12th November 2014, 02:48 | #1621 | Link |
my english sucks, sorry
Hi jdobbs, maybe Im asking too much but would it be possible to have an option under the "Audio Encoding Options" to only keep HD Audio for the main audio track? for example... If I want to keep intact the main DTS-HD english audio track, but I want to encode the french DTS-HD and commentary DTS tracks to AC3. An option like "Only Keep HD Audio for First/Main track" or "Keep First/Main Audio intact" would do Anyways... THANK YOU FOR ALL THE WORK YOU PUT INTO BD REBUILDER! |
14th November 2014, 04:34 | #1622 | Link |
Hi jdobbs, hope youŽre well, i was thinking about if you can make some button just for do "clic" "Pause" and "Continue" some job on any Bd rebuiler process? An example, i currently ripping some bluray movie and i have to stop temporaly the job but i donŽt want to miss all the process, so, if there just could be a button to pause temporaly and later continue, that will perfect. IŽll wonder if you can do that button.
Dear jdobbs, can be this possible? Anyway thank you for your time!! |
14th November 2014, 06:21 | #1623 | Link | |
When you cancel / abort a running job and restart BD-RB it will ask if you want to start from scratch or if you want to resume (continue) the prevoius job. |
22nd November 2014, 06:37 | #1624 | Link | |
For example, if right now IŽm reencoding some movie Reencoding: VID_00001 and the time left is about 3hs but I do cancel that and later resume that, the entire process of that file will start from the beginning and iŽll lose the hours of entire jobs. You know what I mean? I mean about some button to resume the file job just where it was canceled |
22nd November 2014, 06:42 | #1625 | Link | |
22nd November 2014, 07:27 | #1626 | Link |
Are there plans for separate output and work directories? I saw it requested on this thread, but nothing after that.
ATM the final copy/building is pretty slow and HDD intensive since it copies it all happens on the same drive. |
22nd November 2014, 08:14 | #1627 | Link | |
I took the plunge here about 6 months ago and bought a Samsung EVO 250 Gig SSD. It was only about $120 or so (Amazon) and I now ALWAYS make sure that I rip to that drive and do ALL processing on it. I try to use it exclusively if possible for MKVMerge, TSMuxer, BDRB, or any re-encoding of any kind. It REALLY saves a lot of time! Secondarily, if you wanted to, you COULD abort BDRB right after it finishes the encode and just before or just after the start of the rebuilding phase. Then, simply use TSMuxer (which BDRB likely uses anyway) and output to a different conventional HDD if you want. That would spare you what you are talking about, which would be reading / writing / and rebuilding using the same physical drive. Hope that helps somewhat... |
22nd November 2014, 13:42 | #1628 | Link | |
OUTPUT_FOLDER=n, where n must exist |
24th November 2014, 17:09 | #1636 | Link |
That actually brings me to another request. Could outputted discs have an extension added to denote it's the re-encoded disc?
I've occasionally wanted to use the same input and output location, but then the original disc would be overwritten. Ex.: Source: c:\WORKING\MovieName, Output: c:\WORKING\MovieName_BDRB |
24th November 2014, 17:35 | #1637 | Link | |
2nd December 2014, 06:43 | #1638 | Link |
I tested my first Quick Play menu today and thought it looked good. I was surprised that the selections were all top justified with a lot of empty space below it.
I understand dynamically sizing the overlay region where the text appears is probably not simple, but I wouldn't mind seeing the text centered vertically within it. |
2nd December 2014, 16:00 | #1639 | Link | |
2nd December 2014, 20:09 | #1640 | Link |
I know time cannot be saved or banked, so to me OUTPUT_FOLDER=p is a sweet option for a different target drive other than directory on the same drive.
The look of the Quick-Play menu is really useful with its features. A very sweet bonus is, and respect to multiAVCHD, you didn't force, or make by default any automatic music/noises. The only thing I'd like to see added, but don't expect it, would be an option for chapters. That way either a movie from Alternate MKV or...iDevice movies could have chapters. From a programmers view, I can see where that might be a lot more code than you might be willing to add. LOL!
