16th July 2020, 17:49 | #7582 | Link | |
This option only works when you have write access to the player folder. Therefore, there is no need to try to create an INI file in the player folder, which is located in the "Program files" folder.
16th July 2020, 21:43 | #7583 | Link | |
How can I fix this? Since it's not saving any internal change I am making. Of course I have access to everything in this PC, since I am logged as admin. |
16th July 2020, 23:35 | #7584 | Link |
That is MPC-HC, not MPC-BE.
Being an administrator does not mean that all applications run as admin. In fact, almost everything runs with limited user access by default. You must explicitly elevate apps to give the admin rights. Using INI or running as admin is not the solution you are looking for. Settings are stored in the Registry by default, and that should just work fine in normal situations. This will probably solve your problem: 1) Start regedit.exe 2) Delete this key: HKEY_CURRENT_USER\Software\MPC-HC |
17th July 2020, 00:53 | #7585 | Link |
Hungarian translation updated. (untranslated text)
https://www112.zippyshare.com/v/06f088fH/file.html |
19th July 2020, 12:39 | #7588 | Link |
You are doing right - there is no fix in github Wait.
20th July 2020, 03:33 | #7590 | Link |
Hungarian translation updated in custom_messages.iss (small correction)
https://www3.zippyshare.com/v/zy5HMrj8/file.html |
20th July 2020, 03:43 | #7591 | Link |
@s0meone_new
Thanks. Updated in r5385 and r5388.
22nd July 2020, 14:35 | #7593 | Link |
The OSD in MPC-HC is blurry with MPCVR if swap effect discard is used (on Win7). The OSD appears to be stretched vertically. No issue with flip mode.
Small GUI bug: Enable DX11, then press "Default" button. Options that were greyed out are not re-enabled. |
23rd July 2020, 03:41 | #7594 | Link |
@clsid
Thanks. Fixed in MPC VR 0.4.8.1438 git2020.07.23-5b8e111.
25th July 2020, 07:17 | #7595 | Link |
MPC VR 0.4.8.1439 playback not smooth, for 29.970 fps video playback. The following is a print screen FYI:
https://www.dropbox.com/s/ruz02ga2vd...mooth.png?dl=0 It didn't have similar zigzag with 23.976 fps videos, or 25 fps videos. Last edited by Anima123; 25th July 2020 at 08:01. |
25th July 2020, 18:20 | #7596 | Link |
@Anima123
I have no zigzags on the grath on 29.97Hz progressive video. An example of such a video. Win7SP1, GTX 950.
25th July 2020, 21:06 | #7597 | Link | |
Edit: It appeared to be due to the file itself? Last edited by Anima123; 26th July 2020 at 06:17. |
26th July 2020, 18:55 | #7598 | Link |
Your video seems to be fine.
I can get a sawtooth graph, but it will be justified by various factors that are reflected in the statistics parameters. Your statistics are clean and this is strange. I would advise you to try enabling DXVA2 VP for NV12 format.
28th July 2020, 13:32 | #7599 | Link | |
28th July 2020, 23:42 | #7600 | Link |
Update to latest SVN version.
