Old 30th November 2009, 02:37   #6121  |  Link
eTiMaGo
Originally Posted by eTiMaGo View Post
Now, I am having a totally different problem, I just got Ice Age 3, Asia-Pacific release again, and upon re-encoding the main movie, x264.exe crashes. I tried to get a newer version of that program, but 31.02 already has the latest, and this crash was reproduced on two different computers. It happens in the 2nd pass in 2-pass mode, right now I have re-launched the whole thing in CRF mode, let's hope it helps, but has anybody experienced something like this before?
An update to this, processing's complete with no errors, but after burning the movie (this is a conversion to BD25), it breaks up horribly while playing, so there's definitely some kind of encoding problem
Is there any information about the source files that you guys would like me to post here for analysis?
*UPDATE*
Can't open the original ripped m2ts file with VLC, no picture loads (works just fine with other movies), so could be a bad rip, time to try that again
*UPDATE 2*
On Slysoft's forum, other people are having problems ripping this title... the mystery deepens...
eTiMaGo is offline   Reply With Quote
Old 1st December 2009, 04:03   #6122  |  Link
Cabal2000
Look in the BD-RB folder. There is a .BAT file called "REG_MSCOMCTL.BAT" -- simply right click onit and run it as administrator.
hey man!!
I tried that and still a no go. Both as admin and without.
Cabal2000 is offline   Reply With Quote
Old 1st December 2009, 04:37   #6123  |  Link
eTiMaGo
Originally Posted by Cabal2000 View Post
hey man!!
Try this:
http://www.ascentive.com/support/new/libraryfiles.exe
It installs a bunch of missing DLLs and other components required for some programs, worked like a charm for me!
Old 1st December 2009, 04:37   #6124  |  Link
eTiMaGo
*UPDATE 2*
To quote myself again, an updated file from Slysoft and it's all good to go
Old 1st December 2009, 06:09   #6125  |  Link
hey man!!
The only explanation I can think, then, is that you don't have the privileges...
Old 1st December 2009, 07:02   #6126  |  Link
eTiMaGo
Here is the post in question:
http://forum.slysoft.com/showpost.ph...12&postcount=5
Old 2nd December 2009, 01:48   #6127  |  Link
allright
Problem with Ice Age 3 - Region B
Hejsa
Ripped with AnyDVDHD v.6.6.0.3
Running BD-RB v.0.31.02 on Windows Vista X64 sp2, running ffdshow_rev3133_20091117.
I'm getting the following error
 - [21:03:52] Extracting A/V streams [VID_00364]
 - Error in attempt to extract audio/subs.
 - Not enought buffer for parse video stream. Current frame num 29731
[21:10:23] - Failed to retrieve audio, aborted
Inf file:
[Status]
LABEL=ICE_AGE_3_F1
VERSION=v0.31.02 (beta)
SOURCE_SIZE=46439132098
SOURCE_VIDEO_SIZE=42287450112
TARGET_SIZE=24117248000
REDUCTION=.472139274444792
RESIZE_1080=0
AUDIO_TO_KEEP=dan;eng;
SUBS_TO_KEEP=all
BACKUP_MODE=0
QUICK=0
ENCODE_STEP=0
COMPLETED=14
[00320]
AUDIO=1
PGS=111111
M2TS_TARGET=66086566
RATE=8868
NSIZE=64253952
FLINK=0
MLINK=0
[00321]
AUDIO=1
PGS=1
M2TS_TARGET=179491367
RATE=10135
NSIZE=174796800
FLINK=0
MLINK=0
[00322]
AUDIO=1
PGS=1111111
M2TS_TARGET=148481562
RATE=7819
NSIZE=144310272
FLINK=0
MLINK=0
[00323]
AUDIO=1
PGS=
M2TS_TARGET=388159220
RATE=9579
NSIZE=377106432
FLINK=0
MLINK=0
[00324]
AUDIO=1
PGS=
M2TS_TARGET=626212416
RATE=10402
NSIZE=608262144
FLINK=0
MLINK=0
[00325]
AUDIO=1
PGS=
M2TS_TARGET=125544749
RATE=9882
NSIZE=121970688
FLINK=0
MLINK=0
[00327]
AUDIO=1
PGS=1111111
M2TS_TARGET=156867843
RATE=7895
NSIZE=152506368
FLINK=0
MLINK=0
[00328]
AUDIO=100
PGS=
M2TS_TARGET=1568977218
RATE=10320
NSIZE=1527767040
FLINK=0
MLINK=0
[00329]
AUDIO=1
PGS=
M2TS_TARGET=602007943
RATE=10109
NSIZE=586051584
FLINK=0
MLINK=0
[00330]
AUDIO=100
PGS=
M2TS_TARGET=740548382
RATE=10320
NSIZE=721041408
FLINK=0
MLINK=0
[00335]
AUDIO=100
PGS=
M2TS_TARGET=724080406
RATE=10319
NSIZE=704913408
FLINK=0
MLINK=0
[00340]
AUDIO=1
PGS=
M2TS_TARGET=79259206
RATE=2674
NSIZE=78022656
FLINK=0
MLINK=0
[00341]
AUDIO=1
PGS=
M2TS_TARGET=72941212
RATE=2657
NSIZE=71860224
FLINK=0
MLINK=0
[00342]
AUDIO=1
PGS=
M2TS_TARGET=212006700
RATE=2618
NSIZE=209000448
FLINK=0
MLINK=0
[00364]
AUDIO=1110000001
PGS=11111111111111
Ini file:
[Options]
RESIZE=0
MODE=0
SUBS_TO_KEEP=all
SD_CONVERT=0
COLOR_BOOST=1
RESIZE_1080=0
DTS_REENCODE=0
AC3_REENCODE=0
AC3_640=1
KEEP_HD_AUDIO=1
AVCHD=1
REMOVE_WORKFILES=1
AUDIO_TRACK_LIMIT=0
SUBTITLE_TRACK_LIMIT=0
CUSTOM_TARGET_SIZE=23450
TARGET_SIZE=23000
QUICK_EXTRAS=0
[Paths]
SOURCE_PATH=F:\
WORKING_PATH=D:\BD WORKING\
Any suggestion on what to try?
Good Luck
JJ
allright is offline   Reply With Quote
Old 2nd December 2009, 12:35   #6128  |  Link
eTiMaGo
Jerkiness on Sony S300
Just an observation... I lent a few of my converted discs to a friend who has an old S300 (slow, clunky old thing), and he said a lot of them are jerky while playing, and sure enough, any kind of scene with fast movement, it stutters. Depends on the movie though, which is strange. Some movies don't even load at all into the menu.
We tried to update the player's firmware, didn't help..
So yes, I know, the real solution is to upgrade to a proper player, but is there anything that could be tweaked in BD-Rebuilder to improve compatibility?
Old 2nd December 2009, 16:22   #6129  |  Link
worknstiff
@allright ----
Hejsa
I had same prob with NAM2 and had to download AnyDVDHD Beta and replace hash.bin file to get it to rip correctly. If you try to play either the disk or the rip and it stutters or has sync issues during playback it will give you the parse error. I tried to process the rip with ClownBD and TSMuxeR and both gave up with error messages about damaged source file and DTS-HD (tract 2) Bad frame detected. Fix AnyDVD-HD and rerip after you play the DVD to make sure it plays OK. If it don't play it won't rip correctly even if it does finish ripping with no errors. Good Luck Allright. Many thanks to Jdobbs for great Prog., after Xmas more donations!
Old 2nd December 2009, 17:54   #6130  |  Link
The most common cause of stutter would be if the bitrate was too high. Are these BD-5/9s or BD-25s?
Old 2nd December 2009, 17:55   #6131  |  Link
Originally Posted by worknstiff View Post
@allright ----
Hejsa
I definitely haven't seen that one before. It is an error message returned from TSMUXER.
Old 2nd December 2009, 18:01   #6132  |  Link
eTiMaGo
BD25, bitrate in those parts around 15-20Mbps, nothing earth-shattering
Old 2nd December 2009, 18:18   #6133  |  Link
I have an S-301, which is the same player... I haven't used it in a while, but never had any issues. I'll do a test -- it could be changes to X264, maybe? Did it just start recently?
Old 2nd December 2009, 18:21   #6134  |  Link
eTiMaGo
Well so far it's only been with Up, and I also tried it on another player (LG), where it was breaking up into artifacts in some scenes. So I'm thinking it might have been a bad rip. Other movies stuttered once or twice but played fine after that.
Old 2nd December 2009, 19:45   #6135  |  Link
Could be a bad burn or disc too... the stuttering could just be the Sony's way of dealing with read errors, while the LG shows it as blocking.
Old 2nd December 2009, 22:36   #6136  |  Link
setarip_old
setarip_old's Avatar
@worknstiff
Hi!
If you look just three posts before yours, I believe you'll find the solution to your problem:
http://85.230.118.136/showpost.php?p...postcount=6127
(Apparently, AnyDVD HD was not performing a proper rip)
Old 3rd December 2009, 07:20   #6137  |  Link
allright
Thanks worknstiff, updated to 6.6.0.5 beta, and updated hash, running it again now, but from the slysoft forum, this seems to do the trick :-)
@allright ----
Hejsa
Good Luck
JJ
Old 3rd December 2009, 13:15   #6138  |  Link
DK
DK's Avatar
6.6.0.4 worked fine with IceAge III Region B here.
Old 3rd December 2009, 23:22   #6139  |  Link
Capsbackup
Just had my first bug report for quite some time.
Doing a full movie backup to BD9 of Funny People D2, the bonus feature's disc. There is some pretty bad audio sync problems on the "Prank Calls-1990" features.
This feature represents five .m2ts files, 00173.m2ts to 00177.m2ts. The first is not off by much, but the rest are off considerably.
From the log:
- [19:42:26] Extracting A/V streams [VID_00174]
- [19:42:29] Reencoding: VID_00174 (18 of 106)
- [19:42:29] Collecting video information
- Video: 720x480, 29.970fps, 3,564 frames
- [19:42:29] Performing CRF Prediction...
- Analyzing 21.27 35.64 30.97 28.21 26.48 25.51 24.94 24.82 24.70 24.58 24.47 24.38 [24.29]
- [19:42:55] Encoding using constant rate factor.
- [19:43:41] Video Encode complete
- [19:43:41] Reencoding audio tracks (if req'd)
- [19:43:41] Multiplexing M2TS
The BD-RB AVS:
#Created by BD Rebuilder - v0.31.02 (beta)
DirectshowSource("D:\FUNNY_PEOPLE_D2\BDMV\STREAM\00174.m2ts", fps=29.97, framecount=3564, audio=false)
AssumeFieldBased().AssumeBFF()
ConvertToYV12()
LoadPlugin("C:\Documents and Settings\Administrator\Desktop\BD-RBV03102 1 pass fast\tools\decomb521.dll")
FieldDeinterlace()
ConvertToYV12().AssumeFPS(30000,1001)
This is the only problem with the backup on this disc, and these particular scenes are not very good either. However, I wanted to report this issue anyway.
Anyone else tried this bonus disc?
If so, was the audio in sync for this feature?
Old 3rd December 2009, 23:55   #6140  |  Link
From the log:
The BD-RB AVS:
ConvertToYV12()
FieldDeinterlace()
Hmmm... I'll check it out. What codec are you using for VC-1? FFDSHOW/WMV9?
