Old 10th February 2010, 22:33   #6841  |  Link
kalle2k3
Just a short question: Is wpredp used during the encoding in BD25 mode and if yes is it set to 2 ?
Thanks for your kind help.
kalle2k3 is offline   Reply With Quote
Old 10th February 2010, 22:50   #6842  |  Link
X264 doesn't have a setting called "wpredp" of which I'm aware. I think that's probably a MEGUI thing? My guess is that you're talking about weightp? If so, BD-RB disables weightp because there are some players that don't seem to be able to handle it (even though they should).
Old 10th February 2010, 23:14   #6843  |  Link
kalle2k3
Thats exactly what i wanted to hear from you..thanks alot. And i guess you are staying with weightp disabled..right ?
Btw, great prog !
Old 10th February 2010, 23:19   #6844  |  Link
Bystander
Reporting back that the Nordic Sound did process correctly with the DTS MA HD track instead of a DD re-encode with the latest BD-Rebuilder version. Thank you.
Bystander is offline   Reply With Quote
Old 10th February 2010, 23:35   #6845  |  Link
Btw, great prog !
Yes, until something indicates that it isn't an issue anymore. But I don't see that happening any time soon.
Old 10th February 2010, 23:37   #6846  |  Link
Every now and then I do something right. The sun even shines on a dog's butt sometimes.
Old 11th February 2010, 01:20   #6847  |  Link
Capsbackup
The knowledge I get from this thread, priceless!!
Your sense of humor is warmly welcomed and received.
And thanks for the new release, which I continue to have much appreciation for.
EDIT:
Maybe you could start a new trend for Groundhog Day, since Punxsutawney Phil has been deemed to being treated cruelly for his observance!
Old 11th February 2010, 02:48   #6848  |  Link
Capsbackup
@jdobbs;
Just trying out the new release and I noticed that on my rips that have PiP and DTS Express audio for the secondary audio, the audio no longer has an "X" next to it. Did I miss something, or is there now the ability to include this type of secondary audio for full backups that have PiP?
It is not changeable, that is I cannot "X" it out like the other audio streams that are listed.
Old 11th February 2010, 05:52   #6849  |  Link
Duppie
@jdobbs
Thanks for the update. Just to report back. With this release, x264 encoding fails every time? The previous x264 version does work if replaced. I have attached the logs. Also, I think the x264 build is not good. The usual size of the executable is usually between 1 and 2 MB. Why is this x264 build over 6 MB in size?
Thanks again for a great app.
Duppie is offline   Reply With Quote
Old 11th February 2010, 06:28   #6850  |  Link
Originally Posted by Duppie View Post
@jdobbs
The newer versions include the FFMPEG library in them -- that's why they're bigger. I've done numerous encodes with this release -- hmmm.. that's troubling that you're seeing issues. Maybe a processor difference?
Anyone else having encoding problems with the X264 in this release?
Old 11th February 2010, 06:28   #6851  |  Link
Originally Posted by Capsbackup View Post
@jdobbs;
Hmmm... I hope I didn't screw that up. You shouldn't be able to select DTS Express. I'll look at it.
Old 11th February 2010, 07:00   #6852  |  Link
Duppie
I tested it on 2 different Windows XP SP3 PC's that worked previously. I will also test it this afternoon on my home PC on which I never had any problems with BD-RB.
Old 11th February 2010, 12:34   #6853  |  Link
tonimacarronis
Hi, thanks a lot for all your works (BDRebuild and DVDRebuild). I have some problems with english words, iŽll try.
Last beta: problems with x264, crash and must to close???
[03:38:09] BD Rebuilder v0.31.07 (beta)
- Source: UNDERWORLD_EVOLUTION
- Input BD size: 32,54 GB
- Approximate total content: [03:38:06.856]
- Target BD size: 22,66 GB
- Windows Version: 6.1 [7600]
- [04:04:14] Collecting video information
- Rate/Length: 24,000fps, 152.998 frames
- Bitrate: 20.900 Kbs
- [04:04:14] Reencoding: VID_00016, Pass 1 of 2
- [04:04:14] Reencoding: VID_00016, Pass 2 of 2
- Encode failed. Retrying.
[09:43:53]PHASE ONE aborted by user request
p.s. i must to say with 31.06 beta version the encode succes after record with imgburn and see in ps3 the viewing is not so good the image have some cuts everytime, i wait for this new release to prove at new...
tonimacarronis is offline   Reply With Quote
Old 11th February 2010, 13:45   #6854  |  Link
Race Guy
Also on 31.07 audio setup, even though I have "English (only)" & "Limit To One Track" checked, I get ALL the English enabled on the streams tab when the project loads.
I had no prob with the new x264 on a movie only to 9.
Race Guy is offline   Reply With Quote
Old 11th February 2010, 14:25   #6855  |  Link
Validator70
Hi.
In order to work with WinDVD 9 there has to be a "JAR" folder in the "backup" folder.
Sure, I can create it manually but I want to meantion this.
Validator70 is offline   Reply With Quote
Old 11th February 2010, 15:45   #6856  |  Link
Duppie
@jdobbs
Just to confirm. I have just tested the new x264 (BD-RB 31.07) on my home PC and it works fine. My Home PC has an AMD 7750 processor. The issue I have reported this morning was on 2 HP PC's with Intel Processors and x264 worked fine in BD-RB 31.06 on these HP's. Very Strange!!!
Old 11th February 2010, 17:06   #6857  |  Link
laserfan
Aging Video Hobbyist
I tried latest on X-Files 2 and it "aborted" on the DTS Express track, which I subsequently searched-on here and learned it's not something that can be fixed or worked-around.
I had instructed BD-RB to keep all English audio tracks.
Old 11th February 2010, 18:04   #6858  |  Link
I'll look at it today and get another version posted. Right now I'm trying to fix an issue with Trend Micro Internet Security. It's blocking Internet Explorer -- and I have to disable it to browse. It has to be caused by the code I added that fixed the AC-3 encoding glitch.
I know they're a necessity -- but I really, really hate anti-virus software. I'm not thoroughly convinced they aren't mroe of a pain-in-the-ass than viruses are. When they're not blocking legitimate software from running, they're simply slowing you down to a crawl. I switched to Trend a few months ago because McAfee was such a headache.
AHHHHHHH!!!!!!
Old 11th February 2010, 18:52   #6859  |  Link
writersblock29
@Jdobbs
Have you tried Avast? It's free, and works great. I junked Norton years ago in favor of it, and haven't been antivirus-shopping since. The only pain in the butt about Avast is the need to renew your registration yearly (why that's needed in a free software is beyond me), but it doesn't slow down your system or get overly annoying about letting you know it updated itself.
http://www.avast.com/index if you're interested.
Isn't it a bit unnerving that doctors call what they do "practice?"
--George Carlin
writersblock29 is offline   Reply With Quote
Old 11th February 2010, 18:56   #6860  |  Link
Originally Posted by writersblock29 View Post
@Jdobbs
Thanks. I'll check it out. I just uninstalled Trend and then reinstalled it, and now it allows my browser to run. Not sure what happened all at once (it was working yesterday), automatic update I guess, but it sure ticked me off.
