20th November 2017, 16:51 | #47262 | Link | |
looks like nobody here have an answer for me or maybe there isnt anyway, thanks all thanks madshi for this high quality video renderer bye! |
20th November 2017, 23:41 | #47264 | Link | |
command line to execute when this profile is activated/ deactivated
Same question here. I created a *.bat file calling my Harmony hub to control my projector. The *.bat is working but I can't seem to make it work with this Madvr function. The idea is genius though... Any ideas how to make it work? Is the functionality even "functional" ? Thank you to anyone being to give hand on this topic. Florian |
21st November 2017, 02:37 | #47265 | Link | |
21st November 2017, 05:37 | #47266 | Link |
I am the one who knocks
No. It never was. http://bugs.madshi.net/view.php?id=210
21st November 2017, 08:36 | #47267 | Link |
I got annoyed enough at the issue of playback not continuing properly (picture freezes and audio continues) when the screen is blanked by Windows power settings that I decided to look into it.
I found that 0.91.11 has no issues with this and 0.92.1 is where this problem begins. At first I thought it was direct3d11 related but it still happens with dxva2 and cb also. If I switch LAV to software decoding there are no issues with 0.92.9. GTX960 using 388.31 on W10. Last edited by ryrynz; 21st November 2017 at 08:40. |
21st November 2017, 17:20 | #47269 | Link | |
You could also try a different HDMI port of TV / AV receiver. |
22nd November 2017, 08:51 | #47271 | Link |
Is there any way to block automatic updates of the Nvidia drivers that Windows Update installs? they drive me crazy with the new version that does not work with madvr/hdr
"To infinity, and beyond!" |
22nd November 2017, 09:12 | #47273 | Link |
On Windows 10 I use this method to block NVIDIA driver updates, and it works perfectly fine:
https://forums.guru3d.com/threads/wi...rivers.401588/ On Windows 8.1 it always just lists the drivers in WU but never installs them automatically, so I don't bother with anything there.
22nd November 2017, 09:50 | #47274 | Link | |
22nd November 2017, 10:14 | #47275 | Link |
I just run DDU after every major update of Windows 10 - running it automatically disables automatic (graphics) driver updates through Windows Update.
Test patterns: Grayscale yuv444p16le perceptually spaced gradient v2.1 (8-bit version), Multicolor yuv444p16le perceptually spaced gradient v2.1 (8-bit version) |
22nd November 2017, 22:54 | #47277 | Link |
Profile group on "device" section to control the zoom
Hi Madshi
goal is to be able to select the good memory lens of the projector depending on the ratio of the movie (2.40 or 16/9) Using a profile group on "device" section and "screen config" sub section, it works to switch automatically the projector on the good memory as long as the projector JVC X500 is connected and recognize by its IP adress in madVR "devices/xx/properties" section. It does not work with an Epson EH-LS10000. I do not know where to find the information of compatible projectors for this function or to find how to set it if it is possible (there is no information on how to modify or add a control command for a given projector). Does this information is provided somewhere ? TY |
22nd November 2017, 23:35 | #47278 | Link | |
_
23rd November 2017, 04:23 | #47279 | Link |
We fixed a community reported issue where display colors became distorted after upgrading on some TV’s and monitors that incorrectly advertised support for 10/12 bit wire formats.
https://blogs.windows.com/windowsexp...uild-17046-pc/ |
23rd November 2017, 04:55 | #47280 | Link |
Weird, I'm pretty sure that shouldn't happen. If you're sure no major updates (like the Fall Creators update) happened since the last time you used DDU, it might be worth letting the creator of DDU know. Perhaps Microsoft changed something again.
