26th April 2006, 10:29 | #1021 | Link | ||
1. I will not always check out the encoded files at once. I often batch-encode many smaller files and then start working on some Office stuff for example. Windows that are opened without request are just annoying then. 2. I never use the windows explorer. Using it is a complete waste of time (and functionality) compared to programs like Total Commander IMHO. |
26th April 2006, 13:46 | #1022 | Link |
Network XXIII
Stax,
I kinda second Warrex on this "Opening of source & Target" pop ups,It would be nice to be able to select or deselect "Target" & "Source" pop up after encode. Also cleaning up(removing) (all) non essential files from the source after encoding will help the Noob Factor Usage..ie folders like temporary files & the .avs ,demuxed audio & video + *_EncoderOutput. (This might just be me though,i sometimes just throw everything in one folder),then i just gotta pickout the finished encoded and delete the rest. Cheers
Asus PC-DL | 2 x Xeon 3.06@3.52 | 2GB OCZ PC4000 | Raptors x 2 RAID 0 | 6800Ultra | ATA2400a RAID 5 | Watercooled | Vista Ultimate 32bit | StaxRip 1.0.0.1 |
26th April 2006, 16:33 | #1023 | Link | |||
https://github.com/stax76/software-list https://www.youtube.com/@stax76/playlists Last edited by stax76; 26th April 2006 at 16:35. |
26th April 2006, 18:10 | #1024 | Link |
Life's clearer in 4K UHD
Hi Stax,
I've been meaning to mention this... Whenever I try to manually enter a new value into the "Video Bitrate" or "Size" box, I've noticed the backspace key jumps over and leaves the last remaining digit in the box, instead of removing all the digits. Can these boxes be amended to work in the same way the "Resize" boxes do? Also, why does the "Video Bitrate" value I've entered in the box change whenever I fiddle about with the "Audio" (or "Container") parameters? Cheers
27th April 2006, 11:46 | #1025 | Link | |
TeMa=) team member
Location: Universe, Galaxy, Solar System, Earth, Russia, Moscow
VideoBitrate = (FileSize - FilmLength*AudioBitrate - ContainerOverhead)/FilmLength. I.e. changing File Size, Audio Bitrate or Container (type and options) will change VideoBitrate. I thik...
Without effort, you can't even pull a fish out of the pond. Without a pond you can't pull it out even with effort. |
28th April 2006, 09:21 | #1027 | Link |
Network XXIII
@sterlina
View / Project Options / Advanced / Dangerous = Save Cropping option EDIT: Make sure you are using the LATEST build from Stax [4 posts up]
Asus PC-DL | 2 x Xeon 3.06@3.52 | 2GB OCZ PC4000 | Raptors x 2 RAID 0 | 6800Ultra | ATA2400a RAID 5 | Watercooled | Vista Ultimate 32bit | StaxRip 1.0.0.1 Last edited by Gehenna; 28th April 2006 at 09:24. |
28th April 2006, 13:22 | #1028 | Link |
@SeeMoreDigital
Good request, thanks. You can use a hotfix already if you like to. This build is for batch and x264 people worth a try btw., check out the changelog.
28th April 2006, 18:20 | #1029 | Link | |
now that I've seen it... BUG REPORT
28th April 2006, 19:30 | #1030 | Link |
Thanks, I'll fix it. Please let me know if you find more glitches.
28th April 2006, 21:38 | #1031 | Link | |
Struggling for Perfection
28th April 2006, 21:43 | #1032 | Link | |
28th April 2006, 21:56 | #1034 | Link | |
That works more logically now You may be interested to know Kurtnoise13 has compiled a build of MP4box which currently supports the importation of one VOBsub subtitle stream within the MP4 container.... Maybe you'll be able to make use of it Cheers
29th April 2006, 00:50 | #1035 | Link | ||
https://github.com/stax76/software-list https://www.youtube.com/@stax76/playlists Last edited by stax76; 29th April 2006 at 01:02. |
29th April 2006, 00:59 | #1036 | Link |
best settings for stand alone player
ripping my boxed sets to divx or xvid depending on advice, what are the best settings, Ive used simple divx and have found it has a few lackings, wish to try staxrip now.
thanks in advance John
If I meet you I'll ctrl+alt+delete you Wierd al Yankovitch from "it's all about the pentiums baby" |
29th April 2006, 14:02 | #1037 | Link |
Mr. Sandman
rule 12 applies:
Do not ask what's best... also
MPEG-4 ASP Custom Matrices: EQM V1(old), EQM AutoGK Sharpmatrix (aka EQM V2), EQM V3HR (updated 01/10/2004), EQM V3LR, EQM V3ULR (updated 04/02/2005), EQM V3UHR (updated 17/12/2004) and EQM V3EHR (updated 05/10/2004) Info about my ASP matrices. MPEG-4 AVC Custom Matrices: EQM AVC-HR Info about my AVC matrices My x264 builds. Mooo!!! |
29th April 2006, 19:34 | #1038 | Link |
Stax,
I've noticed that the LAME parameters aren't working correctly. It seems that the presets, like "--preset fast standard" or "--preset fast medium" do work. But, the more custom parameters such as "-V 5 --vbr-new" don't. With that setting it will actually use what looks like "-V4". In fact, it will use "-V4" (or whatever it is using) even with other options too, like "-V 6 --vbr-new". |
29th April 2006, 19:54 | #1039 | Link |
StaxRip had this problem but due to some feedback the problem was solved. According to the BeSweet docs '-V 5 --vbr-new' should work like it would work using lame.exe but it don't, what works instead is what StaxRip is using: '-v --vbr-new -V 5'.
gui, h.264, h.265, hevc, mkv, x264, x265 |
