Old 23rd August 2013, 02:42   #161  |  Link
StainlessS
StainlessS's Avatar
Tried as in my previous post with additional #define AVISYNTH_CORE,
and with
static const AVS_Linkage avs_linkage;
const AVS_Linkage* AVS_linkage = &avs_linkage;
in InvertNeg (removing the ptr),
both compile and link OK (thought the static forward decalre would fail, but did not) but
provided an access violation error in v2.5.
You are such a tease.
EDIT:
works after building and testing in both 2.6 and 2.5.8
, maybe I did something wrong.
EDIT: Would this not create a second avs_linkage, static in InvertNeg module (whereas the initialized one is static
in Interface module) rather than combining into a single static AVS_Linkage.
const AVS_Linkage *AVS_linkage = &avs_linkage;
I sometimes post sober.
Old 23rd August 2013, 03:12   #162  |  Link
Robert Martens
Yes, I'd think it would; I made the mistake of using "static" when I'd meant "extern", but correcting my code I see that introduces a new set of errors.
Using the approach I rather irresponsibly suggested, though, still seems to work for my own plugin, if only I could decipher why. I can't successfully use InvertNeg, though, so obviously something's wrong with my idea.
I should probably learn C++ one of these days.
Robert Martens is offline   Reply With Quote
Old 23rd August 2013, 03:17   #163  |  Link
StainlessS
StainlessS's Avatar
Me too.
Strange but if I try to debug, it does not crash (although output video is weird, with some kind of temporal chroma lead/lag).
EDIT:
Wilbert,
	int planes[] = {PLANAR_Y, PLANAR_V, PLANAR_U};
PLANAR_U(1) and PLANAR_V(2) transposed (should not cause problems though).
EDIT: and
++x;
produces better code than
x++;
although not much in it.
EDIT: The above x++; ++x;
The first one 'x++;' implies for a stack variable, that the variable x is gotten off stack , incremented and then updated
on-stack afterwards. The 2nd '++x;' can increment variable directly on-stack (if possible in assembler instruction set),
rather than doing it post increment.
Old 23rd August 2013, 06:24   #164  |  Link
Robert Martens
I think I've managed to work this out; my plugin, TurnsTile, was working because I use my own computed tile width and height, and the input videoinfo's width and height members, but never call GetRowSize or GetHeight. It seems that in the 2.58 code those follow the old fashioned approach of assuming U/V pitch and height are equal to half the Y plane pitch and height, respectively. The 2.6 code for both of those functions relies upon the VideoFrame members row_sizeUV and heightUV, which go uninitialized in 2.58 since they don't actually exist in that version. They end up with insane values, which then affect InvertNeg's loop count, leading to access violations.
I came to the conclusion by first following Ian's instructions as he provided them, then doing what I mentioned earlier and adding #define AVISYNTH_CORE before all includes of the header. Next, in the copy of interface.cpp that I swiped from Avisynth, I removed the static and const keywords from AVS_Linkage; apparently each of those implies, among other things, internal linkage, so the object in question won't be visible outside that source file. If this is a bad idea, please do let me know, I suppose in that case we can put the keywords back and just combine interface.cpp with our own code into one source file.
Over in my other source file, where I define the plugininit functions, I did the same as I did a few posts up but with the proper keyword this time:
extern AVS_Linkage avs_linkage;
extern "C" __declspec(dllexport) const char* __stdcall AvisynthPluginInit3(
    IScriptEnvironment* env, const AVS_Linkage* const vectors) {
This lets the project build properly, but it still doesn't work, so I just threw a little something into the logic of the filter for testing purposes:
row_size = dst->GetRowSize(planes[p]);
height = dst->GetHeight(planes[p]);
if (p == 1 || p == 2) {
    row_size = child->GetVideoInfo().width / 2;
    height = child->GetVideoInfo().height / 2;
for (y = 0; y < height; y++) {
    for (x = 0; x < row_size; x++) {
The plugin then loads (in 2.58; comment out the blue section for 2.60), and YV12 video is processed as expected. As for the proper way to modify the local copy of interface.cpp to handle this, assuming there is one, I'm still working my way through that.
Old 23rd August 2013, 07:54   #165  |  Link
TurboPascal7
TurboPascal7's Avatar
I'm not sure if someone asked this already, but is there any reason why we can't remove unaligned crop or at least make it optional? I believe it's the only function that might produce unaligned results in 2.6 and I really don't see any reasons to keep it this way. Am I missing something?
Also, any plans on making frames 32-bytes aligned for AVX?
TurboPascal7 is offline   Reply With Quote
Old 23rd August 2013, 13:00   #166  |  Link
ultim
AVS+ Dev
ultim's Avatar
I'm hacking around in the AviSynth code, currently mainly familiarizing myself with it, but with ambitious goals. I've already made some progress, and I will probably open a thread for my efforts once I feel confident enough, but now I just have a general question. Given that the "standard/official" AviSynth is single-threaded by nature, why is it littered full with atomic increments and critical sections? Is there some aspect I missed that these are needed?
ultim is offline   Reply With Quote
Old 23rd August 2013, 14:40   #167  |  Link
vcmohan
Originally Posted by IanB View Post
The brief was 2.6 would load and support 2.5 plugins, period!
For me I do not want to meddle with Avisynth core. The alternatives suggested possibly produce in one package two plugins one for each version. It will double the size.
I will stick to the mandate and have a cpp file as suggested by stainless in his earlier post.
mohan
my plugins are now hosted here
vcmohan is offline   Reply With Quote
Old 24th August 2013, 00:40   #168  |  Link
IanB
Avisynth Developer
I did say
Just needs a little imagination .....
so the hacking of Interface.cpp was obviously going to need a little thought and effort apart from the obvious #include's at the top and the extern __declspec at the bottom. All the old 2.5 code is still there in the comments.
In terms of size most plugin code is tiny. Things like fancy tables and runtime libraries usually make up most of the .dll size and these would occur only once. So I would not expect most dual mode plugins to be very much bigger.
@TurboPascal7,
Aligned crop costs an unaligned bitblt, i.e. unaligned read with aligned write in a loop.
For a plugin that does not have an unaligned path and crashes on unaligned reads, then you have no choice.
But for code with a usable unaligned path you are comparing [unaligned read + aligned write + aligned read] with [unaligned read] clearly the second case is faster.
So why do some filters suffer so badly with the unaligned case. Maybe they revert from a fast SSE path to a slow C++ code path, yes that's a bit slack, but maybe an unaligned SSE path won't go fast. More insidious is needing to read the input multiple times then the comparing becomes [1 *unaligned read + 1 * aligned write + N * aligned read] with [N *unaligned read], here the first case pulls ahead as N increases.
As for 32 byte alignment it may become the default in the future, but you have always been able to ask for extra alignment on the env->NewVideoFrame call.
IanB is offline   Reply With Quote
Old 24th August 2013, 02:13   #169  |  Link
TurboPascal7
@IanB,
The problem is added complexity. By having unaligned crop in the core, you essentially destroy all alignment guarantees said core might provide, asking all developers to add multiple code paths to handle unaligned case, thus making implementation harder (and helping introducing template/macro hell), always using slow unaligned loads or simply break with or without error message. Is marginal performance difference in one filter in some cases worth it? You might make unaligned crop optional so people who think it matters for them could still shoot in their feet, but I don't think it's reasonable.
Strict alignment (16 or even better - 32) guarantee would IMHO simplify a lot of things for developers, especially when plugin is using the same codebase for avisynth and vapoursynth versions (vsynth guarantees 32-bytes alignment). It might be even better to completely ignore alignment parameter in env->NewVideoFrame or make 32 the minimum accepted value, but I'm not sure how many (broken) filters that might break.
Old 24th August 2013, 02:41   #170  |  Link
Groucho2004
@IanB
I have a question about AVS_Linkage. In the following code, my program crashes (exactly here: "~AVSValue() AVS_BakedCode( AVS_LinkCall(AVSValue_DESTRUCTOR)() )") if the script (test.avs) does not return a clip. However, if I uncomment the line "AVS_linkage = 0" (bold and red in the code) it seems to work OK. Just wondering if setting "AVS_linkage" to 0 is correct in this context.
Or maybe I should just use "ThrowError()" and let Avisynth clean up by itself.
#include "avisynth.h"
const AVS_Linkage *AVS_linkage = 0;
int main()
 HINSTANCE hDLL = ::LoadLibrary("avisynth");
 if (!hDLL)
  return -1;
 try
  IScriptEnvironment *(__stdcall *CreateEnvironment)(int) = (IScriptEnvironment *(__stdcall *)(int))::GetProcAddress(hDLL, "CreateScriptEnvironment");
  if (!CreateEnvironment)
   ::FreeLibrary(hDLL);
   return -1;
  IScriptEnvironment *AVS_env = CreateEnvironment(AVISYNTH_INTERFACE_VERSION);
  if (!AVS_env)
   return -1;
  AVS_linkage = AVS_env->GetAVSLinkage();
  AVSValue AVSV_main;
  AVSV_main = AVS_env->Invoke("Import", "test.avs");
  if (!AVSV_main.IsClip()) //not a clip
   //AVS_linkage = 0;
   AVSV_main = 0;
   AVS_env->DeleteScriptEnvironment();
   return -1;
 catch(AvisynthError err)
 return 0;
Groucho's Avisynth Stuff
Old 25th August 2013, 00:09   #171  |  Link
IanB
Avisynth Developer
If we look under the covers of the baked macros :-
# define AVS_BakedCode(arg) { arg ; }
# define AVS_LinkCall(arg) !AVS_linkage || offsetof(AVS_Linkage, arg) >= AVS_linkage->Size ? 0 : (this->*(AVS_linkage->arg))
We see :-
which becomes after we unwrap AVS_BakedCode :-
~AVSValue() { AVS_LinkCall(AVSValue_DESTRUCTOR)() ; }
and finally becomes :-
~AVSValue() {
  !AVS_linkage
  offsetof(AVS_Linkage, AVSValue_DESTRUCTOR)()) >= AVS_linkage->Size
  0
  (this->*(AVS_linkage->AVSValue_DESTRUCTOR)()));
and if we follow the function pointer :-
void AVSValue::DESTRUCTOR() { if (IsClip() && clip) clip->Release(); }
So I find it a little strange the crash report is on the link call itself rather than in the actual code, but that may be a lack of symbols thing with the debugger.
Of course setting AVS_linkage = 0 cause the code to be skipped, so what ever is wrong is ignored.
I suspect your problem may be earlier with AVSV_main not being constructed correctly :-
  AVSValue AVSV_main;
it depends on the order the compiler does things, but I suspect AVSV_main tries to get made with AVSValue::CONSTRUCTOR0() before AVS_linkage gets assigned.
So setting AVS_linkage back to zero before the ::FreeLibrary is the right thing to do, but setting it to zero before all the classes are finished is not right. Just like trying to start classes is not right before you initially set AVS_linkage.
I think we need some notes about lifetime and scope of things needing a valid AVS_linkage.
Old 25th August 2013, 00:30   #172  |  Link
Groucho2004
Thanks Ian. I now tested these 2 options:
 AVSV_main = 0;
 AVS_linkage = 0;
 return -1;
 AVS_env->ThrowError("Script did not return a video clip");
Both let the program (a function actually) exit without crashing. I guess I'll use the former.
Edit: Static linking with avisynth.lib also works fine.
Old 28th August 2013, 14:10   #173  |  Link
vcmohan
The windows 32 bit dll is dated jan 2013. Since then a number of changes/ corrections were done. Will it be possible to update the dll and make available for down load?
mohan
Old 28th August 2013, 20:16   #174  |  Link
StainlessS
StainlessS's Avatar
vcmohan,
See Grouch02004 ICL compiler version v2.6a4 with updates, current April 25 2013, works great.
You just need install v2.6a4 and overwrite dll in system32 (SysWOW64 64bit) with the new dll.
http://forum.doom9.org/showthread.php?t=167358
Old 29th August 2013, 01:03   #175  |  Link
Robert Martens
Ian, I wonder if you'd be so kind as to offer a little more help regarding your idea for the dual-host plugin as described here:
Initialise AVS_linkage to the local copy and set it to the core value in the AvisynthPluginInit3 entry code.
    AVS_linkage = vectors;
    env->AddFunction("InvertNeg", "c", Create_InvertNeg, 0);
    return "`InvertNeg' sample plugin";
extern "C" __declspec(dllexport) const char* __stdcall AvisynthPluginInit2(
        IScriptEnvironment* env) {
I've spent the past few days going over C++ books, websites, Stack Overflow posts, basically all the reference material I could get my hands on, digging further into function pointers than I ever thought I would, along with inheritance and a variety of other related topics, but I feel like I'm going around in circles.
Including the Avisynth header with AVISYNTH_CORE defined means the linkage macros evaluate to nothing, so all the header contains are function declarations. I'm then free to implement them as I see fit in interface.cpp. That's great for 2.5, but loading the plugin in 2.6 shows that it uses those same local implementations, since the various methods aren't defined to call AVS_linkage and get the appropriate function pointers from the core.
Trying to include the header twice (once in interface.cpp with AVISYNTH_CORE defined, and once in invertneg.cpp without it) just ends up defining the functions twice, which won't work, and I spun my wheels in the mud playing around with derived classes, friend functions, and function pointer casts only to find myself back where I started.
The only answer I could come up with involves initializing AVS_linkage to zero, and then making every function in my copy of interface.cpp look like this (after copying some of the macro code into the file so it'll evaluate to code calling the function pointer):
bool VideoInfo::HasVideo() const
  if (AVS_linkage) {
    return AVS_LinkCall(HasVideo)();
  } else {
    return (width!=0);
As seen above, however, you suggested initializing AVS_linkage differently, so I'm fairly sure this isn't what you had in mind. Would you by any chance be able to give me a hint where I should go next? I don't expect you to teach me remedial C++, or walk me through the intricacies of the Avisynth codebase, but a nudge in the right direction would be a big help; maybe just the names of the C++ or general programming concepts I'd need to study to solve the problem the way you intended?
Old 29th August 2013, 02:12   #176  |  Link
StainlessS
StainlessS's Avatar
Mucho admiration that you seem to be pursuing this, thought it might better be in the domain of a CPP progger, (me given up),
Hope Mr B gives you an audience.
Old 29th August 2013, 06:31   #177  |  Link
IanB
Avisynth Developer
A solution to the functions defining twice is to wrap one instance in a namespace, then they become distinct. This is pretty much how the first brute solution gets around the same problem of duplicate names.
I did warn that some imagination would be required.
namespace Interface {
/* Modified Interface.cpp */
// 50 #include "stdafx.h"
#include <windows.h>
#define AVISYNTH_CORE // pretend we are avisynth.dll
// Old 2.5 version of code
int VideoFrame::GetHeight(int plane) const {
  switch (plane) {
  case PLANAR_U:
  case PLANAR_V:
    if (pitchUV)
      return height>>1;
    return 0;
  return height;
/* int VideoFrame::GetHeight(int plane) const {
  switch (plane) {
  case PLANAR_U:
  case PLANAR_V:
    if (pitchUV)
      return heightUV;
    return 0;
  return height;
// 746 extern __declspec(dllexport) const AVS_Linkage* const AVS_linkage = &avs_linkage;
And of course you need to reference the namespace version of thing in Interface.cpp
const AVS_Linkage* AVS_linkage = &Interface::avs_linkage;
Old 29th August 2013, 15:40   #178  |  Link
ultim
AVS+ Dev
ultim's Avatar
In the definition of the ScriptEnvironment::NewPlanarVideoFrame method, what is the point of letting plugins force a smaller alignment than the default? Anything else than those very few bytes of memory savings?
Old 29th August 2013, 22:44   #179  |  Link
Chikuzen
typo lover
Chikuzen's Avatar
From core/parser/script.cpp
AVSValue Import(AVSValue args, void*, IScriptEnvironment* env)
    TCHAR full_path[MAX_PATH];
    TCHAR* file_part;
    if (strchr(script_name, '\\') || strchr(script_name, '/')) {
      DWORD len = GetFullPathName(script_name, MAX_PATH, full_path, &file_part);
      if (len == 0 || len > MAX_PATH)
        env->ThrowError("Import: unable to open \"%s\" (path invalid?)", script_name);
    } else {
      DWORD len = SearchPath(NULL, script_name, NULL, MAX_PATH, full_path, &file_part);
        env->ThrowError("Import: unable to locate \"%s\" (try specifying a path)", script_name);
Although Windows API can handle MAX_PATH(260) characters(not bytes) as filepath, 'Import' causes an error by about 130 non-ASCII characters by shortage of a buffer.
(Generally, non-ASCII characters require 2bytes on ACP.)
I think that 'TCHAR full_path[MAX_PATH]' should be changed into 'TCHAR full_path[MAX_PATH * 2]'.
my repositories
Chikuzen is offline   Reply With Quote
Old 29th August 2013, 22:58   #180  |  Link
IanB
Avisynth Developer
@ultim,
Forcing alignment is generally for setting a PVideoFrame to describe an existing foreign video buffer layout. This can avoid an unnecessary copy of the data. e.g. a source filter to match the memory layout delivered by a codec, or matching the memory layout of a hardware device.
Setting some pointers and a few describing numbers is of order a million times faster than actually copying the data bytes. TurboPascal7 above was advocating always making Crop that million times slower for the sake of always maintaining memory alignment.
