Old 7th February 2014, 13:27   #581  |  Link
naoan
Originally Posted by ultim View Post
If it needs to be last, you can also place it after the call to Prefetch().
Nice! didn't know you could do it like that, seems a bit faster/less frame drop now. Thanks!
naoan is offline
Old 7th February 2014, 14:42   #582  |  Link
kypec
User of free A/V tools
kypec's Avatar
I've replaced my Avisynth installation with your x86 build and also replaced AvsPmod files but now AvsPmod refuses to even start with error message below:
Clicking "Yes" and navigating to C:\Windows\SysWOW64 where that Avisynth+ DLL resides does not work either.
kypec is offline
Old 7th February 2014, 21:39   #583  |  Link
Hoping for a build that works with ffdshow, tried it on both my computers win8/win7 i7/i5 and both crash instantly, both are working fine with 2.6MT.
ryrynz is offline
Old 8th February 2014, 11:15   #584  |  Link
turbojet
blankclip(1630,1920,1080,"YV12",23.976)
resize(1280,1080) AVS+  2.6
Lanczos           139   153
Spline64          142   135
Bicubic           241   175
Bilinear          246   240
Same conclusion as Groucho2004's test with lanczos included.
PC: FX-8320 GTS250 HTPC: G1610 GTX650
PotPlayer/MPC-BE LAVFilters MadVR-Bicubic75AR/Lanczos4AR/Lanczos4AR LumaSharpen -Strength0.9-Pattern3-Clamp0.1-OffsetBias2.0
turbojet is offline
Old 8th February 2014, 22:16   #585  |  Link
ultim
AVS+ Dev
ultim's Avatar
So here are some more news I've promised. The list of our Google Summer of Code ideas is online! It is available from the homepage with a single click, but here is a direct link for you. You'll find all kinds of interesting projects there, from native GPU support to scripting language improvements and a GUI plugin manager, just to name a few. Now, cross your fingers for AviSynth to be accepted.
AviSynth+
ultim is offline
Old 8th February 2014, 22:21   #586  |  Link
Stereodude
Your direct link gives a 404.
I also have a question about AviSynth+. I see a big push related to MT in the past week. I thought the whole idea was to get better performance without requiring the user to mess around with MT commands and the like? I'm probably put off to the idea because my experience with MT support in AviSynth is that it's a complete disaster that barely works even on the rare occasions when the stars align just right and I'd not rather not have those headaches again. I've had much better luck with MP_Pipeline at speeding up scripts than I ever had with MT and it doesn't require any sort of celestial alignment or blood sacrifices.
Stereodude is offline
Old 8th February 2014, 22:37   #587  |  Link
ultim
AVS+ Dev
ultim's Avatar
Works for me.
Ultimately, that is what everybody (including us developers) would like to see. But unfortunately what you wish for is simply technically not possible for many filters due to the way they work. What we can do though is to minimize the MT-related commands the user has to issue, instead of completely eliminating them. Minimizing the MT-commands for script writers is the collective goal of many of our efforts, such as many filter rewrites (both internal and external), adding support for filters to signal to Avs+ the MT mode they need, the way SetFilterMTMode() works, and even of this post to teach plugin developers how to support MT hassle-free for the user.
So we do what we can, but sometimes there are hard limits to what is possible at all.
AviSynth+
ultim is offline
Old 8th February 2014, 22:57   #588  |  Link
TurboPascal7
TurboPascal7's Avatar
That's right. When MT is finalized, the only thing the user will have to write in his script is the Prefetch call, which later can probably be added by programs like avsmeter, avs2yuv and the likes. All SetFilterMtMode calls will be hidden in a single .avsi script.
Compared to all those ### MT_Pipeline requires you to write, this is nothing.
Now, the problem is to build this avsi file with MT modes definitions. I put this pad about two weeks ago and posted the link on our IRC channel, ultim also linked it here a few days ago. But since the initial script, only one line has been added (fft3dgpu). With this kind of activity you can't expect MT to get finalized and become user-side overhead free any time soon.
TurboPascal7 is offline
Old 10th February 2014, 19:31   #589  |  Link
HeadlessCow
Is there a reason why you couldn't require the filters to implement a new method that returns the MT modes that they support rather than relying on a community generated avsi script? You'd still need the script for older plugins, but anything new (or anything that you're updating) would just automatically work.
HeadlessCow is offline
Old 10th February 2014, 21:28   #590  |  Link
TurboPascal7
No, there is no reason we couldn't do this. That's why we did. It works by abusing SetCacheHints right now but allows keeping backward compatibility.
Old 10th February 2014, 22:56   #591  |  Link
HeadlessCow
Ah, perfect (and sneaky)! I hadn't seen mention of it in the thread, so I just wanted to make sure the obvious option hadn't been accidentally overlooked :-D
Old 11th February 2014, 08:13   #592  |  Link
turbojet
Here's some results with fastest mt mode:
tfm 1
tdecimate 3 or off, 1 fails
telecide 1
decimate 3 or off, 1 and 2 fails
fielddeinterlace 2, 1 fails
dss2 1, 2 is very slow
lwlibavvideosource(dr=true) 2 is 25% faster with much higher cpu usage, 75 vs 17%, 1 fails
nnedi3 2, 1 corruption
colormatrix("Rec.709->Rec.601") 2 is <1% faster than all modes or off
dfttest 1
fdecimate 1 and 2 tie
it 3, 1 fails, 2 is same speed as 3 but 4x cpu load
jinc36resize(3840,2160) 2, 1 is corrupt
leakkerneldeint(1) 1
repal 3, 1 fails, 2 is slow
sorathread 3, 1 and 2 fails
srestore all tie
tdeint 1
unblend 1 or 2
uncomb 3 or off
unsharphq 1
yadif 1
yadifmod(edeint=nnedi3()) 2, 1 fails
All defaults unless (). When testing it's best to use a real source, some filters work on blankclip() but not on real sources
with the same mtmode.
Mode 1 works on quite a few things. One thing I didn't consider (much) is cpu load. I used prefetch(4) which 50% with most filters while mode 3 and off used 12%. mtmodes during realtime watching should be a big benefit but unless slow filters are used there's a little bit of a slowdown when x264 encoding.
turbojet is offline
Old 11th February 2014, 08:21   #593  |  Link
TurboPascal7
Please do check if the actual output is correct. Fast but broken mode is useless.
I'm asking because for example nnedi3 with mode 1 is completely broken yet you specified it. I'm pretty sure that's the case with most filters in the list.
Easy way of checking would be using something like ColorBars(1920, 1080, "YV12").addgrainc(10000, 10000, seed=1) as a source filter. It doesn't always work right but will do for most stuff (like needi3).
Old 11th February 2014, 08:59   #594  |  Link
turbojet
Does the corruption like nnedi3 only happen with mode 1?
turbojet is offline
Old 11th February 2014, 09:06   #595  |  Link
TurboPascal7
It most cases - yes.
Nnedi3 uses some buffers to do its dirty work and with mode 1 you get multiple threads writing data from different frames to the same buffer. This causes corruption when later someone tries to read from this buffer and gets not what was expected. Most of "more complicated" filters use some kind of temporary storage thus won't work well with this mode. Simple filters might.
Mode 2 doesn't have this issue because multiple threads will get their own buffers and no data will be shared. Hence mode 2 is the "default" mode which should work with most filters, but it wastes memory like crazy (take SangNom2 for example - for 1080p YV12 frame, size of temporary buffers is about 10MB, so with 4 threads you get 40MBs on single filter invocation. Now add some usual supersampling to this and multiple invocations in most aa scripts and... you get the idea).
If the filter requires sequential access or uses some global storage (i.e. written by a very bad person), then mode 3 is the only way to go.
Old 11th February 2014, 09:17   #596  |  Link
turbojet
Tested all the reported 1's and other than nnedi3, jinc36resize didn't look correct. Others worked fine.
turbojet is offline
Old 11th February 2014, 19:53   #597  |  Link
ultim
AVS+ Dev
ultim's Avatar
It wasn't mentioned to avoid plugin writers accidentially using those parts of the new interface which are not safe. The MT-mode specification is safe, but be sure not to use IScriptEnvironment2 at all, for exmaple.
The good thing about MT-mode specification as shown by TurboPascal7, as he already noted, is that it keeps compatibility. So plugins can implemnent it without breaking older AviSynth versions, or non-plus AviSynth. Putting it into SetCacheHints() is ugly I know (TurboPascal7 was very much against it putting it there for this reason), but it is the only way for me to let plugins report their MT-mode without breaking other AviSynths.
Anyway, long story short, you can follow the example here, but don't use any other part of the new interface yet. For plugins that report the MT mode using SetCacheHint(), the user won't have to add a SetFilterMode() call.
AviSynth+
ultim is offline
Old 11th February 2014, 22:12   #598  |  Link
LaTo
LaTo INV.
LaTo's Avatar
What is a good way to detect Avisynth+ without losing compatibility with regular Avisynth?
I need that to automatically disable internal multi-threading in my filters.
LaTo is offline
Old 11th February 2014, 22:47   #599  |  Link
Groucho2004
Originally Posted by LaTo View Post
What is the best way to detect Avisynth+ without losing compatibility with regular Avisynth?
There are several ways to identify the avisynth.dll.
1. Query "AVISYNTH_INTERFACE_VERSION". This only tells you if it's 2.5x or 2.6x
2. Parse the version string ("VersionString"). A bit unreliable.
3. Parse the export functions. That's the most useful and what I do in AVSMeter. For example:
Only 2.6x versions export "DeleteScriptEnvironment()"
Only AVS+ exports "CreateScriptEnvironment2"
Only SEt's and tsp's MT versions export "GetMTMode()".
A combination of the above should provide enough info.
Groucho2004 is offline
Old 12th February 2014, 09:30   #600  |  Link
jpsdr
Should it be better to detect if MT mode is enabled ?
If someone use Avisynth+ without using multi-threading, i think internal multi-threading should be kept.
jpsdr is offline
