17th February 2014, 01:11 | #19262 | Link |
@jdobbs
Thank you for the new release. I notice that BD-RB 0.46.13 still wants to add the sky background Clip as an Extra to the Quick-Menu. It happens after importing, when launching the Quick-Play Menu Editor and Save: Code:
[Titles] Title=SCRATCH Threshold=27000000 00001=BC1 00002=BC2 00003=03. Disc Extra: [00:00:01.042] [Position] 00001=1 00002=2 00003=3 [Selected] 00001=-1 00002=-1 00003=-1 |
17th February 2014, 01:22 | #19263 | Link | |
But I'll look at it and make changes as necessary. Last edited by jdobbs; 17th February 2014 at 01:24. |
17th February 2014, 02:17 | #19264 | Link |
Jdobbs, do we need option write to iso file with imgBurn anymore. Since tsmuxer can do that just fine.
Also I was thinking frimdecode can decode MPEG2, H.264 AVC, H.264 MVC (3D) and VC1 as well, by adding that option for frame-serving it would provide another option.
If you fail to plan; you plan to fail, would you not agree? Think about it. Last edited by HWK; 17th February 2014 at 02:27. |
17th February 2014, 05:55 | #19265 | Link | |
The downside to FRIMDecode (and FRIMSource) is speed compared to other methods. Right now I'm thinking X264's LAVF might be a better option for decoding. Both, though, have quite a few downsides -- especially in the areas of resizing, deinterlacing, iVTC, hybrid sources etc... AVISYNTH gives a lot of power that is difficult to do without. If you set FRIMDecode as an option -- you have to disable a lot of capability in order to use it. Last edited by jdobbs; 17th February 2014 at 06:01. |
17th February 2014, 11:50 | #19266 | Link | |
17th February 2014, 16:02 | #19268 | Link |
"Blank this Item" - Blanked!
Hi jdobbs
When in Full Backup mode I just can't seem to get the title blanking feature to work. Read the various posts on this and added the ENABLE_TEST=1 line to the .INI file but still no joy. Happens with all BD sources, right click any title and the Preview works fine but the "Blank this item" option is always greyed out and not selectable. Options Settings as follows - [Options] ENABLE_TEST=1 RESIZE=0 MODE=0 TARGET_SIZE=8032 AUDIO_TO_KEEP=eng; SUBS_TO_KEEP=eng;spa; SD_CONVERT=0 COLOR_BOOST=0 RESIZE_1080=0 DTS_REENCODE=0 AC3_REENCODE=0 AC3_640=1 KEEP_HD_AUDIO=1 AVCHD=1 REMOVE_WORKFILES=0 AUDIO_TRACK_LIMIT=1 SUBTITLE_TRACK_LIMIT=0 CUSTOM_TARGET_SIZE=3500 ENCODE_QUALITY=2 AUTO_QUALITY=0 ONEPASS_ENCODING=0 OPEN_GOP=1 DEINTERLACE=0 AC3_192=0 FULL_AVCHD=0 REMOVE_OUTPUT=0 USE_FILTERS=0 MOVIE_ONLY_LOOP=1 BDMV_CERT_ONLY=0 USE_LAVF=1 IVTC_PULLDOWN=0 VERSION=0.46.0.13 SD_TO_1080=0 CONVERT_WIDE=0 ASSUME_DVD_PAL=0 AUTO_BLANK=0 UNMASK_CHAPTER=0 COMPLETION_BEEP=0 DGDECNV=0 MIN_PLAYLIST_MINS=1 RESIZE_1440=0 OUTPUT_3D=0 RESIZE_720=0 NEROAAC=0 MOVIEONLY_TYPE=11 ALTCRF=18 ALT_TARGET=18000 ALTMETHOD=0 ALTAUTOCROP=0 IGNORE_3D=0 OUTPUT_SBS=1 SUPTITLE=0 |
17th February 2014, 17:30 | #19270 | Link | |
17th February 2014, 18:35 | #19271 | Link |
Thanks! Working fine now and trying a first experiment. I notice that you cannot select Alternative File output with blanking which is a shame as I much prefer the single file MKV result (better quality vs file size IMHO and easier to work with). Ideally I would like a multi title + custom blanking + menu in MKV format - I assume that is not available!
17th February 2014, 19:34 | #19272 | Link | |
My scenario is to import a couple of files (videocam, TV recordings) and to create a Quick-Menu. All goes well until -- before pressing the 'Backup' button -- I decide to edit the quick menu via Mode/Quick-Play Backup/Edit Quick-Play Menu. The menu editor opens and the menu background file (the default night sky video) is appended to the menu items as an "Extra" (the thresholds are set to 10, so I would not expect the sky video to be included as an Extra in the Quick-Menu) Not a critical issue but I thought it's probably not intentional, and it might be the root cause for the weird menu creation reported earlier. |
17th February 2014, 21:21 | #19273 | Link | |
17th February 2014, 23:42 | #19274 | Link | |
18th February 2014, 14:12 | #19275 | Link | |
Also I noticed that the list of video titles displayed in the stream tab is restricted. The cut off point seems to be file sizes less than 10kb? In the test I ran the annoying copyright / fbi stuff is less than this cutoff so I did not get the option to blank them. Tried the following in the INI file - "MIN_PLAYLIST_MINS=0" which does not make a difference..... I guess there is something obvious i'm missing |
18th February 2014, 15:08 | #19276 | Link | |
Look for MIN_M2TS_SIZE in HIDDENOPTS.TXT. MIN_PLAYLIST_MINS only applies to the selection of other movie-only playlists (in the popup dialog). Last edited by jdobbs; 18th February 2014 at 15:13. |
19th February 2014, 01:19 | #19277 | Link |
Burning a dvd-r
Hey, so i made a backup of game of thrones using Full Backup BD-5/DVD-5 option. I burned the files using Imgburn. When i try to play the dvd-r in my bluray player or in PowerDVD, its giving me an error saying it cant read the disc...This is my first time backing up a TV series type bluray with BDR. Is there a specific way to backup these type of blurays? Am i missing some special settings in the ripping or burning? Should tv series type blurays not use full backup option? Any tips? Ive never had an issue with NON-Series type blurays.
Other settings im using *Use 448 kbs *Strict avchd for bd5/9 movie-only thx for any help/tips |
19th February 2014, 02:32 | #19279 | Link |
@Doctorm: where's the rest of the bdrb log. Jdobbs can't do a damn thing with 3 lines of text
@stigmata: it could simpy be that your player does not support BD5/9. Although burned to a DVD blank, the disc structure is still blu-ray |
