Old 15th December 2005, 01:28   #101  |  Link
stax76
stax76's Avatar
@TEB
If there is no .NET error dialog with the usual debug output then we have a problem I'm afraid.
stax76 is offline
Old 15th December 2005, 09:35   #102  |  Link
TEB
Hei. Theres a debug dialog, but its impossible to copy paste it
And its like 50pages of info
TEB is offline
Old 15th December 2005, 09:56   #103  |  Link
stax76
stax76's Avatar
Then it must be the dialog of windows and not .NET, this debug information is not very helpful.
stax76 is offline
Old 15th December 2005, 13:19   #104  |  Link
TEB
Well i now tested the newest build at work on my WS, (p4 3,6EE, ati x700) windowxpsp2eng dot net 1.0, 1.1 and 2.0.
Here i cannot get it to work at all.. When i click on the .exe it starts, but nothing comes up... no dialog at alll..
Tried it on another macine (collague - .net developer) and the start of the file gave :
EventType : clr20r3 P1 : staxrip.exe P2 : 0.9.1.4 P3 : 439f3b13
P4 : staxrip P5 : 0.9.1.4 P6 : 439f3b13 P7 : 1d P8 : c6
P9 : system.invalidoperationexception
___________
Started debugging in MS-VS2005, CLR-Debugger gave :
An unhandled exception of type 'System.InvalidOperationException' occurred in Microsoft.VisualBasic.dll
Additional information: An error occurred creating the form. See Exception.InnerException for details. The error is: Culture name 'nb' is not supported.
Parameter name: name
TEB is offline
Old 15th December 2005, 13:44   #105  |  Link
stax76
stax76's Avatar
Did some changes, maybe works now, please download the latest build again.
stax76 is offline
Old 15th December 2005, 14:00   #106  |  Link
TEB
Hi again!
From our developers :
Hi!
I tried to compile the project locally here, and it was ok. But running it gave the same problem. I ran it with a debugger and located the problemcode :
In project.vb in the function init() the autoselection of the twoLetterISOLanguageName
causes the problem. It returns 'nb' (Norsk Bokmål = norwegian locale) which causes the problem.
I'll try to comment it out and see if it works running 'en' in all cases.
EDIT 5 min later : Woho!!! Changed New Language(New CultureInfo("en")) as default for subtitles and audio and it worked! (cut out the autoselection)
TEB is offline
Old 15th December 2005, 14:05   #107  |  Link
stax76
stax76's Avatar
Yes, thanks for working this out, does the build I've uploaded work?
stax76 is offline
Old 15th December 2005, 14:08   #108  |  Link
TEB
Yupp, both works
TEB is offline
Old 15th December 2005, 17:17   #109  |  Link
weaver4
I really want to try StaxRip, but I am afraid to install .Net 2.0. I am developing a couple of applications under Visual Studio 2003 that use .Net 1.1. Anyone know if I install .Net 2.0 if it will screw up my work?
I know it is a little off-topic but I thought the author might know.
weaver4 is offline
Old 15th December 2005, 17:21   #110  |  Link
Emp3r0r
Emp3r0r's Avatar
Your Safe
.NET 1.1 and 2.0 work fine side by side
ChapterGrabber - add names to your chapters | AtomSite - open source AtomPub server
Emp3r0r is offline
Old 15th December 2005, 17:27   #111  |  Link
stax76
stax76's Avatar
Different .NET versions are supposed to work side by side. I had similar setups and never problems. You might as well want to give VS 2005 Express a try, it's free. Your chances to screw up are higher than of course but again, also different SDK and Visual Studio Versions are supposed to work side by side. You got to take care of the order you uninstall things.
stax76 is offline
Old 15th December 2005, 21:03   #112  |  Link
JoeBG
stupid
JoeBG's Avatar
@ stax
works great your new release - thank you
cu
Joe
freedom is just another word for nothing left to loose
JoeBG is offline
Old 15th December 2005, 21:34   #113  |  Link
stax76
stax76's Avatar
well, almost. The culture fix caused another culture bug, also there was another culture bug appearing when the DVD has languages not known to .NET. I'm working on it...
stax76 is offline
Old 16th December 2005, 00:46   #114  |  Link
Kostarum Rex Persia
Banned
stax, in which folder I must to copy files DivXMux.exe and DMFCheck.exe so staxrip can start to encode my files in .DIVX container?
Currently, Staxrip can't see that I already downloaded needed files. I can't understand why.
Kostarum Rex Persia is offline
Old 16th December 2005, 01:08   #115  |  Link
stax76
stax76's Avatar
@Kostarum Rex Persia
You can copy them where you want as long as you tell StaxRip where to find them.
The help of the External Applications dialog describes it as follows:
Applications already installed manually can be integrated using the Search option (StaxRip needs to know the location of the application).
If you got the latest build just hit Download (as suggested) for any DivX product.
stax76 is offline
Old 16th December 2005, 02:50   #116  |  Link
Kostarum Rex Persia
Banned
What about x264 codec, it says that I use wrong version, and he try to download very old revision 334. Can you update x264 to 367B revision.
What is Mediainfo?
Old 16th December 2005, 09:35   #117  |  Link
fight2win
What's in a name dude !
fight2win's Avatar
will staxrip run with xvid cvs builds?
fight2win is offline
Old 16th December 2005, 10:07   #118  |  Link
Doom9
clueless n00b
What is Mediainfo?
What is the search engine?
For the web's most comprehensive collection of DVD backup guides go to www.doom9.org
Doom9 is offline
Old 16th December 2005, 14:14   #119  |  Link
stax76
stax76's Avatar
Nice to get some feedback about x264, since I don't use it I already thought nobody does (using StaxRip). What about rev.387B?
What is Mediainfo?
It gives info about media files, you can reach the website directly from the External Applications dialog, select Tools, choose MediaInfo, choose Open Website In Browser, it's there explained better than I possibly could.
I hope so, maybe you can give some feedback.
stax76 is offline
Old 16th December 2005, 17:20   #120  |  Link
stax76
stax76's Avatar
0.9.1.5 (2005-12-16)
  • new: Editor for command lines and scripts with support for preview and execute.
  • new: More than just one command line can be executed.
  • fix: A couple of bugs were fixed.
stax76 is offline
gui, h.264, h.265, hevc, mkv, x264, x265
