9th December 2018, 21:03 | #501 | Link |
Bugfix release, thanks Seedmanc!
Download MvTools2 2.7.38 with depans Code:
- 2.7.38 (20181209) MCompensate: Fix regression in latest v37: overlap=0 crash - ouch, sorry MAnalyze DCT: FFTW float: quicker postprocess of DCT'd blocks, now is correct for non power-of-2 block sizes e.g. 12 or 24 (no effect on 8x8 for which fast integer DCT is used) MAnalyze DCT: more consistent handling of post DCT internal normalization for non-square block sizes. |
2nd January 2019, 11:58 | #503 | Link |
Happy New Year!
New build, a bugfix (thanks ErazorTT for the report) and an MDegrain extension. Download MvTools2 2.7.39 with depans Code:
- 2.7.39 (20190102) - MSuper: fix 16 bits, pel=2, sharp=2, which caused bottom-section artifacts for MDegrain using 8 bit vector origin and 16 bit real clip - MDegrain1-6,N: Enhanced: Input clip (and super) format now is fully independent from vector clip's base format (subsampling had to be the same before) E.g. make motion vector clips from a YV12 source and apply them on a 8-32 bit 4:4:4 input |
27th January 2019, 05:39 | #504 | Link |
And a Happy New Year to you too sir
Small prob in first two (mvtools docs) examples: Code:
# To show the motion vectors ( forward ) : AVISource("c:\test.avi") # or MPEG2Source, DirectShowSource, some previous filter, etc vectors = MSuper().MAnalyse(isb = false) MShow(vectors) # implicit last works properly # ERROR:- MShow: Wrong Super Frame Clip Code:
AVISource("c:\test.avi") # or MPEG2Source, DirectShowSource, some previous filter, etc Last=MSuper() # Assigns implicit last with Super clip vectors = Last.MAnalyse(isb = false) # Implicit Last = super, 1st arg Last.MShow(vectors) # Implicit Last = super, 1st arg
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 27th January 2019 at 15:06. |
12th February 2019, 17:24 | #506 | Link |
New build
Download MvTools2 2.7.40 with depans A bugfix, thanks to zorr a.k.a. father of "Zopti" (formerly Avisynth Optimizer) for the report. Another bugfix for the 16 bit MFlowInter version. Then, perhaps this version a milestone release. Most filters fully support 8-16 bit and 32 bit float with greyscale, YUV and Planar RGB videos. MDegrain family, MCompensate, MFlowXX family, MSuper all can handle practically any Avisynth+ input formats. It was quite a bit of modification, I hope bugs (small or big) will fly elsewhere, at least there won’t be many. Have fun. Code:
- 2.7.40 (20190212) - Fix: MFlowInter possible crash with specific parameter and colorspace settings. - Fix: MFlowInter possible overflow at 16 bit clips (artifacts) - MFlow, MFlowInter, MFlowFPS, MFlowBlur, MBlockFPS: support all 8-16 and 32 bit float Y, YUV (4:2:0, 4:2:2, 4:4:4) and planar RGB color spaces. Input clip format is independent from the ones used for getting motion vectors. Last edited by pinterf; 12th February 2019 at 22:26. |
12th February 2019, 21:10 | #507 | Link | |
Broadcast Encoder
Thank you, pinterf, very appreciated, as always!
I just tested it with a 10bit yv16 source brought to 16bit yv24 and it works: Quote:
Thank you! |
12th February 2019, 21:50 | #508 | Link | ||
FranceBB,
Not sure if problem, just asking. [EDIT: ie, is your MRecalculate a timewasting NOP]
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 12th February 2019 at 22:40. |
13th April 2019, 11:27 | #509 | Link |
Acid fr0g
A curiosity came to me about degraining using larger frame span: beside having less noise, can we say the output is more accurate and/or better quality, given same other parameters, as we are evaluating more frames?
@turment on Telegram |
13th April 2019, 18:37 | #510 | Link |
I've been using this function on 2.7.33 and it's always worked. Today I upgraded to the latest 2.7.40 and the output clip is the same as the input clip(nothing has been filtered). I've sifted through the new readme and couldn't figure what's changed to make it not work. If some kind soul could take a look below and point out what is wrong I'd greatly appreciate it. Using avs+ r2772 mt x64 btw.
EDIT: I had to revert back to 2.7.34 before the function started working as expected. EDIT2: starting with 2.7.35 and up it works in yv12 yv24 colorspace but not yuy2. EDIT3: Ah but it works with yv16 as well. So I guess yuy2 was dropped? In any case, problem solved. Sorry to bother you all. Code:
#Motion Compensated Temporalsoften function TSMC(clip input, int "tradius", int "mthresh", int "lumathresh", int "blocksize") { tradius=default(tradius,5) mthresh=default(mthresh,70) lumathresh=default(lumathresh,255) blocksize=default(blocksize,4) prefilt=input.blur(1.58) super=MSuper(input, pel=2,mt=false) superfilt=MSuper(prefilt,pel=2,mt=false) multivectors=Manalyse(superfilt,multi=true,delta=tradius,mt=false) multivectors2=Mrecalculate(superfilt,multivectors,thsad=mthresh,tr=tradius,mt=false,blksize=blocksize,overlap=2) mc=Mcompensate(input,super,multivectors2,thsad=mthresh,mt=false,tr=tradius,center=true) dnmc=mc.temporalsoften(tradius,lumathresh,lumathresh,15,2) decimate=selectevery(dnmc,tradius * 2 + 1,tradius) return(decimate) } Last edited by althor1138; 13th April 2019 at 20:55. |
2nd May 2019, 09:50 | #511 | Link |
New build, includes an important fix for YUY2 users who experienced troubles after 2.7.35.
Download MvTools with Depans 2.7.41 Now with 2x2 DLL versions, compiled with v142 and v141_xp toolset. XP users please use the latter. Planar RGB support for DepanStabilize is the first mod that I made for myself. I'm using it in my neverending (neverstarting) 8mm film restoration project to have a stabilized intermediate file in the same format (I have RGB source) for better days when I'll have more time for do further filtering. Code:
MvTools2 2.7.41 (20190502) Fix: regression since 2.7.35: MSuper chroma for non-planar YUY2 (Thanks to mkauf) Project moved to Visual Studio 2019, v141_xp and v142 toolset Depan 2.13.1.4 (20190502) DepanStabilize planar RGB 8-16 bits support: Generate motion vectors with mvtools MDepan, use it for DepanStabilize. Input clip can be planar RGB. add missing roundings to some internal interpolation calculations DepanEstimate 2.10.0.3 (20190502) simple rebuild |
5th May 2019, 17:30 | #513 | Link | |
Broadcast Encoder
By the way, v141_xp is still there in Visual Studio 2019, but this time Microsoft clearly stated that is deprecated, sadly (I noticed it when I upgraded from Visual Studio 2017 to 2019): Picture Anyway, thank you, Ferenc, your work is always very appreciated. |
17th May 2019, 22:55 | #514 | Link |
Sorry, can you write or give an instruction how to use this and can it be used for SVP parameters , I ported SVPgenerator to clear avs (I'm newbe in avs and not a coder, script can be stupid) and wanna know can I adapt it https://forum.doom9.org/showthread.php?t=176268
28th May 2019, 21:05 | #515 | Link |
is it ok to use convertbits() with Msuper super clip?
See My Avisynth Stuff |
29th May 2019, 13:48 | #516 | Link |
I'm not 100% sure. There is a hack (as a result of lacking frame properties) with the VideoInfo structure, super clip passes padding and plane handling information through a pointer which is stuffed into num_audio_samples videoinfo field. And audio_samples_per_second if set to zero.
If this videoinfo information is copied between filters _and_ the source MSuper instance is not freed up (the memory for this extra clip info is allocated there inside), you can do with a super clip whatever you want (except size modification) |
29th May 2019, 19:14 | #517 | Link | |
5th November 2019, 13:34 | #520 | Link |
Is this an mvtools2 bug for Occlusion Mask ?
Function VectorTest(Int "Delta",Float "Time",Int "MaskT",Int "BlkSz",Int "XStep",Bool "Align",Bool "HFlip",String "CS") { /* VectorTest(), An MvTools2::MFlowInter folly. by StainlessS @ Doom9 : https://forum.doom9.org/showthread.php?t=175373 Req AVS+ or GSCript, GRunt, MvTools2, RT_Stats v1.43+ Avs v2.58, Avs/+ v2.60. Delta, Default 1. As for MvTools2 Time, Default 50.0, As for MvTools2 MaskT, Default 3, As for MvTools2::MMask(kind=MASK_TYPE), 0=Motion, 1=Sad, 2=Occlusion, 3=Horizontal, 4=Vertical, 5=ColorMap BlkSz, Default 4, As for MvTools2 XStep, Default 8, Motion per frame of synthesized clip. Align, Default True, Aligns forward vector frame n+Delta to n. False show frame n of forward vector. HFlip, Default False, False, Animate from Right to Left, else Left to Right. (Right to Left is less confusing, same direction that the frames come in from). CS, Avs v2.5 defaults "YV12" else "Y8". Returns RGB32 clip. */ Function MTyp(Int n) {Return " Type="+Select(n,"Motion","Sad","Occlusion","Horizontal","Vertical","ColorMap")} myName="VectorTest: " IsAvsPlus=(FindStr(UCase(versionString),"AVISYNTH+")!=0) HasGScript=RT_FunctionExist("GScript") HasGrunt=RT_FunctionExist("GScriptclip") HasMvTools2=RT_FunctionExist("MSuper") Is26=VersionNumber>=2.6 Assert(IsAvsPlus||HasGscript,myName+"Essential AVS+ or GScript installed") Assert(HasGrunt,myName+"Essential GRunt installed") Assert(HasMvTools2,myName+"Essential MvTools2 installed") Delta=Default(Delta,1) Time=Default(Time,50.0) MaskT=Default(MaskT,3) BlkSz=DefaulT(BlkSz,4) XStep=Default(XStep,8) Align=Default(Align,True) HFlip=Default(HFlip,False) CS=Default(CS,Is26?"Y8":"YV12") OLap=(BlkSz>=4)?BlkSz/2:RT_Undefined # OLap=RT_Undefined # EDIT: Fixes Weirdness FuncS=""" Function Fn(clip c,Int Delta,Float Time,Int XStep,Bool Align,Bool HFlip,String mType) { c n=current_frame Hit=(Height-20)/5 if(Align) { Steps=640/XStep x=((n+1)*XStep) + (Delta*XStep/2) x=Min(x,(Steps-1)*XStep) x=HFlip?x:639-x cF=RT_YPlaneMin(n=n,x=x,y=Round(2.5*Hit)+20,w=1,h=1)-128 cB=RT_YPlaneMin(n=n,x=x,y=Round(3.5*Hit)+20,w=1,h=1)-128 Z=c.BlankClip(width=1,height=1,Color=$FFFFFF,Length=1) OverLay(Z,x=x,y=Round(2.5*Hit)+20) OverLay(Z,x=x,y=Round(3.5*Hit)+20) Subtitle(RT_String("@x=%d FGrey=128%+d : BGrey=128%+d",x,cF,cB)) } else { Subtitle("Align=False, Colors NOT shown") } Subtitle(String(n,"SRC[n=%.0f] (1st interp srcS)") , Y=0.5*Hit+20,Align=5) Subtitle(String(n+Delta,"SRC[n+Delta=%.0f] (2nd interp srcE)") , Y=1.5*Hit+20,Align=5) (Align) \ ? Subtitle(String(n+Delta,"FVEC[n+DELTA=%.0f]")+mType+ " (Aligned)" , Y=2.5*Hit+20,Align=5) \ : Subtitle(String(n,"FVEC[n=%.0f]")+mType , Y=2.5*Hit+20,Align=5) Subtitle(String(n,"BVEC[n=%.0f]")+mType , Y=3.5*Hit+20,Align=5) Subtitle(string(n+Delta*Time/100.0,"MFlowInter Predicted @ [%.2f]") , Y=4.5*Hit+20,Align=5) Return Last } Wid=640 Hit=64 Steps=Wid/XStep White=BlankClip(width=WID,height=HIT,Length=1,Color=$FFFFFF,Pixel_type=CS) Black=White.BlankClip srcS=Black.BlankClip(Length=0) For(i=1,Steps-1) { W=White.Crop(0,0,i*XStep,0) K=Black.Crop(0,0,Wid-W.Width,0) Frm=StackHorizontal(K,W) srcS=srcS++Frm } srcS=(HFlip)?srcS.FlipHorizontal:srcS srcE=SrcS.Loop(0,0,Delta-1) # Delete Delta frames, end interp src super=srcS.MSuper(pel=2,hpad=16,vpad=16) fvec =MAnalyse(super, isb=false, blksize=BlkSz, overlap=OLap, delta=Delta, truemotion=true) bvec =MAnalyse(super, isb=true, blksize=BlkSz, overlap=OLap, delta=Delta, truemotion=true) inter=srcS.MFlowInter(super, bvec,fvec, time=Time) mbv=srcS.MMask(bvec,kind=MaskT) mfv=srcS.MMask(fvec,kind=MaskT) mfv=(Align)?mfv.Loop(0,0,Delta-1):mfv # Align, Delete DELTA frames from start, align n+delta with n TXT=SrcS.BlankClip(Height=20,Length=1,Color=$404040) StackVertical(TXT,srcS,SrcE,MFV,MBV,Inter) mType=mTyp(MaskT) ARGS = "Delta,Time,XStep,Align,HFlip,MType" Last.GScriptClip("Fn(last, "+ARGS+")", local=true, args=ARGS) DIR=(HFlip) ? " : ---->" : " : <----" TXT=TXT.Subtitle(String(Delta,"Delta=%.0f")+String(Time," : Time=%.2f")+ \ String(BLKSZ," : BLKSZ=%.0f")+String(XSTEP," : XSTEP=%.0f")+" : ALIGN="+String(ALIGN)+" : HFlip="+String(HFlip)+DIR) return StackVertical(TXT,Last) """ IsAvsPlus?Eval(FuncS):GScript(FuncS) Return Last.ConvertToRGB32 } # 0=Motion, 1=Sad, 2=Occlusion, 3=Horizontal, 4=Vertical, 5=ColorMap VectorTest(Delta=2,MaskT=2,Align=FALSE) Frame 42 Frame 43 Frame 44 Frame 45 (back to normal again) Forward vectors go through a 4 frame cycle, normal, a bit wierd, very weird, a bit weird, back to normal again. Backward vectors no weirdness. EDIT: Weirdness above Type on the FVEC line. EDIT: I've observed similar occlusion weirdness in clip where occlusion appears near top of frame where seemingly sky is pretty much uniform grey [greyscale clip]. EDIT: Changed to ALIGN=False and re-upped images. EDIT: Above script was only really intended for Horizontal motion mask examination. EDIT: I suspect that weirdness might be connected with overlap. EDIT: If you change this Code:
OLap=(BlkSz>=4)?BlkSz/2:RT_Undefined Code:
OLap=RT_Undefined EDIT: I still dont have much clue how that occlusion stuff works. EDIT: I note that author of YFRC Code:
# Author: RunForLife(Oleg Yushko) http://videomontazh.com.ua # http://avisynth.nl/index.php/YFRC Below, both SAD masks used, but only BAK backward Occlusion mask. Code:
## "EM" - error or artifact mask EM = C.MMask(bak, ml=190, kind=1) [** kind=SAD *] EM = EM.Overlay( \ C.MMask(fwd, ml=190, kind=1).DeleteFrame(0), \ opacity=0.5, mode="lighten") EM = EM.Overlay( \ C.MMask(bak, ml=64, kind=2).mt_inpand, [** kind=occlusion *] \ opacity=0.5, mode="lighten")
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 6th November 2019 at 14:54. |
