3rd January 2012, 08:37 | #241 | Link | |
The "Ambient light level" measurement was still configured on dispcalGui from my previous calibrations. Since I have updated the software, the "Ambient light level" configuration was hidden in the new version. I have disabled it through the advanced settings and re-calibrated the TV with XYZ LUT + Matrix with Gamma 2.4. Using the ti3 Parser the 3dlut was created for madVR calibration settings. I have tried several profiles with different brightness/contrast/tint settings. The best results were received with the "Relative" gamma tone curve. The movies are much more vivid and the colors are deeper now comparing to the Rec709 profile i used before. Yet using the gamma curve 2.4 in madVR results a bit darker picture than I would like, but the 2.3 seems to be the sweet spot for me resulting stunning and polished rendering. |
21st January 2012, 22:50 | #242 | Link |
I have ColorMunki and i1 Display 2 and user ColorMunki only for creating correction matrix for Display2. Then I do the actual calibration with Display2. But still, it doesn't get the low light measurents well. At first I didn't understand ti3-file is used only for the black end. I tried using MPC-HC's own ICC-CMS and black end seemed ok. I think MPC-HC's CMS uses LittleCMS and it also creates 3dlut internally. Easy but not perfect solution was to use yCMS and only ti3-file. You don't get perfect calibration though. Launch TI3ParserGUI.exe and open your ti3-file and you'll see what the problem is. My grayscale values were: 0, XYZ, 0, 0, 0 1.7857, XYZ, 0, 0, 0 3.5714, XYZ, 0, 0, 0 5.3571, XYZ, 0.027882, 0.02763, 0.042054 7.1429, XYZ, 0.10489, 0.10941, 0.1317 8.9286, XYZ, 0.2645, 0.28805, 0.2925 10.714, XYZ, 0.4104, 0.43535, 0.45801 12.5, XYZ, 0.65471, 0.69213, 0.6966 etc. The problem in my file is values for 1.7857, 3.5714 and even 5.3571 are too low so my colorimeter doesn't get any values or they are inaccurate. Because program sees to low values, it tries to raise the values in 3dlut, and there you go, gray instead of black. Simple but not perfect and final solution is just to drop those inaccurate values. So I copy&pasted those values to madVR's yCMS and used these values for gray scale: 0, XYZ, 0, 0, 0 7.1429, XYZ, 0.10489, 0.10941, 0.1317 8.9286, XYZ, 0.2645, 0.28805, 0.2925 10.714, XYZ, 0.4104, 0.43535, 0.45801 12.5, XYZ, 0.65471, 0.69213, 0.6966 etc. I just wish we could have a version that has an option to only use ICC-files and LittleCMS. |
22nd January 2012, 05:24 | #243 | Link | |
!Filetype(3DLUT); !Pixel( ColorDec(ColorSpace.madVR), IccSingle("your_profile.icc") );
Forget about my old .3dlut stuff, just use mpv if you want accurate color management |
22nd January 2012, 18:58 | #244 | Link | |
Why don't we have televisions&projectors that support natively 3dlut |
25th January 2012, 02:58 | #247 | Link | |
If I remember correctly, I also disabled the backlight scanning when doing that calibration, which brings the panel brightness up significantly higher, placing the error range down around 6% grey. I have had far greater success running test patterns in MPC-HC with the madVR yCMS options open and manually editing the xyY values (co-ordinates are far easier to manipulate by hand than XYZ) for each point, taking measurements with CalMAN running on another screen. It's far more time consuming than it ought to be—if I could simply enter the RGB value I want out rather than tweaking xyY input, I'd arrive at the correct values a lot quicker, but it gives accurate results without the banding that this introduces. For what it's worth, even then, I won't give it data below about 20% or so. I calibrate that range using the display's own controls, because any changes below 20% or so in yCMS seems to introduce posterisation/discolouration. (not due to meter error) I also have the option of profiling my i1Pro to a colorimeter, but find that it's unnecessary in most cases, unless I need really low-light readings. I have yet to find a display where you have control over the very dark areas of the picture requiring readings that low, which does not introduce banding, discolouration or some other kind of issue, so while it's nice to know what the display is doing there, you can't fix it without introducing bigger errors anyway. Picture controls are very coarse down near black, and it's obvious when something is wrong. Perhaps I'll give this another try some time with a significantly reduced dataset. As I've said from the beginning, problems like this tend to arise from using too much data when profiling a display. Last edited by 6233638; 25th January 2012 at 03:00. |
13th February 2012, 16:00 | #248 | Link | |
MPC-HC Developer
Thanks for great tool. If I may suggest you should add information about LinkICCGUI "auto-calibration" function in yours madvr calibration guide. It's enabled by default, and in your guide you wrote to enable profile before watching what is wrong, because if auto-calibration is enabled we should disable any other color management, but yo know that :-) P.S For rec709 default ambient light level is 1000 lux which is good for studio, but definitely not for home Last edited by kasper93; 13th February 2012 at 16:15. |
20th February 2012, 23:29 | #249 | Link |
when having a lut script like this (.3ls2)
!Filetype(3DLUT); !Input_Primaries(ColorSpace.BT709); !Pixel( Scale(-16.0 / 219.0, 239.0 / 219.0), Clamp(0, 1) );
30th June 2012, 08:53 | #250 | Link |
hi nand chan
I have an error with ti3parser : System.execption : failed parsing the ti3 file : Sample_ID RGB_R .... not found I use Argyll 1.4 and dispcalgui 1.0.7.7 here my ti3 file http://www.mediafire.com/?k847ll93lggxp3z Thank you for your consideration |
23rd August 2012, 16:40 | #251 | Link |
Hi nand,
Just to confirm the proper way of going about calibration for playback with madVR. (These are the steps I took.) 1. Calibrate using DispcalGUI to Chromaticity 0.312713x, 0.329016y, White level @ 120.0 cd/m^2, Black level as measured, Gamma 2.35 Relative, no ambient adjustment, 100% black output offset, no black point correction (for LCD monitor). Calibration quality set to High. Profile quality High, type = curves + matrix w/large testchart. 2. Use DispcalGUI to apply calibration. 3. Load resulting files into TI3Parser and uncheck "Automatic calibration (disable your video card's calibration for this). 4. In madVR, load the 3DLut file, and specify pure power gamma to 2.35. Sound about right? The TI3Parser's automatic calibration worries me. |
1st September 2012, 05:23 | #252 | Link |
I have a couple of questions. But first I need to share my story. I have a 1920 x 1080, 60Hz laptop screen and a 2048 x 1152, 60Hz monitor which is connected to my laptop via HDMI. I have calibrated my laptop monitor with the built-in Windows calibration tool and I ended up simply decreasing the blue tone and green tone by a bit. That was it for that. I calibrated my external monitor with the built-in Windows calibration tool and I basically did nothing but decrease the gamma but 1 point or "registered mouse movement downwards" (since I don't know what units the scale was in). The rest of the calibration for the monitor (Dell SP2309W) was done via it's built-in OSD. I decreased the brightness and contrast from 75 (factory default) to 70. Then I set the colors to "Custom" and it allowed me to change the RGB values individually. I adjusted the red to 92 and the green to 95 and left the blue at 100. The monitor is in "Graphics" mode by default and I left it there.
I use madVR frequently to view Bluray material and I have been meaning to understand and figure out how to best implement a custom calibration solution with yCMS and 3DLUTs but I have come to the conclusion that I don't know nearly enough to even get started in calibrating both my screens in a correct, procedural manner with this technology. My question is, what tools, devices, and materials do I need to correctly calibrate both monitors. What are the steps to doing so in the current situation and settings I have changed/"calibrated" with. And finally, what is the correct way to go about calibrating my panasonic plasma tv as well? (the tv was corrected only with the built-in OSD. Mainly the contrast and brightness were brought down to 65 in custom mode). PS: What does it mean to or what are the differences between calibrating with graphics card software, hardware OSDs, Windows calibration tool and making an ICC file, or using some other calibration software? Thanks! I would truly like to donate to this project if it works for me as well if the author is taking donations at this time. Last edited by dansrfe; 1st September 2012 at 05:25. |
11th February 2013, 04:55 | #253 | Link |
Question on 3D LUT creation and use
I'm a user of JRiver Media Center in an HTPC. Video playback is achieved with LAV Filters and madVR.
I want to apply color management using a .3dLUT in madVR to correct my projector. The short story to accomplish this is: 1. Use ArgyllCMS with dispcalGUI to generate a XYZ LUT + Matrix. 2. Install and load the ICC profile created with Windows 7 color management. 3. Use LinkICCGUI (from the TI3 Parser toolset) to generate the .3dLUT for madVR. 4. Setup madVR to use the 3D LUT. My question is: If I uncheck the box (no auto-calibrate) in the GUI window shown below when generating the .3dLUT, will the .3dLUT be made to work properly along with the ICC profile loaded by Windows 7 (both the ICC profile and the .3dLUT in madVR will be active) |
13th February 2013, 00:28 | #255 | Link |
I'm also interested in the answer. I would suggest, however, that you do the opposite: configure madVR to disable Windows's gamma ramps during playback and then use a full 3DLUT. This is likely to give better results (less banding because the calibration is done before madVR's dithering).
13th February 2013, 03:42 | #256 | Link | |
Update: Seems to work fine both ways, I checked for banding with a full screen gray scale ramp (I'm using Intel HD4000 graphics with HDMI monitor connection @ 1920 x 1080). I prefer to install the ICC profile with Windows 7 for global gray scale correction. MadVR 3D LUT then corrects color gamut during video playback. I posted instructions here: How To Get Perfect Video Color Last edited by hulkss; 18th February 2013 at 07:10. |
23rd February 2013, 17:50 | #258 | Link | |
Are you planning gamut & gamma correction (.3 dlut generator) through HCFR? |
24th February 2013, 00:40 | #259 | Link |
Hi! yes that's me. No, sorry, I couldn't get close to what dispcalGUI/ArgyllCMS could do. I was just curios about 3DLUTs in general, especially for displays like mine which have good onboard CMS systems. I did some testing I might post about on avsforums with the Argyll profiles->3dlut->madVR corrections.
3dlut, argyllcms, color management, icc, madvr, ti3, ycms |
