4th October 2011, 14:51 | #222 | Link |
Thank you very much for your guide. It's very useful.
But I have a problem after reauthoring. One of added subtitles streams is running 1-2 sec forward. However, both added subtitles streams have the same timings (according to srt). Why? What's the problem? How can I correct it? Thank you for advance. |
4th October 2011, 15:14 | #223 | Link | |
Load the .srt file, then go to edit, timings, set delay. Change the +/- for your situation and you can make the necessary adjustments. |
4th October 2011, 16:42 | #224 | Link |
Desync appears after reauthoring... The same subtitles of other language plays correctly. I repeat: both srt-subtitles have the same timings. But after reauthoring the first subtitle stream is desync, and the second is correct. I don't understand why...
21st January 2012, 15:43 | #228 | Link |
1) Please tell me why do I get an error "AVSinfo.exe stopped working" every time when I start multiAVCHD.
This error also is happening sometimes when I try to change something in the program (change the value of a parameter). I installed the latest codecs from the links from your first post. I am running windows 7 x64. 2) Do I need the codecs installed if I am not interested to blank trailers, FBI warning, etc, so I do not need the preview!? I am just interested to add a subtitle to my Bluray. I am asking you this (also) because ffdshow has tens of options and I have no idea which one to thick and which one to disable to get the preview working. Thank you. Last edited by Gabriel88; 21st January 2012 at 16:47. |
21st January 2012, 16:41 | #229 | Link |
When I try to add a subtitle to the Bluray, after I push START button I get an error:
(RT) Invalid numeric format (X) - Line 23. Then another one: (RT) Access violation at address 020035F4 in module 'calclib.dll'. Read of address 00001C1D - Line 57. Please tell me what could be this!? Thank you Last edited by Gabriel88; 21st January 2012 at 16:49. |
22nd January 2012, 03:20 | #230 | Link |
can I add sup files via "external subtitles" (and not replace subtitles)?
I added 2 sup files to the external subs list, but they do not show in the pgs list, so I am confused. I do not want to remove or replace any subs, but it would be nice to edit where in the list my added sups are. At this point I don't even know if the sups are going to show. please advise btw, this is a java title if it matters at all. |
22nd January 2012, 15:03 | #232 | Link |
I created a topic to know if there's a way to transform BD into AVCHD without multiAVCHD when one don't need to change anything in the original folder (if the original BD is not Java authored) ; http://forum.doom9.org/showthread.php?t=163883 The aim is to play BD copies on standalone players which play AVCHD but not BD-5. Some of you maybe know the answer, thanks for your help |
25th January 2012, 22:31 | #233 | Link |
I reinstalled multiAVCHD and the "(RT) Invalid numeric format (X) - Line 23" and the "(RT) Access violation at address 020035F4 in module 'calclib.dll'. Read of address 00001C1D - Line 57" dissapeared
25th January 2012, 22:37 | #234 | Link |
However "AVSinfo.exe stopped working" was still present until I installed AVISynth.
CRL2007, please tell me if you could include in your guide the AVISynth to be installed. It looks the installation of AVISynth is mandatory for the program multiAVCHD (latest version) to work correctly. Thanks. |
26th January 2012, 06:06 | #235 | Link | |
@Gabriel88
Hi! The following are a few lines from the multiAVCHD tutorial, that can be found at: multiavchd.deanbg.com/tutorial.php Quote:
