10th November 2017, 01:44 | #47121 | Link |
Madvr Settings help
Please excuse me if I am in the wrong area.
I am needing help with Madvr settings. I use jriver on windows 10 machine with specs as Intel Core i5-4590 CPU, Haswell Gen2, LGA1150, 3.3GHz 6 DDR3/ 2x PCIE3.0 x16 Windows 7 64 bit Asus Z97-DELUXE ATX Motherboard Nvidia GForce GTX750TI Receiver Onkyo TX-NR925 TV LG LF6300 55" smart TV I have madvr as defaults but I am getting an odd twitch in 23.98 material. Can someone help with settings to try and eliminate this annoyance. |
10th November 2017, 01:49 | #47122 | Link | |
10th November 2017, 08:53 | #47124 | Link |
Are you using other filters like FFDShow Raw Video? Please post a screenshot of your lav settings during playback as well.
I7 2600K@4.4 / GTX1080 / ACER M550 (DLP 4K) / Catleap (IPS 1440p) / Onkyo SE200 Sound card |
10th November 2017, 22:52 | #47126 | Link | |
11th November 2017, 09:39 | #47127 | Link | |
HDR settings in madVR (under the device tab) = "LG Electronics LG TV" set as "Digital Monitor/TV" same settings "set to passthough and send HDR metadata to display checked" and win10 setting for HDR for the normal desktop is off i'll do more test thx anyway |
11th November 2017, 11:37 | #47128 | Link |
I am the one who knocks
@madshi, can you improve black bar detection to include vertical videos?
Spotify started releasing them recently and madVR isn't detecting black bars at all for me. Here's an example: https://www.youtube.com/watch?v=pz95u3UVpaM And here's a 30s sample: http://www13.zippyshare.com/v/PtlV6yqH/file.html |
11th November 2017, 15:37 | #47130 | Link | |
11th November 2017, 21:51 | #47132 | Link | |
Windows 8.1 and 10 x64 - Intel Core i5-4670K (4.2 GHz) - 8 GB DDR3 - MSI Geforce GTX 1080 8 GB - Sony KD-55A1 - Denon AVR-X3600H |
12th November 2017, 01:58 | #47133 | Link |
Rca high - 10
RCA: I almost always end up using, strength 10/high quality. Lower or higher strength, or medium quality, not usually very effective, for most of my anime (mostly average quality). Almost always worth, the slower rendertime, with high quality setting.
GTX 1070; 4k TV (2160p/23); NGU Sharp/high, chroma & luma direct quadruple; SSIM 2D - STRENGTH 100% + ll/ar; upscaling refinement (especially thin edges/soften edges - only once after upscaling is complete - sharpening, is almost always, my #1 issue , I think, mostly, because of 4k upscaling); low 30's render (41+ available). Images look significantly better, with RCA strength 10/high quality (more important to me, than high luma settings). Thank you! Last edited by Gopa; 12th November 2017 at 04:55. Reason: corrections |
12th November 2017, 02:07 | #47134 | Link |
sorry i can't really understand why a good source needs RCA in the first place.
i mean it is made to remove compression artefacts and good sources are not supposed to have them. and even low settings can easily harm a good source. |
12th November 2017, 05:09 | #47138 | Link |
Re-rca
Sorry about that. Should have said, "average" anime sources (many, are very poor) + RCA high quality = very good image quality. I corrected my post. The best thing about madVR, for me, is that almost any source, will look good.
