#1021 | Link |
Just tried it but it's not working. Output file has lost the HDR10 info:
HDR format : Dolby Vision, Version 1.0, dvhe.05.06, BL+RPU Codec ID : hev1 MPC-HC error: Code:
File Source (Async.)::Output Media Type 0: -------------------------- Unknown AM_MEDIA_TYPE: majortype: MEDIATYPE_Stream {E436EB83-524F-11CE-9F53-0020AF0BA770} subtype: Unknown GUID Name {08E22ADA-B715-45ED-9D20-7B87750301D4} formattype: TIME_FORMAT_NONE {00000000-0000-0000-0000-000000000000} bFixedSizeSamples: 1 bTemporalCompression: 0 lSampleSize: 1 cbFormat: 0 Media Type 1: -------------------------- Unknown AM_MEDIA_TYPE: majortype: MEDIATYPE_Stream {E436EB83-524F-11CE-9F53-0020AF0BA770} subtype: TIME_FORMAT_NONE {00000000-0000-0000-0000-000000000000} formattype: TIME_FORMAT_NONE {00000000-0000-0000-0000-000000000000} bFixedSizeSamples: 1 bTemporalCompression: 0 lSampleSize: 1 cbFormat: 0 Code:
HDR format : Dolby Vision, Version 1.0, dvhe.05.06, BL+RPU / SMPTE ST 2094 App 4, Version 1, HDR10+ Profile B compatible Codec ID : dvhe |
#1025 | Link | |
QfG Group Germany
![]() EDIT: Have tried FFMPEG 6 (v0.63.1) and FFMPEG 5, every time same mistake. Can u give me your FFMPEG please?
#1026 | Link |
Just tried with the latest ffmpeg build (ffmpeg-master-latest-win64-gpl) and it's working. I replaced both ffmpeg.exe and ffprobe.exe.
#1029 | Link | |
QfG Group Germany
Open and edit DDVT_DEMUXER.cmd and change line 1028 to: Code:
if "%BL%%REMHDR10P%%SAVHDR10P%%RPU%"=="NONONONO" ( Code:
if "!VIDEO_COUNT!"=="1" ( if "%BL%%REMHDR10P%%SAVHDR10P%%RPU%"=="NONONONO" ( %CYAN% echo. echo Please wait. Demuxing EL... EDIT: Fixed Script as Attach File for Download.
#1031 | Link | |
1. Run DDVT_DEMUXER on the MP4 file that contains the HDR + DV Profile 7. This will demux the DV P7 and convert it to P8. The output will be an RPU.BIN file. 2. Run DDVT_REMOVER on the MP4 file that contains the HDR + DV Profile 7. Make sure "Remove Dolby Vision" = Yes. This will remove the DV P7. The output will be a "No DV.mp4" file. 3. Run DDVT_INJECTOR on the "No DV.mp4" file and select the RPU.BIN file from the output of step 1. This will remux the "No DV.mp4" with the DV P8 (RPU.BIN), creating a Hybrid HDR+DV P8 mp4. |
#1032 | Link | |
QfG Group Germany
If it is a Dual Layer MP4 with P7 the steps right. If it is a Single Layer P7 MP4, you can skip step (2.), the P8 RPU will overwrite the P7 EL layer.
#1034 | Link | |
QfG Group Germany
Started test phase for 0.64.4. Many reworks in the scripts.
#1037 | Link |
But...
General Complete name : D:\Torrents\Movies\Conclave.2024.2160p.WEB-DL.DV-TheEqualizer\Conclave.2024.2160p.WEB-DL.DV-TheEqualizer.mp4 Format : MPEG-4 Format profile : Base Media Codec ID : isom (isom/dby1/iso2/mp41) File size : 13.3 GiB Duration : 2 h 0 min Overall bit rate mode : Variable Overall bit rate : 15.8 Mb/s Frame rate : 23.976 FPS Movie name : Conclave (2024) by TheEqualizer Tagged date : 2024-12-03 10:47:43 UTC Writing application : Lavf60.3.100 Cover : Yes Video ID : 1 Format : HEVC Format/Info : High Efficiency Video Coding Format profile : Main 10@L5@High HDR format : Dolby Vision, Version 1.0, dvhe.05.06, BL+RPU Codec ID : hev1 Codec ID/Info : High Efficiency Video Coding Duration : 2 h 0 min Bit rate : 14.3 Mb/s Width : 3 832 pixels Height : 1 600 pixels Display aspect ratio : 2.40:1 Frame rate mode : Constant Frame rate : 23.976 (24000/1001) FPS Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 10 bits Bits/(Pixel*Frame) : 0.098 Stream size : 12.1 GiB (91%) Title : Conclave Language : English Tagged date : 2024-12-03 10:47:43 UTC Menus : 10 Codec configuration box : hvcC+dvcC Audio #1 ID : 3 Format : AC-3 Format/Info : Audio Coding 3 Commercial name : Dolby Digital Codec ID : ac-3 Duration : 2 h 0 min Bit rate mode : Constant Bit rate : 640 kb/s Channel(s) : 6 channels Channel layout : L R C LFE Ls Rs Sampling rate : 48.0 kHz Frame rate : 31.250 FPS (1536 SPF) Compression mode : Lossy Stream size : 551 MiB (4%) Title : MVO | TVShows Language : Russian Service kind : Complete Main Default : Yes Alternate group : 1 Tagged date : 2024-12-03 10:47:43 UTC Menus : 10 Audio #2 ID : 4 Format : E-AC-3 JOC Format/Info : Enhanced AC-3 with Joint Object Coding Commercial name : Dolby Digital Plus with Dolby Atmos Codec ID : ec-3 Duration : 2 h 0 min Bit rate mode : Constant Bit rate : 768 kb/s Channel(s) : 6 channels Channel layout : L R C LFE Ls Rs Sampling rate : 48.0 kHz Frame rate : 31.250 FPS (1536 SPF) Compression mode : Lossy Stream size : 662 MiB (5%) Title : Original | Amazon Language : English Service kind : Complete Main Default : No Alternate group : 1 Tagged date : 2024-12-03 10:47:43 UTC Menus : 10 Complexity index : Not present / 16 Number of dynamic objects : 15 Bed channel count : 1 channel Bed channel configuration : LFE Text #1 ID : 5 Format : Timed Text Muxing mode : sbtl Codec ID : tx3g Duration : 1 h 59 min Bit rate mode : Variable Bit rate : 5 b/s Frame rate : 0.247 FPS Stream size : 4.70 KiB (0%) Title : Forced | Un Chat Andalou Language : Russian Default : Yes Forced : Yes / No Alternate group : 3 Count of events : 889 Menus : 10 Text #2 ID : 6 Format : Timed Text Muxing mode : sbtl Codec ID : tx3g Duration : 1 h 50 min Bit rate mode : Variable Bit rate : 89 b/s Frame rate : 0.378 FPS Stream size : 72.4 KiB (0%) Title : Full | Un Chat Andalou Language : Russian Default : No Forced : No Alternate group : 3 Count of events : 1255 Menus : 10 Text #3 ID : 7 Format : Timed Text Muxing mode : sbtl Codec ID : tx3g Duration : 1 h 59 min Bit rate mode : Variable Bit rate : 10 b/s Frame rate : 0.201 FPS Stream size : 9.10 KiB (0%) Title : Forced | Amazon Language : English Default : No Forced : No Alternate group : 3 Count of events : 721 Menus : 10 Text #4 ID : 8 Format : Timed Text Muxing mode : sbtl Codec ID : tx3g Duration : 1 h 50 min Bit rate mode : Variable Bit rate : 47 b/s Frame rate : 0.324 FPS Stream size : 38.4 KiB (0%) Title : Full | Amazon Language : English Default : No Forced : No Alternate group : 3 Count of events : 1074 Menus : 10 Text #5 ID : 9 Format : Timed Text Muxing mode : sbtl Codec ID : tx3g Duration : 1 h 53 min Bit rate mode : Variable Bit rate : 55 b/s Frame rate : 0.386 FPS Stream size : 45.5 KiB (0%) Title : SDH | Amazon Language : English Default : No Forced : No Alternate group : 3 Count of events : 1317 Menus : 10 Menu #1 ID : 10 Format : Timed Text Codec ID : text Duration : 2 h 0 min Language : English Bit rate mode : CBR Menu For : 1,3,4,5,6,7,8,9 00:00:00.000 : Chapter 01 00:04:47.620 : Chapter 02 00:09:35.492 : Chapter 03 00:17:46.608 : Chapter 04 00:25:48.173 : Chapter 05 00:33:13.576 : Chapter 06 00:41:42.752 : Chapter 07 00:49:17.791 : Chapter 08 00:55:01.843 : Chapter 09 01:01:06.249 : Chapter 10 01:07:25.795 : Chapter 11 01:12:54.624 : Chapter 12 01:18:13.985 : Chapter 13 01:26:02.537 : Chapter 14 01:29:51.725 : Chapter 15 01:35:00.909 : Chapter 16 01:41:31.633 : Chapter 17 01:46:22.382 : Chapter 18 01:50:43.268 : Chapter 19 01:53:41.363 : Chapter 20 Bit rate mode : Constant Menu #2 00:00:00.000 : Chapter 01 00:04:47.620 : Chapter 02 00:09:35.492 : Chapter 03 00:17:46.608 : Chapter 04 00:25:48.173 : Chapter 05 00:33:13.576 : Chapter 06 00:41:42.752 : Chapter 07 00:49:17.791 : Chapter 08 00:55:01.843 : Chapter 09 01:01:06.249 : Chapter 10 01:07:25.795 : Chapter 11 01:12:54.624 : Chapter 12 01:18:13.985 : Chapter 13 01:26:02.537 : Chapter 14 01:29:51.725 : Chapter 15 01:35:00.909 : Chapter 16 01:41:31.633 : Chapter 17 01:46:22.382 : Chapter 18 01:50:43.268 : Chapter 19 01:53:41.363 : Chapter 20 |
#1038 | Link | |
QfG Group Germany
#1039 | Link |
Hello all,
Running into a new situation here: Source UHD with DV is 3840x1600 (letterboxed), destination UHD that needs DV is 3840x2160 (black bars). When injecting the RPU it says video input matches with output RPU but RPU input does NOT match with video. I also read that: Originally Posted by Boulder View Post My assumption is that whenever the final result doesn't have any black borders, you use the cropping option for the RPU. So, does that mean that since the final result here WILL have black borders I do NOT need to crop? I 'fear' the RPU will not be applied to the middle where the picture is but starts at the top so that the black bars will get DV. Or WILL it be centered? edit: Made a json file where it specifies the crop, but it doesn't take over the values. ![]() Last edited by tijgert; 16th January 2025 at 16:40. |
#1040 | Link | ||
QfG Group Germany
Your OUTPUT RPU has corrected AA with 0,280,0,280. The some borders how your INPUT VIDEO file has = OUTPUT RPU and INPUT VIDEO = MATCH Simply press now [S] and the RPU will be fixed automatically during the injecting process. You need NO JSON file for setting cropping values for all frames in RPU. After muxing you can proof the file with DDVT_MediaInfo and check the borders in RPU.
