29th August 2015, 23:28 | #2661 | Link |
Angel of Night
I could see a use for Quicksync as a superspeed first pass, which can be analyzed to derive a stats file, but I can't think of any other way you could effectively use it as part of x265. The actual encoding is most of what makes it x265.
30th August 2015, 04:11 | #2662 | Link | |
We don't feel like we compete with proprietary encoder APIs. While we don't disagree that it makes sense for semiconductor companies to offer their own proprietary encoder APIs, customers worldwide vastly prefer the quality, features, flexibility and cross platform capability of open source encoder libraries like x264 and x265. It makes sense for semiconductor companies to give us access to the full power of their new architectures. Unfortunately, these hardware pipelines aren't designed as a set of addressable fixed function units that we can quickly and efficiently access. But we're investigating all of the possibilities. |
2nd September 2015, 16:06 | #2663 | Link |
Another "merge with stable", including several bug fixes and some even faster AVX2 routines.
x265 1.7+470-86e9bd7dd192 (GCC 4.9.2) x265 1.7+470-86e9bd7dd192 (GCC 5.2.0) |
2nd September 2015, 22:40 | #2664 | Link |
Interesting results here from 1.7+470 (vs 1.7.382), one 1000 frame test was 9.5% faster and 3% smaller file (lots of panning)
another 1000 frame sample was 5.6% SLOWER than .382, and the same size (.16% smaller) (no panning). 4770K@3.9, 480p sample. Tests run multiple times. Edit: On a 10000 frame test, 470 was 3.5% slower and a 1% BIGGER file. Will test entire encode now. CHeers, Divxmaster Last edited by divxmaster; 2nd September 2015 at 23:20. |
3rd September 2015, 02:09 | #2665 | Link |
I've been experimenting with Handbrake and x265 re-encoding. I find that the quality (for my purposes) is as good if not better (for same file size if not smaller) as x264. Obviously it takes much longer to re-encode, however, I have noticed the resulting file size is much more appealing than an x264 re-encode.
What exactly is the "x265 HEVC Upgrade"? I noticed it costs $29.95, is this an application like Handbrake or is it an extension of some other piece of software? Is Handbrake a good tool to use to re-encode to x265? I am taking full MKV files to MP4 and using default x265 settings in Handbrake ATM. |
3rd September 2015, 07:11 | #2666 | Link |
This is mainly UHDcode, a quite fast and comprehensive HEVC decoder as DirectShow filter, along with a basic recoder for AVC-in-MP4 source files. Not really necessary for most cases, LAV Filters have a good decoder implementation as well, and there are free converters in all different flavours.
3rd September 2015, 09:51 | #2667 | Link | |
The x265 Encoder is a simple Windows 64 bit application designed to make it easy for anyone to use x265. It accepts MP4 files as input, and it will transcode the H.264 video to H.265, passing the audio through to the target MP4 file. There is a basic mode which makes it really easy for non-technical people to use. The advanced mode includes full access to all x265 settings. The UHDcode DirectShow filter allows Windows Media Player to play video files containing HEVC. The x265 HEVC Upgrade is available for $14.98 (50% off the MSRP) for a limited time. We hope to be able to make trial versions available, but we're still waiting to hear if the HEVC Advance patent portfolio will allow for trial software without charging an exorbitant royalty (MPEG-LA allows for trial software with no royalty). |
3rd September 2015, 21:24 | #2668 | Link | |
Cheers, Divxmaster |
4th September 2015, 00:24 | #2669 | Link |
x265 Encoding
any buddy help me which method to encode x265 HEVC small size mobile rip i am try many of encoders but i am not manage it size if any buddy know please help me which encoder i am use for good quality with small size minimum 200MB
4th September 2015, 02:07 | #2670 | Link | |
How does the application compare to Handbrake? If it is as functional and/or better I would be will to pay (heck I'd pay for Handbrake if it wasn't free). |
4th September 2015, 07:14 | #2671 | Link |
@ downloadhub:
1. "anybody" 2. There are no miracles. And there are no crystal balls. Good quality requires a minimum bitrate per image area. If you need a small size, reduce the resolution. Use a 2-pass encoding method to bring your copy down to a desired target size. And stay with H.264 (AVC) for mobile devices, because H.265 (HEVC) requires much more computing power and will drain your battery faster. For better help, post more details; but not in this thread, this is about the development of x265, not a beginners' guide how to use any converter. __ @ jhughy2010: I did not use it yet, but according to the description: MP4 to MP4 only. And probably no filters, just straight video conversion with audio pass-through, certainly not as flexible as Handbrake or StaxRip or MeGUI or Hybrid. |
4th September 2015, 12:12 | #2672 | Link | |
HEVC FullHD 4500kbps i420 8bit 30fps progressive High Quality |
7th September 2015, 19:29 | #2674 | Link |
revision is bugged and just utilize one cpu core (on my hardware). Better stick with rev x265_1.7+470 (until tomorrow)
encoder.pw buildbot is NOT affiliated with, endorsed, or sponsored by the x265 development team, MultiCoreWare Inc, Xiph.Org Foundation nor VideoLAN organization. |
7th September 2015, 19:32 | #2675 | Link | |
I get the same thing on my 16-core dual Xeon. Manually trying to force multithreading via --pools didn't work either. Semi-relatedly, what's the current thinking on gcc 4.9 v. 5.2 builds? |
7th September 2015, 21:44 | #2676 | Link | |
For GCC 4.9 there is a problem that MS gives VS 2015 for free and code generated by VS 2015 is smaller than code generated by GCC 4.9. GCC 4.9 build will be probably slower than the fastest build from GCC 5.2 & VS 2015. |
8th September 2015, 11:13 | #2678 | Link | |
After x265 team turn off AVX assembly code that was 10% faster than SSE4, VS 2015 builds are at the same speed in 8 & 10-bit encoding, much slower in 12-bit encoding. I try to make tables for tomorrow @ AVX level and SSSE3 level. |
8th September 2015, 16:35 | #2679 | Link | |
https://bitbucket.org/multicoreware/...eral-comments: Pradeep Ramachandran author |
9th September 2015, 08:55 | #2680 | Link |
Speed test VS 2015 build vs. GCC 5.2.
Platform: Win7 64-bit, i5 3450S Options: --crf 17.5 --rdoq-level 1 --psy-rd 0.4 --deblock -1 --keyint 288 --colormatrix bt709 Builds: 1.7+473 from site www.msystem.waw.pl/x265 Encoding time in seconds (first table 8-bit, second 10-bit, third 12-bit): Code:
fast medium slow slower verysl placebo vs2015-AVX 69,69 108,21 274,78 368,5 393,92 400,4 msvcr120-AVX 70,3 108,24 274,73 371,23 396,06 403,91 gcc52-AVX 70,14 108,41 274,7 374,19 396,14 405,53 msvcr120-SSSE3 70,71 109,39 298,93 374,42 398,36 407,44 vs2015-SSE2 70,66 110,11 277,19 375,48 399,6 404,15 vs2015-AVX 87,89 132,82 413.04 515.14 552.64 574.87 msvcr120-AVX 88,83 133,81 413.77 518.28 555.17 580.92 gcc52-AVX 89,33 134,45 415.41 519.76 556.77 582.68 msvcr120-SSSE3 89,34 135,18 416.71 521.65 557.83 581.81 vs2015-SSE2 88,89 134,67 413.64 517.96 555.26 576.48 msvcr120-AVX 109,19 168,07 455,76 574,88 gcc52-AVX 109,69 168,56 457,26 576,78 msvcr120-SSSE3 111,96 172,47 461,8 585,26 vs2015-AVX 166,03 250,06 714,95 vs2015-SSE2 167,82 253,73 719,64 On CPU with only SSSE3 result was (encoding time in seconds, first table 8-bit, second 10-bit): Code:
msvcr120-SSSE3 487,42 716,34 991,49 1068,54 1055,51 985,84 gcc52-SSSE3 490,43 729,44 991,58 1055,89 1057,93 983,03 gcc52-SSE2 498,47 768,78 1003,16 1053,75 1194,48 1010,54 vs2015-SSE2 608,29 873,99 1181,09 1267,78 1255,51 1153,93 msvcr120-SSSE3 618,49 899,64 gcc52-SSSE3 620,4 895,69 gcc52-SSE2 647 915,41 vs2015-SSE2 707,55 1004,47 Last edited by Ma; 13th September 2015 at 13:51. Reason: Update results 10-bit from slow to placebo |
