24th June 2018, 06:19 | #15881 | Link | |
At this stage, Ripbot can only process up to 2 audio tracks...I have asked a couple of times if this can be increased to 3 (more would be even better), but as yet, no change |
26th June 2018, 16:43 | #15882 | Link |
ByteShare
I tend to enjoy keeping the mkv title info from tacks so I manually remux subs and audio and/or use an outside tool to mux the audio back in after re-encoding it if more than 1 track (keep mkv title info).
27th June 2018, 11:19 | #15883 | Link | |
So what might this "outside tool" be ?? One good thing about Handbrake is, you can add & change as many audio tracks as you like / need. |
30th June 2018, 11:25 | #15885 | Link |
Hi Atak,
I just thought I'd report back on my use of Windows 7 SP1, over the last few months. I haven't noticed any noticeable "improvement's" in the operation of Ripbot, since trying W7, as compared to my other pc's which are running Windows Server 2016. I am still getting those annoying DE "chunk" / server stall's, which sometimes respond to stopping the particular Server IP, and letting another one take it's place, but sometimes I can't turn the offending server off, which leads me to my next comment... The "Abort" command still doesn't work too well, rarely it will abort, but most times it just "says" it's aborting, but carry's on encoding, so the only option is the "kill it" with Task Manager, and even sometimes that doesn't completely stop everything, and a reboot is needed. I'm not sure what the difference was between the newer "Abort" command, and the one you had in the DE window, that seemed to work every time. That's about all I have to comment on.... Windows 7 has it's Pro's & con's, and so does Windows Server, but I'm not a fan of Windows 10 "1803". |
1st July 2018, 18:44 | #15886 | Link | |
4th July 2018, 13:09 | #15887 | Link |
Hi Atak,
Another update.... Can I ask a BIG favour....it's was way back on the 13th of April, since you updated to version 1.23.00, but 1.22 is still on Mediafire, can you PLEASE post 1.23 on Mediafire, or even better, the very latest build..... Cheers |
5th July 2018, 16:00 | #15889 | Link |
Probably some GPU driver issues. Very common after some random update in win10.
10th July 2018, 22:59 | #15891 | Link |
How do I access old jobs before the update to three audio streams. At first it shows an error about not finding audiolist3.txt file so I copy audiolist2.txt to audiolist3.txt. The next error is shows is:
" is not a valid integer value. So I'm not sure what I need to change in the older jobs. I also seem to have uncovered a bug with 4k discs and seamless branching. If I rip the disc using anydvd and let Ripbot264 combine the m2ts files, I will get audio that is out of sync towards the end of the film. If I rip the disc using MakeMKV and make a mkv file and then use RipBot264 to process the mkv, the audio comes out fine. Problems occurred with King Kong, Independence Day, and Gladiator. |
11th July 2018, 01:21 | #15892 | Link | |
If you haven't got a lot of job's queued, might be best just to reload. Or, try "edit" the "old" jobs, and just pull in the source, again. Fortunately, I only had about 2 jobs queued up. But on another pc, I had a LOT in the queue, that pc hasn't been updated yet. |
11th July 2018, 11:56 | #15893 | Link | |
ByteShare
KNLMeansCL.DLL Not Found
Any ideas why'd I'd get this error:
Using ....Windows 10 64bit I get the same error code (126) when trying to load MedianBlur2.dll as well. Not sure if related. |
11th July 2018, 13:03 | #15894 | Link | |
11th July 2018, 13:55 | #15895 | Link |
I will release an auto-update shortly to address this issue.
11th July 2018, 20:52 | #15896 | Link | |
ByteShare
Since today's RipBot update still getting:
It used to work before a format, not sure what would have changed. I might try another format |
11th July 2018, 21:14 | #15897 | Link |
So, batch scripting seems to want to be available, but is not. With v1.22.0, I have batch files loaded and want to add an AVS file that will apply to all files. There is a drop-down option entitled "CUSTOM SCRIPT" that has two options:
1) "Do not use custom script" 2) "ConvertToInterlaced.avs" On older versions, there was an option to load custom AVS files. In 1.22, there is no such option and the drop-down is useless as it simply limits you to no custom script. Am I missing something here or is it now impossible to add custom scripting to batch processing? |
11th July 2018, 21:19 | #15898 | Link | |
ByteShare
..\RipBot\Tools\AviSynth plugins\Scripts\Custom Once you add them, they'll show up as an option. |
11th July 2018, 22:23 | #15900 | Link | |
Import("C:\Program Files (x86)\AviSynth 2.5\plugins\QTGMC-3.32.avsi") AssumeTFF() QTGMC(Preset="Very Slow") LimitedSharpenFaster() |
