30th September 2014, 01:54 | #21323 | Link |
I was thinking CLI also..but didn't want to assume.
I'm noticing this error with the new release. I've only tried 2 MPEG-2's..with preview. 1080i's and 480i's... I overwrote the exe, Opts file. Deleted the old Tools and copied over new. Then ran BD-RB and attempted Preview as before. There this is what I get now. If I "unselect" all other VIDs and only keep MPEG-2's and force Encoding, it happens also with BD-50. Anyone else? I reverted back to the previous version and it's functioning as before.
Life is not a journey to the grave; but rather to skid out broadside, thoroughly used, torn and warn and loudly proclaim; WOW; What a ride!!! Soon, I'm going to do it AGAiN in different skin!! Last edited by AmigaFuture; 30th September 2014 at 02:21. |
30th September 2014, 02:51 | #21325 | Link |
@AmigaFuture
Can you give me more details, I'm not sure from your description exactly what you are doing and what is happening. A set of steps to recreate the problem would be helpful. I did try a preview with an MPEG-2 and have found an issue (it won't playback) -- but it's nothing like what you have described. I've fixed what I experienced, but I want to make sure it's the same problem. Last edited by jdobbs; 30th September 2014 at 03:14. |
30th September 2014, 05:35 | #21326 | Link |
Start BD-RB. At this moment I'm using Dirty Dancing.. The BD Directory as been scanned. Right click on the biggest set-to-be-blanked-extra MPEG-2 1080i. The CreateAVS error displays. I switched to Footloose, and locating the first MPEG-2 480i that's banked...(VID_00016). Set to be blanked or not...the CreateAVS error displays when I right click to Preview.
There really isn't much I'm doing.
30th September 2014, 07:15 | #21327 | Link |
I also experienced preview problems with MPC, mainly for AVC footage 1080i29.97 (interlaced or telecined Extras).
The player cannont "connect". The video is not shown, only the audio plays. When the current encode will have finished I will try to provide a more accurate description of the issue later today. I have LAV installed, and skipped ffdshow and Haali. The preview.avs plays well in MPC-HC however. Hence my proposal/feature request: A hidden option which allows to select MPC-HC as the player for the preview, rather than MPC classic. |
30th September 2014, 10:50 | #21328 | Link |
hello jdobbs
can not create mkv container HEVC 1920 x 1080 intact audio 2d? p.d: x265 32 and 64bits 8 and 16 bits color http://forum.videohelp.com/threads/3...E-mingw-builds http://forum.videohelp.com/attachmen...c172c1822e4.7z Last edited by lauguru; 30th September 2014 at 11:38. |
30th September 2014, 18:26 | #21329 | Link |
I am using DirectShow and DGDecNV. Using DCDecNV "MPC_VIEW.AVS" is created but only has 1 line: "#Created by BD Rebuilder - v0.49.02 (beta)" in it.
"MUXOPT --no-pcr-on-video-pid --new-audio-pes --demux --vbr --vbv-len=500 --start-time=27000000 V_MPEG-2, "R:\BLU-RAY RIPS\DIRTYDANCING\BDMV\STREAM\00056.m2ts", fps=29.97, track=4113" is in file "AUD_00056.meta". 00056.MKV is also in the WORKFILES but I'm using Movie & Menus... I'm thinking that is related to the Red Text I typed about before...? Clicking on Preview produces these files. DGDecNV & DirectShowSource: 09/30/2014 10:13 AM 15,071,801 00056.MKV 09/30/2014 10:13 AM 15,061,141 00056.track_4113.mpv 09/30/2014 10:13 AM 185 AUD_00056.meta 09/30/2014 10:13 AM 44 MPC_VIEW.AVS 09/30/2014 10:13 AM 0 VID_00056.d2v 6 File(s) 30,133,171 bytes 2 Dir(s) 76,133,761,024 bytes free Anything more to help?
30th September 2014, 18:59 | #21330 | Link | |
The source you are attempting to view is MPEG-2, right? Nothing has changed for any other source type. Last edited by jdobbs; 30th September 2014 at 19:01. |
30th September 2014, 19:03 | #21331 | Link | |
30th September 2014, 19:10 | #21332 | Link |
@AmigaFuture
Try replacing BDRB.EXE with this test version and let me know if it solves your issues. |
30th September 2014, 19:52 | #21333 | Link | |
Edit: Downloaded and checking...
Life is not a journey to the grave; but rather to skid out broadside, thoroughly used, torn and warn and loudly proclaim; WOW; What a ride!!! Soon, I'm going to do it AGAiN in different skin!! Last edited by AmigaFuture; 30th September 2014 at 19:57. |
30th September 2014, 20:00 | #21334 | Link |
Preview is back from a quick test... Thumbs Up! Doing more...testing..
30th September 2014, 20:10 | #21335 | Link |
Uninstalling and reinstalling AVISYNTH didn't help.
- Windows Version: 6.1 [7601] - Working Path Free Space: 359.83GB - AVISYNTH Version: 2.5.8.0, Ok - LAVFILTERS: Ok - AnyDVD settings check: Ok. - X264: Ok - AFTEN: Ok - FAAC: Ok - MP4BOX: Ok - WAVI: Ok - TSMUXER: Ok - FRIMEncode: Ok - FRIMDecode: Ok [09.30.14] Systems Settings Check complete Code:
The following pin(s) failed to find a connectable filter: C:\TEMP\BD REBUILDER\WORKFILES\PREVIEW.AVS::Avisynth video #1 Media Type 0: -------------------------- Video: YV12 480x270 29.97fps AM_MEDIA_TYPE: majortype: MEDIATYPE_Video {73646976-0000-0010-8000-00AA00389B71} subtype: MEDIASUBTYPE_YV12 {32315659-0000-0010-8000-00AA00389B71} formattype: FORMAT_VideoInfo {05589F80-C356-11CE-BF01-00AA0055595A} bFixedSizeSamples: 1 bTemporalCompression: 0 lSampleSize: 194400 cbFormat: 88 VIDEOINFOHEADER: rcSource: (0,0)-(0,0) rcTarget: (0,0)-(0,0) dwBitRate: 0 dwBitErrorRate: 0 AvgTimePerFrame: 333667 BITMAPINFOHEADER: biSize: 40 biWidth: 480 biHeight: 270 biPlanes: 1 biBitCount: 12 biCompression: YV12 biSizeImage: 194400 biXPelsPerMeter: 0 biYPelsPerMeter: 0 biClrUsed: 0 biClrImportant: 0 pbFormat: 0000: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0010: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0020: 00 00 00 00 00 00 00 00 63 17 05 00 00 00 00 00 ........c....... 0030: 28 00 00 00 e0 01 00 00 0e 01 00 00 01 00 0c 00 (...à........... 0040: 59 56 31 32 60 f7 02 00 00 00 00 00 00 00 00 00 YV12`÷.......... 0050: 00 00 00 00 00 00 00 00 ........ MPC-HC plays the preview.avs without problems. |
30th September 2014, 20:50 | #21336 | Link | |
What MPC-HC does really has no bearing at all. [Edit] I tested it thoroughly. I'd suggest you uninstall LAVFilters, then uninstall AVISYNTH and reinstall it again, and then finally reinstall LAVFilters. Something isn't clicking between them. Did you install LAVFilters from the package I have linked in the first post? Last edited by jdobbs; 30th September 2014 at 21:05. |
30th September 2014, 22:21 | #21337 | Link | |
1st October 2014, 04:36 | #21339 | Link |
The red text is still there. Using Dirty Dancing. After starting BD-RB (And using the special link you provided).. Previewing VID_00056 that is set to be blanked looks good and produces these files.
09/30/2014 07:55 PM 15,071,801 00056.MKV 09/30/2014 07:55 PM 15,061,141 00056.track_4113.mpv 09/30/2014 07:55 PM 185 AUD_00056.meta 09/30/2014 07:55 PM 223 MPC_VIEW.AVS Inside MPC_VIEW.AVS which displays fine and is MPEG-2 1080i. Code:
#Created by BD Rebuilder - v0.49.03 (beta) DirectshowSource("X:\OUTPUT\WORKFILES\00056.MKV", fps=29.97) BilinearResize(480,270) ConvertToYUY2().AssumeFPS(30000,1001) Subtitle(x=8,y=8,"This clip is set to be BLANKED.") Click on Backup without enabling to keep it..or any other "default" blanked by BD-RB. Letting it render 1 video...then aborted. Code:
[09/30/14] BD Rebuilder v0.49.03 (beta) [19:59:34] Source: DIRTYDANCING - Input BD size: 46.57 GB - Approximate total content: [04:26:43.637] - Target BD size: 22.95 GB - Windows Version: 6.1 [7601] - MOVIE and MENUS mode enabled - Quality: High-Speed Option (BD-25+), Two Pass - Decoding/Frame serving: DirectShow [4-way] - Audio Settings: AC3=0 DTS=1 HD=0 Kbs=640 [19:59:38] PHASE ONE, Encoding - [19:59:38] Processing: VID_00002 (1 of 58) - [19:59:38] Extracting A/V streams [VID_00002] - [19:59:41] Reencoding video [VID_00002] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 24 frames - Bitrate: 500 Kbs - [19:59:41] Reencoding: VID_00002, Pass 1 of 2 - [19:59:41] Reencoding: VID_00002, Pass 2 of 2 - [19:59:42] Video Encode complete - [19:59:42] Processing audio tracks - [19:59:42] Multiplexing M2TS [19:59:46]PHASE ONE aborted by user request Code:
#Created by BD Rebuilder - v0.49.03 (beta) DirectshowSource("X:\OUTPUT\WORKFILES\00056.MKV", fps=29.97) BilinearResize(480,270) ConvertToYUY2().AssumeFPS(30000,1001) Subtitle(x=8,y=8,"This clip is set to be BLANKED.") This list of files are: Code:
09/30/2014 07:59 PM 332 00002.clpi 09/30/2014 07:59 PM 18,432 00002.m2ts 09/30/2014 07:59 PM 9,409 00002.track_4113.264 09/30/2014 07:59 PM 193 AUD_00002.meta 09/30/2014 07:55 PM 185 AUD_00056.meta 09/30/2014 08:01 PM 223 MPC_VIEW.AVS 09/30/2014 07:59 PM 206 MUX_00002.meta 09/30/2014 07:59 PM 196 VID_00002.AVS 09/30/2014 07:59 PM 4,612 VID_00002.AVS.264 I got it..when the Backup has started, and I click Delete All with BD-RB, after the abort...and go right to preview that VID again, BD-RB isn't remaking the temp MKV. I have to exit BD-RB then run it again for it to Preview again as it should. Any ideas?
1st October 2014, 07:58 | #21340 | Link |
FFDSHOW, Haali Matroska Splitter & the new LAV Directshow filters are not required but recommended.
Which of the two, 2A or 2B on the first page, would give the best result for x264 (MKV 1920x1080) encodings? So far i have used 2B, resulting in very good quality MKV's. Can i use BD Rebuilder without those packages and get the same high quality? Last edited by Glarioo; 1st October 2014 at 10:37. |
