10th April 2019, 05:35 | #6167 | Link | |
MPC-HC can do this through menu item or CTRL + L |
11th April 2019, 12:55 | #6170 | Link |
Intel 3D MVC problem
My setup: MPC-HC / MPC-BE (v1.5.3, build 4455), LAV Filters (0.73.1.30-git), MadVR. Intel NUC7i3BNK, Intel i3-7100U, Intel graphics driver 25.20.100.6618. Windows 10 Pro 1809.
3D MVC used to work a few week ago with the earlier Intel driver (v 6577). Now, when I start playback of an iso image, MPC-BE says: "Starting playback crashed". After 10 seconds or so playback starts without any audio. Changing playback position, and most any change, freezes playback completely. Closing the application thru task manager. 3D playback works nicely with Kodi. PowerDVD works but there is strange motion judder. Is this LAV Filters problem or something else? Maybe caused by a Windows 10 change. |
12th April 2019, 18:06 | #6175 | Link |
Implemented in r4518.
12th April 2019, 18:14 | #6176 | Link |
Quick question : does MPC-BE built in subtitle search engine (shortcut : D key) still work ?
I get "No subtitles found" on every file even when there should be results, I get them when I look for them manually on opensubtitles.org... My files are not even renamed or anything. |
12th April 2019, 19:00 | #6177 | Link |
@Charky
I do not recommend using the search for subtitles on the online database in any MPC. I would delete it from MPC-BE, but people use it (I do not understand how).
MPC-BE 1.7.0 and Nightly builds | VideoRenderer | ImageSource | ScriptSource | BassAudioSource Last edited by v0lt; 12th April 2019 at 19:04. |
12th April 2019, 19:20 | #6178 | Link |
Oh, okay then
That's a shame, auto search and download subtitles is a useful feature. Kodi's implementation of it works really well, but I guess it's easier to do for them because the movies and TV episodes are properly identified, while MPC-BE can only use the filename to look for the right file. And of course, auto search and download subtitles doesn't work in Kodi if you use an external player such as MPC-BE Guess I'll have to keep doing it manually for a while |
