26th March 2010, 20:17 | #5003 | Link |
Hi dean, Ik have a question, alot of sony blu ray players only work with BD-RE if they are made with the sony program "Click to Disc", since it is a software issue then, is there a away you can implent something to make it work for those players? since the software, Click to disc is only available for sony Vaio computers, many thanks
beatnut |
26th March 2010, 22:20 | #5006 | Link |
I was able to fix the detecting avisynth, ffdshow, haali problems I had by rebooting after removing/installing multiavchd. I'm able to encode now directly from a read only source, thanks.
I noticed that the first 30 or so minutes was spent moving the 35 GB m2ts file from read only to temp directory, is this necessary? Also I chose to keep subs but they weren't kept in the DVD output, I remember in the past multiavchd had problems finding java.exe for bdsup2sub.jar on 64 bit systems, could this still be the issue? This is what the log says: [15:37:46] Detected video: ID#0:V_MPEG-2 720x480, fps=23.976 [15:37:46] Display properties: 853x480 (AR:1.78) [15:37:46] DTS-HRA, DTS-MA will not be reencoded. [15:37:46] Encoding [DTS] audio to AC3... [15:37:54] Retrying... [15:48:35] Adding AC3 encoded audio track (eng)... [15:48:35] Detected subtitles: ID#4608:S_HDMV/PGS Language: eng [15:48:35] Detected subtitles: ID#4609:S_HDMV/PGS Language: spa [15:48:35] Detected subtitles: ID#4610:S_HDMV/PGS Language: eng [15:48:35] Detected subtitles: ID#4611:S_HDMV/PGS Language: spa [15:48:35] Total of 2 tracks found in this file. [15:48:36] Creating SD-DVD structure... [15:48:36] Applying pulldown... [15:56:39] Authoring DVD structure... [16:00:48] SD-DVD muxing completed! I agree BD -> DVD is excellent quality, better then the retail DVD of the same movie. I've been doing this for quite a while now but it's a tedious task, this makes it incredibly easier however I need the ability to keep english subs. |
26th March 2010, 22:45 | #5007 | Link | |
Programmer (or just 教务长)
My note few pages back about SD-DVD and subtitles mentioned that only external subtitles are supported (and internal when using files as sources).
When using playlists/BDMV-structures you'll need to have your subtitles prepared before you start the compilation. Extract the SUP/PGS and add it as an external subtitle track. It will be properly resized to DVD resolution and will be present in the DVD. One subtitle track supported anyway. Dean p.s. Quote:
2/ SD-DVD is 1-week-old feature in multiAVCHD with a lot of restrictions. I'll try to add subtitle support for (internal) Blu-ray playlist subtitles and probably more than one audio/subtitle track per SD-DVD title and less-probably multi-title support for SD-DVD. I just need more time, that's it. Last edited by deank; 26th March 2010 at 23:04. |
27th March 2010, 07:30 | #5008 | Link |
@deank
Since other means of communication with you (at least by me) continue to be unsuccessful, I'll simply post the following, unedited: I see that you've now added conversion (of just about anything ;>}) to standard DVD. Other than branching off into other Operating Systems, I for one, can't think of anything else you could conceivably add (But somehow, I'm sure you will anyway). Therefore, I want to suggest to you that the multiAVCHD "package" has become rather weighty - and, perhaps somewhat foreboding in appearance and operation to those who may have just come to discover this remarkably efficient yet complex tool. My quick suggestion is to modify the interface so that it appears as a tabbed notebook or looseleaf binder, with each tab representing one of the primary functions - and clicking on a tab would "turn the pages" to the proper input pages supported, if necessary, by sub-tabs. Your thoughts please? |
27th March 2010, 08:53 | #5009 | Link | |||
Fighting spam with a fish
Okay, my first guide for using multiAVCHD to encode from Blu-ray to DVD has been published! Check it out here: http://adubvideo.net/how-to/converti...dvd-multiavchd
Edit: Okay, well, it seems like the third time was not the charm. I turned on the TrueHD/DTS-MA/HRA to option and the Convert DTS audio to AC3 option, and it appears that eac3to did not like that one bit. Overall multiAVCHD log: Quote:
-TrueHD / DTS-MA... option Quote:
-Second attempt by multiAVCHD: Quote:
Last but not least, the following deadlock appeared to occur within eac3to: This was at the last resort tried by multiAVCHD and for some reason, as soon as it recognizes it needs a second pass, eac3to just stops working, with no detectable CPU usage. Last edited by Adub; 27th March 2010 at 10:13. |
27th March 2010, 11:07 | #5010 | Link | ||
*** Few fixes: * Bitrate estimations for HD and SD DVD will take into account only the 1st audio track and will calculate proper estimation * In case SD-DVD mux fails with muxman, the log is printed and pop-up will ask you to edit the job file (muxman.job) with notepad, fix what may be wrong and let multiAVCHD retry with these changes. * Transcoding will show estimated time-of-the-day (HH:MM:SS) when it is supposed to finish... |
27th March 2010, 16:00 | #5011 | Link | |
Aging Video Hobbyist
I'm still confused though about handling subtitles: 1. Not sure what "hardsubbing" means, i.e. I thought that was when you encoded subtitles into the video itself (where they are part of the video and can't be turned on/off)? Could you explain in your tut. 2. Also deank has said that BD subs must be imported as "external" or some such. If you can clarify what that means (and how to pre-process BD subs if necessary) that would help me as I remain confused about this after several failed attempts. Thanks again! |
27th March 2010, 16:09 | #5012 | Link |
I'll add support for BD subtitles but may be tomorrow or next week.
At the moment you need to open the m2ts file (or the playlist) of the main movie with tsMuxeR_GUI and *demux* the subtitle track you need. Then in [title properties] there is [External subtitles] tab - you add your demuxed .SUP file there. Hard-subbing is exactly what you think - encode the subtitles in the video, so no on/off function. Dean |
27th March 2010, 17:05 | #5013 | Link | |
27th March 2010, 17:10 | #5014 | Link |
I'm currently running an encode of my Ghost Rider Blu-ray disc. I demuxed the Bulgarian subtitles and added them as external. It worked 3 times already, but I'm trying it again.
I'll post the complete log later. It says it will finish in ~50 mins. |
27th March 2010, 17:32 | #5016 | Link |
There will be an update later today - I removed the limit. I doubt you'll be able to fit the output to a DVD disc with such high bitrate, but may be I'm wrong. It is much better to use 2-pass with HCenc!
The update later includes a 'feature' requested by a user: To TOP-ALIGN uncompliant videos while uncropping - in other words not to add 2 black bars at top and bottom, but one huge black bar at the bottom of the video. Also multiAVCHD.log is being flushed more frequently for easier bug-reports. There are few other changes, but not that important atm. |
27th March 2010, 17:50 | #5017 | Link | |
HCenc simply takes too much time on my PC. BTW: I noticed that you removed Trellis for 1pass encoding |
27th March 2010, 18:29 | #5018 | Link | |
@deank
27th March 2010, 19:59 | #5019 | Link |
It took 5 hours and 30 mins to convert Ghost Rider from Blu-ray to DVD.
I trimmed the title just at credits start (saved ~ 7 mins) to raise the average bitrate of the movie, removed all audio tracks but the English 5.1 AC3 one, removed all subtitles, added external .sup (demuxed before compilation start) and used 2-pass HCenc MPEG2 encoding. The result is ~90 mb smaller than the expected DVD5, but it suits me well. I used main movie m2ts file, since the movie is not spread among multiple m2ts files and there was no need to use the mpls file. Code:
[14:18:05] Initialising... [14:18:05] Checking for new version... [14:18:06] New version/build found! [14:18:06] Latest web version is: 4.0 (build 741) [14:18:06] Download from: http://multiavchd.deanbg.com/multiavchd.exe [14:18:06] Consistency check finished! [14:18:06] Initialization finished. multiAVCHD is ready! [14:18:06] 1 year and 91 days since multiAVCHD was published. [14:18:06] 263 people supported it with donations [14:18:06] and you are the 1345360 one to launch the program... [14:18:06] Support multiAVCHD to extend its features and keep it going! [14:18:06] multiAVCHD.dat version: [04000733] [14:25:35] Checking for available space and drive types (FAT32/NTFS)... [14:25:36] Destination [D:]: NTFS, 19774.18 MiB (19.311 GiB) free space [14:25:36] Temp folder [C:]: NTFS, 14914.36 MiB (14.565 GiB) free space [14:25:36] Log started for multiAVCHD v4.0 (build 741) [14:25:36] Selected output mode: DVD player (DVD R/RW disc) [14:25:36] Processing one title... [14:25:36] Processing (I:\GHOST_RIDER\BDMV\STREAM\00066.m2ts)... [14:25:36] This title is marked for reencoding / uncropping... [14:25:36] Encoding process may take 10 min to 10 hours, so be patient... [14:25:36] *** Initiating video encoding: [14:25:36] *** Original : 1920x1080 [14:25:36] *** Crop : 0 [14:25:36] *** Resize : 720x480 [14:25:36] *** Uncrop to : 720x480 [14:25:36] *** Sharpen : 0 [14:25:36] *** Bitrate : 4690 kbps [14:25:36] *** Frame rate: Original (23.976) [14:25:36] *** Profile : SD-DVD (MPEG-2) [14:25:36] *** Encoding : Two pass - content: [01:56:26] (MPEG-2 encoder: HCenc) [18:45:05] *** Close to completion - closing preview... [18:56:34] *** Speed : 10.3 fps (elapsed: 04:30:54 - Realtime x 0.43) [18:56:34] *** Transcoding successful! [18:56:35] Detected video: ID#0:V_MPEG-2 720x480, fps=23.976 [18:56:35] Display properties: 853x480 (AR:1.78) [18:56:35] Encoding [AC3] audio to AC3... [18:56:54] Retrying... [19:32:53] Adding AC3 encoded audio track (eng)... [19:32:53] Total of 2 tracks found in this file. [19:32:53] Adding subtitles (Ghost Rider.bul.sup) (bul) [19:32:53] Title is trimmed: 00:00:00 - 01:56:26 [19:32:53] Creating SD-DVD structure... [19:32:54] Converting subtitles to DVD format... [19:32:55] Converting C:\_TEMP\multiTEMP-20100327\Ghost Rider.bul.sup to SUP (java:BDsup2sub)... [19:33:00] *** Imported subpictures: 961/961 at offset 0x [19:33:00] Applying pulldown... [19:41:22] Authoring DVD structure... [19:56:27] SD-DVD muxing completed! [19:56:32] SD-DVD title saved: [19:56:32] D:\multiAVCHD\AVCHD_GR_DVD\[DVD]\Ghost Rider [19:56:34] Compilation contains 1 (HD)DVD titles and no AVCHD/Blu-ray titles! [19:56:35] Preparing menu pages... [19:56:37] Setting main menu for 0 titles... [19:56:37] Selected TV system: [NTSC] [19:56:43] Done! Compilation summary: Format: DVD player (DVD R/RW disc) (mixed with DVD) Name : multiAVCHD =============================================================================== 1. 1 HD/SD-DVD titles =============================================================================== Output size : 4375 MiB (4.272 GiB) [19:56:43] D:\multiAVCHD\AVCHD_GR_DVD folder created (AVCHD/Blu-ray output)! [19:56:44] Burn its CONTENTS to DVD R/RW UDF 2.50/2.60 disc! [19:56:44] Compilation contains HD-DVD/SD-DVD titles placed in [HD-DVD]/[DVD] folder. [19:56:44] Burn each HD-DVD/SD-DVD title folder contents (both HVDVD_TS and VIDEO_TS for HD-DVD) to a separate DVD disc. [19:56:50] You may now remove temp folder (C:\_TEMP\multiTEMP-20100327\). [19:56:50] multiAVCHD finished in 19870.253 seconds (05:31:10.253)! [19:56:51] End of log. [19:56:51] Cleaning up... [19:56:51] Done! [19:56:51] For technical support, bug reports and questions: [19:56:52] http://multiforum.deanbg.com/ [19:56:52] http://multiAVCHD.deanbg.com/ [19:56:52] http://forum.doom9.org/showthread.php?t=143744 |
27th March 2010, 20:33 | #5020 | Link | ||
Plus, deank, did you notice how multiAVCHD was telling eac3to to encode the video track to AC3 in my last bug post? Is this fixed or do you need more information? |
