29th September 2014, 14:00 | #21302 | Link |
BD Rebuilder v0.49.02 (beta)
I have updated the first post of this thread with a link to the most recent version of BD-RB (v0.49.02). Changes for this release:
- Modified processing so that MPEG-2 sources use DGINDEX and DGDECODE for decoding when DirectshowSource() is selected. This will result in more accurate encoding and sync. This is especially true when LAVFilters are used and iVTC has been selected. - Corrected an issue in which BD-RB could inappropriately keep an original source that is HEVC because its size will fit in the target when "IMPORT_HEVC_INTACT" is enabled. - Corrected an issue in which extracting a BD video source containing HEVC (illegal) would result in an error upon attempt to remux into intact ALTERNATE output. - Corrected an error in which selecting HEVC output with the 2-pass target option set was not working correctly. - Added TWEAK_X265 as a hidden option, allows tweaking, adding command line options, to the x265 command line for HEVC encoding. - Updated x265 version to the daily release for 9/28/2014. - Other minor corrections and cosmetic fixes. Last edited by jdobbs; 29th September 2014 at 15:53. |
29th September 2014, 14:56 | #21303 | Link |
I am unable to download this new beta! I get redirected to a page not found error!
Happens both here and from www.jdobbs.com. |
29th September 2014, 15:12 | #21304 | Link | |
If you fail to plan; you plan to fail, would you not agree? Think about it. Last edited by HWK; 29th September 2014 at 15:20. |
29th September 2014, 15:48 | #21308 | Link | |
it is Jdobbs, new invention which he created in year 2914
29th September 2014, 19:11 | #21316 | Link | |
It's quite a bit faster at decoding than the official build. |
29th September 2014, 20:04 | #21317 | Link |
You can't output to blu-ray with HEVC option, no amount of tweaks will help here.
29th September 2014, 20:11 | #21319 | Link | |
