Old 4th February 2010, 16:56   #4181  |  Link
cwh060
Good news bad news!
Good News - The full files processed properly in XMB menu, the project went through to the end in 8mins <=excellent. Log attached.
Bad News - PS3 playback. The motion menu starts then freezes (title 1). It plays back about 1/2 sec then stops, navigation seems to work fine. Moving to the next title 2, the playback starts for 1/2 sec, then screen goes to black. The navigation (blue highlight) is the only thing on the screen.
cwh
Must have been typing when your last RC candidate was release, I will try agin using XMB again.
cwh060 is offline   Reply With Quote
Old 4th February 2010, 17:01   #4182  |  Link
deank
Programmer (or just 教务长)
deank's Avatar
Please post your log in your message, otherwise it needs a moderator to approve the attachment.
Still I can't replicate your troubles. I have encoded more than 50 compilations with motion menu and all work fine.
It is something related to the encoding process with x264 and avisynth.
Old 4th February 2010, 17:11   #4183  |  Link
cwh060
Here is the log, everything looks fine to me.
I have the most recent version of x264 from your earlier posts. I can replace again, if we think it will help. Everything works fine with Static menu and partially works with XMB motion menu. I'll snap a pic.
[10:17:47] Initialising...
[10:17:47] Checking for new version...
[10:17:47] You have the latest build.
[10:17:47] Consistency check finished!
[10:17:47] Initialization finished. multiAVCHD is ready!
[10:17:47] 1 year and 40 days since multiAVCHD was published.
[10:17:47] Support multiAVCHD to extend its features and keep it going!
[10:17:47] multiAVCHD.dat version: [03010730]
[10:22:19] Checking for available space and drive types (FAT32/NTFS)...
[10:22:20] Destination [F:]: NTFS, 657120.79 MiB (641.72 GiB) free space
[10:22:20] Temp folder [C:]: NTFS, 355114.19 MiB (346.791 GiB) free space
[10:22:20] Log started for multiAVCHD v3.1 (build 730)
[10:22:20] Selected output mode: Playstation 3 (USB/SDHC/MS)
[10:22:20] Processing 2 titles...
[10:22:20] Processing (H:\Movies\CyberLink Projects\Dexter\Dexter-(Hello, Dexter Morgan)-2009-12-06-0.ts)...
[10:22:21] Detected frame reference count: 4 (max:4).
[10:22:21] Detected video: ID#4113:V_MPEG4/ISO/AVC 1920x1080, fps=29.970, ref=4
[10:22:21] Adding AC3 audio track (ID#4352)
[10:22:21] Total of 2 tracks found in this file.
[10:22:21] Creating clip and playlist info (tsMuxeR)...
[10:22:21] Media split set at 4000MiB point...
        tsMuxeR (Version 1.10.6) output:
Decoding H264 stream (track 1): Profile: Main@4.0  Resolution: 1920:1080i  Frame rate: 29.97
H.264 stream does not contain fps field. Muxing fps=29.97
Decoding AC3 stream (track 2): Bitrate: 384Kbps Sample Rate: 48KHz Channels: 6
B-pyramid level 2 detected. Shift DTS to 3 frames
H264 bitstream changed: insert SPS/PPS units
Processed 91872 video frames
Creation of Blu-ray playlist
Creation of Blu-ray stream info and seek index
Mux successful complete.
Muxing time: 2 min 58 sec
        tsMuxeR meta:
MUXOPT --no-pcr-on-video-pid --new-audio-pes --blu-ray --vbr  --custom-chapters=00:00:00.000;00:17:01.666;00:34:03.333;00:51:04.000  --split-size=4000MiB  --vbv-len=500
V_MPEG4/ISO/AVC, "H:\Movies\CyberLink Projects\Dexter\Dexter-(Hello, Dexter Morgan)-2009-12-06-0.ts", insertSEI, contSPS, track=4113, fps=29.970
A_AC3, "H:\Movies\CyberLink Projects\Dexter\Dexter-(Hello, Dexter Morgan)-2009-12-06-0.ts", track=4352, lang=eng, timeshift=0ms
[10:24:51] Setting resolution (1080i).
[10:24:51] Media transfer: 00000 -> 00000.m2ts
[10:25:38] Media transfer: 00001 -> 00001.m2ts
[10:25:39] Processing playlist...
[10:25:39] Title #1 added: "Hello, Dexter Morgan"
[10:25:39] Verifying title...
[10:25:44] Title has: 1 audio tracks and 0 subtitle tracks
[10:25:44] Processing (H:\Movies\CyberLink Projects\Dexter\Dexter-(The Getaway)-2009-12-13-0.ts)...
[10:25:45] Detected frame reference count: 4 (max:4).
[10:25:45] Detected video: ID#4113:V_MPEG4/ISO/AVC 1920x1080, fps=29.970, ref=4
[10:25:45] Adding AC3 audio track (ID#4352)
[10:25:45] Total of 2 tracks found in this file.
[10:25:45] Creating clip and playlist info (tsMuxeR)...
[10:25:45] Media split set at 4000MiB point...
Processed 95917 video frames
Muxing time: 2 min 43 sec
        tsMuxeR meta:
MUXOPT --no-pcr-on-video-pid --new-audio-pes --blu-ray --vbr  --custom-chapters=00:00:00.000;00:17:46.666;00:35:33.333;00:53:19.000  --split-size=4000MiB  --vbv-len=500
V_MPEG4/ISO/AVC, "H:\Movies\CyberLink Projects\Dexter\Dexter-(The Getaway)-2009-12-13-0.ts", insertSEI, contSPS, track=4113, fps=29.970
A_AC3, "H:\Movies\CyberLink Projects\Dexter\Dexter-(The Getaway)-2009-12-13-0.ts", track=4352, lang=eng, timeshift=0ms
[10:28:03] Setting resolution (1080i).
[10:28:03] Media transfer: 00000 -> 00002.m2ts
[10:28:53] Media transfer: 00001 -> 00003.m2ts
[10:28:56] Processing playlist...
[10:28:56] Title #2 added: "The Getaway"
[10:28:56] Verifying title...
[10:29:01] Title has: 1 audio tracks and 0 subtitle tracks
[10:29:01] Preparing authoring information...
[10:29:01] Creating NTSC top menu.
[10:29:01] Setting pop-up menu...
[10:29:02] *** [00000.mpls] - Adding pop-up menu...
[10:29:02] *** [00001.mpls] - Adding pop-up menu...
[10:29:02] *** Completed!
[10:29:02] Authoring menu (NTSC).
[10:29:04] Creating title thumbnails for 2 titles (XMB)...
[10:29:09] Using 4 thumbnail/chapter links for title #1...
[10:29:09]  *** Extracting 4 chapter thumbnails...
[10:29:19] Using 4 thumbnail/chapter links for title #2...
[10:29:19]  *** Extracting 4 chapter thumbnails...
[10:29:23] Image processing for XMB menu completed!
[10:29:23] Preparing menu pages...
[10:29:23] Encoding motion XMB menu page [1/2].
[10:29:40] Encoding motion XMB menu page [1/2]: Chapter page [1/1].
[10:29:45] Encoding motion XMB menu page [2/2].
[10:30:06] Encoding motion XMB menu page [2/2]: Chapter page [1/1].
[10:30:11] Menu authoring completed.
[10:30:12] Encoding Title List menu page [1/1].
[10:30:16] Setting main menu for 2 titles...
[10:30:16] Playback will end after title #2.
[10:30:16] Setting menu properties...
[10:30:16] Selected TV system: [NTSC]
[10:30:16] Processing clip (CPI/CLPI) files...
[10:30:17] Completed.
[10:30:19] Setting FAT compatible 8.3 filenames...
[10:30:19] Done!
[10:30:20] Saving multiAVCHD quick-load project (mpf):
[10:30:20] F:\multiOutput\AVCHD\multiAVCHD.mpf (OK!)
        Compilation summary:
        Format: Playstation 3 (USB/SDHC/MS)
        1. Hello, Dexter Morgan                     [00:51:05]
        2. The Getaway                              [00:53:20]
        Overall duration : 01:44:25
        Output size      : 8300 MiB (8.105 GiB)
[10:30:20] F:\multiOutput\AVCHD folder created (AVCHD/Blu-ray output)!
[10:30:20] Copy F:\multiOutput\AVCHD to root of USB stick/disk or MemoryStick card or to X:\PRIVATE\ of SDHC/SD/MMC card and rename to AVCHD!
[10:30:20] You may now remove temp folder (C:\Program Files (x86)\multiAVCHD\_TEMP\multiTEMP-20100204\).
[10:30:20] Your compilation contains 1hrs 44min 25sec of video material.
[10:30:20] multiAVCHD finished in 480 seconds (00:08:00)!
[10:30:20] End of log.
I can try blu ray output, it just takes forever to create and burn to BR.
Old 4th February 2010, 17:19   #4184  |  Link
deank
deank's Avatar
You log shows that menu encoding is done in 20 seconds, which is impossible. I'll test now again to see if I broke something.
Old 4th February 2010, 17:39   #4185  |  Link
rack04
Are the x/y positions on the menu tab for "Play" "Setup" "Chapters" and "Title List" backwards? "Setup" "Chapters" and "Title List" should have the same y but different x values.
EDIT: I see how these values can be true with XMB menu. I was specifically referring to Carousel menu.
rack04 is offline   Reply With Quote
Old 4th February 2010, 18:09   #4186  |  Link
deank
deank's Avatar
I don't understand your question... These are just coordinates - put whatever you want. To use the values you entered, enable [x] Apply button positions settings option.
Old 4th February 2010, 18:12   #4187  |  Link
Music Fan
Have in mind that the pop-up is 1920x1080, so it won't show if your video is 1280x720 or 720x....
Even if the resolution is set to 1080p in the player's setup ?
Music Fan is offline   Reply With Quote
Old 4th February 2010, 18:18   #4188  |  Link
deank
deank's Avatar
I don't know ALL players. PS3 will switch to 720p and it is not visible. Anyway, I prepared 720p pop-up menu to be used with 1280x720p titles, so it will be okay.
Old 4th February 2010, 18:43   #4189  |  Link
Music Fan
And what happens if we put 720p videos and 1080p videos on the same disc ?
I ask it because I guess there is one pop-menu resolution by disc.
Do you mean that the PS3 doesn't let you the choice of the resolution and that you cannot upscale 720p to 1080p ?
If yes, a test would be nice to know if the pop-menu appears when you set the resolution to 1080p.
Old 4th February 2010, 18:45   #4190  |  Link
deank
deank's Avatar
No.. there are 2 (or three if I make one for 480i/576i).
I just tested it with 2 titles 1920x1080 and 1280x720 - each uses its own pop-up (although they look the same) and both show okay
Old 4th February 2010, 18:56   #4191  |  Link
Music Fan
Cool, amazing !
I edited my message after your response, there is another question.
But after what you said, I guess that even if the resolution is set to 1080p in the setup, the 720p video will automatically "call" the 720p pop-up menu which will be upscaled in 1080p by the player.
But it's not easy to say if both pop-up menu resolutions are on the disc.
Old 4th February 2010, 19:00   #4192  |  Link
deank
deank's Avatar
I prefer writing the code for multiAVCHD than speculating what a player would do. I know what PS3 does and it is enough for me. Either way the pop-up will be visible.
When I find a user to test and report the result I'll know more.
Old 4th February 2010, 19:02   #4193  |  Link
Music Fan
Unless there is a difference between the different pop-up menues. For example, its resolution written discretely on it.
A pop-up menu for 480/576 resolutions is a good idea.
Old 4th February 2010, 19:10   #4194  |  Link
deank
deank's Avatar
Of course there is a difference... it is not just x/y and width/height - the whole image for the pop-up is RLE encoded to fit the screen.
Old 4th February 2010, 19:22   #4195  |  Link
Music Fan
Stay coooool.
I don't understand this reaction, my question is logical because many people use MultiAVCHD to make compilations with different resolutions.
And it was only the continuation of my previous question that you answered nicely.
As you said earlier, you chose to make a free program with donation system to stay free and also (I guess) to stay closer of the users who help you to make it evolve.
Thus, don't be astonished if we make suggestions and if we dare you ask some (punctilious) questions, especially if it concerns a new possibility of your program.
I'm not programer and i'm not supposed to know what you know about your program.
Old 4th February 2010, 19:27   #4196  |  Link
Music Fan
I meant a visible difference, just to know if we are looking at the 720p pop-up menu upscaled in 1080p when we look at a 720p video on a player set on 1080p.
But it's not important, I'm maybe too curious ...
Old 4th February 2010, 19:35   #4197  |  Link
deank
deank's Avatar
You misinterpreted the tone of my message I guess
Still, I'll repeat that I have no answer to your question since I can't test what you ask for. If you can - do it and you will know (and then I will know).
I'm not even sure if Blu-ray players will up-scale 1280x720 to 1920x1080. Most probably they will switch HDMI to 720p (which is the correct thing to do).
As I said, I don't mind your questions, but I have another 20 like yours and I have no one to ask for an answer.
Old 4th February 2010, 19:37   #4198  |  Link
crl2007
I think you like to ask unnecessary questions. The man already said that each resolution has its own pop-up, not upscaled, not downscaled. It is not a studio software, to create a menu from scratch with given elements, all is preset.
l.e. "Most probably they will switch HDMI to 720p (which is the correct thing to do)." - deank put it a whole lot better that I would have.
crl2007 is offline   Reply With Quote
Old 4th February 2010, 19:42   #4199  |  Link
DLynch
Hi Dean,
I've been testing static XMB menus so far on a Sony BDP-S350.
Navigation on the main menu works fine. The chapter menus are a nice addition as is the background sound. Let me know when the user defined option is available.
The pop-up menu appears even though I am using 720p video.
I had a list of pop-up menu problems with Chapters/Title List and Title Menu not working but your last RC appears to have fixed that.
The only issue I now see with the Previous and Next title buttons is that it cycles through the main menu also. For example, if you are on the first title and select previous title, you are sent to the main menu. If you are on the last title and select next title, you are again sent to the main menu.
I'll see how the motion menus are working next. I had some compilation problems last night.
Keep up the excellent work!
DLynch is offline   Reply With Quote
Old 4th February 2010, 19:53   #4200  |  Link
cwh060
dean,
I can report the blank screen is now gone with the latest release candidate. The 1/2sec motion menu is still evident.
[11:42:41] Preparing menu pages...
[11:42:41] Encoding motion XMB menu page [1/2].
[11:42:55] Encoding motion XMB menu page [1/2]: Chapter page [1/1].
[11:43:00] Encoding motion XMB menu page [2/2].
[11:43:09] Encoding motion XMB menu page [2/2]: Chapter page [1/1].
[11:43:13] Menu authoring completed.
As you stated, the menu is not taking long enough to create, it's still the same with this rc.
The pop up menu is a cool additon on PS3!
cwh
avchd, blu-ray hd-dvd, mkv, multiavchd, re-author
