9th August 2013, 17:13 | #17761 | Link |
I've done that same problem...
- [19:05:09] Multiplexing M2TS - Error in attempt to multiplex: MUX_00023.meta - Can't open file: C:\WORKFILES\VID_00023.AVS.264 [19:05:13] - Failed to build structure, aborted ------------------------------ - Windows Version: 6.1 [7601] - AVISYNTH Version: [2.5.7.0], Ok - HAALI Splitter: [1.9.42.1], Ok - FFDSHOW: [3326], Ok - WIN7 preferred AVC CODEC: Ok - WIN7 preferred VC-1 CODEC: Ok - WIN7 preferred MPEG2 CODEC: Ok - FFDSHOW VC-1 set to "wmv9", Ok - FFDSHOW MPEG2 set to "libavcodec": Ok - FFDSHOW AVC set to "libavcodec": Ok - AnyDVD settings check: Ok. - BD Rebuilder v0.44.0.15, Ok - X264: Ok - AFTEN: Ok - FAAC: Ok - MP4BOX: Ok - WAVI: Ok - TSMUXER: Ok |
9th August 2013, 17:26 | #17762 | Link |
Bad rip Wakko. I've dealt with that before. Doesn't matter if the disc was spotless either...
Though I don't recall the error about opening the file.
12th August 2013, 22:12 | #17769 | Link |
Fyi, Cinavia fix - AnyDVD HD 7.3.1.0
From the forum:
7.3.1.0 2013 08 11 - New: AnyDVD's unique Cinavia fix will prevent all currently existing software players - including all TMT 5 and 6 versions, all PowerDVD 12 and 13 versions, all PowerDVD 10 OEM versions, all WinDVD 11 versions, all Nero Blu-ray player versions - to detect Cinavia. |
12th August 2013, 22:14 | #17770 | Link |
No I did not.
If you suspect you are dealing with a Cinavia problem, you will know if, and ONLY IF, you SEE AN ACTUAL CINAVIA MESSAGE ON THE SCREEN. Even if the "title contains Cinavia". If you do NOT see a Cinavia ERROR message, you are NOT dealing with a Cinavia problem. I am not seeing a Cinavia ERROR message. Last edited by steveg32; 13th August 2013 at 11:28. Reason: add on |
13th August 2013, 13:34 | #17771 | Link | |
13th August 2013, 20:53 | #17774 | Link |
Just a quicke if I may...
May I just ask for a simple definition...
I am trying to back up my Blu-ray of THE CURE concert which is approximately 45 Gigs. It has a LOT of audio trax. When I try to use BDRB to reduce it to a single layer Blu-ray I get the error while it is processing the main video track saying: 'audio/pgs sizing issue' I hit 'continue', but the resulting output folder ended up being about 41 Gigs anyway. Everything else ran just fine; no other errors. I DO of course have it set to keep the HD audio which is the point of the having the Blu-ray in this case. I looked in the Work Files and the resulting DTSHD file was indeed pretty big, about 10 Gigs. Without getting to technical or involved, could someone just give me the short explanation of what this error means? Does it mean that the size with all the extra audio trax is just simply too big to shrink down to a BD25? Thank you kindly! |
13th August 2013, 21:06 | #17776 | Link | |
Thank you anyway; I very much appreciate the excellent program! Cheers! |
14th August 2013, 00:12 | #17779 | Link |
[08/13/13] BD Rebuilder v0.44.15 (beta) [14:09:24] Source: ARGO - Input BD size: 25.40 GB - Approximate total content: [02:15:53.036] - Target BD size: 22.95 GB - Windows Version: 6.1 [7601] - Auto Quality: Good (Very Fast), ABR - Decoding/Frame serving: DirectShow - Audio Settings: AC3=0 DTS=0 HD=0 Kbs=640 [14:09:28] PHASE ONE, Encoding - [14:09:28] Processing: VID_00001 (1 of 7) - [14:09:28] Extracting A/V streams [VID_00001] - [14:09:38] Reencoding video [VID_00001] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 1,969 frames - Bitrate: 9,534 Kbs - [14:09:38] Reencoding: VID_00001, Pass 1 of 1 - [14:10:47] Video Encode complete - [14:10:47] Processing audio tracks - Track 4352 (eng): Keeping original audio - [14:10:47] Multiplexing M2TS - [14:10:56] Processing: VID_00002 (2 of 7) - [14:10:56] Extracting A/V streams [VID_00002] - [14:11:09] Reencoding video [VID_00002] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 3,685 frames - Bitrate: 9,077 Kbs - [14:11:09] Reencoding: VID_00002, Pass 1 of 1 - [14:13:14] Video Encode complete - [14:13:14] Processing audio tracks - Track 4352 (eng): Keeping original audio - [14:13:14] Multiplexing M2TS - [14:13:21] Processing: VID_00004 (3 of 7) - [14:13:21] Extracting A/V streams [VID_00004] - [14:13:33] Reencoding video [VID_00004] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 3,529 frames - Bitrate: 10,421 Kbs - [14:13:33] Reencoding: VID_00004, Pass 1 of 1 - [14:15:32] Video Encode complete - [14:15:32] Processing audio tracks - Track 4352 (eng): Keeping original audio - [14:15:32] Multiplexing M2TS - [14:15:39] Processing: VID_00005 (4 of 7) - [14:15:39] Extracting A/V streams [VID_00005] - [14:15:50] Reencoding video [VID_00005] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 3,557 frames - Bitrate: 8,668 Kbs - [14:15:50] Reencoding: VID_00005, Pass 1 of 1 - [14:17:47] Video Encode complete - [14:17:47] Processing audio tracks - Track 4352 (eng): Keeping original audio - [14:17:47] Multiplexing M2TS - [14:17:58] Processing: VID_00007 (5 of 7) - [14:17:58] Extracting A/V streams [VID_00007] - [14:18:12] Reencoding video [VID_00007] - Source Video: MPEG-4 (AVC), 1280x720 - Rate/Length: 59.940fps, 6,901 frames - Bitrate: 10,750 Kbs - [14:18:12] Reencoding: VID_00007, Pass 1 of 1 - [14:20:07] Video Encode complete - [14:20:07] Processing audio tracks - Track 4352 (eng): Keeping original audio - [14:20:07] Multiplexing M2TS - [14:20:13] Processing: VID_00008 (6 of 7) - [14:20:13] Extracting A/V streams [VID_00008] - [14:20:25] Reencoding video [VID_00008] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 3,553 frames - Bitrate: 8,632 Kbs - [14:20:25] Reencoding: VID_00008, Pass 1 of 1 - [14:22:36] Video Encode complete - [14:22:36] Processing audio tracks - Track 4352 (eng): Keeping original audio - [14:22:36] Multiplexing M2TS - [14:22:43] Processing: VID_00023 (7 of 7) - [14:22:43] Extracting A/V streams [VID_00023] - [14:39:38] Reencoding video [VID_00023] - [14:39:38] Keeping original video (no reencode) - [14:39:38] Processing audio tracks - Track 4352 (eng): Keeping original audio - [14:39:38] Multiplexing M2TS - Error in attempt to multiplex: MUX_00023.meta - Can't open file: C:\WORKFILES\VID_00023.AVS.264 [14:39:42] - Failed to build structure, aborted ------------------------- - Windows Version: 6.1 [7601] - AVISYNTH Version: [2.5.7.0], Ok - HAALI Splitter: [1.9.42.1], Ok - FFDSHOW: [3326], Ok - WIN7 preferred AVC CODEC: Ok - WIN7 preferred VC-1 CODEC: Ok - WIN7 preferred MPEG2 CODEC: Ok - FFDSHOW VC-1 set to "wmv9", Ok - FFDSHOW MPEG2 set to "libavcodec": Ok - FFDSHOW AVC set to "libavcodec": Ok - AnyDVD settings check: Ok. - BD Rebuilder v0.44.0.15, Ok - X264: Ok - AFTEN: Ok - FAAC: Ok - MP4BOX: Ok - WAVI: Ok - TSMUXER: Ok this is a new blu-ray any idea? |
14th August 2013, 00:32 | #17780 | Link | |
Well, since my Blu-ray is a concert disc, there are a number of LPCM tracks; and after reading that, I'm pretty sure that was why. So, I am now re-encoding the exact same Blu-ray with the same settings (well, after reading a while I did implement the filter in the 'Settings' tab so that it can use my x64 processors - wow what a difference!) Anyway, I just cancelled out the primary LPCM track since I really only wanted the DTSHD track, and now it is encoding just fine and I DIDN'T get that message this time So, even though no one just gave me the basic reason why that error could be triggered (all someone would have to have said is something like 'the audio files could likely be to large' or something like that I would guess) I now have it encoding just fine. Sorry to bother you guys; I KNOW you really deal with MUCH more complex issues here. Cheers! |
