3rd February 2010, 17:26 | #6781 | Link |
You have to mount it (e.g. with Daemon Tools) if it is an ISO and then point BD-RB to the mounted drive. Even better, instead of ripping to an ISO, simplly copy the BDMV and CERTIFICATE folders to a folder on your hard drive (named after the disc). Then you can point to that with BD-RB.
3rd February 2010, 19:17 | #6782 | Link |
Hello,
I have the configuration set like in the first post of this thread. I wanted to rebuild a BD (decrypted by DVDFab who can select only one sound track but only in "movie only" mode) by just suppress one of the 2 audio tracks of my BD "drag me to hell" (french version). After the workaround for my previous bug (see previous post) i have now another bug after a few hours of reencoding : "x264.exe has stopped working" window (i am on windows 7). This caused BD Rebuilder to freeze.. But i guess you will say me it is not a BD Rebuilder bug.. btw i don't know why "FFMPeg encoder" is grey : i have ffdshow 3128. Last edited by AntonyDu92; 3rd February 2010 at 19:37. |
3rd February 2010, 19:34 | #6783 | Link | ||
Maybe the bug came from my check of "limit to one track for each language" in BD-RB whereas i, after, selected 2 tracks for the VID_00002. Quote:
the box for "do not convert DTS to AC3" is checked, the box "do not reencode AC3" is checked, the box "Keep HD audio for BD25 encoding" is checked. And nothing is checked in "video encoding options". What else ? Is this because i selected target size BD-25 (and not custom size) ? BD-RB itself automaticaly filled a "custom target size" to 23450Megabytes [Options] MODE=0 TARGET_SIZE=23000 AUDIO_TO_KEEP=eng; SUBS_TO_KEEP=all SD_CONVERT=0 COLOR_BOOST=0 RESIZE_1080=0 DTS_REENCODE=0 AC3_REENCODE=0 AC3_640=1 KEEP_HD_AUDIO=1 AVCHD=1 REMOVE_WORKFILES=1 AUDIO_TRACK_LIMIT=1 SUBTITLE_TRACK_LIMIT=1 ENCODER=0 Last edited by AntonyDu92; 4th February 2010 at 09:07. |
3rd February 2010, 20:10 | #6784 | Link |
Hello peeps,
simple question (maybe already answered but its too long to read all..) is there any way to tell BD-RB to not touch the original video at all? since i have a couple BD that are just slighty over the BD25 size, so i could just remove some not needed languages to make them fit on my blank disks. Tia Anac EDIT: Nevermind, i just saw that the software automagically knows what to do Last edited by Anacletus; 3rd February 2010 at 20:31. |
3rd February 2010, 23:25 | #6785 | Link | |
4th February 2010, 18:34 | #6786 | Link |
Hello,
I've used make MKV and multiAVCHD to make a movie only Blu-Ray structure, which works correctly, and now I'd like to use BD Rebuilder to make it fit on a BD-25 disc. My Blu-Ray reauthored with multiAVCHD is very simple: one playlist, and one 27GB M2TS. When I start BD Rebuilder on this structure, it fails with the following output : [17:57:03] BD Rebuilder v0.31.06 (beta) - Source: AVCHD - Input BD size: 26,88 GB - Approximate total content: [02:32:52.159] - Target BD size: 22,46 GB - Windows Version: 6.1 [7600] - MOVIE-ONLY mode enabled - Audio Settings: AC3=0 DTS=0 HD=1 Kbs=448 - Resuming from previously started job. [17:57:05] PHASE ONE, Encoding - [17:57:05] Reencoding: VID_00000 (1 of 1) - [17:57:05] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 219.912 frames - Bitrate: 17.077 Kbs - [17:57:05] Reencoding: VID_00000, Pass 1 of 2 - Encode failed. Retrying. - Encode failed. Retrying. - Reached retry limit. Aborting. - FFDSHOW Revision: (3207) [17:57:09] - Failed video encode, aborted I've looked in the destination folder. The generated AVS doesn't play the m2ts. I've been to #avisynth on irc.freenode.net where I've been told to install AviSynth plugin FFMpegSource2 http://code.google.com/p/ffmpegsource/. With this plugin the video is simply loaded by the code : FFMpegSource2("C:\BUFFER\MKV\AVCHD\BDMV\STREAM\00000.m2ts") (Unfortunately I couldn't verify if my idea would work with BD Rebuilder because when it resumes from a previous job, the AVS is overwritten, and if you protect the file from writing, job is canceled :/) |
4th February 2010, 19:41 | #6787 | Link | |
cwh |
4th February 2010, 20:47 | #6788 | Link |
@shiva-x
Hi! Try the following, VERY similar (and always successful) procedure that I've used literally dozens of times: 1) Use MakeMKV to both rip your original BluRay disc and create a "movie-only" .MKV from the primary title (exclude the subtitles) 2) Load/Drag and Drop the MKV into tsMuxeR GUI, click on the "BluRay" radiobutton in the "Output" section - and click on the "Start muxing" radiobutton |
4th February 2010, 20:59 | #6789 | Link | |
I've found a "hack" to make BD Rebuilder start processing with my custom AVS which uses FFMpegSource2 : Open a Command prompt (cmd.exe) in your working directory - Let BD Rebuilder fail once with its own AVS script - Type copy /y <yourCustomAVSUsingFFMPegSource2> (DO NOT TYPE RETURN !!!!) - When BD Rebuilder asks you if you want to retry encoding the Blu-Ray because the folder is not empty, click yes but you'll have to be quick because it will write VID_00000.AVS which you don't want. So quickly click on your cmd window and press RETURN. I've done that and finally BD Rebuilder started to process my disc . |
4th February 2010, 21:07 | #6790 | Link |
@ ---shiva-x
QUOTE: Hello, I've used make MKV and multiAVCHD to make a movie only Blu-Ray structure, which works correctly, and now I'd like to use BD Rebuilder to make it fit on a BD-25 disc. My Blu-Ray reauthored with multiAVCHD is very simple: one playlist, and one 27GB M2TS. When I start BD Rebuilder on this structure, it fails with the following output : [17:57:03] BD Rebuilder v0.31.06 (beta) - Source: AVCHD - Input BD size: 26,88 GB - Approximate total content: [02:32:52.159] - Target BD size: 22,46 GB - Windows Version: 6.1 [7600] - MOVIE-ONLY mode enabled - Audio Settings: AC3=0 DTS=0 HD=1 Kbs=448 - Resuming from previously started job. I have been using multiAVCHD also and I noticed that you are trying to create a " MOVIE ONLY " disk. If you want to create the MENU and then use BD_Rebuilder you need to create an "AVCHD" disk and then use BD_Rebuilder to compress the output as a "FULL" disk backup and leave everything intact. I have lots of luck using "CLOWN_BD": as frontend to remove all the "EXTRA STUFF" leaving just the movie and audio tracks I want and then using multiAVCHD to make custom "MENU" and compress with BD_Rebuilder. Lots of steps but turns out good results when you have episodic disks like Band of Brothers. |
4th February 2010, 21:46 | #6791 | Link |
@worknstuff
My goal is to make a movie only disc. I've used MakeMKV to extract main movie, then multiAVCHD to recreate a BD structure, now I want to recompress it. I'm just trying to make BD rebuilder not crash when I make a main movie only rip, which is always what I'm interested in. I'm now wondering if those multiAVCHD steps are not useless now that I'm using FFMpegSource2 but I'm just experimenting . Edit: I meant for this Blu-Ray, main movie backup crashed and full backup crashed too so I'm trying alternate methods. Last edited by shiva-x; 4th February 2010 at 21:48. |
5th February 2010, 06:26 | #6794 | Link | |
Any help or suggestions would be much appreciated.. |
5th February 2010, 16:32 | #6795 | Link | ||
Make MKV may work fine, as might DVDFab HD, but AnyDVD HD is and has been the most consistent and reliable ripper. BD-RB is designed to work on a full disc rip, which can than be converted to a movie only or a full backup, but the original structure is the source to work with. Any other method is preprocessing. I have done other methods myself, but do not and will not report a bug from the results, nor should it be reported here in this thread. There are other methods to get movie only backups, but I think this thread should respect the wishes and demands of the software developer! |
5th February 2010, 22:11 | #6796 | Link |
@Capsbackup
I am well aware of the purpose of this thread - and my (useful) response to "shiva-x" (about tools specifically used by "shiva-x") would, hopefully, result in the end of postings mistakenly made to this thread about this by "shiva-x" ;>} |
6th February 2010, 02:02 | #6797 | Link |
@jdobbs
I just encountered odd behavior with v.0.31.06 that is quite similar (if not identical)to what I believe was twice previously reported: I had BD-RB processing "Amelia" (movie-only) while I was surfing. I also had two windows open in Explorer. BD-RB was minimized. As soon as BD-RB reached 100% (but not totally finished), the mouse ceased functioning. I left the machine for about three minutes and returned to find that everything was fine - mouse okay, Explorer windows okay, and BD-RB had completed its task. Any thoughts? |
6th February 2010, 03:44 | #6798 | Link | |
2. FFMPEG is not the same thing as FFDSHOW. Ignore the greyed out choice. 3. Most of the time if you see that error it is a system instability. Are you overclocked? Last edited by jdobbs; 6th February 2010 at 04:25. |
6th February 2010, 03:47 | #6799 | Link | |
6th February 2010, 04:02 | #6800 | Link | |
And BDRB is working fine on that dirive now, BTW. I just reinstalled BDRD over what was there and tried it for the hell of it before I reinstalled Vista. It just started working fine. I've got no clue what the problem could have been. |
