19th February 2010, 17:03 | #6921 | Link |
No. The Hi-Speed option is pretty much the fastest you can get with X264 while remaining BD compliant... in most cases it is fine for a BD-25. The setting I recommended (GOOD/ABR) is what I believe to be a good balance of speed and quality that can be used with confidence for all BD-25 encodes. For BD-9/5 encodes -- I would always recommend "High Quality". It takes a long time -- but when you're compressing that much you need to use X264's best bells-and-whistles.
20th February 2010, 00:07 | #6922 | Link |
jdobbs, first off - great program. I ran into my first problem that I've been unable to get around, It has to do with a BD Season type disk, Weeds Season 4 to be exact. I do a full disk backup to BD25 from a 48GB source (the disks contain 8 episodes). Everything runs normally and I create the disk in imgburn with no errors anywhere along the way from rencode to final disk. Problem becomes that the disk plays fine in a software player but in my Panasonic BD55 evrything works fine through the menu selection, the episode starts with the DTS HD spashscreen all the way through and then it freezes -right where the episode would start. To validate it was a good rip from AnyDVD, I burned an unprocessed full image to BD50 (it plays fine on the player) then use that for the source into BDRebuilder. Any ideas for what I could try to do differently? I upgraded from 3.1.06 to 3.1.08 - no change
20th February 2010, 03:27 | #6923 | Link | |
DVD Magistrate
Now highest quality....tried one...cancelled after 1.5 days LOL!!! |
20th February 2010, 05:51 | #6924 | Link | |
SLOVEHEART
ROSE... |
20th February 2010, 13:28 | #6925 | Link |
anyone else having trouble backing up surrogates?
decrypted using dvdfab 6.2.0.5 full rip full bd-25 backup 2pass, custom tatrget size 24000, highest(very slow) encoder settings, english only audio and all subtitles included, keep hd audio for bd25 encoding selected. when i play the finished bd-re in my player i get the first menu then a blank screen and it stops there nothing else i had the same problem with transformers 2 and xmen 2 which i never solved i have 28 others that were 100% succesful and super quality Thanks jdobbs for a great program |
20th February 2010, 16:02 | #6926 | Link | |
Do you think you could download the trial version of AnyDVD, give it a try, and let me know if the same thing happens? It would be good to know. Last edited by jdobbs; 20th February 2010 at 16:05. |
20th February 2010, 19:23 | #6927 | Link | |
20th February 2010, 23:25 | #6928 | Link |
This on Win7 x64 and BD-RE v0.31.08.
Tried to re-encode In The Loop (UK). First 15 titles (from VID_0000 to VID_00014) were no problem for x264.exe. They contained video encoded as MPEG-2/576i/25fps, AVC/576i/25fps and AVC/1080p/23.98fps. VID_00015 is AVC/1080i/25fps and crashes x264.exe constantly. I realise this is not BD-RE's fault but figured it won't hurt to let jdobbs know about it. |
20th February 2010, 23:30 | #6929 | Link | |
x264 developer
21st February 2010, 00:12 | #6931 | Link |
decoder
21st February 2010, 00:49 | #6932 | Link |
I did surrogates with no problems, I did have a problem with gamer playing in the PS3, I finally figured out it was BD-Live, I re-ripped the BD-Rebuilder output of Gamer and removed BD-Live, re-burned it and it plays fine now. Not sure if this would work for you. I also used AnyDVD HD to rip it.
21st February 2010, 01:01 | #6933 | Link | |
BTW, not a one-to-one but I did the US version of "In the Loop" with no problems. Last edited by jdobbs; 21st February 2010 at 01:04. |
21st February 2010, 02:19 | #6935 | Link |
Sounds like you're not using the latest version. It's not only disabled -- it no longer exists. You force subtitles by right clicking on the one you want to enable in the STREAMS list. Please note that it only works when you are using movie-only mode.
21st February 2010, 02:26 | #6936 | Link |
Banned
Hello,
i have a question and a little problem. First thanks for BD_Rebuilder. It's a great program and the quality is amazing I've encoded a lot of BD's and all of them are fine. A few days ago i had problems with 2 Discs. One Disc was Batman Returns and the other was Urban Legends. I've used BD-RB 31.06 (Updated today to 31.08) Here my settings: Code:
[Options] MODE=0 QUICK_EXTRAS=1 PRIORITY_CLASS=0 RESIZE=0 AUDIO_TO_KEEP=deu; SUBS_TO_KEEP=deu; TRELLIS=1 COLOR_BOOST=0 RESIZE_1080=0 DTS_REENCODE=0 AC3_REENCODE=0 AC3_640=1 KEEP_HD_AUDIO=1 AVCHD=0 AUDIO_TRACK_LIMIT=0 SUBTITLE_TRACK_LIMIT=0 CUSTOM_TARGET_SIZE=24100 ENCODE_QUALITY=0 TARGET_SIZE=24100 AUTO_BURN=0 VERBOSE_STATUS=1 REMOVE_WORKFILES=1 SD_CONVERT=0 ONEPASS_ENCODING=2 This one is from Urban Legends Code:
[16:51:33] Reencoding audio tracks (if req'd) - ERROR in attempt to reencode audio (AFTEN) [AUD_00168__4352.WAV] [16:51:34] - Failed to reencode audio, aborted I've checked the Files.It was a Trailer. To solve this problem i've changed the mt2s File. I removed the Trailer m2ts File and inserted a litte m2ts File from the beginning of the Disc. Renamed it correctly and the encoding works fine. Played the encoded Disc from HDD with a Software Player and instead of the Trailer the player plays the File i've inserted. All is fine. Can i do this with every Bluray Disc? Remove Warnings and other crap, replace it with short Blackscreen m2ts Files, rename it like the original ones and encode the Disc? I want to keep the Menu and Extras, but i want to remove warnings and logos..- |
21st February 2010, 02:31 | #6937 | Link | |
I'll pick up "Urban Legends" and see if I can repeat the issue. |
21st February 2010, 02:38 | #6938 | Link | |
Banned
Do you have a tutorial for creating CLPI and MPLS File? |
21st February 2010, 02:53 | #6939 | Link | |
It may work... it all depends. I'd try a rewritable first. |
21st February 2010, 03:23 | #6940 | Link |
Banned
My Sony PS3 dont like Sony BD-RE Discs
Could the encoding problem be a problem of ripping with DVDFab? I rip the Urban Disc again right now with the Red Fox and try to encode again with 31.08 Let's see what happens... Another little question. I've encoded all my Discs with High Quality (Default) and 2pass. It takes about 6-12 Hours. (Length of the movie) I've read that you say that you encode at Good and 1pass ABR. Tested it and BD-RB says it takes round about 2 Hours, for all the extras and the Main Movie. Is there a big Quality difference between High Quality 2pass and Good 1pass? The time saving is very well. |
