20th March 2020, 12:31 | #1201 | Link |
gMKVExtractGUI author
Hey guys!
I run into a problem with LSmashSource by using the LWLibavAudioSource with AviSynth+ 3.5 The resulting audio script has significantly smaller length from the original file. (03:17 instead of 04:07) The original audio track properties are: Code:
Audio ID : 1 Format : WMA Format version : Version 2 Codec ID : 161 Codec ID/Info : Windows Media Audio Description of the codec : Windows Media Audio 9.2 - 20 kbps, 32 kHz, mono (A/V) 1-pass CBR Duration : 4 min 7 s Bit rate mode : Constant Bit rate : 1 411 kb/s Channel(s) : 1 channel Sampling rate : 32.0 kHz Bit depth : 16 bits Stream size : 41.6 MiB (21%) Language : English (Great Britain) Code:
commit 2f9d49914f42c2ffe62a9fc20b48de4d3657ffd9 [revision 921] Author: Yusuke Nakamura <muken.the.vfrmaniac@gmail.com> Date: Tue Dec 20 07:21:13 2016 +0900 lwindex: Consider draining mode for actual audio decoding. I also tested with FFMS2 and I had no problem with that. Could someone take a look? Thank you very much! |
22nd March 2020, 13:13 | #1203 | Link | |
Thank you so much for the swift resolve HolyWu! |
25th March 2020, 09:44 | #1204 | Link |
Can someone help me, please?
When I load this kind of video (e.g. in VirtualDub2) with l-smash as avs: https://www.dropbox.com/s/nq65dc8ha0ogww7/x.mov?dl=1 using: Code:
vid = LSMASHVideoSource("x.mov", format="YUV420P10") aud = LSMASHAudioSource("x.mov") AudioDub(vid, aud) Thank you! |
25th March 2020, 13:18 | #1205 | Link |
Video: AVDH 1280x720 29.97fps 97223kbps [V: Apple Video Media Handler [eng] (dnxhd dnxhr hqx, yuv422p10le, 1280x720, 97223 kb/s)]
Audio: PCM 48000Hz stereo 1536kbps [A: Apple Sound Media Handler [eng] (pcm_s16le, 48000 Hz, stereo, s16, 1536 kb/s)] Codec ID: sowt My guess would be that the endianness of the PCM audio was not correctly respected. |
25th March 2020, 23:12 | #1206 | Link | |
Without an install prefix set, it installs to what I guess is meson's default $libdir, so it gets installed to /usr/local/lib/x86_64-linux-gnu/avisynth/ instead of /usr/local/lib/avisynth. Since AviSynth+ installs a pkg-config file with the relevant information, it can pretty much mirror the meson.build for VapourSynth that uses pkg-config to set those values. Or does that cause some kind of conflict with MSVC builds? The plugin entry point isn't visible, so AviSynth+ can't load it. Setting -fvisibility=default in CPPFLAGS fixed it, although since meson.build has the gnu_symbol_visibility field, that might be a better place for it, or the exact symbols could be marked visible in the source. |
26th March 2020, 00:49 | #1207 | Link |
Pajas Mentales...
in ubuntu pkg-config see the path /usr/local/lib/pkgconfig by default?
if is no, you need set PKG_CONFIG_LIBDIR or PKG_CONFIG_PATH pounts to "/usr/local/lib/pkgconfig:" for meson can look at it EDIT: good cat about -fvisibility=default ! edit2: patch Code:
diff --git a/AviSynth/meson.build b/AviSynth/meson.build index b20c0d4..97c0255 100644 --- a/AviSynth/meson.build +++ b/AviSynth/meson.build @@ -57,6 +57,7 @@ sources = [ includes = include_directories('../include') deps = [ + dependency('avisynth'), dependency('liblsmash'), dependency('libavcodec', version : '>=58.18.0'), dependency('libavformat', version : '>=58.12.0'), @@ -78,5 +79,5 @@ shared_module('lsmashsource', sources, include_directories : includes, install : true, install_dir : join_paths(get_option('libdir'), 'avisynth'), - gnu_symbol_visibility : 'hidden' + gnu_symbol_visibility : 'default' ) Last edited by sl1pkn07; 26th March 2020 at 01:47. |
26th March 2020, 02:50 | #1208 | Link |
I'm logged in under Windows at the moment, but as I do have WSL with Ubuntu 19.10 set up,
$ pkg-config --variable pc_path pkg-config /usr/local/lib/x86_64-linux-gnu/pkgconfig:/usr/local/lib/pkgconfig:/usr/local/share/pkgconfig:/usr/lib/x86_64-linux-gnu/pkgconfig:/usr/lib/pkgconfig:/usr/share/pkgconfig ¹ Code:
diff --git a/AviSynth/meson.build b/AviSynth/meson.build index b20c0d4..75a92fa 100644 --- a/AviSynth/meson.build +++ b/AviSynth/meson.build @@ -56,7 +56,10 @@ sources = [ includes = include_directories('../include') +avisynth_dep = dependency('avisynth').partial_dependency(compile_args : true, includes : true) + deps = [ + dependency('avisynth'), dependency('liblsmash'), dependency('libavcodec', version : '>=58.18.0'), dependency('libavformat', version : '>=58.12.0'), @@ -77,6 +80,6 @@ shared_module('lsmashsource', sources, dependencies : deps, include_directories : includes, install : true, - install_dir : join_paths(get_option('libdir'), 'avisynth'), - gnu_symbol_visibility : 'hidden' + install_dir : join_paths(avisynth_dep.get_pkgconfig_variable('libdir'), 'avisynth'), + gnu_symbol_visibility : 'default' ) |
26th March 2020, 07:11 | #1209 | Link |
Pajas Mentales...
└───╼ nm -D /usr/lib/avisynth/liblsmashsource.so | grep Avis 000000000001de70 T AvisynthPluginInit3 you need set manually where install the libraries in meson with `--libdir` (or `--libexecdir`) and `--prefix` if you want install in a custom path see https://mesonbuild.com/Configuring-a...directory.html Last edited by sl1pkn07; 26th March 2020 at 07:29. |
26th March 2020, 08:10 | #1210 | Link |
I am well aware of how pkg-config and custom prefixes and install dirs work.
That doesn't change the fact that I said 'to mirror the meson.build for VapourSynth': https://github.com/HolyWu/L-SMASH-Wo...eson.build#L65 And that this means it goes into the same plugin directory VapourSynth itself creates and uses for the plugins that come with the upstream source. Something which the meson.build for AviSynth is not doing at the current time. |
26th March 2020, 08:46 | #1211 | Link |
Pajas Mentales...
Installing liblsmashsource.so to /usr/local/lib/avisynth Code:
└───╼ yay -Ql avisynthplus-git avisynthplus-git /etc/ avisynthplus-git /etc/avisynth/ avisynthplus-git /etc/avisynth/avisynth.conf avisynthplus-git /usr/ avisynthplus-git /usr/include/ avisynthplus-git /usr/include/avisynth/ avisynthplus-git /usr/include/avisynth/avisynth.h avisynthplus-git /usr/include/avisynth/avisynth_c.h avisynthplus-git /usr/include/avisynth/avs/ avisynthplus-git /usr/include/avisynth/avs/alignment.h avisynthplus-git /usr/include/avisynth/avs/capi.h avisynthplus-git /usr/include/avisynth/avs/config.h avisynthplus-git /usr/include/avisynth/avs/cpuid.h avisynthplus-git /usr/include/avisynth/avs/minmax.h avisynthplus-git /usr/include/avisynth/avs/posix.h avisynthplus-git /usr/include/avisynth/avs/types.h avisynthplus-git /usr/include/avisynth/avs/win.h avisynthplus-git /usr/lib/ avisynthplus-git /usr/lib/libavisynth.so avisynthplus-git /usr/lib/pkgconfig/ avisynthplus-git /usr/lib/pkgconfig/avisynth.pc Code:
└───╼ LC_ALL=C pacman -Qo /usr/local /usr/local/ is owned by filesystem 2019.10-2 Code:
└───╼ cat /usr/lib/pkgconfig/avisynth.pc |grep ^libdir libdir=${exec_prefix}/lib so yes, i think is working Last edited by sl1pkn07; 26th March 2020 at 10:19. |
27th March 2020, 16:11 | #1212 | Link | |
27th March 2020, 17:18 | #1213 | Link |
Use another audio source filter for now as a temporary workaround
eg Code:
vid = LSmashVideoSource("x.mov") aud = FFAudioSource("x.mov") AudioDub(vid,aud) Code:
vid = LSmashVideoSource("x.mov") aud = LWLibavAudioSource("x.mov") AudioDub(vid,aud) Last edited by poisondeathray; 27th March 2020 at 17:21. |
27th March 2020, 20:35 | #1214 | Link |
wow, I dodn't expect a solution that quick.
Yes, the new "temporary fix" build working fine No distorted audio. Thank you. The FFAudioSource workaround is also doing the job, but indexing takes really a long time here. |
13th April 2020, 10:58 | #1216 | Link |
New patched for ffmpeg 4.2.2
https://gist.github.com/maki-rxrz/5a...853b5358fb8a29 |
24th April 2020, 08:34 | #1217 | Link | |
(If there's no LSMASHVideo for XP, what's a good alternative that would allow me to feed an m2ts directly into avspmod? DirectShowSource is giving me "no video") Last edited by bruno321; 24th April 2020 at 09:31. |
24th April 2020, 11:03 | #1220 | Link |
結城有紀
Windows XP does not have the functionality to correctly run modern applications.
In C++ application, static variables need to be safely initialized to properly run. It needs a large thread local storage, which Windows XP doesn't have. Of course you can disable thread safe init and re-compile, which allows it to run. But then you'll suffer thread-unsafe init and it will potentially give you incorrect result silently. For now, most XP compatible filters are provided giving the notice that you are willing to take the risk of unreliable running results. TL;DR: Recompile it with "/Zc:threadSafeInit-" option, make it unsafe, and it should work for you. |
