20th February 2018, 05:10 | #441 | Link | |
also you can use ie convertbits(10,dither=1) before mdegrain stuff and convertbits(16) after. also having a rounding option other than truncate/dithering options will be good.
powered by Google Translator Last edited by Motenai Yoda; 20th February 2018 at 05:12. |
20th February 2018, 14:33 | #442 | Link | |
the bits parameter will do same thing with bits=16, and it's should be faster than lsb, and can use another bit setting like 12 for more speed, and can use 10 bit clip (for 10 bit source and output 16 bit or any other depending on the settings) or others, let see what pinterf say
See My Avisynth Stuff Last edited by real.finder; 20th February 2018 at 14:36. |
20th February 2018, 18:22 | #443 | Link | |
Since I had found the reason of another mysterious crash, namely 64bit x264 exited when a specific Qtgmc + Tivtc script was used. The culprit was an ancient assembler mmx code used in MSuper. This code did not clear mmx state, as the original asm code did not issue emms, and the Microsoft x64 mode lacks _mm_empty() command (unlike the Intel compiler possibly used in the 2.6.0.5 era). The result was a crash, x264_64.exe probably was conflicted with the non-restored FPU/MMX states. So after having inserted the missing 'emms' instruction it became rock solid. But I was so angry on MSuper's mmx heritage that I started to backport the sse2 intrinsic rewrite from VapourSynth mvtools. Then I added 10-16 bit sse2 versions. So MSuper is much faster now in 16bits (50+%). As a side-effect MSuper now works in 32bit float (no SSE2 yet). Having a 32 bit float MSuper, I was wondering what happens in a 32bit float MDegrain? (Primarily to see that the 16bit-mode color shift would be seen in 32bit mode, using the artifical example in the previous posts) I made MDegrain able to use arbitrary bit-depth Super clip with vectors created in 8-16 bit mode. For example we can have vectors created in 16 bit mode and use MDegrain2 on a 32bit float clip by simply passing a 32bit Super clip for MDegrain. I have to clean up the code, there was quite a bit of work with implementing these features. And I still need to run tests because 8 bit MDegrain with overlaps uses a strange rounding but since it exists in the C code and used in the asm assembler files also (copy paste?), I need to know whether it is intentional on a bug. There is a 11 bit precision integer arithmetic that is converted back in two steps: lose first 6 bit (,sum up them) then lose 5 bits. In 16 bits (and stacked) mode: final_pixel = (x + 1024) / 2048 In 8 bit: final_pixel = ((x + 256) >> 6) >> 5 I don't think the latter is correct. It results an 0.125 increase on average in the final pixel values. Probably it should be: final_pixel = ((x + 32) >> 6) + 16) >> 5 ? |
27th February 2018, 16:20 | #444 | Link |
Download MvTools2 2.7.25 with depans
There were quite a big changes, so please test it. Apart from the time-consuming mmx state bugfix there is a significant change in MDegrain worth to mention. Source and Super clip format is now independent of the motion vector clip formats. (apart from the subsampling differences which should be the same - I'm lazy). This means: one can Degrain even a 32bit float (new!) clip with e.g. 8 bit vectors. Pass a 8 bit clip to Super, then to Analyse and get the vectors. Then use these vectors in MDegrain, while passing a 32 bit source and a 32 bit Super clip. Code:
- 2.7.25 (20180227) Fix: x64: not-cleared mmx state in MSuper assembly code would cause crash later, e.g. in x264 encoding, depending on following filters. Fix: MSCDetection SC value parameter name to Ysc from Yth (must be an ancient typo), docs are OK, the fix is now mentioned in docs MSuper: import 8 bit sse2 interpolators from mvtools-vs. Extend them for 10-16bits (faster super clip). Some filters are still todo. MSuper: support 32bit float clips, which can be used later by MDegrains (but not for MAnalyse) MDegrains: allow degraining clip with different bit depth from vectors. Clip and Super must be the same bit depth MDegrains: consistently use limit and limitC, 255 do nothing, otherwise scale 0-254 value to the current bit-depth range Overlaps: more correct internal rounding for 8 bits: old: pixel = Sum( (tmp + 256) >> 6) >> 5 new: pixel = (Sum( (tmp + 32) >> 6) + 16) >> 5 Overlaps: round for 16bits old: pixel = Sum(tmp) >> 11 new: pixel = (Sum(tmp) + 1024) >> 11 Overlaps: 32bit float (but still use the original 11 bit window constants) Project: change from yasm to nasm. |
27th February 2018, 23:06 | #445 | Link |
thanks
and the "bits" parameter in MDegrains?
See My Avisynth Stuff |
28th February 2018, 00:34 | #447 | Link | |
but still lsb a bit faster than native all 8 bit:- 13.93 fps native 16 with 8 bit vectors:- 13.34 fps 8 bit with lsb:- 13.60 fps native 32 with 8 bit vectors:- 11 fps the test done with ColorBars(width=640, height=480, pixel_type="yv12").AddGrainC
28th February 2018, 14:04 | #448 | Link |
Acid fr0g
"Precision" is the same? Effectiveness in removing noise? Perceived quality output?
I am a old aged noob, I prefer to have smart guys opinions about matters I just play with.
@turment on Telegram |
28th February 2018, 18:44 | #449 | Link | |
HBD or lsb should give no banding output mean it will more quality but has some unseen noise, so 8bit should removing more noise but anyway let see what pinterf say
1st March 2018, 03:32 | #451 | Link | |
https://forum.doom9.org/showpost.php...&postcount=424 and yes motion analysis in 16 is slower
1st March 2018, 13:24 | #452 | Link |
Acid fr0g
From DGDecNV manual:
fulldepth: true/false (default: false) When fulldepth=true and the encoded video is HEVC 10-bit or 12-bit, then DGSource() delivers 16-bit data to Avisynth with the unused lower bits zeroed. The reported pixel format is CS_YUV420P16. If either of the two conditions are not met, then DGSource() delivers 8-bit YV12 or I420 data, as determined by the i420 parameter. When fulldepth=false and the video is HEVC 10-bit or 12-bit, then the video is dithered down to 8-bit for delivery. If you need a reduced color space (less than 16 bits) for your high-bit-depth processing, you can use ConvertBits() as needed after your DGSource() call. How should I feed that 16 bit stream to SMDegrain? LSB is not an option in this case, I think. The funny part would be also to output a dithered 10 bit video to feed x265 in Main10 profile or 8 bit to feed x264. Without thinking, at this moment, to HDR.
1st March 2018, 14:02 | #453 | Link | |
anyway I don't know anything about DGDecNV, but ffms2 do it without any parameter and for avs+ it will output the HBD as it and if you feed native HBD to SMDegrain it will work in most cases (if all filters that used are support HBD which I think in your cases all them are support HBD nowday) and of course lsb is not option if your source is HBD, since mvtools has only lsb output
See My Avisynth Stuff Last edited by real.finder; 1st March 2018 at 14:08. |
1st March 2018, 16:17 | #454 | Link | |
Acid fr0g
lsb= true makes 32 bit denoising lsb_in = true is used to get the source as native 16 bit (right?) lsb_out = true outputs 16 bit clip as output mode = 0…9 convert from internal 32bit to 8 bit (would be nice to have 10 or 12 too). So, if I have a 16 bit video input (i.e. 10 bit with all upper 0), I should use lsb=true+lsb_in=true+lsb_out=true (unless you develop a mode for 10 and 12 bit), right?
1st March 2018, 22:29 | #456 | Link | |
and this dither tools method (that used to support lsb_in by dogway) will not be real 16 bit, even if it better than doing 8bit in short, for SMDegrain lsb and lsb_out are real 16 bit and it's ok for use them, but they still hack, lsb_in in SMDegrain will not be real 16 bit and for dither back to 8 bit modes as pinterf said, it's not 32 bit, it's just 16 bit stacked and these mode come from dither tools again, not in or from mvtools!
See My Avisynth Stuff Last edited by real.finder; 1st March 2018 at 22:38. |
1st March 2018, 22:48 | #457 | Link |
Next version will come with that "bits" or whatever parameter that returns native 16bit instead of the stacked one from 8 bit source. The mv bitdepth independent inputs could be applied to other filters as well, I think.
2nd March 2018, 10:21 | #458 | Link |
Acid fr0g
So, if I understood well, at the moment a DGDecNV output from DGDecNV, that outputs a Ultra HD BD from 10 bits to 16bits with upper 0, is not natively useful when applying filters in a avisynth script with mvtools or dither, correct? We need dither (RGTools) update too, right?
2nd March 2018, 10:35 | #459 | Link | |
