Old 11th March 2019, 00:10   #6101  |  Link
Aleksoid1978
Aleksoid1978's Avatar
Originally Posted by Perenista View Post
Version 1.5.3 (build 4455) beta
A few settings tried
https://imgur.com/a/EgG4AhK
Filtros externos = external filters
I changed that area by adding LAV and selecting PREFER, but that didn't help, still crackling.
Try reset settings and delete all external filters. Just for test.
P.S. Check on latest SVN - https://yadi.sk/d/hlf1lfC8mKU58/!_last
Old 11th March 2019, 04:57   #6102  |  Link
Perenista
I was looking for this and couldn't find (reset to factory settings). Where should I go?
Perenista is offline   Reply With Quote
Old 11th March 2019, 05:17   #6103  |  Link
Aleksoid1978
Options -> Miscellaneous -> Settings management
Old 11th March 2019, 10:20   #6104  |  Link
Grimsdyke
I love the dual-audio out feature of BE !! But unfortunately I do need much more gain on HDMI (=> connected to TV) than on 5.1-Analog (=> connected to Amplifier).
Would it be possible to add a second slider so that gain could be adjusted independently ?
Old 11th March 2019, 10:25   #6105  |  Link
Aleksoid1978
Volume slider ?? If so - not.
Old 11th March 2019, 10:40   #6106  |  Link
Manni
If you need more volume on HDMI it could be because you are converting to LPCM before sending to the AVR. If it's an option in your setup, try to bitstream audio over HDMI, volume tends to be higher in that case. But then of course you have no volume control from MPC.
Win11 Pro x64 b23H2
madVR/LAV/jRiver/MyMovies/CMC
Old 11th March 2019, 10:50   #6107  |  Link
Grimsdyke
@Aleksoid. I mean: Options -> Audio -> Sound Processing -> Volume Control -> GAIN. Would need one slider for each audio out.
@Manni. Thanx, I will check that.
Old 11th March 2019, 11:05   #6108  |  Link
Aleksoid1978
Dual audio not working for bitstreaming + PCM output.
Only bitstream or PCM
Old 11th March 2019, 11:18   #6109  |  Link
Grimsdyke
Bitstreaming over HDMI seem to be not louder on my equipment.
Old 11th March 2019, 11:42   #6110  |  Link
Manni
It's not always the case, but it was worth checking
Win11 Pro x64 b23H2
Old 22nd March 2019, 00:33   #6111  |  Link
beter
Update for translation of Chinese traditional and Dutch
https://www.sendspace.com/file/x1lt1i
beter is offline   Reply With Quote
Old 22nd March 2019, 03:36   #6112  |  Link
Anima123
Using recent mpc-be builds (till 4455, didn't test latest), the progress bar will not appear for a while after starting playback the video, and certainly not be able to enter full-screen mode by Alt-Enter.
Anima123 is offline   Reply With Quote
Old 22nd March 2019, 21:44   #6113  |  Link
mkver
DVBSUB subtitles are usually displayed until the next subtitle packet (often an empty subtitle that just says "Stop displaying the previous subtitles") is due for display. If a file does not contain these end-of-display subtitles, MPC-BE crashes. Such files can be produced by e.g. splitting files with mkvmerge. It doesn't seem to matter whether the DVBSUB packet (in Matroska) is in a SimpleBlock or a BlockGroup with an explicit nonzero duration or a BlockGroup with a zero duration. Here, here and here are samples for this. I can sometimes produce crashes if I am near the end of a transport stream with DVBSUBs as active subtitles, so this doesn't seem to be limited to Matroska, although it is not so easy to reproduce the crash there.
(If a DVBSUB in a BlockGroup has a nonzero duration, then actually this should be used as the duration; it should override the duration implied by the next subtitle packet. (The reason I am treating a BlockGroup with a zero duration specially is that FFmpeg has a bug in that it writes duration zero if the duration is unknown.))
mkver is offline   Reply With Quote
Old 23rd March 2019, 10:13   #6114  |  Link
Arm3nian
If I seek before a file starts to play initially, MPC-BE stops responding. Same if I seek a second time too quickly after the first one. Turning off wait for render queue in madVR makes it better, but it still crashes. This has been happening ever since the UI change. I've tried nightlies of MPC-BE and LAV for a month but it does the same thing.
Also, before the UI change, if I had 2 screens connected, and I switched the file to fullscreen, and pulled the display plug on one of them, it would automatically continue playing on the other display. Doesn't do that anymore.
Arm3nian is offline   Reply With Quote
Old 23rd March 2019, 10:44   #6115  |  Link
Aleksoid1978
Thanks - fixed.
Old 23rd March 2019, 10:45   #6116  |  Link
Aleksoid1978
1 - reset settings.
2 - try without LAV and madVR.
Old 23rd March 2019, 19:33   #6117  |  Link
Anima123
Just tried the latest nightly and found the problem has gone. Thanks a lot!
Old 24th March 2019, 11:42   #6118  |  Link
mkver
Thanks - fixed.
Works fine in 4466. Thanks.
Old 1st April 2019, 08:31   #6119  |  Link
Klaus1189
Thank you very much for 1.5.3
Old 1st April 2019, 09:12   #6120  |  Link
v0lt
MPC-BE 1.5.3 (build 4488) stable
MPC-BE 1.5.4 Nightly builds: main file store, alternative
Also new and old versions can be found on VideoHelp.com.
