7th July 2008, 15:43 | #281 | Link | |
AVStoDVD Dev
What do you mean by "slightly out of time to the other"? Bye |
7th July 2008, 15:50 | #282 | Link |
Hi MrC - for some reason it appeared that the hard coded subtitles appeared at a slightly different time to the normal subtitles. Not sure which was correct through.
Also, if you have any alpha versions, there always good to play with and provide feedback for! |
7th July 2008, 16:05 | #283 | Link | |
7th July 2008, 22:00 | #284 | Link |
Hi, I think I've found a little bug, at least on my pc...
After selecting source video file, and press the button "Preview file output", if I select "Goto frame..." and then press "Cancel", the program crashes with a "Run-time error 13: type mismatch". Can anyone reproduce it? Bye |
7th July 2008, 22:03 | #285 | Link | |
10th July 2008, 15:33 | #287 | Link | |
AVStoDVD Dev
Bye |
10th July 2008, 15:37 | #288 | Link | |
AVStoDVD Dev
- Go to 'Settings'/'Encoding' - Select 'QuEnc CBR 1-pass' - Put 'Lower bitrate level' to 9000 Done! Simple, isn't it? You can also customize bitrate levels for 'HCenc OPV 1-pass' and 'HCenc VBR 2-pass'. Ah, do not forget to check 'Save current settings as default' before exiting from Settings window. Bye |
10th July 2008, 15:44 | #289 | Link | |
AVStoDVD Dev
Mabye does Wine lack VB6 runtime libraries? Bye |
10th July 2008, 15:51 | #290 | Link | ||
AVStoDVD Dev
Bye |
14th July 2008, 14:59 | #294 | Link | |
AVStoDVD Dev
I'm not plannig to put an option to customize HCenc profile, at least it is not on top of my ToDo list. And I fear that grabbing HCenc ini file (created by AVStoDVD and stored in Temp folder) is not very easy because there is no time span between ini creation and usage... Let me know if I have answered to your question. Bye |
14th July 2008, 16:25 | #295 | Link | ||
I'd normally only use best, but if I want to do a fast test or something I'm not really bothered about, I'd have liked the option to change the profile.
It appears I need to edit hc.ini for another reason (as discussed in the HC forum here for a problem I've been having) Quote:
15th July 2008, 15:38 | #296 | Link |
For people interested in adding custom initialisations to the encodes based on HCenc, Darksoul71 has just released a very interesting wrapper for HCenc. See here the details:
http://forum.doom9.org/showthread.php?t=139277 However I did not perform any test on my own (at least up to this moment...) of AVStoDVD + HCWrap... Cheers, SD Last edited by Sir Didymus; 15th July 2008 at 15:41. |
15th July 2008, 16:03 | #297 | Link | |
15th July 2008, 16:04 | #298 | Link | |
AVStoDVD Dev
Bye |
