Old 31st May 2007, 13:27   #281  |  Link
LoRd_MuldeR
Software Developer
LoRd_MuldeR's Avatar
Originally Posted by LotharZ View Post
http://tibrium.neuf.fr = error404
Seems tha website its down, anyone can provide a link for the last version?
All MPC Homecinema downloads are hosted on SourceForge:
http://sourceforge.net/projects/mpc-hc/
LoRd_MuldeR is offline
Old 31st May 2007, 13:53   #282  |  Link
Rash
Rash's Avatar
Does anyone know a nice 16->255 converter shader? MPC's procamp doesn't work on my system. I would like to test it with EVR custom.
Rash is offline
Old 31st May 2007, 14:11   #283  |  Link
Mc Onyx
Mc Onyx's Avatar
At Sourceforge daily builds are not available, like 1072 version, where can we get them, as .fr page is unavailable?
If you need an MC on a party, I'm the man 4 you! :)
Mc Onyx is offline
Old 31st May 2007, 14:31   #284  |  Link
MatMaul
I uploaded it here :
http://www.etud.insa-toulouse.fr/~mv...hc-1.0.7.2.zip
MatMaul is offline
Old 31st May 2007, 14:46   #285  |  Link
Sirber
retired developer
Sirber's Avatar
Maybe I could make a setup out of it and host a mirror...
Detritus Software
Sirber is offline
Old 31st May 2007, 15:22   #286  |  Link
Sirber
retired developer
Sirber's Avatar
http://www.detritus.qc.ca/files/mpchc/mpchc_1072.exe (2.79MB)
Includes:
MPC HC 1.0.7.2
XviD DShow Decoder 1.1.2 final
So you are free to use ffdshow, cyberlink, coreavc or the decoder of your choice for H264
MPC and XviD settings are at default, don't forget to configure them!
Detritus Software
Sirber is offline
Old 31st May 2007, 19:46   #287  |  Link
Delerue
Originally Posted by Avish View Post
@chros & JarrettH, if your replies were to my query, then I already know that libmpeg2 can do all MPEG streams & in ffdshow it's multithreaded.
But my query was about MPC's internal MPEG-1 Decoder. Why it's tooltip says that "mpeg1 video decoding is bogus"???
Changing the subjetct a little... I think that the only problem with FFDShow MPEG decoder is that it can't know when a video is interlaced or not, so you must keep 'Deinterlacing' enable all the time (not good, I know) or enable only when you see the 'empty lines' cutting all the frames, hehehe. MPC MPEG internal decoder, in the other side, seems to know when a video is interlaced if you set the decoder to 'Auto'. BTW, for DVDs I can't use 'libavcodec' because it stutters too much. Libmpeg2 do the work perfectly.
Delerue is offline
Old 31st May 2007, 20:34   #288  |  Link
Casimir666
Release 1.0.8.0 is now available on SourceForge (my site is still down ) :
http://sourceforge.net/project/showf...ease_id=512588
Fix all this points :
- Fixed : jitter test did not display on some files
- Fixed : crash if display statistics when d3dx9_29.dll was not present
- Fixed : crash possible with OSD when closing file
- Fixed : kick off power option screen saver with Vista (if MPC have focus only)
- Fixed : DVD menu freeze with EVR custom and nVidia Pure Video decoder on Windows XP
- Fixed : clic to play not working at the bottom of video
- Fixed : MKV internal subtitles did not displayed from time to time
- Fixed : in EVR custom presenter with dual display, video disapeared when moving MPC on other screen
Tired of tearing?
Try this Media Player Classic mod : http://mpc-hc.sourceforge.net
Casimir666 is offline
Old 31st May 2007, 20:52   #289  |  Link
Egh
Aha, new shader :P
Well as i tested it, it seems to be a shader which does identity transform for now. But you can tweak brightness/constrast constants to approximate TV->PC range conversion.
In that shader (use Edit from menu), find constants definition lines and change two of them into
#define Brightness -0.08
#define Contrast 1.15
Profit! :P does conversion with high speed here, not slowing down main CPU. So if someone does proper conversion on shaders, it is gonna be fast indeed.
Egh is offline
Old 31st May 2007, 21:18   #290  |  Link
Sirber
retired developer
Sirber's Avatar
@Casimir666
Thanks for the release!
[edit]
http://www.detritus.qc.ca/files/mpchc/mpchc_1080.exe
Detritus Software
Sirber is offline
Old 31st May 2007, 21:54   #291  |  Link
cyberbeing
Broadband Junkie
VMR9 + YUV Mixing is borked in your build Casimir666
drevill_xxl's mpc build VMR9 + YUV Mixing (normal)
Casimir666's build VMR9 + YUV Mixing (everything is blue and yellowish)
cyberbeing is offline
Old 31st May 2007, 22:37   #292  |  Link
vortex_hl
look at your WMR9 color tunings. seems hue value <> 0.
vortex_hl is offline
Old 31st May 2007, 22:44   #293  |  Link
skafidask
thanks for the release i will try it out as soon as i can.
Any luck on the dxva 2.0 thing and EVR custom because on the previous version it was not working.
skafidask is offline
Old 31st May 2007, 22:59   #294  |  Link
Casimir666
Not fixed yet
Tired of tearing?
Old 31st May 2007, 23:08   #295  |  Link
Sirber
retired developer
Sirber's Avatar
about still say 1.0.7.0
Detritus Software
Sirber is offline
Old 31st May 2007, 23:29   #296  |  Link
cyberbeing
Broadband Junkie
This only seems to happen with Casimir666's build when YUV Mixing is enabled. If I disable YUV mixing everything is fine.
Now its showing up as B&W with YUV mixing enabled...
Edit: I did some further testing and it seems the bug was introduced in 1.0.7.0 because 1.0.6.0 is fine.
Edit2: It seems if I use the mplayerc.ini from mplayerc_homecinema_v1.0.6.0.zip with 1.0.8.0 I don't have the problem. The mplayerc.ini from 1.0.7.0 results in blue and yellow colors. For 1.0.8.0 which doesn't have an mplayerc.ini bundled with it the picture is black and white.
Old 31st May 2007, 23:38   #297  |  Link
JarrettH
What is YUV mixing for? the M$ page just seemed to describe it as something that would benefit old cards with low amounts of memory.
JarrettH is offline
Old 31st May 2007, 23:52   #298  |  Link
Sirber
retired developer
Sirber's Avatar
maybe VMR9 is usualy doing a conversion to RGB...
Detritus Software
Sirber is offline
Old 1st June 2007, 07:21   #299  |  Link
CruNcher
CruNcher's Avatar
By the way i went from powerdvd 7.3.2605 to 7.3.2911 and i got black screen on all players(powerdvd,wmp 11,mpc,zoom) using cyberlink decoder and dxva 2.0 and i went back to 2605 anybody else having the same problem??
See here for info
http://forum.doom9.org/showthread.php?t=124945
@Casimir666
Do you have any idea why the video is stoping for a milisecond (micro lag) when opening the OSD Slidebar (same for MPC's normal Slidebar) ?
It is about Time
CruNcher is offline
Old 1st June 2007, 13:52   #300  |  Link
iron2000
Questioning User
Why is it d3dx9_29.dll?
What if I put d3dx9_31.dll?
If not there it will automatically look in the system folder?
iron2000 is offline
dxva, h264, home cinema, media player classic, mpc-hc
