30th April 2017, 23:16 | #3361 | Link |
Thank you master (slap, slap).
1st May 2017, 13:14 | #3362 | Link | ||
SetFilterMTMode("DGSource", 3)
BeHappy, AviSynth audio transcoder. Last edited by tebasuna51; 1st May 2017 at 13:16. |
1st May 2017, 14:42 | #3363 | Link | |
I don't think that's the problem, even thought SetFilterMTMode("DGDecodeNV", 3) is incorrect, as you've already pointed out. AviSynth+ automatically recognizes source filters. If it sees a source filter which has no MT-mode specified, it will automatically use mode 3 instead of the default MT mode. This has been the behavior since r2069.
2nd May 2017, 02:23 | #3364 | Link | |
Exception 0xC0000005 [STATUS_ACCESS_VIOLATION] Module: C:\WINDOWS\SysWOW64\KERNELBASE.dll Address: 0x75EAB782 I guess that falls under the "not show anything useful" heading. I'll try running the other filters separately to narrow the field. |
2nd May 2017, 02:39 | #3365 | Link | |
Groucho's Avisynth Stuff |
2nd May 2017, 11:12 | #3366 | Link |
Found the problem. It was an old plugin (SplineResize.dll). Run with it, crash. With out it, no crash. Found a replacement: ResizersPack4.5.avsi. Slower but better quality and it works. Thanks to Reel.Deel and Groucho2004 for your guidance and software.
2nd May 2017, 13:54 | #3367 | Link |
If the resamplers in the AviSynth kernel are not versatile enough for you, you might also be interested in ResampleHQ. The features in the Resizers Functions Pack 4.5 by Dogway are rather special, though, and I would not be sure which of them are portable to new color spaces/configurations of AviSynth 2.6 and AviSynth+ without quirks, may require general updates...
2nd May 2017, 19:39 | #3368 | Link | |
2nd May 2017, 21:23 | #3369 | Link |
Probably not remarkably great. You should learn how the parts of each algorithm work, to understand which purpose they serve. "EDI" (Edge Directed Interpolation) functions are especially made to aid upsampling. I see no reason to believe that downsampling would be improved by it, the way it works.
And it is not even specifically related to AviSynth+. Another thread derailing... it's getting common in the last time. Well, this time I am involved... |
2nd May 2017, 21:39 | #3370 | Link |
NNEDI / EEDI can't downscale. What they do is double the image height. So, this code will double both image width and height:
nnedi3(dh = true).turnleft().nnedi3(dh = true).turnright()
Groucho's Avisynth Stuff Last edited by Groucho2004; 3rd May 2017 at 08:37. |
3rd May 2017, 09:08 | #3371 | Link |
Imagine I want to avoid autoloading for some plugins, prefer explicit loading for specific reasons; and I have such plugins in both 32-bit and 64-bit flavour.
Does AviSynth+ provide a core {function|constant} to check whether my script runs in a 32 or 64 bit environment, to calculate a base plugin directory accordingly? Something like: Code:
MyPluginBase = "D:\AviSynthPlugins\special\" + (Is64bit() ? "x64" : "x86") |
3rd May 2017, 09:29 | #3372 | Link | |
if (sizeof(void*) == 8) //64 bit module on Win64 With a bit more code this could be extended to report a WoW64 process (32 bit process on 64 bit Windows) and consequently a plain 32 bit process (error handling mostly omitted in the example): Code:
#define PROCESS_32_ON_32 0 #define PROCESS_32_ON_64 1 #define PROCESS_64_ON_64 2 ... int ProcessType() { if (sizeof(void*) == 8) return PROCESS_64_ON_64; //64 on 64 BOOL bWoW64Process = FALSE; typedef BOOL (WINAPI *LPFN_ISWOW64PROCESS) (HANDLE, PBOOL); LPFN_ISWOW64PROCESS fnIsWow64Process; HMODULE hKernel32 = GetModuleHandle("kernel32.dll"); if (hKernel32 == NULL) return -1; fnIsWow64Process = (LPFN_ISWOW64PROCESS)GetProcAddress(hKernel32, "IsWow64Process"); if (fnIsWow64Process != NULL) fnIsWow64Process(GetCurrentProcess(), &bWoW64Process); else return -1; if (bWoW64Process) return PROCESS_32_ON_64; //WoW64 return PROCESS_32_ON_32; }
Groucho's Avisynth Stuff Last edited by Groucho2004; 3rd May 2017 at 10:34. |
3rd May 2017, 12:54 | #3373 | Link |
I seem to have hit a bug in Overlay, namely the "lighten"-mode:
Maske=BlankClip(1,156,42,pixel_type="YV24",fps=25,color=$000000,channels=0) Mard=BlankClip(1,56,42,pixel_type="YV24",fps=25,color=$000000,channels=0) Mard2= Maske.Overlay(Mard,mode="Lighten") Return Mard2 Info() reported the following CPU instruction sets: SSE4.2, SSE3, AVX, AVX2, FMA3, F16C. [Edit]: I am using 64bit r2455. It works with standard Avisynth 2.6. Last edited by mkver; 3rd May 2017 at 13:11. |
3rd May 2017, 19:25 | #3377 | Link |
I'm still not able to solve the stability of the multithread-ScriptClip-with-nested-ConditionalFunctions problem (deadlock).
But there had been a couple of fixes and small additions since r2455, what's your opinion about a maintenance release soon? Code:
- Fix: Overlay Lighten: artifacts when base clip and overlay clip have different widths (regression since r2290) - Fix: YUY2 HorizontalReduceBy2 did nothing if target width was not mod4 - ImageReader: 16 bit support; "pixel_type" parameter new formats "RGB48", "RGB64" and "Y16" - ImageWriter: 16 bit support; save RGB48, RGB64, Y16, planar RGB(A) 8 and 16 bit formats (note: greyscale through devIL can be corrupt with some formats, use png) - ImageWriter: flip greyscale images vertically (except "raw" format) - SubTitle: new parameter "font_filename" allows using non-installed fonts - (project can be compiled using gcc) - Allows opening unicode filenames through VfW interface (virtualdub, MPC-HC) - Script function Import: new parameter bool "utf8" to treat the filenames as UTF8 encoded (not the script text!) - SubTitle: new parameter bool "utf8" for drawing strings encoded in UTF8. Title="Cherry blossom "+CHR($E6)+CHR($A1)+CHR($9C)+CHR($E3)+CHR($81)+CHR($AE)+CHR($E8)+CHR($8A)+CHR($B1) SubTitle(Title,utf8=true) - New script functions: ScriptNameUtf8(), ScriptFileUtf8(), ScriptDirUtf8(), they return variables $ScriptNameUtf8$, $ScriptFileUtf8$ and $ScriptDirUtf8$ respectively |
3rd May 2017, 19:52 | #3378 | Link |
Implement a core function / variable reporting whether the current process uses 32 or 64 bit code (maybe even WoW64)... not urgent, only if you get immediately a good idea how to realize it sensibly.
5th May 2017, 23:19 | #3379 | Link |
And I ran into another issue with weird chroma: The blur filter doesn't seem to like input that is 32 pixel wide:
Return BlankClip(1,32,62,pixel_type="YV12",fps=25,color=$000000,channels=0).Blur(1.4) |
