Old 18th April 2018, 16:49   #3001  |  Link
Selur
Selur's Avatar
I have 16gb of ram.
with core.max_cache_size = 32768
this seems strange,...
Old 19th April 2018, 17:24   #3002  |  Link
Boulder
Pig on the wing
Boulder's Avatar
I did some tests on a Blu-ray source with my usual script to denoise and downsize to 720p, 2000 frames from the middle:
v44-test1, cache 32768:
Large pages - 10,74 fps
No large pages - 11,06 fps
v43
cache 32768 - 11,02 fps
default cache - 10,02 fps
So no use for me, but the cache size needs to be increased - so thanks for that tip I have 16 GB of memory and an AMD Ryzen 1800X system.
Old 21st April 2018, 08:10   #3003  |  Link
Selur
Selur's Avatar
Still a bit confused about max_cache_size.
max_cache_size
Set the upper framebuffer cache size after which memory is aggressively freed. The value is in megabytes.
set_max_cache_size(mb)
Deprecated, use max_cache_size instead.
so since max cache size is in MB and you have 16GB why set it to 32768 = 32GB, shouldn't your 16GB (- normal system memory usage) of RAM be the largest value one should set and not twice the available RAM or am I missing something?
Old 25th April 2018, 16:34   #3004  |  Link
foxyshadis
ангел смерти
foxyshadis's Avatar
It's a workaround for large pages in the current version only. If you aren't interested in large pages right now, or you're worried about a filter sucking up all of the cache, don't touch it.
Old 25th April 2018, 16:52   #3005  |  Link
DJATOM
DJATOM's Avatar
I found a bug. Well, not sure if that's really a bug, but might be unwanted behaviour of resizer.
Nowadays almost all anime blu-rays are upscales. I'd like to fight such upscales downscaling to original resolution using the mixed Descale and Spline36 clip, upscale back with eedi3 and merge it with source clip using lines mask.
Today my friend noticed slight shift in the source/AA comparisons. I tried to debug my script and found that resizer is just copying clip instead of fixing eedi3 shift. In that case 1920x1080 clip was downscaled to 960x540 and upscaled back (so we got 1920x1080 after eedi3 stuff).
As I understand, vapoursynth (zimg) resizer is just copying clip if input width and height matches with output. That might be unwanted if cropping options is set.
On my opinion resizer should check for crop options and do proper resizing in that case.
Me on GitHub
PC Specs: Ryzen 5950X, 64 GB RAM, RTX 2070
DJATOM is offline   Reply With Quote
Old 25th April 2018, 17:43   #3006  |  Link
Selur
Selur's Avatar
@foxyshadis: I get what max_cache_size is meant to do, what I don't get is why setting it to two times your RAM size is the right thing.
Old 25th April 2018, 18:25   #3007  |  Link
Boulder
Pig on the wing
Boulder's Avatar
It's really not. It can easily eat all the RAM you have when the script is initialized and it takes quite a lot of time for VS to release the excess memory so your computer is pretty much frozen. I've settled down for 10240 on my 16 GB system as I can just manage that with BD to 720p encodes.
Old 26th April 2018, 10:00   #3008  |  Link
DJATOM
DJATOM's Avatar
You probably need to provide an script to demonstrate what you really do, if you want the developers to resolve your doubts.
Okay. Script below is just stripped version to reproduce my problem.
PHP Code:
import havsfunc as haf
import mvsfunc
as mvf
import descale
as dsc
clip
= <some 1920x1080 clip>
descale_str 0.32
kernel
'bicubic'
descale_h 540 # 1080/2 to reproduce the problem
clip.width
clip.height
descale_w
haf.m4((descale_h) / h)
descale_natural dsc.Descale(clipdescale_wdescale_hkernel=kernel)
descale_aa core.resize.Spline36(clipdescale_wdescale_h)
descaled core.std.Merge(clipb=descale_naturalclipa=descale_aaweight=descale_str)
dx w
dy
h
ux
descale_w 2
uy
descale_h 2
rescale
core.eedi3m.EEDI3(descaledfield=1dh=Truealpha=0.2beta=0.25gamma=1000.0vcheck=3sclip=core.znedi3.nnedi3(descaledfield=1dh=Truensize=0nns=4pscrn=1))
rescale core.std.Transpose(clip=rescale)
rescale core.eedi3m.EEDI3(rescalefield=1dh=Truealpha=0.2beta=0.25gamma=1000.0vcheck=3sclip=core.znedi3.nnedi3(rescalefield=1dh=Truensize=0nns=4pscrn=1))
#rescale = core.fmtc.resample(rescale, dx, dy, -0.5, -0.5, ux, uy, kernel='spline36').fmtc.bitdepth(bits=8) # always fixes eedi3 shift, but I need to call bitdepth function, that's not convenient.
rescale core.resize.Spline36(rescaledxdysrc_left=-0.5src_top=-0.5src_width=uxsrc_height=uy# leaves eedi3 shift untouched if rescale clip's width and height matches the source.
Me on GitHub
Old 26th April 2018, 11:16   #3009  |  Link
ChaosKing
You could also use edi_rpow2.py https://gist.github.com/YamashitaRen...7524e794779d9c (or just copy the shifting code)
Old 26th April 2018, 11:50   #3010  |  Link
DJATOM
DJATOM's Avatar
zimg way is most likely broken, I didn't checked.
PHP Code:
Y=core.std.ShufflePlanes(clips=clipplanes=0colorfamily=vs.GRAY)
Y=core.resize.Spline36(clip=Y,width=clip.width,height=clip.height,src_left=hshift,src_top=-0.5
clip.width = Y.width, clip.height = Y.height, so resizer is just copying whole plane without doing the job. Another planes should be fixed if colorspace is not YUV444.
Me on GitHub
Old 28th April 2018, 02:49   #3011  |  Link
hydra3333
Yay, vapoursynth ffmpeg integration seems to be in its way.
http://ffmpeg.org/pipermail/ffmpeg-d...il/229137.html
I also hold some hope for "for dummies" vapoursynth library build instructions leading to building of a static ffmpeg.exe (including python libs and any other dependencies) ...
hydra3333 is offline   Reply With Quote
Old 28th April 2018, 06:57   #3012  |  Link
Selur
Selur's Avatar
... leading to building of a static ffmpeg.exe (including python libs and any other dependencies) ...
I highly doubt that will happen, since you would probably need to include a whole Python portable environment (or at least a huge portion of it).
To open .vpy-scripts you at least some sort of a Python (runtime) environment.
Cu Selur
Ps.: To open .avs-scripts you need the avisynth.dll (and dependencies).
Old 28th April 2018, 07:05   #3013  |  Link
hydra3333
Ah. I'd hoped, since youtube-dl manages to do it resulting in a standalone .exe ...
For some, unless maybe it could use vapoursynth portable in the same folder, non-static would be as useful as teats on a bull
Old 28th April 2018, 07:26   #3014  |  Link
Selur
Selur's Avatar
youtube-dl isn't statically compiled it seems to wrap all the dependencies it requires.
Yes once could also wrap a whole hdd this way and create one large binary, but that isn't statically compiling that is basically the same thing Mac does with it's .app files.
(Provide mostly standalone packages which are basically a folder structure which contains dependencies&co.)
Cu Selur
Old 30th April 2018, 00:36   #3015  |  Link
ChaosKing
Is it possible to compare the value of f.props.PlaneStatsAverage in a FrameEval function with the previous and the next frame (n-1 and n+1)? Sould I use get_frame_async() for that?
def g(n, f, clip, d_clip):
	clip=clip.text.Text("current: "+ f.props.PlaneStatsAverage)
	clip=clip.text.Text("\nPrev: "+ ???)
	clip=clip.text.Text("\n\nNext: "+ ???)
	return clip
clip = clip.std.FrameEval(functools.partial(g, d_clip=d_clip, clip=clip), prop_src=x)
Edit
This works but feels more like a hack.
x= clip.std.PlaneStats()
x1= clip.std.PlaneStats().std.DuplicateFrames(0) #prev
x2= clip.std.PlaneStats().std.Trim(1) #next
clip = clip.std.FrameEval(functools.partial(g, d_clip=d_clip, clip=clip), prop_src=[x, x1, x2])
Old 1st May 2018, 22:39   #3016  |  Link
amayra
Quality Checker
amayra's Avatar
Python development mode
A new command-line switch for the Python interpreter, -X, lets the developer set a number of low-level options for the interpreter. With Python 3.7, the option -X dev enables “development mode,” a slew of runtime checks that normally have a big impact on performance, but are useful for a developer during the debugging process
as vapoursynth user is this benefits me ?
I love Doom9
Old 1st May 2018, 22:44   #3017  |  Link
Myrsloik
Professional Code Monkey
Myrsloik's Avatar
	return clip
Edit
That's the right way.
Old 1st May 2018, 23:03   #3018  |  Link
@ amayra:
Users will probably not benefit directly from debugging switches, because users will usually prefer the fastest possible execution. You may have read that these additional runtime checks will "have a big impact on performance" (see your quote), which means that it will run a lot slower and report a lot of warnings, even of less probable conditions.
But if a developer can use this mode to discover risky code and fix bugs (possibly even before they cause noticeable issues), then users may benefit indirectly from an advanced release build.
Old 2nd May 2018, 14:16   #3019  |  Link
ChaosKing
@Myrsloik
Ok, thx.
I found a strange behaviour while playing with FrameEval func.
The very same function gives different output if it's called within FrameEval.
Is it a bug or did I miss something?
Here's an animated gif of my problem (correct output is in the middle):
And my script (You'll need also Single Precision MVTools https://github.com/IFeelBloated/vapo...h-mvtools-sf):
import sys
import os
import functools
import vapoursynth as vs
import mvsfunc as mvf #https://github.com/HomeOfVapourSynthEvolution/mvsfunc/blob/master/mvsfunc.py
import mvmulti as mv #https://github.com/IFeelBloated/vapoursynth-mvtools-sf/blob/master/src/mvmulti.py
import fvsfunc as fvf #https://github.com/Irrational-Encoding-Wizardry/fvsfunc/blob/master/fvsfunc.py
core = vs.get_core()
def myFilter(clip):
	pre = haf.SMDegrain(clip, tr=2, pel=2, contrasharp=False, thSAD = 1200, thSADC = 1200, prefilter=2)
	pre = pre.flux.SmoothT(temporal_threshold=6)
	pre = haf.DitherLumaRebuild(pre, s0=1)
	pre = fvf.Depth(pre, 32, range_in=1)
	clip = mvf.Depth(clip, 32)
	super = core.mvsf.Super(pre,16,16,1,0)
	vectors = mv.Analyze(super, blksize=16, overlap=8, search=4, tr=6)
	super = core.mvsf.Super(clip,16,16,1,1)
	blur_clip = mv.DegrainN(clip, super, vectors, thsad=600, tr=6)
	grain = blur_clip.grain.Add(var=1200.0, constant=True)#.std.BoxBlur(hradius=1, hpasses=1, vradius=1, vpasses=1)
	#return grain
	diff_clip = core.std.Expr([clip, blur_clip], 'x y - abs').std.Inflate(threshold=200/255).std.Inflate(threshold=200/255)
	mask_clip = diff_clip.std.Binarize(threshold=[3.3/219, 3.3/224], v0=0, v1=80/255)
	clip = core.std.MaskedMerge(clipa=blur_clip, clipb=grain, mask=mask_clip)
	return mvf.Depth(clip, 8)
clip = core.std.BlankClip(format=vs.YUV420P8, width=120*2, height=80*2, length=100, color=[206,235,135])
g_static  = clip.grain.Add(var=100.0, constant=True)
g_dynamic = clip.grain.Add(var=100.0, constant=False)
clip = core.std.StackHorizontal([
	core.std.StackVertical([g_static, g_static]),
	core.std.StackVertical([g_static, g_dynamic])
goal = core.std.StackHorizontal([
orig=clip
def asd(n, c):
	return myFilter(c)
feval = clip.std.FrameEval(functools.partial(asd, c=clip))
def comp(a, b, crop=0):
	return core.std.StackHorizontal([
		core.std.CropRel(a, crop,crop,0,0), \
		core.std.CropRel(b, crop,crop,0,0), \
nofeval = myFilter(clip)
clip = comp(feval.text.Text("Function inside FrameEval").std.AddBorders(right=2), nofeval.text.Text("No FrameEval").std.AddBorders(right=2), crop=0)
clip = comp(clip, orig.text.Text("unfiltered"), crop=0)
clip.set_output()
Old 2nd May 2018, 14:22   #3020  |  Link
Myrsloik
Myrsloik's Avatar
@Myrsloik
Ok, thx.
The same function gives different output if it's called within FrameEval.
Here's a animated gif of my problem (correct output is in the middle):
Should be identical in theory, yes. Unless some filter stores temporal state incorrectly. Then you get this. Gradually remove each filter and see when the output is once again identical, then report which filter it was. I'm going to bet mvtools or fluxsmooth right away.
speed, vaporware, vapoursynth
