Old 18th January 2018, 15:32   #22441  |  Link
chros
chros's Avatar
Originally Posted by yukinok25 View Post
You have no idea how much I would like to scream this to Intel!
Btw, does any laptop exist nowdays with only nvidia card that doesn't have this sh*t?
Originally Posted by BDFan View Post
Read my first post.
D3D11 should theoretically work (see image DXVA Checker).
No. NVIDIA GPU active.
It works for me (see my signature), but I switched back to dxva2-cb, because there's no black-bar-cropping implemented with it in madvr yet.
Old 18th January 2018, 15:49   #22442  |  Link
clsid
With Optimus only one GPU is active from the perspective of the application. So if you select the NVIDIA GPU, then you can't use any functionality from the Intel one and vice versa.
Old 18th January 2018, 16:24   #22443  |  Link
BDFan
No. Intel Quick Sync active.
BDFan is offline   Reply With Quote
Old 18th January 2018, 20:57   #22444  |  Link
el Filou
el Filou's Avatar
Read my first post.
OK, I didn't really get what you meant. My bet is that the system calls DXVA Checker use to get the device capabilities are independent of the Optimus setting in NVIDIA Control Panel.
D3D11 video decode probably doesn't respect that Optimus setting either, that's why I was suggesting to use copy-back if you want to use the Intel D3D11 decode. I understand if you'd prefer native mode, but does it work with copy-back?
Also, QuickSync decoding is a private Intel API and not a DirectX one so I guess it's not impacted by the Optimus setting in NVIDIA control panel either.
Old 18th January 2018, 21:47   #22445  |  Link
BDFan
Depends!
DXVA Checker image №2 (if in the nVidia control panel selected Intel GPU).
http://i102.fastpic.ru/big/2018/0118...3c53928658.jpg
DXVA CB image
http://i99.fastpic.ru/big/2018/0118/...2929dfeee1.jpg
Old 19th January 2018, 20:46   #22446  |  Link
varekai
varekai's Avatar
Subtitles won't show up.
Using LAVFilters-0.70.2 and nightly build LAVFilters-0.70.2-88 with PotPlayer 1.7.7150.
When playing BD (mpls) or mkv's no subtitles show up.
Also using madVR v0.92.10
Perhaps this is a PotPlayer issue?
If not are there some settings in LAVFilters I'm missing?
With this setting I can view subtitles both embedded BD (PGS) and .srt, I can also load .sup and .srt.
https://s17.postimg.org/5eh5lihwv/LAV-_OK.png
With this setting there is no way to view any subtitles.
I can add them but they doesn't show up.
https://s17.postimg.org/n4iu6ldi7/LAV-_NO.png
Regards
Old 20th January 2018, 12:48   #22447  |  Link
el Filou
el Filou's Avatar
Isn't the source filter the one responsible for selecting and 'sending' subtitles to the renderer?
In both your screenshots you're using Potplayer's built-in source (BDMV) filter. Is there an option to use LAV source filter instead?
Edit: what I mean is, also use LAV's own source filter if you're using its video decoder. Maybe that's where the problem is coming from.
Old 20th January 2018, 13:20   #22448  |  Link
varekai
varekai's Avatar
@el Filou
Do you mean the tick at "Use Built-in DXVA Video Decoder?
If I disable that there is no change, no subtitles.
I'm not shure what you mean "Potplayer's built-in source (BDMV) filter."
I can't find that inside PotPlayer.
Old 20th January 2018, 13:25   #22449  |  Link
el Filou
el Filou's Avatar
Sorry, I mean the 'Built-in HDMV playlist source'.
Maybe that filter and madVR can't agree on a way to exchange subtitle data?
Old 20th January 2018, 13:39   #22450  |  Link
varekai
varekai's Avatar
@el Filou
I can't find "Built-in HDMV playlist source" inside PotPlayer.
Looked att all possible settings but can't see where to change that.
Old 20th January 2018, 13:58   #22451  |  Link
el Filou
el Filou's Avatar
I think maybe you'd find better help asking in a PotPlayer forum, because personally I don't have any problems with PGS subs using LAV and madVR both in MPC-HC and MediaPortal, and that 'Built-in HDMV playlist source' you see in the filter drop down menu is PotPlayer's own.
Old 20th January 2018, 14:08   #22452  |  Link
varekai
varekai's Avatar
OK, MPC-HC is no problem. PGS and srt works.
Strange thing is their not working in PotPlayer after adding LAV Filters...
Old 20th January 2018, 14:52   #22453  |  Link
el Filou
el Filou's Avatar
As I said, MPC-HC built-in Blu-ray playback uses a bundled version of LAV's own splitter to demux streams and manage the subtitles:
https://s9.postimg.org/ni73u0obj/MPC...y_subs_LAV.jpg
I don't know what software PotPlayer's own 'Built-in HDMV playlist source' is based on, but maybe it's not "collaborating" with LAV and/or madVR in the same way as LAV's own source filter does. You need to ask PotPlayer's developer.
Edit: is there an option in PotPlayer to force it to use an external filter, like this one in MPC: https://s9.postimg.org/bt346i027/image.png ?
If yes then try adding LAV splitter source and LAV splitter.
Old 20th January 2018, 15:12   #22454  |  Link
sneaker_ger
Yes, in PotPlayer you select LAV Splitter (Source) here:
But I don't know if it works for BD if you select MPEG2 TS or if that is extra.
Could be that the PotPlayer internal splitter has some custom connection to the PotPlayer video decoder that passes the subtitle. LAV Video does not do that, in the LAV "ecosystem" the splitter is supposed to pass the subtitles to the subtitle renderer (e.g. AssFilterMod or XySubFilter) and that one passes to the video renderer (e.g. madvr). (Except maybe DVD buttons or something...)
Best to ask in the PotPlayer forum.
Last edited by sneaker_ger; 23rd January 2018 at 15:58. Reason: LAV Splitter -> AssFilterMod -> madvr, not LAV Splitter -> madvr
Old 20th January 2018, 16:42   #22455  |  Link
varekai
varekai's Avatar
@el Filou
Tried again and again but no subtitles... :\
https://s17.postimg.org/7wto138rj/LAV.png
The Fall is a lovely movie!
Regards
Old 20th January 2018, 16:44   #22456  |  Link
varekai
varekai's Avatar
@sneaker_ger
Thanks for your input.
PotPlayer forum is not very active, I'll make a post there.
Old 21st January 2018, 11:35   #22457  |  Link
PCU
how to deblock bink video with lav filters?
PCU is offline   Reply With Quote
Old 21st January 2018, 13:31   #22458  |  Link
sneaker_ger
LAV Video doesn't have any post-processing filters like that. Try madvr artifact removal features.
Old 21st January 2018, 15:31   #22459  |  Link
el Filou
el Filou's Avatar
Indeed! Its Digital Intermediates were done in 4K too, and I think it's one of the rare movies I would buy a second time on UHD BD.
Sorry I can't see what else could interfere there and I never use PotPlayer so don't know about its potential quirks.
Last idea: if you click on LAV Splitter in that menu, can you check if you have a "[Out] Subtitle" entry like this: https://s9.postimg.org/cvw4qxb7j/image.png and what next filter it is connecting to?
I'm using MPC-HC's internal subtitle renderer so I guess that's what 'TextPassThru' is on my screenshot, but on yours it should probably connect to madVR directly? Or does PotPlayer have an internal sub renderer?
Old 21st January 2018, 23:53   #22460  |  Link
arrgh
Win8.1x64, Kaby Lake i5 7200U/HD620 : 3D-MVC-mkv
I could reproduce the problem on a disc with an Intel GPU, unfortunately it appears to be a long-standing Intel issue that can result in the GPU reporting a "busy" state infinitely, causing decoding to just die. So for the time being, i've turned off hardware accelerated decoding again.
I'm having the Problem described here:
https://forum.doom9.org/showthread.p...45#post1827545
I tried the nightly .88. Unfortunately now I have a picture in the "black-screen-movies" of before but they are now jerky and also those who worked with .83 are jerky too…
Went back to .83…..
Maybe there is a way to override the “busy” flag of the hardware?....
(samples of working/not working movies are still available for download via PM link I have sent you)
arrgh is offline   Reply With Quote
