22nd August 2019, 21:36 | #21 | Link | |
There are renders, filters and shaders that are better in video and audio quality than those in the MPC-HC factory. and that are not at all difficult to configure: installed and ready to use? this for GTX 960 video card and Full-hd LED monitor? |
22nd August 2019, 22:11 | #22 | Link |
Only for video; use madVR as a video renderer. Use the defaults if you do not want to change settings. madVR has good defaults that will run very well on a GTX 960.
I do not know of any way to improve audio quality.
madVR options explained |
22nd August 2019, 22:57 | #23 | Link | |
do the standards come with madvr? or do i have to download? my video card is: GTX 960 My monitor is: Samsung T27B350 (Full-hd LED) do you have a link? if I don't like the result: can you reverse? how do i do it? reset the MPC-HC? Last edited by Bily; 22nd August 2019 at 23:05. |
23rd August 2019, 22:08 | #24 | Link | |
Is there any short-keys in MPC-HC to save the changes I make watching a movie for use in the next movies I see? I can resynchronize audio and video if I close and open MPC-hc Is there a way to create a shortcut that resets playback to resynchronize audio and video? thank you Last edited by Bily; 23rd August 2019 at 23:38. |
24th August 2019, 18:11 | #25 | Link |
madVR has its own settings page that saves its settings for the next time you watch something. I know of no presets for your configuration (that is pretty specific). I do link two settings files for madVR in the third post of my Options Explained thread (link in my signature) but I am not sure the 960 is fast enough.
Your sync issues need to be investigated, something is not right. Can you decode the video fast enough?
24th August 2019, 19:00 | #26 | Link | |
works most of the display normally but always syncs at some point like i said i close mpc-hc and reopen and that solves the problem Is there a way to reset playback without closing Mpc-hc? If so, can I create a shortcut to reset playback without closing MPC-hc? |
24th August 2019, 19:01 | #27 | Link |
Oh, the 960 is plenty fast for madVR, depending on how you use it
Bily, please read both Asmodian's and Warner's guides. You can find the links in their respective signatures. You won't find a better explanation of madVR, LAV Filters, and MPC-HC/BE anywhere on the web.
25th August 2019, 01:25 | #28 | Link |
actually is asynchrony occurs when I advance / rewind the movie with the keyboard arrow keys
Is it normal for asynchrony to occur under these circumstances? Is there a way to correct? if I can load more of the movie into the ram than buffering, can this solve this problem? If so, how do I do it? can having two devices on the headset give interference? I have the smartfone and the pc on the phone I can reset the phone so that only one device I connect one device at a time: or the smartphone or the pc I never leave the two connected How do I reset the bluetooth headset? squeeze which buttons? In win 7, you need to: remove device / headset and then search again? a doubt : Are upscaling 4k TVs good as upscaling madvr? thank you Last edited by Bily; 25th August 2019 at 22:37. |
26th August 2019, 01:19 | #29 | Link |
if i try another usb port on which bluetooth audio transmitter is installed can i get results for audio / video asynchrony?
if so : What about the current installation of bluetooth transmitter and bluetooth headset? do i have to delete something? thanks for listening |
29th August 2019, 20:05 | #31 | Link |
I found the problem.
we don't think about it: The signal from the bluetooth transmitter was weak. I changed the rear USB port and plugged it into the front USB. Resolved 99% of the problem. thank you all for your attention. |
