17th May 2023, 18:43 | #1861 | Link |
So MKVToolNix will be forever stuck in dark mode with no way to change it back? A shame really. The interface looks horrible in dark mode to me. And having to switch the whole system for one external program doesn't make sense. I like dark mode on Windows itself but I want programs in light mode. For me things I stay little time in or are mostly in the background are good in dark mode, like windows settings, explorer. Programs I spent quite some time with are better in light mode.
All programs with dark modes that I've encountered have a switch, like MKVToolNix did until 75.0.0. Usually a "default", meaning follow system scheme, and a light and dark options, or other colour schemes if the program has them. It's like the most basic of options. Never an issue until today. Why Fusion doesn't allow for a switch between modes I don't understand. Time to keep and cherish 75.0.0 indefinitely then. I do mostly BD remuxing which has a limited selection of settings/codecs already very mature so I'm not really too bothered. But talk about silly regressions. |
17th May 2023, 19:45 | #1862 | Link | |
MKVToolNix author
Latest MKVToolNix is v83.0 If I ever ask you to upload something, please use my file server. |
4th June 2023, 16:39 | #1864 | Link |
MKVToolNix author
MKVToolNix v77.0 released
Hey! 😁
It's nearly summer & the weather's nice where I live. So why not do another MKVToolNix release today? 😁 This release mostly fixes the messy situation with the dark application mode on Windows among a lot of other things. Additionally mkvmerge will now sort tracks by their type by default! Here are the usual links: the MKVToolNix home page, the downloads section and the source code. The Windows and macOS binaries as well as the Linux AppImage are available already. The other Linux binaries are still being built and will be available over the course of the next couple of hours. Here are the NEWS since the previous release: Version 77.0 "Elemental" 2023-06-04 New features and enhancements
Bug fixes
Build system changes
Have fun 😁
8th June 2023, 13:48 | #1865 | Link |
QfG Group Germany
Bug in v0.77 (x64 / x86)
If i using the "Header Editor" load a file and then i choose "Segment Information - Title" and set "Add Element" now to Yes/No the Tool crashes. This feature works fine in v0.76. EDIT Not only the function "Title" is corrupt, all functions under Segment Informations corrupted.
8th June 2023, 13:49 | #1866 | Link |
MKVToolNix author
Already fixed. See this issue.
10th June 2023, 15:39 | #1868 | Link |
How to make a Blu Ray Remux? Tell me the procedure for creating a Bluray remux with Dolby Vision 7 from a BDMV container.
I use programs: MakeMKV, MKVToolNix. Do I need to make mkvextract gMKVExtractGUI after MakeMKV or just add MKV to MKVToolNix? |
10th June 2023, 15:53 | #1869 | Link |
MKVToolNix author
First use MakeMKV as that'll preserve DV properly when reading from Blu-rays (MKVToolNix doesn't support reading DV from MPEG transport streams yet, nor from HEVC elementary streams). Then remux the MKV created with MakeMKV with MKVToolNix. No need for extraction. In fact extraction of DV & remuxing the extracted streams will be result in non-compliant Matroska files for the moment as, again, MKVToolNix doesn't support readint DV from MPEG TS & HEVC elementary streams.
12th June 2023, 13:04 | #1871 | Link |
MKVToolNix author
There's no codec called "Matroska Audio". "Matroska Audio" can only mean a Matroska container that only contains audio (no video, no subtitles), but the audio codec can be anything (AAC, AC-3, DTS, Opus…).
14th June 2023, 10:08 | #1872 | Link |
I have a couple of suggestions/requests regarding the MKVToolNix GUI. How hard they'd be to implement, I have no idea.
One of the things I seem to do most when remuxing is to set or change a delay for a stream and also change a stream's name/description. I had to do this for quite a few files today and having to constantly switch tabs makes the process harder, so it made me wonder how hard it'd be to add a Custom tab to the GUI. The idea being the Custom tab could be configured by the user to contain the most used items from any of the other tabs, saving a lot of tab switching. Another idea would be to make the columns themselves more useful, so appropriate items could be changed "in-place", rather than just passively display what's been entered under a tab. I'm referring to the section of the GUI in the screenshot below. An example would be changing the delay by clicking on the area where -21 is displayed and entering a new value, or by clicking under the default track column to automatically change the default status. That sort of thing. Cheers. https://i.imgur.com/IJID3z7.png PS I still think having a copy of the "Abort Job" button on the multiplexer window would be a good idea. 99% of the time when I need to abort a job it's right after I've started it running from the multiplexer widow only to realize I need to change something, so it'd be handy to be able to stop the job from the same window too. |
14th June 2023, 11:08 | #1873 | Link |
MKVToolNix author
Thanks for your suggestions. However, I won't implement them. They're all require a lot of effort to implement correctly, and I'm not keen on doing any of the work. Additionally I consider having an "Abort job" button on the multiplexer to be very bad design as there's no guarantee that the job that'll be aborted has anything to do at all with the current multiplex settings.
15th June 2023, 14:05 | #1874 | Link | ||
What about a situation like that where a second job is added to the queue with the same name as a running job or a job already in the queue? You have to click through a warning about over-writing the first job to show that's you're intention, so would it make sense for any existing job with the same name to be aborted automatically if it's running or prevented from running if it hasn't started, given it'll be over-written anyway? The warning dialogue could possibly have an extra button, one to add the new job to the queue without killing any existing job as it currently works, and another to also stop/abort any existing job with the same output file name, or something like that.... Last edited by hello_hello; 15th June 2023 at 14:21. |
15th June 2023, 16:10 | #1875 | Link |
Using mkvmerge v77:
mkvmerge --ui-language en -o "G:\Output\2023-06-15@16_46_50_3010__03.mkv" --global-tags "G:\Output\mkvtags_2023-06-15@16_46_50_3010__03.xml" -d 0 --default-track 0:yes --default-duration "0:50/1fps" --aspect-ratio-factor 0:1150/1053 --fourcc 0:MP4V --no-chapters --compression -1:none --forced-track 0:yes --field-order 0:0 --no-audio --no-subtitles "G:\Output\2023-06-15@16_47_01_0110_02.264" Code:
MP4Box -par 1=1150:1053 -add "G:\Output\2023-06-15@16_47_01_0110_02.264"#video:fps=50:name="":lang="" -brand avc1 -itags tool="Hybrid 2023.06.15.1" -tmp "G:\Output" -new "G:\Output\2023-06-15@16_47_01_0110__03.mp4" For the mkv 'mediainfo --full' reports: Code:
Width : 692 Width : 692 pixels Height : 568 Height : 568 pixels Stored_Width : 704 Stored_Height : 576 Sampled_Width : 692 Sampled_Height : 568 Pixel aspect ratio : 1.331 Original pixel aspect ratio : 1.092 Display aspect ratio : 1.621 Display aspect ratio : 16:10 Original display aspect ratio : 1.331 Original display aspect ratio : 4:3 Code:
Width : 692 Width : 692 pixels Height : 568 Height : 568 pixels Stored_Width : 704 Stored_Height : 576 Sampled_Width : 692 Sampled_Height : 568 Pixel aspect ratio : 1.092 Display aspect ratio : 1.329 Display aspect ratio : 4:3 Original display aspect ratio : 1.331 Original display aspect ratio : 4:3 Code:
ffmpeg -y -r 50/1 -i "J:\tmp\2023-06-15@17_04_11_3410__04.mkv" -vcodec copy -metadata encoding_tool="Hybrid 2023.06.15.1" -map 0:0 -bsf:v h264_mp4toannexb -aspect 1.3305378330 -r 50/1 "G:\Output\par_1150_1053_ffmpeg.mkv" I get: Code:
Width : 692 Width : 692 pixels Height : 568 Height : 568 pixels Stored_Width : 704 Stored_Height : 576 Sampled_Width : 692 Sampled_Height : 568 Pixel aspect ratio : 1.092 Display aspect ratio : 1.331 Display aspect ratio : 4:3 Code:
mkvmerge --ui-language en -o "G:\Output\2023-06-15@17_09_18_2810_02.mkv" --global-tags "J:\tmp\mkvtags_2023-06-15@17_07_47_7110__04.xml" -d 0 --default-track 0:yes --default-duration "0:50/1fps" --aspect-ratio-factor 0:1150/1053 --no-chapters --compression -1:none --forced-track 0:yes --field-order 0:0 --no-audio --no-subtitles "J:\tmp\av1_mkvmerge_1_2023-06-15@17_07_47_7110_02.265" Code:
MP4Box -par 1=1150:1053 -add "J:\tmp\av1_1_2023-06-15@17_09_18_2810_02.265"#video:fps=50:name="":lang="" -brand hvc1 -itags tool="Hybrid 2023.06.15.1" -tmp "J:\tmp" -new "G:\Output\2023-06-15@17_09_18_2810__04.mp4" Code:
Width : 692 Width : 692 pixels Height : 568 Height : 568 pixels Stored_Width : 704 Stored_Height : 576 Sampled_Width : 692 Sampled_Height : 568 Pixel aspect ratio : 1.092 Display aspect ratio : 1.329 Display aspect ratio : 4:3 Original display aspect ratio : 1.331 Original display aspect ratio : 4:3 => Did something change on how to tell mkvmerge so set a specific par, is something broken? Cu Selur |
15th June 2023, 17:22 | #1876 | Link |
MKVToolNix author
Sure, one could add yet even more functionality and special-cases for those types of user errors, but I just don't want to.
15th June 2023, 17:23 | #1877 | Link |
MKVToolNix author
I don't think so. Did you try earlier versions? How do they behave compared to v77?
16th June 2023, 08:16 | #1879 | Link |
MKVToolNix author
If you find one that behaves differently & the next one doesn't, that'd help me a great deal. I really cannot think of the last time I changed aspect ratio handling.
matroska |
