3rd June 2011, 23:27 | #21 | Link |
A VERY minor mod to InfoF.h, the Info.h companion for printing
formatted text, no real need to change it but here it is anyway. These are the lines as they were: Code:
const unsigned char *se, *ss; // unsigned for(ss=(unsigned char*)s; *ss; ss=se) { // while, some to do int n; for(se=ss; n = *se, n>=' ' && n <= 223; ++se); // Find end+1 of printable int len = se - ss; // Len of printable if (len) { // Some to print DrawStringPlanar(dst,x,y,(const char*)ss,len); Code:
void __stdcall DrawFStringPlanar(PVideoFrame &dst,int x,int y,const char *s,bool pix = true) { // Draw formatted string at pixel or character coords, pix == false = character coords if(pix == false) {x *= 10; y *= 20;} // To Chars int in_x = x; // REM x for '\r' const unsigned char *se=(unsigned char*)s; // unsigned while(*se) { // while, some to do int n; for(s=(char*)se; n = *se, n>=' ' && n <= 223; ++se); // Find end+1 of printable int len = (char*)se - s; // Len of printable if (len) { // Some to print DrawStringPlanar(dst,x,y,s,len); // do the biz x += len * 10; // update x coord } else { // Ctrl code OR nonsense; if(n == '\n') { x = 0; y+=20; // Newline, down 1, LHS } else if (n == '\r') { x = in_x; y +=20; // Newline Special, Down 1, orig x coord } else if(n == '\b') { x -= 10; // Backward Space } else if (n == '\f') { x += 10; // Forward Space } else if (n == '\t') { x+= ((4*10)-(x%(4*10))); // H-Tab (step 4) } ++se; // skip ctrl code (and unknowns, outer loop detects nul sentinel) } } } void __stdcall DrawFStrPlanar(PVideoFrame &dst,int x,int y,const char *s) { // Formatted Print @ character coords DrawFStringPlanar(dst,x,y,s,false); } The above code is for the Planar rendering function only, amend the other 3 also. EDIT:- shall within minutes of this edit, add (above modified) "InfoF.H" to the 1st post for those that might want to try the companion header that allows formatted print at both pixel and character coords via the standard Info.h, (of course no color control is possible). Just include the InfoF.h header after Info.h and call the InfoF.h functions when either character or formatted print is required.
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 5th June 2011 at 19:54. Reason: Adding Infoh.h to 1st post. |
12th June 2011, 07:44 | #22 | Link |
Is there any chance that a moderator could at some stage, approve the
2nd attachment in the first post, if there seems to be a problem, I could always delete it, (or save me the bother and do it yourselves). About 7 days waiting now. ta.
20th April 2013, 19:18 | #24 | Link |
DDigitTest.dll & DDigitTest26.dll with source, update, see 1st post.
Complied for Avisynth v2.6. YV411 looks pretty awful with color (as expected).
5th June 2013, 03:43 | #25 | Link |
v1.05, DDigitTest.dll & DDigitTest26.dll with source, update, see 1st post.
Complied for Avisynth v2.6. Implemented additional 16 Greyscale print colors. YV411, optionally prints only luma channel and ignores chroma. (looks better).
10th July 2013, 19:10 | #26 | Link |
DDigit v1.06 with DDigitTest.dll and DDigitTest26.dll with source, update. See 1st post.
30th March 2015, 16:34 | #27 | Link |
DDigitTest (DDigit test dll) v2.6 dll recompiled with Avisynth Version 6 Header.
See 1st post. No version number increment, uses same version No as DDigit (v1.06). EDIT: A Few screens from DDigitTest (with a few Info.H screens) DDigit MONOLITHIC Renderer at YV24 Names One Pixel At a Time Col Off Screen One Pixel At a Time Mono Color Codes Vertical One Pixel At a Time Diag Full Character Set (Identical for Info.H) Info.H Renderer Tests @ YV24 (with synthesized InfoF.H support) Info.H Off Screen Info.H One Pixel At a Time Info.H One Pixel At a Time Diag Info.H Control Codes EDIT: Above images seem to be all broken, sorry. EDIT: Fixed.
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 10th May 2018 at 11:11. |
2nd January 2019, 18:14 | #28 | Link |
DDigit demo DDigitTest dll's for avs v2.58, v2.60/+, x86 and x64. Requires VS 2008 CPP Runtimes.
See 1st post. EDIT: Cannot rename the thread title when thread reaches a certain age.
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 2nd January 2019 at 20:52. |
plugin, sdk, text |
