25th June 2020, 21:58 | #7521 | Link | |
If you use the zip or 7z archives (non installers), and create a ini file to store the settings, the player should be portable. I've used the 7z from the get-go, and created a ini to match the exe. I always save a backup of the ini and just copy it to the new version, all the settings are saved including the lav filter settings. mpc-be64.exe mpc-be64.ini The player becomes less portable when you begin to need external filters, like the lav filters, mad-vr. Of course, if you are already using the external tools then MPC-BE can simply be pointed to them, but (in my case), if you want to add these tools to MPC-BE I believe they must be registered, which in my view makes things less portable. Now, I don't know if I'm fooling myself but because I like to use only portable apps (stealth if possible, no writting to the registry, etc), I did extract the lav filter zip to my MPC-BE root folder: C:\MyApps\MPCBE ...........................\x64\ -> this is where MPCBE is ...........................\lav\ -> the extracted lav filters (0741) Here's where I might be fooling myself as to whether I'm even benefiting from the lav filters, I only extracted the lav filter zip, I did not register the filters using the bat file. I disabled all the Internal filters in Options and in External Filters pointed to (IIRC) ax files, set to Prefer... as far as I can tell I'm using the four required files: LAV Audio Decoder LAV Splitter LAV Splitter Source LAV Video Decoder As far as I can tell MPCBE is using LAV and the player is excellent, and I figure portable...??? I've wanted to try the other video renderer but I haven't because I don't want to have to register anything... leave my registry alone MPCBE is working fine, but I could be missing out on better performance but my system is very modest so I don't know that I would benefit from mad-vr, the stand alone filters, or the mpc video renderer. I've had some questions about my setup (the settings in Options), how to get the most out of things, I'll save them for another day. Sorry for the long rant, hope some of it is useful |
26th June 2020, 00:05 | #7522 | Link | |
If MPC-BE's `current dir` is the dir where mpc-be64.exe resides, and the paths in mpc-be64.ini can actually be set to "." instead of something like "C:", then I think it can be completely portable. If so, maybe a `portable` switch can be added to the external filters settings which will set the path to "path=." if the .ax is located in the same dir as mpc-be64.exe, or a subdir of it. Something like: if MPC-BE dir = C:\portable\mpc-be\ then mpc-be bin = C:\portable\mpc-be\mpc-be64.exe if LAVSplitter.ax = C:\portable\mpc-be\lavfilters\LAVSplitter.ax and external filters portable switch is on then mpc-be64.ini would point to "path=.\lavfilters\LAVSplitter.ax" if external filters portable switch is off then mpc-be64.ini would point to the full path "path=C:\portable\mpc-be\lavfilters\LAVSplitter.ax" |
26th June 2020, 15:48 | #7524 | Link |
Updated german translation based on r5353
27th June 2020, 04:31 | #7526 | Link |
Yes, see here:
https://sourceforge.net/p/mpcbe/code...15b75022c:5352 |
28th June 2020, 00:04 | #7528 | Link | |
"Enable preview" "Preview is currently disabled. You can enable it in MPC-BE's options." Here is the Hungarian update: https://www118.zippyshare.com/v/ez5AZ0Y5/file.html |
28th June 2020, 06:24 | #7529 | Link |
@Klaus1189, @wushantao, @s0meone_new
Thanks. Updated in r5354 and r5358.
28th June 2020, 10:13 | #7532 | Link |
According to history of italian translation, definitely
https://sourceforge.net/p/mpcbe/code...yerc.it.rc.txt Download this file: https://sourceforge.net/p/mpcbe/code...yerc.it.rc.txt Edit and upload to google drive or what you like and post link for devs |
29th June 2020, 03:58 | #7535 | Link |
2nd July 2020, 00:17 | #7536 | Link |
Update for translation of Chinese Traditional and Dutch based on 5353.
https://www.sendspace.com/file/9zuhm4 |
2nd July 2020, 18:44 | #7538 | Link |
@beter
Thanks. Updated in r5366.
3rd July 2020, 00:51 | #7539 | Link |
Latest Turkish translation based on r5366.
3rd July 2020, 16:40 | #7540 | Link |
@cmhrky
Thanks. Updated in r5368. MPC VideoRenderer 0.4.8.1407. Added support for exclusive full screen for DX11 mode.
