28th January 2019, 17:34 | #81 | Link |
Clear all bookmarks is fixed.
Uploaded to GitHub. At the version number nothing has changed! All you have to do is replace lib and src directory.
Live and let live Last edited by gispos; 28th January 2019 at 17:36. |
29th January 2019, 07:01 | #82 | Link |
it works now, thanks
See My Avisynth Stuff |
4th February 2019, 20:41 | #85 | Link |
It is (screen shot taken on English Windoze):
Groucho's Avisynth Stuff Last edited by Groucho2004; 4th February 2019 at 21:53. |
4th February 2019, 22:17 | #87 | Link |
Can you upload one of these?
Groucho's Avisynth Stuff |
4th February 2019, 22:34 | #89 | Link | |
However, I'll have to check to be sure.
Groucho's Avisynth Stuff Last edited by Groucho2004; 4th February 2019 at 22:36. |
5th February 2019, 00:22 | #91 | Link |
Please upload the .avs file that causes the problem.
6th February 2019, 02:23 | #92 | Link |
Feature request/suggestion:
Some filters accumulate data from each frame. It would be handy to have a command, perhaps from the "Tools" drop-down, that would scan each frame in an entire video so that the right-arrow button wouldn't have to be manually held down to do this. |
6th February 2019, 20:39 | #93 | Link | |
Live and let live |
7th February 2019, 01:53 | #95 | Link | |
Under Video > Run analysis pass. |
7th February 2019, 04:09 | #97 | Link |
Add
Assumefps(250) at end of script, & hit play
7th February 2019, 15:02 | #98 | Link |
Perfect (almost), as usual. Thanks.
Interesting use of AssumeFPS. Can I be greedy and ask for more than double the speed? It seems that any value chosen beyond double the source FPS will still yield only about double the playback speed, e.g.; the 250 you suggested is no faster than 70, where fps is 29.97. Is this doubling of the speed the maximum limit possible with AssumeFPS? |
7th February 2019, 15:23 | #99 | Link |
Maybe 70 is the max render fps. You could try the "Run analysis pass" in virtualdub and compare it.
7th February 2019, 19:56 | #100 | Link |
Top speed for AssumeFPS, depends upon how fast your machine can display frames [also, I think in VDub, there is some kind of "drop frames when behind" option which would probably have effect, never tried it].
I used to use AssumeFPS(250.0) in VDubMod instead of Run Video Analysis pass, (VDMod did not have that option) and as VD original Run Video Analysis jumped automatically back to frame 0 on completion, I could not see any metrics on final frame. [Also, AssumeFPS(300.0) or more used to produce some error alert I think, hence 250.0]. I only used to use VD standard Analysis when I did not want to see metrics, and that meant switching from VDMod to VD std., and then back again (VD Std did not have AVS script editor, VD2 now takes over from both VDMod and VD std functionality [thanks to "Shekh the Magnificent"], and VDub2, now does not jump back to frame 0 [on my request] so not a problem any more). Run Video Analysis pass in VDub only renders on screen every now and then (maybe every [EDIT: real time] 1.0 second, maybe every 0.5 second, dont know), and so the frames NOT shown on screen are processed but not rendered/resized for display. So Run Video Analysis is faster at processing only, because of this non display. [will likely complete earlier than result of AssumeFPS(250)]. EDIT: As well as colorspace conversion, resizing and rendering, there seems to be some kind of beautification done to hide pixel 'squareness', probably some kind of anti-aliasing. It is sometimes possible to see the un-beautified frames in VDub if you switch to some other window and then back, where pixels do indeed seem a bit coarse and clearly visible. ("beautification", probably part of DirectX stuff, don't know. Maybe Video Renderer ... Overlay Mixer, VRM Windowed etc does it, [no idea really])
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 8th February 2019 at 12:16. |
