give it the chance to validate the entered value. |
16th May 2009, 21:29 | #390 | Link | ||
16th May 2009, 22:00 | #391 | Link | ||
Author of BDSup2Sub
If you enter a time or any other value in a text input field inside the edit dialog (or any other dialog), you have to press RETURN to allow BDSup2Sub to validate the value. After the value has been validated and has been found to be different from the original value, the save button is enabled. Generally speaking, there are only three possibilities for a program to handle text edit boxes:
And again: these assumptions are not limited to BDSup2Sub. You're well advised to press return in any edit box of any tool if it's obviously not reacting during typing (which is something I personally hate in 99% of cases). Last edited by 0xdeadbeef; 16th May 2009 at 22:03. |
16th May 2009, 22:22 | #392 | Link | ||
16th May 2009, 22:27 | #393 | Link | |
Author of BDSup2Sub
16th May 2009, 22:44 | #394 | Link | |
What is written in the help "The rest should be pretty self-explanatory. "Ok" stores the changes and returns, "Cancel" returns without taking over the changes, "Save Changes" stores the changes but doesn't close the dialog. "Prev" and "Next" skip to the previous/next subtitle without (!) saving the changes." and also what you wrote earlier today is not true in BDSup2Sub when typing in text boxes as 'enter' must be pressed however if text boxes are changed another way it is true. But I got the program to do what I was trying to achieve from your first post which you claim I didn't understand so I'm done with this discussion. Last edited by turbojet; 16th May 2009 at 22:47. |
16th May 2009, 23:22 | #395 | Link | |
Author of BDSup2Sub
Then again, if you insist to claim the opposite, please don't expect that I'll bother to respond. I'm kinda tired to explain this again and again and again. |
17th May 2009, 00:56 | #396 | Link |
No one asked you to explain it more then once, if it acted normally you'd never have to explain it at all.
Save generally means save, not save only if you hit enter after typing. The latter is exactly the rule in bds2up2sub. Imagine opening a text editor entering 1 line of text, save & close, reopen to find the line hadn't been saved because you didn't hit enter. While it may be normal to you as you always hit enter after typing you can't expect every one else to do the same. By having this text box behavior and omitting any mention of having to hit 'enter' or 'return' after editing a text box I'm led to believe you expect every one else presses enter after editing. WYSINWYG |
17th May 2009, 01:55 | #397 | Link | |
Dean edit: Just tested it and it is perfect! Thanks! Last edited by deank; 17th May 2009 at 02:10. |
17th May 2009, 02:22 | #398 | Link |
Senior Kindergarten
Hello Ox,
Your most ardent supporter here. Right upto your last version...still no luck inputting into Subtitlecreator...with 3 titles so far...2 avc and 1 vc1. Load demuxed Sup by Tsmuxer. Source NTSC, 23.976....target 720x480, same fps. Did not touch anything! Hi-low, medium thresholds, nothing! Save. Load...no go. How about chasing me away with a new sddvd compliant SUP output instead of the roundabout sub/idx? TIA |
17th May 2009, 10:06 | #399 | Link | |
Author of BDSup2Sub
Generally speaking (and repeating myself as well), compatibility to SC was always good: I tried hundreds of VobSub created by BDSup2Sub in (VobSub Resync) and SC and none ever completely refused to load. Before 3.5.4, some VobSub weren't displayed correctly (only) in SC (e.g. only half of the captions were displayed). Due to the changes in 3.5.4, I'm yet to find a VobSub that didn't display every caption correctly in SC. Anyway, just for the sake of it, I just converted a few complex SUP to VobSub (NTSC, 24p) and loaded them in SC 2.2 and SC 2.3rc1. Both loaded the VobSubs without any glitch and showed all of the captions. |
17th May 2009, 10:26 | #400 | Link |
Matroska find' ich toll
hello
here is a new sample and a question to. Some captions are colored but in the sub/idx-mode are all captions white. I saw in SC you can choose different colors for the captions. Is it possible to keep the Sup-color in the vobsub.idx-file? hubble |
