9th February 2021, 12:13 | #961 | Link |
MKVToolNix author
This happens mostly when the appended files has more tracks than the file it's being appended to. In that case the GUI cannot really find a good place where to place the superfluous tracks, and it ends up laying them out in way that the superfluous tracks would be appended to the last non-superfluous track of the appended file.
You'll have to deactivate those appended tracks for which there's no corresponding track in the file they're appended to. Example: Let's assume your first file contains one video, one audio track, and that your second file (the one you're trying to append to) contains one video, one audio and one subtitle track. In such a setup the GUI will set up things this way by default:
In that case you'd have to deactivate the subtile track from file 2.
Latest MKVToolNix is v83.0 If I ever ask you to upload something, please use my file server. |
12th February 2021, 04:39 | #963 | Link |
Hi Moritz,
I have a question on stretching chapters. I have subtitles and chapters from an old mkv file @ 23.976 and the new on is 24fps. I can stretch the subs to perfectly match by stretching it by 0.999 but if I do the same for the chapters they all end up as 0s. I had first extracted it as XML and added it via "Chapter file". Additionally: is there any reason one cannot delay the chapters directly from the properties tab rather than extracting it, re-adding it and then adding a delay in the Chapters section? It would also be helpful if you could give some examples of the stretching in the wiki you wrote about avoiding to stretch audio? E.g. 23.976fps->24fps, 25fps -> 23.975 and so on. https://gitlab.com/mbunkus/mkvtoolni...k-audio-tracks I tried to look everywhere for help on this but didn't find any examples. Lastly, your contact page is still linking to the old forum post: https://mkvtoolnix.download/community.html Thank you. Last edited by odino; 12th February 2021 at 04:47. |
12th February 2021, 14:35 | #964 | Link |
MKVToolNix author
mkvmerge treats chapters completely differently than regular tracks. This means that all calculating operations on chapters are pretty hacky and not tested well.
Use the chapter editor, open the chapters, right-click on the top-most item, select "Additional modifications" from the popup menu, enable "Multiply start and end timestamps…". Calculate 23.976/24 and enter the result in the dialog. I'm not keen on giving a lot of examples. It's better to understand what you're doing/what you're calculating, 'cause then you don't have to look for the exact example matching your current use case, but you can calculate it yourself. If your original video track plays at x FPS, and your new one at y FPS, then the factor to use is always x/y. If you're going from 23.976 FPS to 24 FPS you play _more_ frames per second meaning same number of frames will result in a _shorter_ video meaning the resulting factor for adjusting other tracks to the new rate must be < 1. That's your check to see if you swapped the two values. I'll fix the link. Thanks.
12th February 2021, 14:38 | #965 | Link |
MKVToolNix author
Addendum: which MKVToolNix version are you trying the chapter sync with? 'cause there was a pretty important fix in v53 for --chapter-sync.
I also just tried the following: mkvmerge -o out.mkv --chapter-sync 0,0.999 in.mkv with v53 and the resulting chapter timestamps in out.mkv are just; they're exactly the original timestamps * 0.999.
Latest MKVToolNix is v83.0 If I ever ask you to upload something, please use my file server. Last edited by Mosu; 12th February 2021 at 14:49. |
14th February 2021, 03:48 | #966 | Link |
PnS Rotate Y- flips horizontally ******* I noticed a video I have here needs me to apply this MPC-HC feature, which also doesn't seem to work with madVR, only Enhanced Video Renderer. Alt + num 6 will do the trick. I was wondering if it's possible to apply this without reencode, and using MKVToolnix. The file is a Matroska. Or perhaps a lossless change as suggested here: https://stackoverflow.com/questions/...ut-re-encoding However this one only applies to MP4. |
17th February 2021, 17:11 | #967 | Link |
Hi, I?ve some mp4 produced by an Hikvision DVR that I want to join.. they are without timestamps, as the the recorder don't care do well pack the mp4 before close it, so it's up to the software solve this problem. Avidemux doesn't accept these files, so I try to join to mkv but the result isn't so good, half of the video is "masked/corrupted" and it appears only when people are passing by it. I attach 2 files here, maybe they can be helpful to solve the problem, if possibile.Thanks
https://drive.google.com/file/d/1WIw...ew?usp=sharing PS: if you may suggest me a way to correct the problem, maybe a command line with ffmpeg, I'll be glad to try. Thank you! PS2: I've the latest version 53 EDIT: I can solve the error in files using this command: ffmpeg -err_detect ignore_err -i 1.mp4 -c copy output.mp4 I suppose you use ffmpeg too to manage and merge mp4 files, may you please introduce che chance to apply a ffmpeg command to any input file boefore processing? It would be great to have a batch/gui interface to do that.. thanks Last edited by Barabba; 17th February 2021 at 18:06. |
19th February 2021, 10:47 | #968 | Link |
I think there is a Unicode issue:
mkvextract .\unicode-🙂.mkv tracks 1:.\unicode-🙂.aac
19th February 2021, 21:27 | #969 | Link |
MKVToolNix author
Thanks, that should be fixed now.
20th February 2021, 20:57 | #970 | Link |
Thanks!
26th February 2021, 20:23 | #971 | Link |
MKVToolNix author
MKVToolNix v54.0.0 released
Heya,
again I'm releasing a bit early, not even four weeks after the previous one. This release, however, does pack quite a bit more of a punch than the previous ones, both in terms of enhancements and bug fixes. On top of that one of the libraries used (libEBML) has just been released fixing several heap overflow bugs, and I didn't want to wait too long to get those fixes into a new MKVToolNix release. There have been several changes concerning package maintainers. Please refer to the NEWS below for details. Here are the usual links: the MKVToolNix home page, the Windows installer/portable version & macOS DMG & Linux AppImage and the source code. The Windows and macOS binaries as well as the Linux AppImage are available already. The other Linux binaries are still being built and will be available over the course of the next couple of hours. Here are the NEWS since the previous release: Version 54.0.0 "F Maj Pixie" 2021-02-26 New features and enhancements
Bug fixes
Build system changes
Have fun
26th February 2021, 21:36 | #972 | Link |
Thanks for the new version...
I found one small issue (using the 32-bit portable version under Win7-64): After overinstalling over the previous version keeping the old INI file the program always hangs when trying to open a file via right-click in the source window. Drag and Drop with Explorer works. What fixed it was deleting the old INI file and reentering my settings. Must be some inconsistency with the INI entries between the old and the new version. No big deal... |
26th February 2021, 21:40 | #973 | Link |
MKVToolNix author
Too bad you removed the file. I would surely have liked to take a look at the issue, but without… Well.
26th February 2021, 22:24 | #974 | Link |
Just repeated the installation on another ThinkPad with almost identical setup. No problems with this one, and I believe it has something to do with the font size setting.
The laptop which had no issues uses a font size of 100%. The other one which had the issues has a higher resolution screen and uses a font size of 125% (my eyes getting a little old). And this bigger font size made the difference. //EDIT// Oh damn, I mixed it all up... The laptop which had the issue also uses a display setting of 100%. What I did to improve readability was to reduce the screen resolution from the native 1600x900 to a smaller resolution of 1360x768. This usually does not cause problems, but the Qt library might behave differently. //EDIT2// If you still want to look at my previous INI file, I do have Rollback RX installed so I can easily retrieve the old INI file and upload it. Let me know... Last edited by manolito; 26th February 2021 at 22:43. |
26th February 2021, 23:04 | #975 | Link |
MKVToolNix author
Yeah, I don't support such low resolutions. The GUI has certain minimum required sizes that depend on the active language (as labels, combo box contents etc. have different lengths in different languages). There will be weird interactions if the automatically stored/remembered frame positions & sizes don't fit into the screen anymore and similar things. Nothing I want to spend time on.
28th February 2021, 01:37 | #976 | Link |
Still a little bit weird...
The laptop which has no problems has a screen resolution of 1280x800. The other one which showed the problem has a resolution of 1360x768. This is in the same ballpark for me, and both resolutions are certainly HD resolutions. So I don't really understand why one of these screen resolutions works and the other does not... Well, at least it does work after deleting the INI file, so no real problem... Last edited by manolito; 28th February 2021 at 01:41. |
1st March 2021, 17:24 | #978 | Link |
Hi - Thanks for the continued development of this very useful tool.
Wanted to add that I have the same issue as reported above with v54.0. I usually open sources via the 'Add source files' button but doing that in this version results in the application hanging and having to be killed. Folders/sources don't appear, it just hangs. This is on a laptop with a 1920*1080 display with text/apps display set to 125% if that matters, saw it mentioned above. I can still use mkvtoolnix by dragging and dropping sources. And I guess a clean install may resolve the issue if that worked for others. But before I do that if you want me to send in the configuration settings file let me know. |
2nd March 2021, 02:46 | #979 | Link |
I used to be able to cut off audio/sub tracks that ran longer than the video with the split function. This no longer works.
>have 22:09 video >audio and sub tracks are 23:40 because they have an ending I cut from the video >set to split after 22:09 >Doesn't split. |
2nd March 2021, 12:31 | #980 | Link | |
MKVToolNix author
matroska |
