14th November 2009, 12:23 | #10461 | Link | |
BTW guys, congratulations on releasing a leet build 1337 |
14th November 2009, 15:33 | #10462 | Link |
>>^^__^^<<
Ok, got some free time to make bugreport
MPC HC doesn't show subtitles on some BD (Ip Man in my case) File info Code:
General ID : 1 Complete name : H:\New\Ip.Man.2008.1080p.H264.Remux\BDMV\STREAM\00001.m2ts Format : BDAV Format/Info : Blu-ray Video File size : 22.0 GiB Duration : 1h 46mn Overall bit rate : 29.6 Mbps Maximum Overall bit rate : 35.5 Mbps Video ID : 4113 (0x1011) Menu ID : 1 (0x1) Format : AVC Format/Info : Advanced Video Codec Format profile : High@L4.1 Format settings, CABAC : Yes Format settings, ReFrames : 4 frames Duration : 1h 46mn Width : 1 920 pixels Height : 1 080 pixels Display aspect ratio : 16:9 Frame rate : 24.000 fps Resolution : 24 bits Colorimetry : 4:2:0 Scan type : Progressive Color primaries : BT.709-5, BT.1361, IEC 61966-2-4, SMPTE RP177 Transfer characteristics : BT.709-5, BT.1361 Matrix coefficients : BT.709-5, BT.1361, IEC 61966-2-4 709, SMPTE RP177 Audio #1 ID : 4352 (0x1100) Menu ID : 1 (0x1) Format : AC-3 Format/Info : Audio Coding 3 Duration : 1h 46mn Bit rate mode : Constant Bit rate : 384 Kbps Channel(s) : 6 channels Channel positions : Front: L C R, Surround: L R, LFE Sampling rate : 48.0 KHz Stream size : 292 MiB (1%) Language : Russian / / Audio #2 ID : 4353 (0x1101) Menu ID : 1 (0x1) Format : DTS Format/Info : Digital Theater Systems Format profile : MA Duration : 1h 46mn Bit rate mode : Variable Channel(s) : 8 channels Channel positions : Front: L C R, Surround: L C C R, LFE Sampling rate : 48.0 KHz Resolution : 16 bits Language : Chinese / / Text #1 ID : 4608 (0x1200) Menu ID : 1 (0x1) Format : PGS Language : English / / Text #2 ID : 4609 (0x1201) Menu ID : 1 (0x1) Format : PGS Language : Chinese / / Internal splitter also doesn't help and it's behavior depends on revision: 1) b1249 detects all subtitle streams right, but doesn't show 2) b1326 incorrectly detects language of secondary stream 3) b1337 doesn't detect subtitle streams at all Bug exists independent on opening m2ts file, index.bdmv or "Open DVD" With PowerDVD subtitles shows fine |
14th November 2009, 17:07 | #10463 | Link |
Hi there guys!
MPC-HC is crashing with Intel GMA500 graphics chipset when trying to play any video using EVR-CP in Windows 7. I would like to help you by providing you with minidumps but I'm not finding them. I've confirmed this behavior in several laptops using this chipset with Windows 7 (latest drivers). |
14th November 2009, 18:48 | #10464 | Link |
Feature Request: Smart-Stretch Shader
Would it be possible to add a shader that "smart-stretches" 4:3 media content to 16:9 similar to the way that PowerDVD does for DVD material, ie, where the center 1/3 of the image remains mostly undistorted, and the bulk of the stretching is done in the outer thirds, more towards the edges of the video frame? Kind of like projecting the image onto a cylinder...
Cheers, The REAL Joe Last edited by therealjoeblow; 14th November 2009 at 20:26. |
14th November 2009, 19:42 | #10465 | Link |
http://mpc-hc.svn.sourceforge.net/vi...7&pathrev=1338
Wouldn't it be more appropriate if the stream names were "MPEG-2" instead of "MPEG 2", "H.264" instead of "H264", "Secondary DTS-HD High Resolution Audio" instead of "Secondary DTS HD High Resolution Audio", and "VC-1" instead of "VC1?" |
14th November 2009, 19:52 | #10466 | Link | |
MPC-HC Project Manager
https://sourceforge.net/apps/trac/mpc-hc/newticket
MPC-HC, an open source project everyone can improve. Want to help? Test Nightly Builds, submit patches or bugs and chat on IRC |
14th November 2009, 21:36 | #10468 | Link | |
15th November 2009, 03:59 | #10469 | Link |
tetsuo55:
do you think it would be a worthy feature is there was a method to override a sub style with default? I know the styles can be edited on-the-fly, but if you want to revert a style to one's default choice, you have to adjust font, scaling, several colours, outline/shadow size etc. An "override" button in that tabsheet would be handy, imo. I'm so annoyed by some "creativity" styles that I quite so often just override them manually. |
15th November 2009, 09:04 | #10470 | Link | |
You can add it to the tracker, but we have no coders who want to work on adding this right now.
15th November 2009, 14:22 | #10473 | Link |
wishilist:
1. update ogglib in ogg Directshow splitter to support more formats: like Kate stream. 2. add Kate format subtitle support to subtitle render engine. Then mpc-hc can completely support new version of ogv format. This format is totally free and theora, vorbis and kate are patent free codecs. Right now only VLC can support its subtitle. |
16th November 2009, 00:29 | #10474 | Link |
i have run mpc-hc through the microsoft application verifier and it fails quite a few tests.
This is a call to all coders, please help us fix the crashes and memory leaks. the verifier can be downloaded here: http://www.microsoft.com/downloads/d...DisplayLang=en The tests that give errors and cause crashes are: Handles, Heaps, locks, low resource, LuaPriv and DangerousAPi the goal should be to have an error free (and warning free) result with all tests enabled. --------------- EDIT: Also /SAFESEH fails to complete, some precompiled parts need to be recompiled with vs2008 with the /SAFESEH switch before MPC-HC itself can be compiled with it --------------- EDIT2: /DYNAMICBASE, /NXCOMPAT should be added by default (and /SAFESEH once that has been fixed) Also /RTC1, /Od can be used to find out more about the memory leaks/crashes and if you happen to have a enterprise version of vs2008 /analyse will give even more info ----------- EDIT3: Some data: On my systems: about 80% of allocated ram is unused/leaked by mpc-hc mpc-hc leaks 4kb/s during playback during playback 200MB+ of pagefile is allocated and heavily used (many pagefaults) Cleaned with no movie mpc-hc only uses 700kb of ram, uncleaned it uses 13MB and with a movie the lowest i've seen is 40MB(18MB cleaned)
MPC-HC, an open source project everyone can improve. Want to help? Test Nightly Builds, submit patches or bugs and chat on IRC Last edited by tetsuo55; 16th November 2009 at 00:37. |
16th November 2009, 03:41 | #10476 | Link |
tetsuo55,
Have you read my report in post 10489 of this thread? Please let me know how I can help you solving this problem. Thanks |
16th November 2009, 08:56 | #10479 | Link | |
16th November 2009, 14:11 | #10480 | Link | |
4:2:0 hater
Error 2 error C2065: 'MEDIASUBTYPE_DVB_SUBTITLES' : undeclared identifier SubtitleInputPin.cpp 68 |
dxva, h264, home cinema, media player classic, mpc-hc |
