Old 25th September 2011, 22:43   #13121  |  Link
omegaman7
omegaman7's Avatar
The program is in Beta stage man... And you really didn't give us much(any) information.
Old 25th September 2011, 22:59   #13122  |  Link
Originally Posted by jlm86 View Post
Long time BD Rebuilder user...
Upgraded to latest version, nothing but trouble..
VC-1 errors, X264.exe errors....versions, etc...
may be looking for other options....
Downloaded all versions on homepage for recommended versions etc, have fooled with this now for 2 days.....
Was working perfectly till i upgraded to latest.... ridiculous....
Since it is working for everyone else the question would be: "What else have you changed on your system?" The odds are high you'll find your problem there.
Also... since you're using the program for free, keep your attitude in check. Go to any "option" you prefer, but I'd be surprised if you'll be able to "go" without your checkbook. I'd be even more surprised if the output was even close in quality to what you get for free with BD-RB.
Some people's sense of entitlement is what I find "ridiculous".
What's even funnier is that you waited two days to get your DOOM9 account, only to make your first post a "whine" without any description of your problem, log, error report, or issue...
Old 25th September 2011, 23:13   #13123  |  Link
Sharc
The important thing is that if the original isn't telecined -- it is going to be 1080i not matter what. There aren't very many 1080i telecined streams. In fact, I'm not sure I've ever actually seen one.
I just got 3 of these, left untouched in Auto-blank mode as superfluous clips which couldn't be blanked on the disc I PMed you earlier today.
(Seems that there's just too much space left on BD disks to accommodate all kind of crap.)
Old 25th September 2011, 23:24   #13124  |  Link
If it's not letting you blank them, there's gotta be a reason. Either is has IGS in a subpath, is linked to another MPLS that has IGS, it has menu flags of some kind, or it is "leader/trailer" info related to a menu. You're saying their telecined at 1080i? What disc is it?
I read your PMs -- but I don't see the connection? In those you were talking about CRF sizing.
Old 25th September 2011, 23:32   #13125  |  Link
sonate
Well let me put that one to rest, out of all the BD programs out there there may be one other which works sort of decent. Yours blows it away. Not just quality of image and processing speed, but versatility and functionality. Try fast forward or reverse with anything else and you will find they never can and often freeze the video.
And if I have had certain difficulty with the AC3 conversions, none of the others offer it anyway. If I can get it to work it would be like icing on one of the best cakes.
Keep up the good work JD, I don't think I'm wrong to say that more people appreciate your efforts then they let on.
sonate is offline   Reply With Quote
Old 25th September 2011, 23:52   #13126  |  Link
RobertM
But did you uninstall all the previous versions before installing the new one? That may make a difference. BTW, what version of BDRB were you running previously?
Nobody else has mentioned anything like this. When I upgraded to the latest version there was no issue whatsoever.
Old 26th September 2011, 00:59   #13127  |  Link
jlm86
I must retract most of my post, and also give accolades to the development team...
Lack of sleep, and frustration in other areas, so my apologies..
I'm usually extremely capable to troubleshooting, but this one has me pretty good....
I'll do complete uninstall of all programs, reload, reconfigure, and see where that leads.
Yes, as most say, the app is light years ahead of anything else, and again, my hat off to development team.
jlm86 is offline   Reply With Quote
Old 26th September 2011, 11:11   #13128  |  Link
jlm86
X264.exe error
I seem to not be able to resolve the "x264.exe" error..
any suggestions...
Old 26th September 2011, 12:36   #13129  |  Link
RobertM
any suggestions...
Jim,
Nobody can help you if you don't give more information. I have no ideal what you are trying to say by "the "x264.exe" error".
You should post the log from your latest attempt (copy from the end of your BD-Rebuilder log file in your working folder). You should post your "BD-Rebuilder.ini" file. You should post the contents of your "inspect.exe" results. You must state the EXACT wording of the error messages that you see.
We can't help you if you don't help us understand the issue.
Old 26th September 2011, 19:15   #13130  |  Link
Sharc
Yes, same disc I reported about the CRF sizing. The crf sizing is however solved. The disk is Enemy of the state, region 2.
3 files are kept in Auto-blank mode, which look like poor quality uspscaled and telecined 1080i@29.97 DVD clips. I don't find these related to a menu, but I'll check again if I find some link.
Old 27th September 2011, 16:03   #13131  |  Link
cannibalc
First error with BDRebuilder after 2 years: CopyDirStructure() 00005 1200
Jdobbs,
Thank you so much for your efforts and all the time you have put into BDRebuilder... It is an amazing little application and you deserve far more praise then you get. I have had good luck with the app as you are very complete in your documentation and the thing just works or problems are usually swiftly resolved in new versions. I did run into an error for the first time that has me scratching my head. It may just be the disk itself or something with the file structure but I thought I would provide some information and see if you may have some insight as to what is going on. No rush or anything but if you could decode the following error messages it would be a big help:
09/26/11 [01:33:47] CopyDirStructure() 00005 1200
09/26/11 [04:38:03] CopyDirStructure() 00075 1200
PROBLEM DISK:
BluRay- Beverly Hills Cop
Ripped/Cloned with DVDFAB 8.1.2.0
All M2TS files tested for integrity for EAC3TO
Encoding Workstation:
Windows 7 x64 Enterprise
Core i7 920 2.66Ghz Quad Core
12GB of DDR3 1600
Inspect Log from BDRebuilder:
- Windows Version: 6.1 [7600]
- HAALI Splitter: 1.11.96.14, Ok
- FFDSHOW: 3882, Ok
- BD Rebuilder v0.39.0.1, Ok
- X264: Ok
- AFTEN: Ok
- FAAC: Ok
- MP4BOX: Ok
- WAVI: Ok
- TSMUXER: Ok
BDRebuilder 0.39.0.1 Project Settings:
[Options]
MODE=0
ENCODE_QUALITY=3
ONEPASS_ENCODING=0
AUTO_QUALITY=0
TARGET_SIZE=24400
PRIORITY_CLASS=0
AUDIO_TO_KEEP=eng;
SUBS_TO_KEEP=eng;
SD_CONVERT=0
OPEN_GOP=0
RESIZE_1080=0
DEINTERLACE=0
DTS_REENCODE=0
AC3_REENCODE=0
AC3_640=1
AC3_192=0
KEEP_HD_AUDIO=1
AVCHD=0
REMOVE_WORKFILES=0
MOVIE_ONLY_LOOP=0
REMOVE_OUTPUT=0
USE_FILTERS=0
AUDIO_TRACK_LIMIT=1
SUBTITLE_TRACK_LIMIT=0
CUSTOM_TARGET_SIZE=24400
QUICK_EXTRAS=1
SHOW_ENCODER=1
KEEP_HD_LPCM=1
MIN_M2TS_SIZE=160
BDMV_CERT_ONLY=1
USE_LAVF=0
VERSION=0.39.0.1
MOVIEONLY_TYPE=0
ALTCRF=20
ALT_TARGET=3000
ALTMETHOD=0
SD_TO_1080=0
CONVERT_WIDE=0
IVTC_PULLDOWN=0
ASSUME_DVD_PAL=0
AUTO_BLANK=0
UNMASK_CHAPTER=1
[Paths]
SOURCE_PATH=G:\
WORKING_PATH=E:\TEMP\
Basically I did a FULL BACKUP with quick encode for extras (2pass / HIGH QUALITY) to fit on Custom size 24400 BD25 Disk and all the encoding went flawlessly without an incident as usual but I ran into an error when building the FINAL BD structure that resulted in:
BDRebuilder Project File (BEVERLY_HILLS_COP.inf)
[Status]
LABEL=BEVERLY_HILLS_COP
VERSION=v0.39.01 (beta)
SOURCE_SIZE=37889165867
SOURCE_VIDEO_SIZE=37152485376
TARGET_SIZE=25585254400
REDUCTION=.66882669241428
RESIZE_1080=0
AUDIO_TO_KEEP=eng;
KEEP_HD_AUDIO=-1
SUBS_TO_KEEP=eng;
BACKUP_MODE=0
MOVIEONLY_TYPE=0
USE_LAVF=0
QUICK=1
ENCODE_STEP=0
COMPLETED=5
REBUILD_COMPLETE=0
[00417]
AUDIO=1
PGS=1000
HYBRID=0
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=304221675
NSTART=27000000
NEND=48108960
NSIZE=169113600
FLINK=0
MLINK=0
[00418]
AUDIO=1
PGS=
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=379470649
NSTART=27000000
NEND=33916284
NSIZE=302948352
FLINK=0
MLINK=0
[00416]
AUDIO=1
PGS=1000
HYBRID=0
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=380818490
NSTART=27000000
NEND=53003520
NSIZE=203999232
FLINK=0
MLINK=0
[00415]
AUDIO=1
PGS=1000
HYBRID=0
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=1142492453
NSTART=27000000
NEND=105811200
NSIZE=725710848
FLINK=0
MLINK=0
[00414]
AUDIO=10001
PGS=11000
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=23446801877
RATE=23112
NSTART=27000000
NEND=310694880
NSIZE=22653118464
FLINK=0
MLINK=0
BDRebuilder.log
[16:27:50] BD Rebuilder v0.39.01 (beta)
- Source: BEVERLY_HILLS_COP
- Input BD size: 35.29 GB
- Approximate total content: [02:45:10.375]
- Target BD size: 23.83 GB
- Quality: Highest (Very Slow), Two Pass
[16:27:50] PHASE ONE, Encoding
- [16:27:50] Processing: VID_00417 (1 of 5)
- [16:27:50] Extracting A/V streams [VID_00417]
- [16:27:57] Reencoding video [VID_00417]
- Source Video: MPEG-2, 720x480
- Rate/Length: 29.970fps, 14,059 frames
- [16:27:57] Reencoding: VID_00417, Pass 1 of 1
- [16:28:27] Video Encode complete
- [16:28:27] Reencoding audio tracks (if req'd)
- [16:28:27] Multiplexing M2TS
- [16:28:29] Processing: VID_00418 (2 of 5)
- [16:28:29] Extracting A/V streams [VID_00418]
- [16:28:34] Reencoding video [VID_00418]
- Rate/Length: 23.976fps, 3,686 frames
- [16:28:34] Reencoding: VID_00418, Pass 1 of 1
- [16:30:23] Video Encode complete
- [16:30:23] Reencoding audio tracks (if req'd)
- [16:30:23] Multiplexing M2TS
- [16:30:25] Processing: VID_00416 (3 of 5)
- [16:30:25] Extracting A/V streams [VID_00416]
- [16:30:33] Reencoding video [VID_00416]
- Rate/Length: 29.970fps, 17,319 frames
- [16:30:33] Reencoding: VID_00416, Pass 1 of 1
- [16:31:09] Video Encode complete
- [16:31:09] Reencoding audio tracks (if req'd)
- [16:31:09] Multiplexing M2TS
- [16:31:11] Processing: VID_00415 (4 of 5)
- [16:31:11] Extracting A/V streams [VID_00415]
- [16:31:34] Reencoding video [VID_00415]
- Rate/Length: 29.970fps, 52,489 frames
- [16:31:34] Reencoding: VID_00415, Pass 1 of 1
- [16:33:36] Video Encode complete
- [16:33:36] Reencoding audio tracks (if req'd)
- [16:33:36] Multiplexing M2TS
- [16:33:41] Processing: VID_00414 (5 of 5)
- [16:33:41] Extracting A/V streams [VID_00414]
- [16:39:54] Reencoding video [VID_00414]
- Rate/Length: 23.976fps, 151,153 frames
- Bitrate: 23,112 Kbs
- [16:39:54] Reencoding: VID_00414, Pass 1 of 2
- [18:18:18] Reencoding: VID_00414, Pass 2 of 2
- [01:29:54] Video Encode complete
- [01:29:54] Reencoding audio tracks (if req'd)
- [01:29:54] Multiplexing M2TS
[01:33:46]PHASE ONE complete
[01:33:46]PHASE TWO - Rebuild Started
- [01:33:47] Rebuilding BD file Structure
- [01:33:47] CopyDirStructure() 00005 1200
[04:37:31] - Aborted at user request
[04:37:51] BD Rebuilder v0.39.01 (beta)
- Resuming from previously started job.
[04:37:53] PHASE ONE, Encoding
[04:37:53]PHASE ONE complete
[04:37:53]PHASE TWO - Rebuild Started
- [04:37:53] Rebuilding BD file Structure
- [04:38:03] CopyDirStructure() 00075 1200
[04:43:00] - Encode and Rebuild complete
[04:43:00]JOB: BEVERLY_HILLS_COP finished.
[04:43:10] BD Rebuilder v0.39.01 (beta)
[04:43:12] PHASE ONE, Encoding
[04:43:12]PHASE ONE complete
[04:43:12]PHASE TWO - Rebuild Started
- [04:43:12] Rebuilding BD file Structure
- [04:43:12] CopyDirStructure() 00005 1200
[04:48:46] - Aborted at user request
[04:49:48] BD Rebuilder v0.39.01 (beta)
[04:49:57] PHASE ONE, Encoding
[04:49:57]PHASE ONE complete
[04:49:57]PHASE TWO - Rebuild Started
- [04:49:57] Rebuilding BD file Structure
[04:50:30] - Failed to REBUILD
[04:50:32] BD Rebuilder v0.39.01 (beta)
[04:50:34] PHASE ONE, Encoding
[04:50:34]PHASE ONE complete
[04:50:34]PHASE TWO - Rebuild Started
- [04:50:34] Rebuilding BD file Structure
- [04:50:34] CopyDirStructure() 00005 1200
[04:53:53] - Aborted at user request
[04:58:20] BD Rebuilder v0.39.01 (beta)
[04:58:21] PHASE ONE, Encoding
[04:58:21]PHASE ONE complete
[04:58:21]PHASE TWO - Rebuild Started
- [04:58:21] Rebuilding BD file Structure
- [04:58:23] CopyDirStructure() 00005 1200
[05:00:41] - Aborted at user request
[05:00:48] BD Rebuilder v0.39.01 (beta)
[05:00:49] PHASE ONE, Encoding
[05:00:49]PHASE ONE complete
[05:00:49]PHASE TWO - Rebuild Started
- [05:00:49] Rebuilding BD file Structure
- [05:00:50] CopyDirStructure() 00005 1200
[05:00:57] - Aborted at user request
[05:07:35] BD Rebuilder v0.39.01 (beta)
[05:07:37] PHASE ONE, Encoding
[05:07:37]PHASE ONE complete
[05:07:37]PHASE TWO - Rebuild Started
- [05:07:37] Rebuilding BD file Structure
- [05:07:38] CopyDirStructure() 00005 1200
[05:08:26] - Aborted at user request
[05:08:42] BD Rebuilder v0.39.01 (beta)
[05:08:43] PHASE ONE, Encoding
[05:08:43]PHASE ONE complete
[05:08:43]PHASE TWO - Rebuild Started
- [05:08:44] Rebuilding BD file Structure
- [05:08:45] CopyDirStructure() 00005 1200
[05:25:47] - Aborted at user request
[05:25:51] BD Rebuilder v0.39.01 (beta)
[05:25:53] PHASE ONE, Encoding
[05:25:53]PHASE ONE complete
[05:25:53]PHASE TWO - Rebuild Started
- [05:25:53] Rebuilding BD file Structure
- [05:25:54] CopyDirStructure() 00005 1200
[05:25:57] - Aborted at user request
[05:29:18] BD Rebuilder v0.39.01 (beta)
[05:29:20] PHASE ONE, Encoding
[05:29:20]PHASE ONE complete
[05:29:20]PHASE TWO - Rebuild Started
- [05:29:20] Rebuilding BD file Structure
- [05:29:21] CopyDirStructure() 00075 1200
[05:29:23] - Encode and Rebuild complete
[05:29:23]JOB: BEVERLY_HILLS_COP finished.
[05:29:44] BD Rebuilder v0.39.01 (beta)
[05:29:45] PHASE ONE, Encoding
[05:29:45]PHASE ONE complete
[05:29:45]PHASE TWO - Rebuild Started
- [05:29:45] Rebuilding BD file Structure
- [05:29:45] CopyDirStructure() 00005 1200
[05:29:48] - Aborted at user request
[05:30:15] BD Rebuilder v0.39.01 (beta)
[05:30:16] PHASE ONE, Encoding
[05:30:16]PHASE ONE complete
[05:30:16]PHASE TWO - Rebuild Started
- [05:30:16] Rebuilding BD file Structure
- [05:30:17] CopyDirStructure() 00075 1200
[05:30:18] - Encode and Rebuild complete
[05:30:19]JOB: BEVERLY_HILLS_COP finished.
[05:33:10] BD Rebuilder v0.38.09 (beta)
[05:33:11] PHASE ONE, Encoding
[05:33:11]PHASE ONE complete
[05:33:11]PHASE TWO - Rebuild Started
- [05:33:11] Rebuilding BD file Structure
- [05:33:11] CopyDirStructure() 00005 1200
[09:19:38] - Aborted at user request
ErrLog.txt
09/26/11 [04:43:12] CopyDirStructure() 00005 1200
09/26/11 [04:50:34] CopyDirStructure() 00005 1200
09/26/11 [04:58:23] CopyDirStructure() 00005 1200
09/26/11 [05:00:50] CopyDirStructure() 00005 1200
09/26/11 [05:07:38] CopyDirStructure() 00005 1200
09/26/11 [05:08:45] CopyDirStructure() 00005 1200
09/26/11 [05:25:54] CopyDirStructure() 00005 1200
09/26/11 [05:29:21] CopyDirStructure() 00075 1200
09/26/11 [05:29:45] CopyDirStructure() 00005 1200
09/26/11 [05:30:17] CopyDirStructure() 00075 1200
09/26/11 [05:33:11] CopyDirStructure() 00005 1200
09/26/11 [09:23:12] CopyDirStructure() 00005 1200
LastCMD.TXT
"C:\Users\CannibalC\Desktop\Appz\BD_Rebuilder\tools\x264.exe" "E:\TEMP\WORKFILES\VID_00414.AVS" --preset slow --bluray-compat --ref 4 --b-adapt 1 --b-pyramid none --weightp 1 --qpmin=0 --bitrate 23112 --level 4.1 --qpfile "E:\TEMP\WORKFILES\VID_00414.CHP" --sar 1:1 --aud --nal-hrd vbr --pic-struct --vbv-bufsize 30000 --keyint 24 --min-keyint 1 --ipratio 1.1 --pbratio 1.1 --vbv-maxrate 35000 --threads auto --slices 4 --thread-input --stats "E:\TEMP\WORKFILES\VID_00414.AVS.264.stats" --pass 2 --output "E:\TEMP\WORKFILES\VID_00414.AVS.264"
I checked file permissions and made sure I was running BDRebuilder as Administrator and everything seems to be inline. First time with this error so I am a bit perplexed as to what is happening. It is also worth mentioning I am reading the cloned disk as a mounted virtual drive using Virtual Clone Drive but I have always done that and been on the same version for six months now. I backed down to the previous BD rebuilder and tried again but end up with the same error code. Also no major system changed in the last few months... Codecs and everything are still the same so I can't think of any third party software that may be causing the issue especially since it is during a file operation rather than encoding...
Thank you kindly for any insight you may have on the matter.
Regards,
CannibalC
cannibalc is offline   Reply With Quote
Old 27th September 2011, 18:08   #13132  |  Link
@cannibalc
Odd one. The "00005" indicates a bad parameter that has been passed to a subroutine. It's happening in a routine that is copying the folder structure from the source to the destination. I just looked through the code. Essentially BD-RB does a directory scan using O/S calls and pulls the names of all folders, it then goes through all those folders doing the same stepping down the folder tree. The parameters are all provided by the operating system (as folder names).
Any chance you have issues on your source or destination hard drive? Try running chkdsk.
Old 28th September 2011, 03:50   #13133  |  Link
cannibalc
@cannibalc
jobbs,
Sorry man... Actually I figured out the issue a few hours ago. Hehe you called it... it was a corrupt file on the cloned ISO file itself. I used teracopy to copy the entire cloned ISO to another drive and low and behold it appears there was a single JAR file that was unreadable. I rebuilt the ISO without the JAR and resumed the Bdrebuilder job and it passed without any issues...and final disc played perfectly. I'll be sure to utilize this process in the future if this occurs again. Usually I just verify the integrity of the m2ts files with EAC3to and move ahead if everything passes... Never ran into an issue with any other files but it must have been something on the original disk itself even though when I cloned it no errors were encountered. I even checked the hard drive I originally wrote the image to see if there were any issues with bad sectors... Everything came back clean and SMART didn't indicate any issues. Hehe must have been the original disk... perhaps an intentionally corrupt file to thwart simple clone backups.
Sorry for taking up your time.
Once again can't thank you enough for BDRebuilder...phenomenal app! As soon as I land a new job I'll definitely get a donation to you to further show my gratitude.
Regards,
-CannibalC
Old 1st October 2011, 03:17   #13134  |  Link
owine
jdobbs,
Am rebuilding one of my BDs, but the output ISO is 37GB. Second time this has happened with this particular disk. Here is my log. Any ideas? This is the only disk I have experience this with, all others rebuild with no problems.
[10:34:16] BD Rebuilder v0.39.01 (beta)
  - Source:  THE_MATRIX_REVOLUTIONS_(2003)
  - Input BD size: 31.70 GB
  - Approximate total content: [06:58:24.326]
  - Target BD size: 22.95 GB
  - Windows Version: 6.1 [7601]
  - MOVIE and MENUS mode enabled
  - Auto Quality: High Quality (Default), Two Pass
[10:34:18] PHASE ONE, Encoding
 - [10:34:18] Blanking: VID_00079 (1 of 49)
 - [10:34:20] Blanking: VID_00005 (2 of 49)
 - [10:34:20] Blanking: VID_00068 (3 of 49)
 - [10:34:20] Blanking: VID_00069 (4 of 49)
 - [10:34:21] Blanking: VID_00006 (5 of 49)
 - [10:34:21] Blanking: VID_00009 (6 of 49)
 - [10:34:21] Blanking: VID_00065 (7 of 49)
 - [10:34:21] Blanking: VID_00067 (8 of 49)
 - [10:34:21] Blanking: VID_00070 (9 of 49)
 - [10:34:21] Blanking: VID_00066 (10 of 49)
 - [10:34:22] Blanking: VID_00013 (11 of 49)
 - [10:34:22] Processing: VID_00044 (12 of 49)
 - [10:34:22] Extracting A/V streams [VID_00044]
 - [10:34:45] Reencoding video [VID_00044]
   - Rate/Length: 29.970fps, 4,398 frames
   - Convert: 1920x1080, 29.970fps, 4,398 frames
 - [10:34:46] Reencoding: VID_00044, Pass 1 of 1
 - [10:40:40] Video Encode complete
 - [10:40:40] Reencoding audio tracks (if req'd)
 - [10:40:40] Multiplexing M2TS
 - [10:41:16] Blanking: VID_00048 (13 of 49)
 - [10:41:16] Processing: VID_00054 (14 of 49)
 - [10:41:16] Extracting A/V streams [VID_00054]
 - [10:41:44] Reencoding video [VID_00054]
   - Rate/Length: 29.970fps, 5,628 frames
   - Convert: 1920x1080, 29.970fps, 5,628 frames
 - [10:41:44] Reencoding: VID_00054, Pass 1 of 1
 - [10:49:00] Video Encode complete
 - [10:49:00] Reencoding audio tracks (if req'd)
 - [10:49:01] Multiplexing M2TS
 - [10:49:37] Processing: VID_00052 (15 of 49)
 - [10:49:37] Extracting A/V streams [VID_00052]
 - [10:50:01] Reencoding video [VID_00052]
   - Rate/Length: 29.970fps, 5,885 frames
   - Convert: 1920x1080, 29.970fps, 5,885 frames
 - [10:50:01] Reencoding: VID_00052, Pass 1 of 1
 - [10:57:47] Video Encode complete
 - [10:57:47] Reencoding audio tracks (if req'd)
 - [10:57:47] Multiplexing M2TS
 - [10:58:41] Blanking: VID_00011 (16 of 49)
 - [10:58:41] Processing: VID_00039 (17 of 49)
 - [10:58:41] Extracting A/V streams [VID_00039]
 - [10:59:08] Reencoding video [VID_00039]
   - Rate/Length: 29.970fps, 7,868 frames
   - Convert: 1920x1080, 29.970fps, 7,868 frames
 - [10:59:08] Reencoding: VID_00039, Pass 1 of 1
 - [11:10:06] Video Encode complete
 - [11:10:06] Reencoding audio tracks (if req'd)
 - [11:10:06] Multiplexing M2TS
 - [11:11:03] Blanking: VID_00049 (18 of 49)
 - [11:11:04] Processing: VID_00043 (19 of 49)
 - [11:11:04] Extracting A/V streams [VID_00043]
 - [11:11:48] Reencoding video [VID_00043]
   - Rate/Length: 29.970fps, 8,233 frames
   - Convert: 1920x1080, 29.970fps, 8,233 frames
 - [11:11:49] Reencoding: VID_00043, Pass 1 of 1
 - [11:23:07] Video Encode complete
 - [11:23:07] Reencoding audio tracks (if req'd)
 - [11:23:08] Multiplexing M2TS
 - [11:24:03] Processing: VID_00003 (20 of 49)
 - [11:24:03] Extracting A/V streams [VID_00003]
 - [11:24:51] Reencoding video [VID_00003]
   - Rate/Length: 29.970fps, 8,407 frames
   - Convert: 1920x1080, 29.970fps, 8,407 frames
 - [11:24:52] Reencoding: VID_00003, Pass 1 of 1
 - [11:36:16] Video Encode complete
 - [11:36:16] Reencoding audio tracks (if req'd)
 - [11:36:16] Multiplexing M2TS
 - [11:36:50] Blanking: VID_00046 (21 of 49)
 - [11:36:50] Blanking: VID_00047 (22 of 49)
 - [11:36:50] Processing: VID_00045 (23 of 49)
 - [11:36:50] Extracting A/V streams [VID_00045]
 - [11:37:10] Reencoding video [VID_00045]
   - Rate/Length: 29.970fps, 8,889 frames
   - Convert: 1920x1080, 29.970fps, 8,889 frames
 - [11:37:10] Reencoding: VID_00045, Pass 1 of 1
 - [11:44:34] Video Encode complete
 - [11:44:34] Reencoding audio tracks (if req'd)
 - [11:44:34] Multiplexing M2TS
 - [11:45:15] Processing: VID_00058 (24 of 49)
 - [11:45:15] Extracting A/V streams [VID_00058]
 - [11:45:36] Reencoding video [VID_00058]
   - Rate/Length: 29.970fps, 9,180 frames
   - Convert: 1920x1080, 29.970fps, 9,180 frames
 - [11:45:36] Reencoding: VID_00058, Pass 1 of 1
 - [11:52:29] Video Encode complete
 - [11:52:29] Reencoding audio tracks (if req'd)
 - [11:52:29] Multiplexing M2TS
 - [11:53:13] Processing: VID_00057 (25 of 49)
 - [11:53:13] Extracting A/V streams [VID_00057]
 - [11:53:35] Reencoding video [VID_00057]
   - Rate/Length: 29.970fps, 9,210 frames
   - Convert: 1920x1080, 29.970fps, 9,210 frames
 - [11:53:35] Reencoding: VID_00057, Pass 1 of 1
 - [11:59:49] Video Encode complete
 - [11:59:49] Reencoding audio tracks (if req'd)
 - [11:59:49] Multiplexing M2TS
 - [12:00:30] Processing: VID_00041 (26 of 49)
 - [12:00:30] Extracting A/V streams [VID_00041]
 - [12:00:52] Reencoding video [VID_00041]
   - Rate/Length: 29.970fps, 9,341 frames
   - Convert: 1920x1080, 29.970fps, 9,341 frames
 - [12:00:52] Reencoding: VID_00041, Pass 1 of 1
 - [12:07:48] Video Encode complete
 - [12:07:48] Reencoding audio tracks (if req'd)
 - [12:07:48] Multiplexing M2TS
 - [12:08:30] Processing: VID_00053 (27 of 49)
 - [12:08:30] Extracting A/V streams [VID_00053]
 - [12:08:52] Reencoding video [VID_00053]
   - Rate/Length: 29.970fps, 9,413 frames
   - Convert: 1920x1080, 29.970fps, 9,413 frames
 - [12:08:52] Reencoding: VID_00053, Pass 1 of 1
 - [12:14:15] Video Encode complete
 - [12:14:15] Reencoding audio tracks (if req'd)
 - [12:14:15] Multiplexing M2TS
 - [12:15:09] Processing: VID_00051 (28 of 49)
 - [12:15:09] Extracting A/V streams [VID_00051]
 - [12:15:46] Reencoding video [VID_00051]
   - Rate/Length: 29.970fps, 10,298 frames
   - Convert: 1920x1080, 29.970fps, 10,298 frames
 - [12:15:46] Reencoding: VID_00051, Pass 1 of 1
 - [12:24:10] Video Encode complete
 - [12:24:10] Reencoding audio tracks (if req'd)
 - [12:24:10] Multiplexing M2TS
 - [12:25:03] Processing: VID_00042 (29 of 49)
 - [12:25:03] Extracting A/V streams [VID_00042]
 - [12:25:39] Reencoding video [VID_00042]
   - Rate/Length: 29.970fps, 10,380 frames
   - Convert: 1920x1080, 29.970fps, 10,380 frames
 - [12:25:39] Reencoding: VID_00042, Pass 1 of 1
 - [12:34:54] Video Encode complete
 - [12:34:54] Reencoding audio tracks (if req'd)
 - [12:34:54] Multiplexing M2TS
 - [12:36:01] Processing: VID_00040 (30 of 49)
 - [12:36:01] Extracting A/V streams [VID_00040]
 - [12:36:40] Reencoding video [VID_00040]
   - Rate/Length: 29.970fps, 10,749 frames
   - Convert: 1920x1080, 29.970fps, 10,749 frames
 - [12:36:40] Reencoding: VID_00040, Pass 1 of 1
 - [12:49:53] Video Encode complete
 - [12:49:53] Reencoding audio tracks (if req'd)
 - [12:49:53] Multiplexing M2TS
 - [12:50:52] Processing: VID_00031 (31 of 49)
 - [12:50:52] Extracting A/V streams [VID_00031]
 - [12:51:35] Reencoding video [VID_00031]
   - Rate/Length: 29.970fps, 12,930 frames
   - Convert: 1920x1080, 29.970fps, 12,930 frames
 - [12:51:35] Reencoding: VID_00031, Pass 1 of 1
 - [13:02:48] Video Encode complete
 - [13:02:48] Reencoding audio tracks (if req'd)
 - [13:02:48] Multiplexing M2TS
 - [13:04:09] Processing: VID_00001 (32 of 49)
 - [13:04:09] Extracting A/V streams [VID_00001]
 - [13:04:51] Reencoding video [VID_00001]
   - Rate/Length: 29.970fps, 12,353 frames
   - Convert: 1920x1080, 29.970fps, 12,353 frames
 - [13:04:52] Reencoding: VID_00001, Pass 1 of 1
 - [13:16:16] Video Encode complete
 - [13:16:16] Reencoding audio tracks (if req'd)
 - [13:16:16] Multiplexing M2TS
 - [13:17:30] Blanking: VID_00064 (33 of 49)
 - [13:17:30] Processing: VID_00062 (34 of 49)
 - [13:17:30] Extracting A/V streams [VID_00062]
 - [13:18:36] Reencoding video [VID_00062]
   - Rate/Length: 29.970fps, 13,234 frames
   - Convert: 1920x1080, 29.970fps, 13,234 frames
 - [13:18:37] Reencoding: VID_00062, Pass 1 of 1
 - [13:29:50] Video Encode complete
 - [13:29:50] Reencoding audio tracks (if req'd)
 - [13:29:50] Multiplexing M2TS
 - [13:30:46] Processing: VID_00032 (35 of 49)
 - [13:30:46] Extracting A/V streams [VID_00032]
 - [13:31:58] Reencoding video [VID_00032]
   - Rate/Length: 29.970fps, 14,535 frames
   - Convert: 1920x1080, 29.970fps, 14,535 frames
 - [13:31:59] Reencoding: VID_00032, Pass 1 of 1
 - [13:45:54] Video Encode complete
 - [13:45:54] Reencoding audio tracks (if req'd)
 - [13:45:55] Multiplexing M2TS
 - [13:47:44] Processing: VID_00061 (36 of 49)
 - [13:47:45] Extracting A/V streams [VID_00061]
 - [13:48:36] Reencoding video [VID_00061]
   - Rate/Length: 29.970fps, 13,500 frames
   - Convert: 1920x1080, 29.970fps, 13,500 frames
 - [13:48:36] Reencoding: VID_00061, Pass 1 of 1
 - [13:59:40] Video Encode complete
 - [13:59:40] Reencoding audio tracks (if req'd)
 - [13:59:40] Multiplexing M2TS
 - [14:00:57] Processing: VID_00000 (37 of 49)
 - [14:00:57] Extracting A/V streams [VID_00000]
 - [14:01:43] Reencoding video [VID_00000]
   - Rate/Length: 29.970fps, 14,025 frames
   - Convert: 1920x1080, 29.970fps, 14,025 frames
 - [14:01:44] Reencoding: VID_00000, Pass 1 of 1
 - [14:17:27] Video Encode complete
 - [14:17:27] Reencoding audio tracks (if req'd)
 - [14:17:27] Multiplexing M2TS
 - [14:18:48] Processing: VID_00030 (38 of 49)
 - [14:18:48] Extracting A/V streams [VID_00030]
 - [14:19:26] Reencoding video [VID_00030]
   - Rate/Length: 29.970fps, 15,790 frames
   - Convert: 1920x1080, 29.970fps, 15,790 frames
 - [14:19:26] Reencoding: VID_00030, Pass 1 of 1
 - [14:33:47] Video Encode complete
 - [14:33:47] Reencoding audio tracks (if req'd)
 - [14:33:47] Multiplexing M2TS
 - [14:35:19] Processing: VID_00060 (39 of 49)
 - [14:35:19] Extracting A/V streams [VID_00060]
 - [14:36:31] Reencoding video [VID_00060]
   - Rate/Length: 29.970fps, 15,750 frames
   - Convert: 1920x1080, 29.970fps, 15,750 frames
 - [14:36:32] Reencoding: VID_00060, Pass 1 of 1
 - [14:52:21] Video Encode complete
 - [14:52:21] Reencoding audio tracks (if req'd)
 - [14:52:21] Multiplexing M2TS
 - [14:53:14] Processing: VID_00050 (40 of 49)
 - [14:53:14] Extracting A/V streams [VID_00050]
 - [14:53:50] Reencoding video [VID_00050]
   - Rate/Length: 29.970fps, 15,761 frames
   - Convert: 1920x1080, 29.970fps, 15,761 frames
 - [14:53:51] Reencoding: VID_00050, Pass 1 of 1
 - [15:05:12] Video Encode complete
 - [15:05:12] Reencoding audio tracks (if req'd)
 - [15:05:12] Multiplexing M2TS
 - [15:06:16] Processing: VID_00056 (41 of 49)
 - [15:06:16] Extracting A/V streams [VID_00056]
 - [15:07:01] Reencoding video [VID_00056]
   - Rate/Length: 29.970fps, 18,090 frames
   - Convert: 1920x1080, 29.970fps, 18,090 frames
 - [15:07:01] Reencoding: VID_00056, Pass 1 of 1
 - [15:23:59] Video Encode complete
 - [15:23:59] Reencoding audio tracks (if req'd)
 - [15:23:59] Multiplexing M2TS
 - [15:24:43] Processing: VID_00055 (42 of 49)
 - [15:24:43] Extracting A/V streams [VID_00055]
 - [15:25:27] Reencoding video [VID_00055]
   - Rate/Length: 29.970fps, 17,807 frames
   - Convert: 1920x1080, 29.970fps, 17,807 frames
 - [15:25:27] Reencoding: VID_00055, Pass 1 of 1
 - [15:39:21] Video Encode complete
 - [15:39:21] Reencoding audio tracks (if req'd)
 - [15:39:21] Multiplexing M2TS
 - [15:41:19] Processing: VID_00033 (43 of 49)
 - [15:41:19] Extracting A/V streams [VID_00033]
 - [15:42:15] Reencoding video [VID_00033]
   - Rate/Length: 29.970fps, 19,785 frames
   - Convert: 1920x1080, 29.970fps, 19,785 frames
 - [15:42:16] Reencoding: VID_00033, Pass 1 of 1
 - [15:56:13] Video Encode complete
 - [15:56:13] Reencoding audio tracks (if req'd)
 - [15:56:13] Multiplexing M2TS
 - [15:57:27] Processing: VID_00059 (44 of 49)
 - [15:57:27] Extracting A/V streams [VID_00059]
 - [15:58:04] Reencoding video [VID_00059]
   - Rate/Length: 29.970fps, 17,919 frames
   - Convert: 1920x1080, 29.970fps, 17,919 frames
 - [15:58:04] Reencoding: VID_00059, Pass 1 of 1
 - [16:11:53] Video Encode complete
 - [16:11:53] Reencoding audio tracks (if req'd)
 - [16:11:53] Multiplexing M2TS
 - [16:13:05] Processing: VID_00007 (45 of 49)
 - [16:13:05] Extracting A/V streams [VID_00007]
 - [16:13:53] Reencoding video [VID_00007]
   - Rate/Length: 29.970fps, 22,290 frames
   - Convert: 1920x1080, 29.970fps, 22,290 frames
 - [16:13:53] Reencoding: VID_00007, Pass 1 of 1
 - [16:32:09] Video Encode complete
 - [16:32:09] Reencoding audio tracks (if req'd)
 - [16:32:10] Multiplexing M2TS
 - [16:33:37] Processing: VID_00034 (46 of 49)
 - [16:33:37] Extracting A/V streams [VID_00034]
 - [16:34:30] Reencoding video [VID_00034]
   - Rate/Length: 29.970fps, 27,928 frames
   - Convert: 1920x1080, 29.970fps, 27,928 frames
 - [16:34:30] Reencoding: VID_00034, Pass 1 of 1
 - [16:57:35] Video Encode complete
 - [16:57:35] Reencoding audio tracks (if req'd)
 - [16:57:35] Multiplexing M2TS
 - [16:59:33] Processing: VID_00063 (47 of 49)
 - [16:59:33] Extracting A/V streams [VID_00063]
 - [17:00:37] Reencoding video [VID_00063]
   - Rate/Length: 29.970fps, 29,122 frames
   - Convert: 1920x1080, 29.970fps, 29,122 frames
 - [17:00:37] Reencoding: VID_00063, Pass 1 of 1
 - [17:22:08] Video Encode complete
 - [17:22:09] Reencoding audio tracks (if req'd)
 - [17:22:09] Multiplexing M2TS
 - [17:23:59] Processing: VID_00038 (48 of 49)
 - [17:23:59] Extracting A/V streams [VID_00038]
 - [17:25:33] Reencoding video [VID_00038]
   - Rate/Length: 29.970fps, 48,690 frames
   - Convert: 1920x1080, 29.970fps, 48,690 frames
 - [17:25:33] Reencoding: VID_00038, Pass 1 of 1
 - [17:56:51] Video Encode complete
 - [17:56:51] Reencoding audio tracks (if req'd)
 - [17:56:51] Multiplexing M2TS
 - [18:00:05] Processing: VID_00008 (49 of 49)
 - [18:00:05] Extracting A/V streams [VID_00008]
 - [18:24:02] Reencoding video [VID_00008]
 - [18:24:02] Reencoding secondary video [TRK_02]
   - Rate/Length: 23.976fps, 185,957 frames
 - [18:39:28] Reencoding: VID_00008, Pass 1 of 1
 - [20:47:31] Video Encode complete
 - [20:47:31] Reencoding audio tracks (if req'd)
 - [20:47:31] Multiplexing M2TS
[20:58:43]PHASE ONE complete
[20:58:44]PHASE TWO - Rebuild Started
 - [20:58:44] Rebuilding BD file Structure
[20:59:33] - Encode and Rebuild complete
[20:59:33] Writing BD structure to ISO file
 - ImgBurn completed successfully
 - THE_MATRIX_REVOLUTIONS_(2003) folder removed.
 - WORKFILES folder removed.
[21:37:04]JOB: THE_MATRIX_REVOLUTIONS_(2003) finished.
Any ideas why this is happening? It's coming out larger than the source...
owine is offline   Reply With Quote
Old 1st October 2011, 03:41   #13135  |  Link
owine
Here's my INI too. Couldn't fit in a single post.
[Status]
LABEL=THE_MATRIX_REVOLUTIONS_(2003)
SOURCE_SIZE=34032848093
SOURCE_VIDEO_SIZE=33477408768
TARGET_SIZE=24641536000
REDUCTION=.719473148053894
RESIZE_1080=0
AUDIO_TO_KEEP=eng;
KEEP_HD_AUDIO=-1
SUBS_TO_KEEP=eng;
BACKUP_MODE=0
MOVIEONLY_TYPE=0
USE_LAVF=-1
QUICK=1
ENCODE_STEP=0
COMPLETED=49
REBUILD_COMPLETE=1
[00044]
AUDIO=1
PGS=1000000000
HYBRID=0
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=75567473
NSTART=27000000
NEND=33602095
NSIZE=298985472
FLINK=0
MLINK=0
[00054]
AUDIO=1
PGS=1000000000
HYBRID=0
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=96038545
NSTART=27000000
NEND=35448940
NSIZE=344592384
FLINK=0
MLINK=0
[00052]
AUDIO=1
PGS=1000000000
HYBRID=0
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=101055748
NSTART=27000000
NEND=35834826
NSIZE=418689024
FLINK=0
MLINK=0
[00039]
AUDIO=1
PGS=1000000000
HYBRID=0
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=134801410
NSTART=27000000
NEND=38812300
NSIZE=524568576
FLINK=0
MLINK=0
[00043]
AUDIO=1
PGS=1000000000
HYBRID=0
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=141012132
NSTART=27000000
NEND=39360348
NSIZE=507224064
FLINK=0
MLINK=0
[00003]
AUDIO=1
PGS=1000000000
HYBRID=0
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=144676680
NSTART=27000000
NEND=39621608
NSIZE=474034176
FLINK=0
MLINK=0
[00045]
AUDIO=1
PGS=1000000000
HYBRID=0
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=152156069
NSTART=27000000
NEND=40345331
NSIZE=559233024
FLINK=0
MLINK=0
[00058]
AUDIO=1
PGS=1000000000
HYBRID=0
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=158238599
NSTART=27000000
NEND=40782268
NSIZE=607494144
FLINK=0
MLINK=0
[00057]
AUDIO=1
PGS=1000000000
HYBRID=0
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=158494985
NSTART=27000000
NEND=40827313
NSIZE=541341696
FLINK=0
MLINK=0
[00041]
AUDIO=1
PGS=1000000000
HYBRID=0
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=161191455
NSTART=27000000
NEND=41024009
NSIZE=569659392
FLINK=0
MLINK=0
[00053]
AUDIO=1
PGS=1000000000
HYBRID=0
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=162318668
NSTART=27000000
NEND=41132117
NSIZE=531529728
FLINK=0
MLINK=0
[00051]
AUDIO=1
PGS=1000000000
HYBRID=0
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=177122731
NSTART=27000000
NEND=42460945
NSIZE=498481152
FLINK=0
MLINK=0
[00042]
AUDIO=1
PGS=1000000000
HYBRID=0
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=177277447
NSTART=27000000
NEND=42584068
NSIZE=640770048
FLINK=0
MLINK=0
[00040]
AUDIO=1
PGS=1000000000
HYBRID=0
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=184093770
NSTART=27000000
NEND=43138121
NSIZE=601423872
FLINK=0
MLINK=0
[00031]
AUDIO=1
PGS=1000000000
HYBRID=0
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=201943519
NSTART=27000000
NEND=46412893
NSIZE=793774080
FLINK=0
MLINK=0
[00001]
AUDIO=1
PGS=1000000000
HYBRID=0
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=211703857
NSTART=27000000
NEND=45546527
NSIZE=750710784
FLINK=0
MLINK=0
[00062]
AUDIO=1
PGS=1000000000
HYBRID=0
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=227135624
NSTART=27000000
NEND=46869349
NSIZE=510486528
FLINK=0
MLINK=0
[00032]
AUDIO=1
PGS=1000000000
HYBRID=0
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=228174428
NSTART=27000000
NEND=48822800
NSIZE=855226368
FLINK=0
MLINK=0
[00061]
AUDIO=1
PGS=1000000000
HYBRID=0
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=233505482
NSTART=27000000
NEND=47268748
NSIZE=705312768
FLINK=0
MLINK=0
[00000]
AUDIO=1
PGS=1000000000
HYBRID=0
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=241347348
NSTART=27000000
NEND=48057035
NSIZE=760700928
FLINK=0
MLINK=0
[00030]
AUDIO=1
PGS=1000000000
HYBRID=0
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=246298244
NSTART=27000000
NEND=50707183
NSIZE=909803520
FLINK=0
MLINK=0
[00060]
AUDIO=1
PGS=1000000000
HYBRID=0
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=268426982
NSTART=27000000
NEND=50647123
NSIZE=765665280
FLINK=0
MLINK=0
[00050]
AUDIO=1
PGS=1000000000
HYBRID=0
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=271600860
NSTART=27000000
NEND=50663639
NSIZE=879876096
FLINK=0
MLINK=0
[00056]
AUDIO=1
PGS=1000000000
HYBRID=0
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=300881875
NSTART=27000000
NEND=54160633
NSIZE=738527232
FLINK=0
MLINK=0
[00055]
AUDIO=1
PGS=1000000000
HYBRID=0
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=306380906
NSTART=27000000
NEND=53735708
NSIZE=984305664
FLINK=0
MLINK=0
[00033]
AUDIO=1
PGS=1000000000
HYBRID=0
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=308953604
NSTART=27000000
NEND=56705675
NSIZE=980324352
FLINK=0
MLINK=0
[00059]
AUDIO=1
PGS=1000000000
HYBRID=0
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=309192308
NSTART=27000000
NEND=53903876
NSIZE=963637248
FLINK=0
MLINK=0
[00007]
AUDIO=1
PGS=1000000000
HYBRID=0
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=347787196
NSTART=27000000
NEND=60466933
NSIZE=1171261440
FLINK=0
MLINK=0
[00034]
AUDIO=1
PGS=1000000000
HYBRID=0
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=437310008
NSTART=27000000
NEND=68932389
NSIZE=1605722112
FLINK=0
MLINK=0
[00063]
AUDIO=1
PGS=1000000000
HYBRID=0
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=501649556
NSTART=27000000
NEND=70725180
NSIZE=1535422464
FLINK=0
MLINK=0
[00038]
AUDIO=1
PGS=1000000000
HYBRID=0
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=757129060
NSTART=27000000
NEND=100106532
NSIZE=2744358912
FLINK=0
MLINK=0
[00008]
AUDIO=1000001
PGS=10000000000000100000000000
VIDEO2=561224866.596639
V2MBRATE=7000
M2TS_TARGET=-687045853
NSTART=27000000
NEND=376107840
NSIZE=11789395968
FLINK=0
MLINK=0
Old 1st October 2011, 15:46   #13136  |  Link
jfcarbel
Programmer
I used search and FAQ and could not find an answer to this question.
Say I want to burn to BD25 but the backup is a tad over. I would like to do full backup, keep movie untouched, but re-encode the extras/supplements down as much as neeeded to meet target.
Can and how can this be done?
I did find that:
"Quicker" Encode for Extras means you prefer a faster encoding setting for the extras."
But does that mean it will reduce the extras down and by how much and can it be adjusted?
What happens if even after it compresses the extras it misses the target and thus kicks in re-encoding on the movie. Is there a way to force it to not re-encode main movie and more importantly can I adjust the quick settings to add more compression and then give it a go on a second try.
UPDATE:
Ok, I did check hidden opts and this time noticed in there these options:
ALTCRF=n (n = 0-50) - CRF value to use for Alternate Movie-Only encodes (default=20)
FORCE_NOENCODE=n n = 0/1 - if set to 1, BD-RB will always use original video
But still unsure of 2 things. If FORCE_NOENCODE=1 does that apply to the extras as well even though QUICK for extras is set? And I assume a higher CRF adds more compression - correct?
jfcarbel is offline   Reply With Quote
Old 1st October 2011, 17:42   #13137  |  Link
Ch3vr0n
2nd Movie & Menu's test encode completed without a hitch. Space Battleship Yamato shrunk perfectly, blanking worked flawless. Disc play's through them like they were normal clips, and proceeds to playing the next title. Love the blanking feature
Old 1st October 2011, 17:59   #13138  |  Link
omegaman7
omegaman7's Avatar
The other night, I ran Star Trek TOS S1D1. I blanked 6 identical trailers(Star Trek 2009) 2.07Gb. It worked perfectly. The output was 22.1Gb. That's plenty close enough I thought for sure it would have been ~20Gb. Not sure why TMT5 displays the aspect improperly, but that's a different problem. Wish they'd get on the ball with Star Trek TNG A lot of people say they won't do it. Time effort money... I say the return would be worth it if they offered enough on the BD's Heck, I'd easily spend 1,000USD on the complete TNG BD set!
Awesome software JD
Old 1st October 2011, 19:22   #13139  |  Link
Sharc
BD2DVD audio sync
I came across a sync issue today:
Source is BD with 2 DTS language tracks selected.
While the backup to BD5 was perfect, I found that on the DVD5 alternate (mpeg2) PAL output one audio track was offset by about 3 seconds, the other audio track was in sync.
For the BD source I found:
Audio track 1 = 2876 ms delay
Audio track 2 = 0 ms delay
Normally audio delays are 0ms for most BD's I think, so this particular case looks like an exception. My question is if BD RB is supposed to handle such cases for DVD5 alternate PAL backup, or if this is beyond the scope and I should adjust the delay manually, or put it aside...
Old 1st October 2011, 23:58   #13140  |  Link
xterminater
jdobbs... I don't know if this is a previous issue, I set everything to auto for encode quality, used the movie and menu only options, and set to BD-9 but my encode came out to be oversized. I only kept one audio track and that is DTS. I had to re-ran that encode to BD-RB once again to get it to reduce to size. I deleted the inf file by accident already but do you know what the issue could be?
xterminater is offline   Reply With Quote
