27th March 2015, 03:45 | #13425 | Link |
4K Test (att Atak)
Hi Atak,
I thought I'd "test" a 4K resolution movie thru Ripbot. Firstly I upscaled a movie to 3840 x 2160 @ 40mps with Premiere Pro CC, which created a 29Gb mp4. Loaded that into Ripbot, left the video res to "do not change", used hevc h265, distributed encoding, and let it go....took approx 13 hours on my 12C Xeon. Encoded file was just under 9Gb, and played back very nicely with VLC. Can't play 4K on my TV So then I wanted to compare encoding time & file output size, using h264, but just after it starts encoding the chunks it locks up the PC, so I'm thinking h264 doesn't like encoding 2160P (4K) files. Any thoughts ???? |
27th March 2015, 18:22 | #13426 | Link |
1.18.2 beta
Added: support for extra audio stream Added: 4K-UHD resize profile Updated: eac3to 3.29, MediaInfo 0.7.72, MKVToolnix 7.7.0, x264 r2538, x265 1.5.420
27th March 2015, 20:39 | #13428 | Link |
1.18.2 beta
This message appears when I change the output mkv to avchd or change some parameters. Edit: Excuse my ignorance, but this error has something to do with decimal point(out of place) representing the 1.509Kbps in some string conversion? Last edited by soneca; 27th March 2015 at 23:20. |
28th March 2015, 00:14 | #13429 | Link | |
I haven't run it yet, but it would be useful to choose (or change) a default audio track Maybe a radio button over 1 or 2 Or audio 1 is always default?
E5 2697 v2 @ 3.0GHz on P9X79 Deluxe 24GB Xeon E5-2680 v2 @ 3.1GHz 16GB Sony Vaio VPC-F13Z1E/B Last edited by slalom; 28th March 2015 at 07:22. |
30th March 2015, 16:32 | #13432 | Link |
Error with multiple tracks
Ripbot 1.18.2 BETA
I get an error when trying to convert 2 audio tracks: Code:
analyze: 100% M2TS, 1 video track, 5 audio tracks, 11 subtitle tracks, 1:37:38, 24p /1.001 1: Chapters, 16 chapters 2: h264/AVC, 1080p24 /1.001 (16:9) 3: DTS Master Audio, English, 5.1 channels, 24 bits, 48kHz (core: DTS, 5.1 channels, 1509kbps, 48kHz) 4: AC3, English, 5.1 channels, 640kbps, 48kHz, dialnorm: -27dB 5: DTS Master Audio, German, 5.1 channels, 16 bits, 48kHz (core: DTS, 5.1 channels, 1509kbps, 48kHz) 6: DTS Master Audio, Spanish, 5.1 channels, 16 bits, 48kHz (core: DTS, 5.1 channels, 1509kbps, 48kHz) 7: AC3, Catalan, 5.1 channels, 640kbps, 48kHz, dialnorm: -27dB 8: Subtitle (PGS), English 9: Subtitle (PGS), English 10: Subtitle (PGS), German 11: Subtitle (PGS), Spanish 12: Subtitle (PGS), Danish 13: Subtitle (PGS), Finnish 14: Subtitle (PGS), Hindi 15: Subtitle (PGS), Norwegian 16: Subtitle (PGS), Swedish 17: Subtitle (PGS), Turkish 18: Subtitle (PGS), Catalan a03 dts, 48000, 5.1 a05 dts, 48000, 5.1 a05 The Arcsoft DTS Decoder only allows one operation at a time. |
30th March 2015, 17:08 | #13433 | Link |
I've been using Ripbot for years, and love the program. Every once in awhile I will get a demux error and the program stops. My last three backups have all been failures. They are all newer releases and 2 of the three are Universal titles. I get a demux error caused by eac3to. I was using an old version, so I went with the version on the front page and got the same result. I haven't tried the beta listed on the last page. All these files will correctly backup in makemkv, though I'd rather not have 29Gig mkv files. Is there a fix for this?
30th March 2015, 18:44 | #13434 | Link |
@Soneca & jett2
Try this http://www.mediafire.com/download/0n.../RipBot264.exe
30th March 2015, 18:45 | #13435 | Link | |
30th March 2015, 20:04 | #13437 | Link | |
30th March 2015, 23:42 | #13438 | Link |
Here's the demux log from my most recent attempt:
eac3to v3.27 command line: "C:\Program Files (x86)\Ripbot 264\Tools\eac3to\eac3to.exe" "E:\Video\backup\Transformers_Age_of_Extinction\" 1) 2: "C:\Temp\RipBot264temp\job1\video.mkv" -seekToIFrames 4: "C:\Temp\RipBot264temp\job1\audio_English.ac3" 10: "C:\Temp\RipBot264temp\job1\10_subtitles_English_1080.sup" 11: "C:\Temp\RipBot264temp\job1\11_subtitles_English_1080.sup" 12: "C:\Temp\RipBot264temp\job1\12_subtitles_French_1080.sup" 13: "C:\Temp\RipBot264temp\job1\13_subtitles_Spanish_1080.sup" 14: "C:\Temp\RipBot264temp\job1\14_subtitles_Portuguese_1080.sup" 1: "C:\Temp\RipBot264temp\job1\chapters.txt" -progressnumbers -log="C:\Temp\RipBot264temp\job1\demuxlog.txt" ------------------------------------------------------------------------------ M2TS, 1 video track, 7 audio tracks, 5 subtitle tracks, 2:45:07, 24p /1.001 1: Chapters, 22 chapters 2: h264/AVC, 1080p24 /1.001 (16:9) 3: TrueHD/AC3, English, unknown parameters 4: AC3, English, 5.1 channels, 640kbps, 48kHz, dialnorm: -27dB 5: AC3 Surround, English, 2.0 channels, 224kbps, 48kHz, dialnorm: -27dB 6: AC3, French, 5.1 channels, 640kbps, 48kHz, dialnorm: -27dB 7: AC3, Spanish, 5.1 channels, 640kbps, 48kHz, dialnorm: -27dB 8: AC3, Portuguese, 5.1 channels, 640kbps, 48kHz, dialnorm: -27dB 9: AC3, English, 5.1 channels, 640kbps, 48kHz, dialnorm: -27dB 10: Subtitle (PGS), English 11: Subtitle (PGS), English 12: Subtitle (PGS), French 13: Subtitle (PGS), Spanish 14: Subtitle (PGS), Portuguese Bitstream parsing for track 3 failed. <WARNING> Demuxing this track may still produce correct results - or not. <WARNING> Creating file "C:\Temp\RipBot264temp\job1\chapters.txt"... [s10] Extracting subtitle track number 10... [s13] Extracting subtitle track number 13... [s14] Extracting subtitle track number 14... [a04] Extracting audio track number 4... [a04] Removing AC3 dialog normalization... [v02] Extracting video track number 2... [s12] Extracting subtitle track number 12... [s11] Extracting subtitle track number 11... [v02] Muxing video to Matroska... [a04] Creating file "C:\Temp\RipBot264temp\job1\audio_English.ac3"... [s11] Creating file "C:\Temp\RipBot264temp\job1\11_subtitles_English_1080.sup"... [s12] Creating file "C:\Temp\RipBot264temp\job1\12_subtitles_French_1080.sup"... [s10] Creating file "C:\Temp\RipBot264temp\job1\10_subtitles_English_1080.sup"... [s13] Creating file "C:\Temp\RipBot264temp\job1\13_subtitles_Spanish_1080.sup"... [s14] Creating file "C:\Temp\RipBot264temp\job1\14_subtitles_Portuguese_1080.sup"... [a04] Writing the destination file failed. <ERROR> Aborted at file position 32176603136. <ERROR> Please let me know if I need to supply more information. |
31st March 2015, 10:22 | #13440 | Link |
Hi all, just wondering if the is a solution to a problem I am having with distributed encoding... I have been using it for a few months now and general it works perfectly.. however occasionally the server locked up... Not to much of a problem, just abort and then restart it... And the process continues.... The problem I am having is occasionally when the server locks up and I press abort not all the clients end... So when I restart the server some of the clients do not recommence encoding... The status in the server window just stays on "connecting" the only way I have worked out how to fix this is to abort the process and the reset the clients encoding server. The restart the main encoding server..... Is their a way to for the reset on the client and continue encoding without stopping and restarting the server?
