2nd March 2016, 18:36 | #861 | Link |
@dandyclubs
nice clip , I've created a ticket and let you know when VFR-maniac replies.
2nd March 2016, 19:35 | #862 | Link | |
2nd March 2016, 20:00 | #863 | Link |
yes but probably won't be long
2nd March 2016, 20:15 | #864 | Link |
also another bug for you to sort out, its the video comparison it seems if the filter is set to something other than manual ? it will fail i only notice this myself since i like to use dgsource myself
http://gfycat.com/BrokenHoarseFruitbat would it also be possible to show what the crop values are set to via mouse over event or something since the "preview" tab is missing |
2nd March 2016, 20:54 | #865 | Link |
The source filter used for the video comparison is hardcoded to ffms2 I think so it don't matter what source filter is in the main dialog, choosing DGSource triggered a bug however, it'll be fixed.
The crop values mouse over issue I don't understand yet, you mean in the video comparison?
2nd March 2016, 20:57 | #866 | Link | |
as in 1.1.8 you had the preview tab when you double click on crop Last edited by cegy; 2nd March 2016 at 21:03. |
2nd March 2016, 21:11 | #867 | Link |
You can find the crop values:
in the crop dialog in the status bar in the options dialog under Image | Crop double click filters to show Scripting Editor > show context menu > Script Preview
2nd March 2016, 21:22 | #868 | Link | |
better yet if you want to keep it clean but to the point how about ? (not sure of the name click able title?) Last edited by cegy; 2nd March 2016 at 23:43. Reason: pic added |
3rd March 2016, 08:31 | #869 | Link |
Stax,
Are the settings for the default template been updated. For instance, in x265 the default psy rd was changed from 0.3 to 2
3rd March 2016, 09:05 | #870 | Link |
My code is fairly up-to-date, I'm using a diff checker tool to catch changes. I did not reset the profiles and templates though, if you want to reset there is a reset feature for both profiles and templates.
3rd March 2016, 09:35 | #871 | Link | |
stax, I'm trying to use "RemoveGrainHD" in lieu of "RemoveGrain" for HD sources. Is this possible? Thanks
3rd March 2016, 10:15 | #872 | Link |
have you seen main menu > tools > directories > plugins ?
3rd March 2016, 11:20 | #873 | Link |
I'm getting script error - "There is no function named RemovegrainHD
This is what I did. I copied the Removegrainhd.dll to the avisynth plugin folder then I added Removegrainhd in the filter profile. Did I missed something? Thanjks
3rd March 2016, 15:28 | #874 | Link |
Are you aware that StaxRip x64 supports only AviSynth+ x64 and AviSynth+ x64 supports only x64 plugins?
http://avisynth.nl/index.php/AviSynt...2B_x64_plugins
4th March 2016, 03:19 | #875 | Link |
some fixes and a feature requested since years
### Download https://drive.google.com/folderview?...kE&usp=sharing http://1drv.ms/1OqPDOe ### New Features - support for 3 or more audio tracks added to the muxing dialog - code preview added to filters menu and script preview renamed to code preview in script editor ### Fixed Bugs - fixed window freeze in eac3to dialog happening when eac3to fails on the input. - fixed showing filter selection dialog even if the source is vpy or avs - fixed StaxRip trying to auto correct the script even if the source is avs - fixed StaxRip recalculating the video bitrate even when the fixed bitrate option is used - avi muxer supports two audio tracks now - in some cases the two audio output file paths were identical - moving subtitles up and down wasn't working correctly - the new mp4box update should fix a bug many people reported ### Tweaks - better error handling when the source is vpy or avs - when loading an audio file without language info the language of the audio profile/stream stays instead of being changed to undetermined ### Updated Tools - mp4box 0.6.0 - QSVEncC 2.37
4th March 2016, 15:50 | #876 | Link |
Is it possible to give the infotext in the preview a black border? Sometimes it's hard to see anything.
Minor inconsistency: When opening a file normaly StaxRip asks to select a source filter and if any of the audio track should be demuxed. When opening a file with the "open with" dialog (rightclick->open with->StaxRip) StaxRip chooses the source filter and demuxes all audio tracks. |
4th March 2016, 16:01 | #877 | Link | ||
5th March 2016, 01:43 | #878 | Link |
https://github.com/stax76/staxrip/wiki/test-build
5th March 2016, 10:15 | #880 | Link |
If I remember right then Python and JavaScript allow strings defined with both ' and " and since VB.NET uses " I used ' to define all the Python code, if I change it to " then it will be fine I hope.
