7th February 2014, 21:04 | #521 | Link |
This is strange, this is how it should be used.
I ran your command without any issues c:\Prj\IntelMedia\_bin\Win32\Release\FRIMDecode -i::mvc SRC_L.h264 SRC_R.h264 -sbs -o - | c:\Prj\IntelMedia\_bin\Win32\Release\FRIMEncode -sbs 2 -i - -o::mvc Z.h264 -w 1920 -h 1080 -f 23.976 -vbr 28000 40000 FRIM Encoder version 1.22 (build: Feb 2 2014) - based on Intel(R) Media SDK Media SDK impl HARDWARE - D3D9 (C:\Program Files\Intel\Media SDK\libmfx hw32.dll) Media SDK version 1.7 Memory type System Input format YUV420 Output video AVC Source picture: Resolution 1920x1088 Crop X,Y,W,H 0,0,1920,1080 Destination picture: Resolution 1920x1088 Crop X,Y,W,H 0,0,1920,1080 Frame rate 23.976 Bitrate control VBR avg,maximum 28000,40000 GOP structure: GOP length 24 I-/P-frame distance 4 IDR-frame interval 0 GOP type Opened Num of slices 6 Target usage 4 (balanced) Processing started Frame number: 276 Processing finished in 3.43 seconds Please try it with FRIMEncode -sw (or maybe also for FRIMDecode) (I faced some issues when running in -hw mode, HW acceleration depends on driver version) Last edited by videofan3d; 7th February 2014 at 21:40. |
7th February 2014, 22:33 | #522 | Link | |
P.S. What is your video card?(HD 4000).. And, why -hw not working at all, with first example.. Last edited by sef; 7th February 2014 at 23:27. |
7th February 2014, 23:38 | #523 | Link | |
I noticed that there are sometimes some limitations (or bugs?) when using -hw mode. In -hw mode Intel Media uses graphic driver and calls GPU accelerated routines. They are "bloody-faster", on decoding 8x(!), but with some limits. I can only guess: In -sw mode each process allocates resources (memory, thread pool, etc.) in regular PC memory, so there are almost no limitations. But in -hw mode each process can use/share resources on the GPU - which are not endless, and probably depend on specific given GPU. Once exhausted (for example when running more processes/threads), each additional process fails. And number of available resources probably depends on specific GPU family. My experience is to play with -hw and -sw, and try to find proper combination. |
8th February 2014, 15:36 | #525 | Link | |
#Created by BD Rebuilder - v0.46.12 (beta) LoadPlugin("C:\APPS\DGDecNV\DGDecodeNV.dll") DGSource("D:\WORKING8\WORKFILES\VID_00000.DGI", fieldop=0).Trim(0,-91203) Spline16Resize(3840,1080) ConvertToYV12().AssumeFPS(24000,1001) Code:
#Created by BD Rebuilder - v0.46.12 (beta) LoadPlugin("C:\APPS\DGDecNV\DGDecodeNV.dll") DGSource("D:\WORKING8\WORKFILES\VID_00000.DGI", fieldop=0).Trim(91203,0) Spline16Resize(3840,1080) ConvertToYV12().AssumeFPS(24000,1001) Code:
"D:\BD_Rebuilder\tools\FRIMEncode.exe" -avi -sbs 2 -i "D:\WORKING8\WORKFILES\VID_00000.1.avs" -viewoutput -o::mvc "D:\WORKING8\WORKFILES\VID_00000.1.264" "D:\WORKING8\WORKFILES\VID_00000.1.mvc" -w 3840 -h 1080 -f 23.976 -u 6 -cpbsize 3750 -l 6 -profile high -level 4.1 -vbr 23376 35000 -gop 24 4 0 S -maxdpb 4 Code:
"D:\BD_Rebuilder\tools\FRIMEncode.exe" -avi -sbs 2 -i "D:\WORKING8\WORKFILES\VID_00000.2.avs" -viewoutput -o::mvc "D:\WORKING8\WORKFILES\VID_00000.2.264" "D:\WORKING8\WORKFILES\VID_00000.2.mvc" -w 3840 -h 1080 -f 23.976 -u 6 -cpbsize 3750 -l 6 -profile high -level 4.1 -vbr 23376 35000 -gop 24 4 0 S -maxdpb 4 If I do a single file with the same settings etc... it will complete with no issues. It's not something critical -- as a single encode always works. The purpose of the experiment is just to save time when encoding. [Edit] Note also, that either of the two specific command lines above will complete successfully if run as a single instance -- but one will fail if run concurrently. Last edited by jdobbs; 8th February 2014 at 22:31. |
9th February 2014, 09:42 | #526 | Link | |
Maybe try also upgrade video driver - Intel HW library used to be part of it, and I realized it really matters what version you have. |
9th February 2014, 09:46 | #527 | Link | |
I'll try to simulate it somehow differently ... |
9th February 2014, 21:08 | #530 | Link | |
10th February 2014, 08:01 | #533 | Link | ||
Not sure, if this is any help or not. I finish encoding world war z with multiple instance of FRIMEncode (x2) and it finished without a problem, will do Pacific Rim next with two instance and balance setting in FRIM.
(Around 60% done) (100% done) First Instance Quote:
If you fail to plan; you plan to fail, would you not agree? Think about it. Last edited by HWK; 10th February 2014 at 16:01. |
10th February 2014, 12:13 | #534 | Link |
I tried to reproduce it .... with mixed results ...
VID.1.avs: Code:
L=DirectShowSource("VIDEO.m2ts").Trim(0,-60000) StackHorizontal(L,L) Code:
L=DirectShowSource("VIDEO.m2ts").Trim(60000, 0) StackHorizontal(L,L) Input video was ~130000 frames long. Encode 1 Code:
FRIMEncode.exe -avi -sbs 2 -sw -i VID.1.avs -viewoutput -o::mvc VID.1.h264 VID.1.mvc -w 3840 -h 1080 -f 23.976 -u 6 -cpbsize 3750 -l 6 -profile high -level 4.1 -vbr 23376 35000 -gop 24 4 0 S -maxdpb 4 Code:
FRIMEncode.exe -avi -sbs 2 -sw -i VID.2.avs -viewoutput -o::mvc VID.2.h264 VID.2.mvc (...same params..) Running on i7 Haswell. And my results: When I run in -sw encoding mode, I faced the same (rather stochastic) failure on one process. When I run in -hw encoding mode, both finished correctly! As you commented, it is very time consuming to reproduce it. .... at this moment I can only add it will be very difficult to investigate the root cause - in order even to try to fix it ...) Last edited by videofan3d; 10th February 2014 at 12:17. |
10th February 2014, 16:08 | #535 | Link |
Did you get a significant speed-up with -hw set? Just wondering... I'm just going to disable multiple instance processing for FRIM in BD-RB, I think it's too unpredictable as to when it will or will not fail. While it was failing on every job before, I've since had a couple shorter jobs that completed successfully. The probability is that the issue is in the library somewhere anyway -- and that would have to be fixed by Intel anyway.
I think it's a lot more likely to happen when BD-RB starts the process and has to make frequent checks for process completion -- although I don't know why that would impact it. But even then it goes through thousands of frames (and a few hours) before it finally trips. Thanks for the look. Last edited by jdobbs; 10th February 2014 at 16:13. |
10th February 2014, 16:16 | #536 | Link |
Jdobbs, so you are dropping the idea of multi-process for time being. I manage to do something which is shown in post # 533 not sure if it is any good.
I am gone try later today with method similar to yours for dgdecnv.
If you fail to plan; you plan to fail, would you not agree? Think about it. Last edited by HWK; 10th February 2014 at 16:18. |
10th February 2014, 16:25 | #537 | Link | |
I may just leave it in and use an undocumented hidden option to enable it. Unfortunately when it happens, the encode process never ends and BD-RB just keeps waiting. Eventually you have hit the "Abort" button. Unless you have "show_encoder=1" set in the config file, you don't even know why it's hung. Last edited by jdobbs; 10th February 2014 at 16:30. |
10th February 2014, 16:28 | #538 | Link | |
At least there is light at end of tunnel Anyways, like I said I will use script posted by you and see if it works at all for information purposes, if it works fine and if not good with me.
If you fail to plan; you plan to fail, would you not agree? Think about it. Last edited by HWK; 10th February 2014 at 16:53. |
10th February 2014, 16:35 | #539 | Link | |
I see the same speed effect on my system when trying to run more than 2 instances. But that makes sense when there's no available processor bandwidth available. I would expect it to do better with -hw set. Last edited by jdobbs; 10th February 2014 at 16:42. |
10th February 2014, 16:38 | #540 | Link | |
http://forum.doom9.org/showthread.ph...83#post1667083
If you fail to plan; you plan to fail, would you not agree? Think about it. Last edited by HWK; 10th February 2014 at 16:41. |
encoders, mvc |
