Old 3rd June 2009, 13:28   #241  |  Link
Didée
No.
TemporalSoften is, roughly, 100 times faster than TGMC as a whole. Even if temporalsoften2 (very old & outdated, wasn't it designed for Avisynth 2.0, IIRC?) would be some percent faster, it wouldn't matter. Some percent from one percent is ... practically null.
BTW, somewhen lately I made I rough implementation (only POC, not *generally* functional, hence not posted yet) of your faster ME proposal, which also included the transition from MVTools v1.9.x (original TGMC) to the actual MVTools v2.4.x. What I observed was that there's a small speed improvement of "fast-ME" vs. the original "full-ME", but ... somehow, even with "fast-ME", the new MVTools-v2 version was slower than the original MVTools-v1 version ...
It seems a bit ridiculous to put effort into micro-improvements on the script level, when the hosting environment/tools get slower on a macro level ...
- We´re at the beginning of the end of mankind´s childhood -
My little flickr gallery. (Yes indeed, I do have hobbies other than digital video!)
Didée is offline   Reply With Quote
Old 3rd June 2009, 15:06   #242  |  Link
Terka
yes, i know that the improvement is low.
1.what is the most time consumer in TG? mvtools time could be halved, bob instead of nnedi/edi can be used.
2.so mvtools2 are slower than mvtools1? and what about quality?
3. im using TGMC on DV sources. unfortunately DV has quite big artefacts, so some appear more visible when TGMC calms most of the picture.
but TGMC is far best deinterlacer.
Terka is offline   Reply With Quote
Old 3rd June 2009, 17:06   #243  |  Link
2Bdecided
But doesn't MVTools-v2 multi-thread properly? So it could be faster?
I don't know - I find it hard to keep up!
Cheers,
David.
2Bdecided is offline   Reply With Quote
Old 4th June 2009, 01:14   #244  |  Link
Adub
Fighting spam with a fish
Adub's Avatar
Yes, MVTools2 multithreads nicely with MT. I have seen a speed up of several fps on my "heavy scripts" when compared to v1.
FAQs:Bond's AVC/H.264 FAQ
Site:Adubvideo
Adub is offline   Reply With Quote
Old 4th June 2009, 03:45   #245  |  Link
aegisofrime
Personally for me TGMC Alpha 3 runs faster than TGMC Beta 2 by adding a Distributor() to the end of the script. I usually get 10 FPS that way when on a pre-rendering job, as opposed to 8 FPS for Beta 2.
aegisofrime is offline   Reply With Quote
Old 12th June 2009, 15:35   #246  |  Link
Terka
how modify TGMC to
use more frames in MVDegrain?
when used filtering like see below on DV source, result is more stable. But im sure Didee knows why he put the other routines to TGMC.
clp=avisource("c:\hj\kamera\avisynth\psi\!Psi.avi")
SetMemoryMax(512)
bob=clp.bob(0,0.5)
bob=clp.nnedi2(field=-2)
# denoise ##############################################################
calm = calmI(bob)
denoised = mo_denoiseAB (calm,bob)
denoised.Sharpen(0.5)
function mo_denoiseAB (clip calm,clip denoise , int "blksize", int "overlap", int "blksize", int "sharp", int "thSAD", int "refframes")
clp=denoise
idx = 20
blksize = default(blksize,4) # blksize value (4, 8 or 16)
overlap = default(overlap,blksize/2) # overlap value (0 to half blksize)
sharp = default(sharp,1) # 0=bilinear softest, 1=bicubic, 2=Wiener sharpest
thSAD = default(thSAD,400) # 640didee,200 orig. higher risks motion ghosting and swimming, lower risks blotchy denoising
refframes = default(refframes,8) # temporal radius for MVTools using the "Multi" modification by Josey Wells
vectors = calm.MVAnalyseMulti(refframes = refframes, pel = 2, blksize=blksize, overlap=overlap, sharp=sharp, idx = idx)
clp.MVDegrainMulti(vectors, refframes = refframes, thSAD = thSAD, idx = idx + 1)
return(last)
function calmI (clip)
t1 = clip.temporalsoften(1,255,255,28,2)
t2 = clip.temporalsoften(2,255,255,28,2)
t1.merge(t2,0.357).merge(clip,0.125)
return(last)
Old 14th June 2009, 21:33   #247  |  Link
Chainmax
Huh?
Chainmax's Avatar
TGMC's latest version is TempGaussMC_beta1, right?
Read Decomb's readmes and tutorials, the IVTC tutorial and the capture guide in order to learn about combing and how to deal with it.
Chainmax is offline   Reply With Quote
Old 15th June 2009, 07:22   #248  |  Link
Terka
i think so.
Old 15th June 2009, 19:37   #249  |  Link
WorBry
TempGaussMC_beta1 is the latest/last official release from the author, Didee. There's a modded version TempGaussMC_beta1mod (courstesy of thetoof) that uses the multi-threaded branch of MVtools or MVTools2.
http://avisynth.org/mediawiki/TempGaussMC
Probably both versions can be updated to include NNEDI2, just released:
http://forum.doom9.org/showthread.ph...28#post1296128
Easy enough to do:
# Create spatially interpolated bob-clips
dbob = clp.bob(0,0.5)
edi  = (EdiMode=="NNEDI") ? clp.nnedi(field=-2)
 \   : (EdiMode=="NNEDI2")? clp.nnedi2(field=-2)
 \   : (EdiMode=="EEDI2") ? clp.SeparateFields().EEDI2(field=-2, maxd=EEDI2maxd)
 \   : (EdiMode=="Yadif") ? clp.Yadif(mode=1)
 \                        : dbob
Nostalgia's not what it used to be
WorBry is offline   Reply With Quote
Old 22nd June 2009, 05:58   #250  |  Link
henryho_hk
I love this function. It works even on those ill-brained footage with mixed interlaced and field-duplicated materials (....though I seem to find ghosting on those field-duplicated scenes.... very occasionally.... It may actually exist in the footage itself... not 100% sure).
henryho_hk is offline   Reply With Quote
Old 29th June 2009, 03:27   #251  |  Link
Undead Sega
Originally Posted by Adub View Post
Typically, the choices between motion compensated deinterlacers lies between MCBob and TempGaussMC. The latter has a nice effect in that it also filters noise, but you can't go wrong with either of these deinterlacers. Just pick the one that works best for your purposes.
sorry for the late response, upon reading all the other replies here, i am still wondering, if MCBob and TempGaussMC are deinterlacers that cant go wrong as u described, what is really the main difference?
as i mentioned before in my previous post, is TempGaussMC 'the' motion compensation technique? i say this because, if i am correct, there are many different techniques that motion compensation has? like on the way it searches pixels and data?
Undead Sega is offline   Reply With Quote
Old 29th June 2009, 10:03   #252  |  Link
2Bdecided
Oh come on man! "you can't go wrong" is colloquial speech - it doesn't mean the result is faultless!
Cheers,
Davd.
Old 29th June 2009, 13:32   #253  |  Link
Undead Sega
I was only retorting this line here but probably rephrased it wrong or didnt come out right.
anyways, anyone may i ask?
Old 29th June 2009, 14:50   #254  |  Link
Didée
If you expect an "A is better than B, period." answer, then stop reading NOW.
MCBob
Pro:
- "lossless" bobbing, in the sense that the original fields' scanlines remain absolutely unchanged.
Con:
- result is less stable & less compressible than TGMC, i.e. MCBob has more residual bob shimmer in the output.
- instead of field(x)<-->field(x+1) motion compensation, it uses field(x-1)-->(x)<--field(x+1) motion interpolation. Motion interpolation is (much) more prone to fail.
- uses static masking for reckognition of no-motion areas. Though that's good for (really) static areas, there's always the danger that repetitive motion is misjudged.
(Sidenote: MCBob's Shape Transposition Technology is a failed concept..!)
TGMC:
Pro:
- result is more stable & more compressible, residual bob shimmer is (most likely) the most minimal you'll get from any existing bob- or deinterlacing filter for Avisynth.
- uses motion compensation, which is less likely to fail.
Con:
- TGMC is not lossless, i.e. the original fields' scanlines are altered. (*technically* that's a cutback, but it helps to improve the *visual* quality)
Pro AND Con:
- doesn't use any kind of static-masking.
(Pro: since not used, it can not fail.)
(Con: Slightly artificial resolution in perfectly-static areas)
___
In direct comparison of "how much effort" it takes for "what kind of result", I'd say that MCBob is overly expensive.
Personally, in most circumstances I prefer TGMC.
Old 30th June 2009, 18:13   #255  |  Link
Dominiko
I can't understand this complex script and it's way for deflickering. Can it be made usefull for deflickering without deinterlacing(bobing) on progressive frames (from DVD)? And will it be better than simple script like this so called Stab().
Dominiko is offline   Reply With Quote
Old 30th June 2009, 21:27   #256  |  Link
Lynx Pardinus
What if we combine MCBob and TempGaussMC? I mean using MCBob as the initial bobber for TemGauss instead of NNEDI or yadif.
Do we get the best from both worlds and get a better result or do we get the worst from both worlds?
I have made a try and to my eyes teh result looks better but I would like to know the experts opinion.
Lynx Pardinus is offline   Reply With Quote
Old 30th June 2009, 21:57   #257  |  Link
TiGR
TiGR's Avatar
Wouldn’t that be slow as hell?
Best people are not angels quite:
While—not the worst of people’s doings scare
The devil; so there’s that proud look to spare!
Robert Browning: Pippa Passes
TiGR is offline   Reply With Quote
Old 30th June 2009, 23:28   #258  |  Link
Lynx Pardinus
Of course I am asking quality wise not speed wise.
I know it is slow as hell, I have already tried it. 1 fps to get the MCBob and 1 fps for the TempGauss, 0.5 fps for a T5600.
Old 30th June 2009, 23:37   #259  |  Link
shoopdabloop
0.5 fps!?
so does it produce the results you were hoping for?
shoopdabloop is offline   Reply With Quote
Old 1st July 2009, 07:25   #260  |  Link
Lynx Pardinus
I tested it on a video wich still had some noticeable flicker after TempGaussMC and, although it was still not perfect, almost all the flicker had dissapeared.
I also noticed that in some frames where MCBob had better results than TempGaussMC, the new result was closer to MCBob's.
deinterlace, flickering
