12th June 2008, 03:54 | #5061 | Link | |
b4k3d
The thing is when ever I have a delay, say in a EVO file, if I demux the ES streams from the container with EVOdemux then run them through eac3to it seems to remove the delay but my streams always play fine and in synch. Actually when I let eac3to process delay it sometimes makes my files out of synch after remuxing with tsMuxeR. To be safe if my streams have delay reported by eac3to I always demux to get rid of the delay. It has seemed to work every time for me. |
12th June 2008, 20:41 | #5063 | Link |
madshi, would it be possible that you could output more of the undocumented switches (either here or in eac3to) ? I have a problem with a .m2ts file and am looking for that switch to ingore possible errors now, but since its not documented in eac3to I cant find it.
13th June 2008, 02:42 | #5064 | Link |
hi guys, i have 3 little question about eac3to
---- 1 ---- Code:
wine --version wine-1.0-rc3 Code:
M2TS, 1 video track, 5 audio tracks, 1:45:58 1: h264/AVC, 1080p24 /1.001 (16:9) 2: RAW/PCM, 5.1 channels, 16 bits, 48khz 3: AC3, 5.1 channels, 640kbit/s, 48khz, dialnorm: -28dB 4: AC3, 5.1 channels, 640kbit/s, 48khz 5: AC3, 2.0 channels, 192kbit/s, 48khz 6: AC3, 2.0 channels, 192kbit/s, 48khz Hooking WriteConsoleA failed (Erfolg). [v01] Extracting video track number 1... [v01] Muxing video to Matroska... [v01] Starting DirectShow conversion failed. Aborted at file position 1409024. wine /home/earl/.wine/drive_c/Programme/eac3to_2-46/eac3to.exe -test Code:
Sonic Audio Decoder (2.46.0.0) doesn't seem to be installed Haali Media Splitter (2008-3-29) is installed Surcode DTS Encoder (1.0.23.0) is installed MkvToolnix (v2.2.0) is installed ---- 2 ---- Code:
eac3to 1.evo+2.evo 2: d:\abc_movie.mkv 4: d:\abc_4audio.eac3 5: d:\abc_5audio.eac3 6: d:\abc_6audio.eac3 EVO, 2 video tracks, 5 audio tracks, 6 subtitle tracks, 2:12:34 1: Joined EVO file 2: h264/AVC, 1080p24 /1.001 (16:9) with pulldown flags 3: VC-1, 480p30 /1.001 (3:2), -80ms 4: E-AC3, 5.1 channels, 1536kbit/s, 48khz, dialnorm: -27dB, -80ms 5: E-AC3, 5.1 channels, 768kbit/s, 48khz, dialnorm: -27dB, -80ms 6: E-AC3, 5.1 channels, 768kbit/s, 48khz, dialnorm: -27dB, -80ms 7: E-AC3, 2.0 channels, 192kbit/s, 48khz, dialnorm: -27dB, -80ms 8: E-AC3, 2.0 channels, 192kbit/s, 48khz, dialnorm: -27dB, -11ms 9: Subtitle 10: Subtitle 11: Subtitle 12: Subtitle 13: Subtitle 14: Subtitle [v02] Extracting video track number 2... [a05] Extracting audio track number 5... [a06] Extracting audio track number 6... [a04] Extracting audio track number 4... [a06] Removing dialog normalization... [v02] Muxing video to Matroska... [a04] Removing dialog normalization... [a06] Applying (E-)AC3 delay... [a04] Applying (E-)AC3 delay... [a05] Removing dialog normalization... [a05] Applying (E-)AC3 delay... [a04] Creating file "d:\abc_4audio.eac3"... [a05] Creating file "d:\abc_5audio.eac3 "... [a06] Creating file "d:\abc_6audio.eac3 "... ---- 3 ---- "[a04] Applying (E-)AC3 delay..." i convert the .eac3 to .ac3, and i will mux it with mkvmerge with the abc_movie.mkv file, what have i to do with the "-80ms delay" ? .... i must set -80 ms in the mkvmerge(gui) ? or does eac3to change anything on the delay ? |
13th June 2008, 04:46 | #5065 | Link |
Location: The Great North (the better half of North America)
LPCM to DTS-help
I just tried to convert a LPCM track @ approx 7MB/s to DTS @1536kbps using eac3to with eac3toGUI. I used the sonic filter and Surcode is intstalled on my PC. Everything started fine, the single 5GB LPCM file was split to six single channels by eac3to then the recode began and finished after about 15 minutes. I then tried to load the file in tsMuxeR but it came back "cannot detect stream", any ideas?
Also, in eac3toGUI the default output was AC3, I changed it to DTS. Thanks in advance. |
13th June 2008, 08:11 | #5066 | Link |
The (E-)AC3 reader didn't receive the format information.
I've been using eac3to for some time with no problems on both BD and HD-DVD. Just starting tonight I get the following error:
D:\LIAR_LIAR>D:\HDDVDTL\eac3to feature.evo The (E-)AC3 reader didn't receive the format information. The (E-)AC3 reader didn't receive the format information. The (E-)AC3 reader didn't receive the format information. EVO, 1 video track, 2 subtitle tracks, 1:25:56 1: VC-1, 1080p24 /1.001 (16:9) with pulldown flags 2: Subtitle 3: Subtitle D:\LIAR_LIAR> Code:
D:\THE_LOST_CITY>D:\HDDVDTL\eac3to PEVOB_1.evo+PEVOB_2.evo The (E-)AC3 reader didn't receive the format information. This doesn't seem to be a valid (E-)AC3 stream. The format of the source file could not be detected. D:\THE_LOST_CITY> Code:
D:\LICENSE_TO_WED>D:\HDDVDTL\eac3to feature_01.evo+feature_02.evo The (E-)AC3 reader didn't receive the format information. The (E-)AC3 reader didn't receive the format information. The (E-)AC3 reader didn't receive the format information. The format of the source file could not be detected. D:\LICENSE_TO_WED> Code:
D:\HDDVDTL>eac3to -test Nero Audio Decoder (Nero 7 or older) works fine Sonic Audio Decoder (4.3.0.169) works fine Haali Media Splitter (2008-3-29) is installed Surcode DTS Encoder (1.0.23.0) is installed MkvToolnix (v2.2.0) is installed D:\HDDVDTL> Did a check disk, and HDD is fine. Nero is v7.11.10.0. Finally, I'm using Windows XP Pro SP3. And yes, everything was working fine even after I installed SP3... at least for a while. Anyone have an idea what's going wrong here? Thanks. |
13th June 2008, 08:15 | #5067 | Link |
@ earl
1. Probably wine. Wait until madshi shows up to be sure. 2. Read here. 3. A few posts above is your answer... eac3to can delay all audio tracks. Only exception is truehd demuxing (the delay value is written to the filename then). You don't to do anything in mkvtoolnix. @ odin24 Post the eac3to log file. Probably surcode didn't start encoding (the processing time is too short). @ bigdog660 It doesn't have to do anything with the codecs installed (-test) - these are for decoding/encoding, not reading the source files. Perhaps it is caused from bad ripped discs. Did you got all these errors in one day? Can you find a disc that works to ensure that it's not your system's problem? Can you send a sample from one of those movies to test it? Last edited by nautilus7; 13th June 2008 at 08:24. |
13th June 2008, 08:45 | #5068 | Link |
Hey folks, is BDEdit (or similar manual approach), and then entering each .m2ts filename on the command line, still the only way to figure out and then select which files to include for a branching disc?
Or is there an automatic way to select which .m2ts files to include in my "eac3to 00001.m2ts+00002.evo movie.mkv" command (e.g. if I could just specify a playlist file that would be pretty cool!) Last edited by ntk; 13th June 2008 at 09:00. |
13th June 2008, 11:06 | #5069 | Link |
eac3to can read playlist files and find the correct order automatically. Just run eac3to and set as input the root folder of your blu-ray disc. Then select the appropriate title { 1) or 2) or 3) or... } and add it to the previous command line.
13th June 2008, 15:50 | #5073 | Link |
And also the pulldown removal in eac3to is for the same purpose, but as madshi have said latest vc1conv does a better job. That's why he had removed that functionality from eac3to (he put it back by request).
13th June 2008, 16:05 | #5074 | Link | |
One other question, will eac3to demux m2ts files and produce a raw 264 file? |
13th June 2008, 16:26 | #5075 | Link | |
eac3to "F:\Rambo IV 2008 Blu-ray 1080p H.264 DTS-HD MA 7.1" 1) 00041.mpls, 2:00:22 [112+127+115+128+117+129+119+130+121+131+123+132+125].m2ts - h264/AVC, 1080p24 /1.001 (16:9) - h264/AVC, 480p24 /1.001 (16:9) - DTS Master Audio, English, multi-channel, 48khz - AC3, French, multi-channel, 48khz - AC3, English, stereo, 48khz 2) 00042.mpls, 2:00:22 [112+127+115+128+117+129+119+130+121+131+123+132+125].m2ts - h264/AVC, 1080p24 /1.001 (16:9) - h264/AVC, 480p24 /1.001 (16:9) - DTS Master Audio, English, multi-channel, 48khz - AC3, French, multi-channel, 48khz - AC3, English, stereo, 48khz 3) 00040.mpls, 1:31:32 [112+114+115+116+117+118+119+120+121+122+123+124+125].m2ts - h264/AVC, 1080p24 /1.001 (16:9) - h264/AVC, 480p24 /1.001 (16:9) - DTS Master Audio, English, multi-channel, 48khz - AC3, French, multi-channel, 48khz - AC3, English, stereo, 48khz 4) 00037.mpls, 1:10:56 [87+88+89+90+91+92+93].m2ts - MPEG2, 1080i30 /1.001 (16:9) - AC3, English, stereo, 48khz 5) 00056.mpls, 00125.m2ts, 0:25:16 - h264/AVC, 1080p24 /1.001 (16:9) - h264/AVC, 480p24 /1.001 (16:9) - DTS Master Audio, English, multi-channel, 48khz - AC3, French, multi-channel, 48khz - AC3, English, stereo, 48khz 6) 00046.mpls, 00115.m2ts, 0:22:32 - h264/AVC, 1080p24 /1.001 (16:9) - h264/AVC, 480p24 /1.001 (16:9) - DTS Master Audio, English, multi-channel, 48khz - AC3, French, multi-channel, 48khz - AC3, English, stereo, 48khz 7) 00011.mpls, 00087.m2ts, 0:19:45 - MPEG2, 1080i30 /1.001 (16:9) - AC3, English, stereo, 48khz Code:
eac3to "F:\Rambo IV 2008 Blu-ray 1080p H.264 DTS-HD MA 7.1" 1) M2TS, 2 video tracks, 3 audio tracks, 2:00:22 1: Chapters, 17 chapters 2: h264/AVC, 1080p24 /1.001 (16:9) 3: h264/AVC, 480p24 /1.001 (20:11) 4: DTS Master Audio, English, 5.1 channels, 24 bits, 48khz 5: AC3, French, 5.1 channels, 640kbit/s, 48khz, dialnorm: -27dB 6: AC3, English, 2.0 channels, 192kbit/s, 48khz, dialnorm: -27dB Code:
eac3to "F:\Rambo IV 2008 Blu-ray 1080p H.264 DTS-HD MA 7.1" 1) 1: c:\rambo\rambo.chapters.txt 2: c:\rambo\rambo.mkv 4: c:\rambo\rambo.flac 4: c:\rambo\rambo.dts -core 5: c:\rambo\rambo.comm.ac3 M2TS, 2 video tracks, 3 audio tracks, 2:00:22 1: Chapters, 17 chapters 2: h264/AVC, 1080p24 /1.001 (16:9) 3: h264/AVC, 480p24 /1.001 (20:11) 4: DTS Master Audio, English, 5.1 channels, 24 bits, 48khz 5: AC3, French, 5.1 channels, 640kbit/s, 48khz, dialnorm: -27dB 6: AC3, English, 2.0 channels, 192kbit/s, 48khz, dialnorm: -27dB Creating file "c:\rambo\rambo.chapters.txt"... [v02] Extracting video track number 2... [a04] Extracting audio track number 4... [a04] Extracting audio track number 4... [a05] Extracting audio track number 5... [v02] Muxing video to Matroska... [a04] Extracting DTS core... [a04] Decoding with DirectShow (Sonic Audio Decoder)... [a05] Removing dialog normalization... [a04] DirectShow reports 5.1 channels, 24 bits, 48khz [a04] Encoding FLAC... [a04] Creating file "c:\rambo\rambo.flac"... [a04] Creating file "c:\rambo\rambo.dts"... [a05] Creating file "c:\rambo\rambo.comm.ac3"... ---------- Last edited by nautilus7; 13th June 2008 at 16:36. |
13th June 2008, 16:51 | #5078 | Link | |
I'll probably try the gui, I was like nautilus7 when I tried the gui before, now that I've used eac3to some and am a little more familiar with it, the gui might be great, but I didn't have a clue about eac3to to start with and the gui was overwhelming. |
13th June 2008, 21:03 | #5079 | Link |
That's probably the root folder for a ripped disc. If you're running straight from your HD-DVD/BD drive then d:\ is fine.
Eac3to And More GUI |
13th June 2008, 23:29 | #5080 | Link | |
HD DVD disc structure not found. I can run eac3to directly on the main m2ts file in D:\BDMV\STREAMS, but that is all it works on the best I can tell, I've tried the mpls files and that doesn't work either. Running 2.42, ouch, I would have sworn I had 2.46. Anyway, downloaded 2.46 and now all works as it should. Thanks for the replies, I would have suffered through until a newer version was released. |
eac3to |
