13th November 2009, 00:17 | #6101 | Link |
@BobZhome: Great suggestion, I never thought of the .cmd file... unfortunately that route would yield me a .ts or .m2ts file while I wanted an .mkv.
As you all know, MKVmerge does not support .sup or .sub subtitles and OCR is a major drag... hence my suggestion to have RipBot handle the audio and video and just have it merge already prepared video. |
13th November 2009, 01:38 | #6102 | Link |
HD-Fan
Will these come in next updates?
- savable custom resolutions in select down menu - savable custom color tweak in select down menu having to change the resolution is really taking extra time when doing many little videos since it's not possible to just type in the desire resolution in the box but have to click on the arrow buttons. So I think that should be a high priority in next update. The color tweak isn't that important but will be cool if possible to implement it too. |
13th November 2009, 09:08 | #6103 | Link | |
1) De-Mux with Yamb 2) Re-Encode the AC3 to 5.1 AAC 3) Re-Mux with Yamb A real pain, Direct Stream copy would be great as would a button to execute the audio encoding option you have selected independantly (StaxRip does this, It's the only thing I use it for!)
Q6600 @ 3.2Ghz -Asus P5Q-Pro 4Gb DD2, GTX260 core 216 Win 7 64bit Home Premium |
14th November 2009, 18:22 | #6105 | Link |
>=v1.14.4 = No avi's
v1.14.4
Added: RipBot264 will force ffdshow as prefferd Xvid and Divx 4/5 decoder in Windows 7 Changed: Avi files will be decoded via DirectShowSource instead of OpenDMLSource (Reason: OpenDMLSource does not work well with Windows 7 RTM) Changed: Avs files wiil be imported via Import() instead of DirectShowSource Changed: Lossless audio is automatically selected instead of first audio stream in Demuxing window Changed: Bitmap based suptitles are also allowed for none-standard resolutions (MKV) Fixed: Blu-ray subtitles were not resized if user changed resolution after adding subtitles Fixed: FLAC will be decoded by madFLAC instead of BassAudio due to weird problems on Windows 7 RTM (Avs script hangs if bassaudio.dll is loaded) Fixed: temporary files will not be automatically stored on non-NTFS drives (external usb drive for example) Fixed: 24fps subtitles were automatically converted to 23.976fps due to missing /fps:keep option Updated: x264 r1251M, NicAudio 2.0.4, MediaInfo 0.7.21, Yadif 1.6, BDSup2Sub 3.9.7 After incrementally upgrading from v1.14.3 to v1.14.4 and later, I have had major issues with RipBot failing to load certain *.avi containers. All I'm greeted with is a MPC window with the message... DirectShowSource i can't determine the frame rate of the video, you must use the "fps" parameter. (C:\Temp\Ripbot264temp\job1\getinfo.avs, line 2) After going through all the rigmarole of reinstalling AviSynth/Haali Splitter/FFDShow etc, I finally found the issue was all to do with the highlighted "fix" above. So I guess my question is, am I stuck with using v1.14.3 or earlier, as all the later editions fail to load AVIs? I am running Vista 64, Incidentally. Thanks |
14th November 2009, 20:42 | #6107 | Link |
send me 50MB sample. Use DGsplit and www.mediafire.com. I need .m2ts file.
14th November 2009, 21:06 | #6108 | Link |
Atak, do any of your movies not offer Direct Copy for DTS/AC3? I've tried numerous movies of late, and nothing. I am using 1.14.5.
Here is GI Joe which has a DTS-MA track. Last edited by stryker412; 14th November 2009 at 21:53. |
15th November 2009, 03:01 | #6110 | Link | |
Here's the first 50MB
http://www.mediafire.com/?y2jydmymjxn Quote:
15th November 2009, 11:07 | #6112 | Link |
For Atak_Snajpera:
My videos have AC3 audio and these are recorded with my video camera and have 448 Kbps (CBR) audio, but with RipBot I can convert to AAC only up to 320 kbps (ABR). I want to preserve de audio at 448 Kbps. You said: "320kbps is max what CT-AAC supports" If so ... why you don't add Nero AAC as a second option ? Both CT-AAC and Nero AAC are freeware. With Nero AAC other softwares can convert AC3 to AAC at 448 Kbpbs, 512 Kbps, 640 Kbps, and over ... while RipBot can convert with CT-AAC only up to 320 Kbps. You can add Nero AAC Codec for audio (can encode to AAC over 320 kbps, while CT-AAC cannot) Link for Nero AAC Codec test: Two images shows for Nero AAC that the best audio quality, combined with a low size in MB, is at 700-800 kbps, when encoding Blu-ray with a 24bit 48kHz soundtrack ... to AAC: http://www.hydrogenaudio.org/forums/...hp/t68122.html Last edited by Mihai_; 21st December 2009 at 11:47. |
15th November 2009, 20:04 | #6113 | Link | |
Any ideas? Thanks Last edited by jacksback; 15th November 2009 at 20:10. |
15th November 2009, 21:33 | #6114 | Link |
^ Yes, I have an idea, and it's a good one.
Because you have the Arcsoft decoder installed, you cannot direct stream copy. You wind up with the uncompressed audio instead. You then have the option of transcoding to the available audio formats presented. If you remove that decoder from your system, you will then see the option to extract the core DTS file (copy stream). I've asked Atak if he would be so kind to give us the option to extract the core AC3/DTS with a little check mark box when the source TrueHD and DTS-MA are present . I think it has fallen on deaf ears though. This audio question gets raised over and over and leads to much confusion. Other than that, it's a great app. Last edited by kikker; 15th November 2009 at 21:38. |
15th November 2009, 21:38 | #6115 | Link |
This is my final answer:
DTSMA -> wav -> AC 640kbps = DTS core 1,5 MBps in terms of quality. Now tell me why would use DTS if you could get the same quality with smaller AC3??? Blind tests made by professional do not lie. Just use google. @jacksback I forgot to add proper downmix for 6.1 audio. You will have to wait for new version.
Windows 7 Image Updater - SkyLake\KabyLake\CoffeLake\Ryzen Threadripper Last edited by Atak_Snajpera; 15th November 2009 at 21:40. |
15th November 2009, 21:42 | #6116 | Link |
ok so to achieve this, we would NOT select flac on the first screen, then when we get to the second screen select the 640kb option? I assume the "DTSMA -> wav" step is done automatically after the first screen, right?
15th November 2009, 21:46 | #6117 | Link | |
15th November 2009, 21:52 | #6118 | Link | |
Furthermore, it would eliminate a ton of audio confusion in this thread. I'm pretty sure all that would be required is to add an option for the --core argument to the eac3to command line. The option could be presented in the streams dialog box as an "extract core audio" checkbox, which would cover both TrueHD and DTS-MA. Lastly, I understand your argument that AC3 quality with its smaller bitrate is equivalent to DTS, but even when only TrueHD is available on disc, the only way to obtain an AC3 track is to encode it, when it's already available straight from the disc and the way the producers intended it! Otherwise, a fantastic app and my "go to" encoder. |
15th November 2009, 22:01 | #6119 | Link | |
15th November 2009, 22:09 | #6120 | Link |
Yes, you're right. I guess I'm not that much of a purist then.
But, if the option were present, it wouldn't change anything for those who are encoding with constant size, to a DVD as you mention. They would still be able to encode to AC3 if a DTS-MA track were present. BTW, what's the rationale for not extracting core AC3 then? That would be a wonderful addition in my humble opinion!! I can always stay away from the Arcsoft decoder to get core DTS, but I can't do anything about getting that core AC3 in Ripbot. |
