28th July 2010, 03:18 | #6162 | Link |
Why are you using coreAVC? Is your graphics card using the latest Nvidia GPU chipset?
If so, you need to look at DGDecNV It is, IMHO, a better GPU serving program that works perfectly with AVISynth. If you aren't using a Nvidia GPU chipset, nevermind! |
28th July 2010, 04:45 | #6163 | Link |
deank, I have been experimenting with Carousel motion menus on some AVCHD backups. The style is appealing to me, as it also resembles many Blu-ray menus.
However, I was wondering if it is possible to have that same type of menu that will only display the words for buttons, without the black border at the bottom of the menu? This way, it would display the full motion menu video on screen, with only the words visible as the button selections. Also, I have a project with 5 imported mpls/videos. The first in the list is set to hidden, since I want it to be played only at disc start and not included in the menu. After this first hidden video plays, I want to go to the main menu, for selection of the other four titles. However, my project will only start at the main menu, no intro hidden title ever plays. What do I need to do or set to make a title play first when a disc is started, instead of the menu, and after this titles ends it goes to the menu? |
28th July 2010, 06:09 | #6164 | Link |
Programmer (or just 教务长)
Take a look at:
.\multiAVCHD\templates\res\Carousel\ There is a file: CM_bott.bmp which is the bottom strip. Edit/resize it to 1x1 and you'll get rid of the bottom line. About the menu: [x] Skip top menu playback will make your player play the hidden/first title and then go to the menu. Dean |
28th July 2010, 06:16 | #6165 | Link |
Just realized I forgot to set skip top menu playback, so now it is working. Thanks.
I will now check the menu template! OK I have found the CM_bott.bmp, it says 1920 x 148. How do you edit to 1x1? Last edited by Capsbackup; 28th July 2010 at 06:20. |
29th July 2010, 23:51 | #6172 | Link |
I'm wanting to convert a blu-ray to AVCHD and I want to keep the menus as well. I don't want to have to recreate the menus from scratch.
I don't want BD5/BD9 either or I'd just use BDRB. Will this program work for that? |
30th July 2010, 03:11 | #6173 | Link |
If it is not BD5/9, is it BD25/-R/RE?
What is your playback method, PC, standalone, etc...? You can use multiAVCHD in re-author mode to keep the Blu ray structure with menus, etc... and if you are burning to BD-R/RE you may not have to reencode all files, only some to fit BD25. AVCHD, typically to BD5/9 media, will need to be reencoded to a lower bitrate per AVCHD specs for standalone playback. PC playback is more forgiving. So, yes it will work for that, and depending on your method of playback, will determine what steps from multiAVCHD you will need to perform. |
30th July 2010, 08:28 | #6174 | Link | |
The answer to your question is simple - use BD-Rebuilder to get Blu-ray backup. There is no point in creating AVCHD disc, especially when using BD media. |
30th July 2010, 12:27 | #6175 | Link |
In build 762:
* Warning when loading files muxed with mkvmerge 4.1/4.2 * Additional check/processing for files with audio tracks with wrong sample rate (48/96/192kHz supported only) * Fixed chapters/thumbnail links for thumbs 13-96 * Advanced subtitle processing fix (and goSUP, too) - sometimes the last SRT line is not imported if no CR+LF is present as last line EOL Dean Last edited by deank; 30th July 2010 at 15:40. |
30th July 2010, 21:31 | #6178 | Link |
@deank
Hi! As I mentioned to you via one-way email, it will be interesting to see if the "Cinavia" watermarking flourishes - and if it does, how HD-DVD (more complete, including chaptering, etc) may prove to be a godsend. If nothing else, I'm tenacious ;>} |
31st July 2010, 06:19 | #6179 | Link | |
Sounds like this might want to be a checkbox in the future: [x] display menu button underline |
