7th April 2012, 18:23 | #14941 | Link | |
7th April 2012, 19:11 | #14942 | Link | |
7th April 2012, 19:15 | #14943 | Link | |
- Windows Version: 6.1 [7601] - AVISYNTH Version: [2.5.8.0], Ok - HAALI Splitter: [1.11.96.14], Ok - FFDSHOW: [3882], Ok - WIN7 preferred AVC CODEC: Ok - WIN7 preferred VC-1 CODEC: Ok - WIN7 preferred MPEG2 CODEC: Ok - FFDSHOW VC-1 set to "wmv9", Ok - FFDSHOW MPEG2 set to "libavcodec": Ok - FFDSHOW AVC set to "libavcodec": Ok - BD Rebuilder v0.40.0.8, Ok - X264: Ok - AFTEN: Ok - FAAC: Ok - MP4BOX: Ok - WAVI: Ok - TSMUXER: Ok |
8th April 2012, 09:13 | #14944 | Link |
'SourceCheck() 00006 2501' using current versions
Refering to my current posts starting with posting #14921 "'SourceCheck() 00006 2501' using current versions" on page 747 and after some tests I conclude, that for my test BDs BDRB reports _false negatives_: Besides of having no problems to play the BDs with several SW and SAL HW BD players, processing is possible, e.g. DVDF.b demo version accepts the BD and multiAVCHD re-author mode can create excellent DVD9 Full Backups including menus and extras which again play well on all tested players.
Both test BDs contain the correct BD folders CERTIFICATE BDMV - AUXDATA - BACKUP - BDJO - CLIPINF - JAR - META - PLAYLIST - STREAM index.bdmv MovieObject.bdmv Still missing an _explanation_ why BDRB refuses to open with obviously false negatives SourceCheck() 00006 2501 (for test BD 1) SourceCheck() 00055 2501 (for test BD 2) What are the reasons for the verdicts "Selected source is not BD format" and for refusing to accept the Source Path? What are the secrets of the BDRB jury? Opera lovers who want to dig deaper can do so using test DB 1 (Anna Bolena, 2011 Vienna performance on BD from DG) and test DB 2 (Rusalka, 2010 Munich performance on BD from C major), both amazing performances available from amazon.de, and report results. Where are the easter eggs? Happy Eastern! Last edited by Cela; 9th April 2012 at 16:34. |
8th April 2012, 20:08 | #14945 | Link |
Hello,
After many years of using BD Rebuilder, i bought a Asus Laptop with Windows 7 x64 Home Premium and everytime i start the program it gives me this: Problem signature: Problem Event Name: APPCRASH Application Name: BDRB.exe Application Version: 0.40.0.8 Application Timestamp: 4f495606 Fault Module Name: BDRB.exe Fault Module Version: 0.40.0.8 Fault Module Timestamp: 4f495606 Exception Code: c0000005 Exception Offset: 0017d7e5 OS Version: 6.1.7601.2.1.0.768.3 Locale ID: 2070 Additional Information 1: 0a9e Additional Information 2: 0a9e372d3b4ad19135b953a78882e789 Additional Information 3: 0a9e Additional Information 4: 0a9e372d3b4ad19135b953a78882e789 I have all the addons installed but cannot run it ... any idea? Inspect: - Windows Version: 6.1 [7601] - AVISYNTH Version: [2.5.8.0], Ok - HAALI Splitter: [1.9.42.1], Ok - FFDSHOW: [3882], Ok - WIN7 preferred AVC CODEC: Ok - WIN7 preferred VC-1 CODEC: Ok - WIN7 preferred MPEG2 CODEC: Ok - FFDSHOW VC-1 set to "wmv9", Ok - FFDSHOW MPEG2 set to "libavcodec": Ok - FFDSHOW AVC set to "ffmpeg-mt": Ok - BD Rebuilder v0.40.0.8, Ok - X264: Ok - AFTEN: Ok - FAAC: Ok - MP4BOX: Ok - WAVI: Ok - TSMUXER: Ok thanks Last edited by gandalf027; 8th April 2012 at 20:49. |
8th April 2012, 20:38 | #14946 | Link |
Cannot get new version to work!
I have been using this product successfully for about a year. I also own DVD-Rebuilder Pro. I get errors on every attempt for every movie. It cannot extract the audio, or it fails to rebuild. I have removed every app, used Revo, then reinstalled with recommended options. No luck.
- Windows Version: 6.1 [7601] - AVISYNTH Version: [2.5.8.0], Ok - HAALI Splitter: [1.9.42.1], Ok - FFDSHOW: [3882], Ok - WIN7 preferred AVC CODEC: Ok - WIN7 preferred VC-1 CODEC: Ok - WIN7 preferred MPEG2 CODEC: Ok - FFDSHOW VC-1 set to "wmv9", Ok - FFDSHOW MPEG2 set to "libmpeg2": Ok - FFDSHOW AVC set to "ffmpeg-mt": Ok - BD Rebuilder v0.40.0.8, Ok - X264: Ok - AFTEN: Ok - FAAC: Ok - MP4BOX: Ok - WAVI: Ok - TSMUXER: Ok Any suggestions? Is this a bug or user error? |
10th April 2012, 13:38 | #14950 | Link |
'SourceCheck() 00006 2501' - Workaround
While testing, see my post #14945, I may have found a workaround.
It may help those who also may be stopped using BDRB by a _false negative_ BDRB verdict <"Selected source is not BD format" (SourceCheck() 00006 2501', 'SourceCheck() 00055 2501')> and for who, like me, cannot find other help and where nothing else helps. There may help as workaround to transform the original source in such a way that it may be accepted by BDRB. Disclaimer: It may or may not work for you. No warrenty! multiAVCHD re-author (remuxing only! no re-encoding! no transcoding) Workaround > Open multiAVCHD > In settings pane, make sure you uncheck 'Move transitional files' and '(all)' and that both, the 'Temp folder path' and 'Destination path', are properly set. >Back in Media pane, load ( drag and drop ) the BDMV folder from the "Original" one. > Wait for multiAVCHD to import the BDMV. > The program will ask you if you want to switch to Blu-Ray Re-Author mode. Press "Yes" > Select destination media and playback device > Start multiAVCHD's remuxing job by single clicking >Start > select output mode> Blu-ray Disk (let multiAVCHD remux a BD compliant disk) > Wait for ~1 hour until multiAVCHD will have finished its remuxing task! > and hands off your computer while multiAVCHD is working! That's the simple workaround. Remember: The goal is to use the phantastic re-authoring capabilities of DBRB! If you insist to do some minor re-authoring tasks in multiAVCHD, e.g. >DTS audio >Core only (for selected playlists) >optionally >blank studio ads and logos then you may do it before clicking the Start button: > In "Media" Tab> single click the first title > wait for the Properties window to appear > In Properties window> do your choices for the playlists you want re-author. But Remember: >> do NOT select transcoding (no reencoding! remuxing only!) >> ONLY select >DTS audio >Core only (where appropriate) >> optionally >blank> studio ads and logos >> Start> Blu-ray Disk (let multiAVCHD remux a BD compliant disk) ... --- ... -> Surprise: BDRD accepts and processes multiAVCHD export! Note: 1. You need a working multiAVCHD installation verified with multiTest (see multiAVCHD thread, post #1, Notes) 2. You need sufficient free disk space for the remuxed copy (~100GiB) 3. You need to let multiAVCHD let do its remuxing job for ~1 to 2 hours in standalone mode (hands off mouse and keyboard! any user interference may spoil the result!) 4. You may also consult the "Guide for Blu-Ray Re-Authoring using multiAVCHD" @jdobbs To overcome the _false negative_ error, isn't there a better/quicker solution available? (Hidden option BDMV_CERT_ONLY=1 does not do the job.) P.S. More Errors? Probably user errors? 1. Target size cannot be changed! E.g. changing the target size in BDREBUILDER.INI in the BD_Rebuilder folder has no effect! E.g. the line TARGET_SIZE=7300 is not read and used in the program but gets overwritten (!) by whatever Output Option (DVD-5, DVD-9, BD-5, Custom Size) was selected. 2. Corrections of TARGET_SIZE in 'View/Edit config file' have no effect for the current BDRB session nor for following sessions. I never achieve other values than 4469, 8032, 23500. Last edited by Cela; 10th April 2012 at 13:45. |
10th April 2012, 16:13 | #14952 | Link |
@jdobbs
I guess those test-BDs for 'opera lovers' mentioned in #14945 will also be available at amazon.com in the US. Please also have a look at the 'customize TARGET_SIZE=7300' issue. I use to take care to fill my Verbatim DVD+DL not to 100%. Above 7300 KiB my DVD-writer needs to fully cool down before it will write the next DVD without coaster. Is to run goBD still necessary to support full DVD9 playback at the PS3? (see here) Last, not least, a PAUSE option would be often helpful when unexpected higher priority work has to done immediately forces to interrupt BDRB. Thanks for your great programs! Last edited by Cela; 10th April 2012 at 16:18. |
11th April 2012, 03:02 | #14953 | Link |
Hey jdobbs, you able to test out smurfs like this post?
http://forum.doom9.org/showthread.ph...52#post1568552 |
11th April 2012, 08:09 | #14954 | Link | |
11th April 2012, 10:57 | #14955 | Link |
@Cela
"Hands off mouse and keyboard! Any user interference may spoil the result!" Only if...you're not aware of what you're doing, AND/OR...if computer drivers/OS aren't functioning as they should.
11th April 2012, 18:21 | #14956 | Link |
BD Rebuilder v0.40.09 (beta)
I have updated the first post of this thread with links to a new release of BD-RB (v0.40.09). Changes for this release:
- Changed default grayscale values for conversion of subtitles in ALTERNATE/DVD. - Added checks for incompatible AnyDVD settings to inspect and error exit reporting. - Corrected the type of DGDecNV field operation used when IVTC is enabled. This should correct audio sync issues with IVTC/DGDecNV/MPEG-2 pulldown combinations. - Modified processing so that MULTIPROCESS is not used when the source that are to be processed for inverse telecining. - Corrected an issue related to calculation of lead-in frames on splits. - Corrected a problem in which the 720p/59.94 frame rate was incorrectly calculated. - Updated the included version of X264.EXE to the latest release (r2184). - Updated the included version of X264-64.EXE to the latest release (r2184). - Other minor corrections and cosmetic fixes. |
